FRS
Revision as of 14:54, 1 May 2020 by R4002 (Talk | contribs)
Family Radio Service
UHF replacement (or rather supplement) to the CB service. Created in the late 1990s by the FCC after intense lobbying by RadioShack.
Ch Freq MHz - Notes -
1 462.5625 Shared with GMRS - FRS Calling Channel 2 watts maximum TX power
2 462.5875 Shared with GMRS 2 watts maximum TX power
3 462.6125 Shared with GMRS 2 watts maximum TX power
4 462.6375 Shared with GMRS 2 watts maximum TX power
5 462.6625 Shared with GMRS 2 watts maximum TX power
6 462.6875 Shared with GMRS 2 watts maximum TX power
7 462.7125 Shared with GMRS 2 watts maximum TX power
8 467.5625 FRS only 0.5 watt 500mw maximum TX power
9 467.5875 FRS only 0.5 watt 500mw maximum TX power
10 467.6125 FRS only 0.5 watt 500mw maximum TX power
11 467.6375 FRS only 0.5 watt 500mw maximum TX power
12 467.6625 FRS only 0.5 watt 500mw maximum TX power
13 467.6875 FRS only 0.5 watt 500mw maximum TX power
14 467.7125 FRS only 0.5 watt 500mw maximum TX power
15 462.5500 Shared with GMRS 2 watts maximum TX power
16 462.5750 Shared with GMRS 2 watts maximum TX power
17 462.6000 Shared with GMRS 2 watts maximum TX power
18 462.6250 Shared with GMRS 2 watts maximum TX power
19 462.6500 Shared with GMRS 2 watts maximum TX power
20 462.6750 Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power
21 462.7000 Shared with GMRS 2 watts maximum TX power
22 462.7250 Shared with GMRS 2 watts maximum TX power
Late 2010s/early 2020s Chinese manufactured and sold FRS units with FCC Part 95 FRS radio authorization indicate emission types including 10K0F3E for all 22 channels (462 MHz - 467 MHz), 12K0F3E emission, 9K64F3E emission, 11K3F3E emission, 11K0F3E emission, 8K00F3E emission and other bandwidths, including super-narrow FM emission 5K81F3E, 6K00F3E, 5K75F3E and others. Some of these radios are clearly marketed as children's walkie-talkies and offer only 50mw-100mw transmit power (compared to higher-end radios, even Chinese radios, which offer 500mw to 1 watt to 2 watt power output on the 462 MHz frequencies). Cheap children's walkie talkies designed for short range purposes transmit 250mw on 462.55 MHz - 467.7125 MHz, with emission type 9K64F3E on 462.55 MHz - 462.725 MHz and emission 9K69F3E on 467.5625 MHz - 467.7125 MHz. Almost all of these lower-grade transceivers offer all 22 channels, and simply transmit below the 500mw power limit for FRS on all 22 FRS channels.
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a "monitor" or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours).
