FRS
Revision as of 11:17, 4 May 2020 by R4002 (Talk | contribs)
Family Radio Service
Ch Freq MHz - Notes -
1 462.5625 Shared with GMRS - FRS Calling Channel 2 watts maximum TX power
2 462.5875 Shared with GMRS 2 watts maximum TX power
3 462.6125 Shared with GMRS 2 watts maximum TX power
4 462.6375 Shared with GMRS 2 watts maximum TX power
5 462.6625 Shared with GMRS 2 watts maximum TX power
6 462.6875 Shared with GMRS 2 watts maximum TX power
7 462.7125 Shared with GMRS 2 watts maximum TX power
8 467.5625 FRS only 0.5 watt 500mw maximum TX power
9 467.5875 FRS only 0.5 watt 500mw maximum TX power
10 467.6125 FRS only 0.5 watt 500mw maximum TX power
11 467.6375 FRS only 0.5 watt 500mw maximum TX power
12 467.6625 FRS only 0.5 watt 500mw maximum TX power
13 467.6875 FRS only 0.5 watt 500mw maximum TX power
14 467.7125 FRS only 0.5 watt 500mw maximum TX power
15 462.5500 Shared with GMRS 2 watts maximum TX power
16 462.5750 Shared with GMRS 2 watts maximum TX power
17 462.6000 Shared with GMRS 2 watts maximum TX power
18 462.6250 Shared with GMRS 2 watts maximum TX power
19 462.6500 Shared with GMRS 2 watts maximum TX power
20 462.6750 Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power
21 462.7000 Shared with GMRS 2 watts maximum TX power
22 462.7250 Shared with GMRS 2 watts maximum TX power
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a "monitor" or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours).
These wireless intercom systems generally include a GROUP CALL or HOME channel feature, that switches all intercoms to a dedicated channel/code combination.
  • CHANNEL 1 - 467.6375 MHz
  • CHANNEL 2 - 462.5875 MHz
  • CHANNEL 3 - 462.6125 MHz
  • CHANNEL 4 - 462.6375 MHz
  • CHANNEL 5 - 462.6625 MHz
  • CHANNEL 6 - 462.6875 MHz
  • CHANNEL 7 - 467.7125 MHz
  • CHANNEL 8 - 462.5500 MHz
  • CHANNEL 9 - 462.5750 MHz
  • Code 1 - 162.2 Hz PL
  • Code 2 - 69.3 Hz PL
  • Code 3 - 67.0 Hz PL
  • CHANNEL 1 - 462.5625 MHz
  • Code 3 - 67.0 PL
  • Code 1 - 743 DCS / 743 DPL
  • Code 2 - 732 DCS / 732 DPL
  • Code 3 - 731 DCS / 731 DPL
  • Calford Technology Ltd. AF333 wireless intercom
234mw power output, 11K0F3E emission
  • Calford Technology Ltd. AF411 wireless intercom
  • CHANNEL A - 462.5625 MHz
  • CHANNEL B - 462.5875 MHz
  • CHANNEL C - 462.6125 MHz
  • CHANNEL D - 462.6375 MHz
  • SAMCOM / SANCON FTAN10AA 10 channel wireless intercom
  • CHANNEL 0 - 462.6625 MHz
  • CHANNEL 1 - 467.7125 MHz
  • CHANNEL 2 - 467.6875 MHz
  • CHANNEL 3 - 467.6625 MHz
  • CHANNEL 4 - 467.6375 MHz
  • CHANNEL 5 - 467.6125 MHz
  • CHANNEL 6 - 467.5875 MHz
  • CHANNEL 7 - 467.5625 MHz
  • CHANNEL 8 - 462.7125 MHz
  • CHANNEL 9 - 462.6875 MHz
  • Code A - 110.9 Hz PL
  • Code B - 136.5 Hz PL
  • Code C - 186.2 Hz PL
  • SAMCOM / SANCON FTAN20AA 20 channel wireless intercom
  • CHANNEL 10 - 462.6375 MHz
  • CHANNEL 11 - 462.6125 MHz
  • CHANNEL 12 - 462.5875 MHz
  • CHANNEL 13 - 462.5625 MHz
  • CHANNEL 14 - 462.7250 MHz
  • CHANNEL 15 - 462.7000 MHz
  • CHANNEL 16 - 462.6750 MHz
  • CHANNEL 17 - 462.6500 MHz
  • CHANNEL 18 - 462.6250 MHz
  • CHANNEL 19 - 462.6000 MHz
  • Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same code.
  • Shenzhen Macros Industrial Co. Ltd. WL666 or LD666 wireless intercom
  • CHANNEL 0 - 467.6125 MHz
  • CHANNEL 1 - 462.7250 MHz
  • CHANNEL 8 - 467.5625 MHz
  • CHANNEL 9 - 467.5875 MHz
  • Code A - 754 DCS / 754 DPL
  • Code B - 743 DCS / 743 DPL
  • Code C - 734 DCS / 734 DPL
