PMR446
Analog and digital license-free low power radio service, similar to FRS and GMRS in the United States, 477 MHz UHF CB in Australia and New Zealand, the 448 MHz South Korean Personal Radio Service and several other UHF band license free two-way radio service es.
Unlike most other country-specific services, PMR446 is standardized throughout Europe, the UK and numerous other countries worldwide. 500mW power limit. CTCSS, DCS and other selective calling and squelch systems are allowed in analog mode, digital "group" (selective calling) permitted in digital voice mode.
PMR446 was originally assigned 8 analog FM voice channels from 446.0 MHz to 446.1 MHz then expanded to 16 analog/digital channels + 32 digital only voice/data channels in the 446.0 to 446.2 MHz range for a total of 48 available channels (in digital voice mode, not counting selective calling/group calling features available in analog and digital voice modes). Where the PMR446 service is authorized the 446 MHz frequency spectrum is not part of the 70cm amateur band.
Contents[hide] |
Channel | Freq MHz |
1 | 446.00625 |
2 | 446.01875 |
3 | 446.03125 |
4 | 446.04375 |
5 | 446.05625 |
6 | 446.06875 |
7 | 446.08125 |
8 | 446.09375 |
9 | 446.10625 |
10 | 446.11875 |
11 | 446.13125 |
12 | 446.14375 |
13 | 446.15625 |
14 | 446.16875 |
15 | 446.18125 |
16 | 446.19375 |
Digital FDMA dPMR446
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital dPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
1 | 446.003125 |
2 | 446.009375 |
3 | 446.015625 |
4 | 446.021875 |
5 | 446.028125 |
6 | 446.034375 |
7 | 446.040625 |
8 | 446.046875 |
9 | 446.053125 |
10 | 446.059375 |
11 | 446.065625 |
12 | 446.071875 |
13 | 446.078125 |
14 | 446.084375 |
15 | 446.090625 |
16 | 446.096875 |
17 | 446.103125 |
18 | 446.109375 |
19 | 446.115625 |
20 | 446.121875 |
21 | 446.128125 |
22 | 446.134375 |
23 | 446.140625 |
24 | 446.146875 |
25 | 446.153125 |
26 | 446.159375 |
27 | 446.165625 |
28 | 446.171875 |
29 | 446.178125 |
30 | 446.184375 |
31 | 446.190625 |
32 | 446.196875 |
- Channel 1 - 446.00625 MHz - “Children’s Channel” - baby monitors, etc.
- Channel 8 - 446.09375 MHz - TDMA digital 12.5 kHz - Calling / DX Channel - digital DX frequency
Authorized PMR446 Countries
