PMR446
Revision as of 18:47, 9 May 2020 by R4002 (Talk | contribs)
Analog and digital license-free low power radio service, similar to the 462 MHz - 467 MHz FRS and GMRS services in the United States, the 477 MHz UHF CB in Australia and New Zealand, the 448 MHz South Korean Personal Radio Service and several other UHF band license free two-way radio services.
PMR446 was originally assigned 8 analog FM voice channels from 446.0 MHz to 446.1 MHz then expanded to 16 analog/digital channels + 32 digital only voice/data channels in the 446.0 to 446.2 MHz range for a total of 48 available channels (in digital voice mode, not counting selective calling/group calling features available in analog and digital voice modes). Where the PMR446 service is authorized the 446 MHz frequency spectrum is not part of the 70cm amateur band.
Channel Freq MHz
1 446.00625
2 446.01875
3 446.03125
4 446.04375
5 446.05625
6 446.06875
7 446.08125
8 446.09375
9 446.10625
10 446.11875
11 446.13125
12 446.14375
13 446.15625
14 446.16875
15 446.18125
16 446.19375
Digital FDMA dPMR446
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital dPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
Channel Freq MHz
1 446.003125
2 446.009375
3 446.015625
4 446.021875
5 446.028125
6 446.034375
7 446.040625
8 446.046875
9 446.053125
10 446.059375
11 446.065625
12 446.071875
13 446.078125
14 446.084375
15 446.090625
16 446.096875
17 446.103125
18 446.109375
19 446.115625
20 446.121875
21 446.128125
22 446.134375
23 446.140625
24 446.146875
25 446.153125
26 446.159375
27 446.165625
28 446.171875
29 446.178125
30 446.184375
31 446.190625
32 446.196875
  • Channel 1 - 446.00625 MHz - “Children’s Channel” - baby monitors, etc.
Authorized PMR446 Countries
