PMR446
Analog and digital license-free low power radio service, similar to the 462 MHz - 467 MHz FRS and GMRS services in the United States, the 477 MHz UHF CB in Australia and New Zealand, the 448 MHz South Korean Personal Radio Service and several other UHF band license free two-way walkie-talkie radio services.
PMR446 was originally assigned 8 analog FM voice channels from 446.0 MHz to 446.1 MHz then expanded to 16 analog/digital channels + 32 digital only voice/data channels in the 446.0 to 446.2 MHz range for a total of 48 channels.
Channel | Freq MHz |
1 | 446.00625 MHz |
2 | 446.01875 MHz |
3 | 446.03125 MHz |
4 | 446.04375 MHz |
5 | 446.05625 MHz |
6 | 446.06875 MHz |
7 | 446.08125 MHz |
8 | 446.09375 MHz |
9 | 446.10625 MHz |
10 | 446.11875 MHz |
11 | 446.13125 MHz |
12 | 446.14375 MHz |
13 | 446.15625 MHz |
14 | 446.16875 MHz |
15 | 446.18125 MHz |
16 | 446.19375 MHz |
Digital FDMA dPMR446
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s (3600 baud). These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital dPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
1 | 446.003125 MHz |
2 | 446.009375 MHz |
3 | 446.015625 MHz |
4 | 446.021875 MHz |
5 | 446.028125 MHz |
6 | 446.034375 MHz |
7 | 446.040625 MHz |
8 | 446.046875 MHz |
9 | 446.053125 MHz |
10 | 446.059375 MHz |
11 | 446.065625 MHz |
12 | 446.071875 MHz |
13 | 446.078125 MHz |
14 | 446.084375 MHz |
15 | 446.090625 MHz |
16 | 446.096875 MHz |
17 | 446.103125 |
18 | 446.109375 |
19 | 446.115625 |
20 | 446.121875 |
21 | 446.128125 |
22 | 446.134375 |
23 | 446.140625 |
24 | 446.146875 |
25 | 446.153125 |
26 | 446.159375 |
27 | 446.165625 |
28 | 446.171875 |
29 | 446.178125 |
30 | 446.184375 |
31 | 446.190625 |
32 | 446.196875 |
- Channel 1 - 446.00625 MHz - “Children’s Channel” - baby monitors, etc.
- Channel 8 - 446.09375 MHz - TDMA digital 12.5 kHz - Calling / DX Channel - digital DX frequency
Authorized PMR446 Countries
