Military ISR
Originally intended to be a military only FRS type service.
Not to be confused with VHF/UHF militia inter squad radio and 16 channel UHF low power intra-squad radio (Baofeng UV-5R, UV-82, VHF/UHF handheld COTS radios, etc.)
14 channels, with the FRS-standard 38 CTCSS tones to reduce interference from weak/distant signals. 0.5 watt 500mW power limit (just like the original FRS service). 380-400 MHz band shared with military land mobile and UHF aircraft band 225-400 MHz. Functionally, appears to have been replaced by the Integrated Intra Squad Radio system, although the VULOS service offered by standard tactical radios cover these frequencies.
- Channel 1 - 396.875 MHz
- Channel 2 - 397.125 MHz
- Channel 3 - 397.175 MHz
- Channel 4 - 397.375 MHz
- Channel 5 - 397.425 MHz
- Channel 6 - 397.475 MHz
- Channel 7 - 397.550 MHz
- Channel 8 - 397.950 MHz
- Channel 9 - 398.050 MHz
- Channel 10 - 399.425 MHz
- Channel 11 - 399.475 MHz
- Channel 12 - 399.725 MHz
- Channel 13 - 399.925 MHz
- Channel 14 - 399.975 MHz
