Military ISR
Revision as of 11:47, 12 May 2022 by R4002 (Talk | contribs)
Originally intended to be a military only FRS type service.
Not to be confused with VHF/UHF militia inter squad radio and 16 channel UHF low power intra-squad radio (Baofeng UV-5R, UV-82, VHF/UHF handheld COTS radios, etc.)
  • Channel 1 - 396.875 MHz
  • Channel 2 - 397.125 MHz
  • Channel 3 - 397.175 MHz
  • Channel 4 - 397.375 MHz
  • Channel 5 - 397.425 MHz
  • Channel 6 - 397.475 MHz
  • Channel 7 - 397.550 MHz
  • Channel 8 - 397.950 MHz
  • Channel 9 - 398.050 MHz
  • Channel 10 - 399.425 MHz
  • Channel 11 - 399.475 MHz
  • Channel 12 - 399.725 MHz
  • Channel 13 - 399.925 MHz
  • Channel 14 - 399.975 MHz
