Revision as of 15:37, 16 October 2024 by R4002 (Talk | contribs)
49 MHz RC Frequencies
50 MHz RC 50.80 MHz - 50.98 MHz 53 MHz RC 53.10 MHz - 53.80 MHz.
  • 72.010 MHz
  • 72.030 MHz
  • 72.050 MHz
  • 72.070 MHz
  • 72.090 MHz
  • 72.110 MHz
  • 72.130 MHz
  • 72.150 MHz
  • 72.170 MHz
  • 72.190 MHz
  • 72.210 MHz
  • 72.230 MHz
  • 72.250 MHz
  • 72.270 MHz
  • 72.290 MHz
  • 72.310 MHz
  • 72.330 MHz
  • 72.350 MHz
  • 72.370 MHz
  • 72.390 MHz
  • 72.410 MHz
  • 72.430 MHz
  • 72.450 MHz
  • 72.470 MHz
  • 72.490 MHz
  • 72.510 MHz
  • 72.530 MHz
  • 72.550 MHz
  • 72.570 MHz
  • 72.590 MHz
  • 72.610 MHz
  • 72.630 MHz
  • 72.650 MHz
  • 72.670 MHz
  • 72.690 MHz
  • 72.710 MHz
  • 72.730 MHz
  • 72.750 MHz
  • 72.770 MHz
  • 72.790 MHz
  • 72.810 MHz
  • 72.830 MHz
  • 72.850 MHz
  • 72.870 MHz
  • 72.890 MHz
  • 72.910 MHz
  • 72.930 MHz
  • 72.950 MHz
  • 72.970 MHz
  • 72.990 MHz
  • 75.410 MHz
  • 75.430 MHz
  • 75.450 MHz
  • 75.470 MHz
  • 75.490 MHz
  • 75.510 MHz
  • 75.530 MHz
  • 75.550 MHz
  • 75.570 MHz
  • 75.590 MHz
  • 75.610 MHz
  • 75.630 MHz
  • 75.650 MHz
  • 75.670 MHz
  • 75.690 MHz
  • 75.710 MHz
  • 75.730 MHz
  • 75.750 MHz
  • 75.770 MHz
  • 75.790 MHz
  • 75.810 MHz
  • 75.830 MHz
  • 75.850 MHz
  • 75.870 MHz
  • 75.890 MHz
  • 75.910 MHz
  • 75.930 MHz
  • 75.950 MHz
  • 75.970 MHz
  • 75.990 MHz
900 MHz RC Frequencies
902-928 MHz limits:
2.4 GHz RC Frequencies
Canada
47 MHz band
  • 47.020 MHz
  • 47.030 MHz
  • 47.050 MHz
  • 47.050 MHz
  • 47.070 MHz
  • 47.110 MHz
  • 47.130 MHz
  • 47.150 MHz
  • 47.170 MHz
  • 47.230 MHz
  • 47.250 MHz
  • 47.270 MHz
  • 47.290 MHz
  • 47.300 MHz
  • 47.310 MHz
  • 47.330 MHz
  • 47.350 MHz
49 MHz band
72 MHz band
  • 72.010 MHz - Channel 11
  • 72.030 MHz - Channel 12
  • 72.050 MHz - Channel 13
  • 72.070 MHz - Channel 14
  • 72.090 MHz - Channel 15
  • 72.110 MHz - Channel 16
  • 72.130 MHz - Channel 17
  • 72.150 MHz - Channel 18
  • 72.170 MHz - Channel 19
  • 72.190 MHz - Channel 20
  • 72.210 MHz - Channel 21
  • 72.230 MHz - Channel 22
  • 72.250 MHz - Channel 23
  • 72.270 MHz - Channel 24
  • 72.290 MHz - Channel 25
  • 72.310 MHz - Channel 26
  • 72.330 MHz - Channel 27
  • 72.350 MHz - Channel 28
  • 72.370 MHz - Channel 29
  • 72.390 MHz - Channel 30
  • 72.410 MHz - Channel 31
  • 72.430 MHz - Channel 32
  • 72.450 MHz - Channel 33
  • 72.470 MHz - Channel 34
  • 72.490 MHz - Channel 35
  • 72.510 MHz - Channel 36
  • 72.530 MHz - Channel 37
  • 72.550 MHz - Channel 38
  • 72.570 MHz - Channel 39
  • 72.590 MHz - Channel 40
  • 72.610 MHz - Channel 41
  • 72.630 MHz - Channel 42
  • 72.650 MHz - Channel 43
  • 72.670 MHz - Channel 44
  • 72.690 MHz - Channel 45
  • 72.710 MHz - Channel 46
  • 72.730 MHz - Channel 47
  • 72.750 MHz - Channel 48
  • 72.770 MHz - Channel 49
  • 72.790 MHz - Channel 50
  • 72.810 MHz - Channel 51
  • 72.830 MHz - Channel 52
  • 72.850 MHz - Channel 53
  • 72.870 MHz - Channel 54
  • 72.890 MHz - Channel 55
  • 72.910 MHz - Channel 56
  • 72.930 MHz - Channel 57
  • 72.950 MHz - Channel 58
  • 72.970 MHz - Channel 59
  • 72.990 MHz - Channel 60
75 MHz band
  • 75.410 MHz - Channel 61
  • 75.430 MHz - Channel 62
  • 75.450 MHz - Channel 63
  • 75.470 MHz - Channel 64
  • 75.490 MHz - Channel 65
  • 75.510 MHz - Channel 66
  • 75.530 MHz - Channel 67
  • 75.550 MHz - Channel 68
  • 75.570 MHz - Channel 69
  • 75.590 MHz - Channel 70
  • 75.610 MHz - Channel 71
  • 75.630 MHz - Channel 72
  • 75.650 MHz - Channel 73
  • 75.670 MHz - Channel 74
  • 75.690 MHz - Channel 75
  • 75.710 MHz - Channel 76
  • 75.730 MHz - Channel 77
  • 75.750 MHz - Channel 78
  • 75.770 MHz - Channel 79
  • 75.790 MHz - Channel 80
  • 75.810 MHz - Channel 81
  • 75.830 MHz - Channel 82
  • 75.850 MHz - Channel 83
  • 75.870 MHz - Channel 84
  • 75.890 MHz - Channel 85
  • 75.910 MHz - Channel 86
  • 75.930 MHz - Channel 87
  • 75.950 MHz - Channel 88
  • 75.970 MHz - Channel 89
  • 75.990 MHz - Channel 90
See IR2030/23/1
  • 26.965 MHz - RC Channel 1
  • 26.985 MHz - RC Channel 3
  • 27.005 MHz - RC Channel 5
  • 27.015 MHz - RC Channel 6
  • 27.035 MHz - RC Channel 8
  • 27.055 MHz - RC Channel 10
  • 27.065 MHz - RC Channel 11
  • 27.085 MHz - RC Channel 13
  • 27.105 MHz - RC Channel 15
  • 27.115 MHz - RC Channel 16
  • 27.135 MHz - RC Channel 18
  • 27.155 MHz - RC Channel 20
  • 27.165 MHz - RC Channel 21
  • 27.185 MHz - RC Channel 23
  • 27.205 MHz - RC Channel 25
  • 27.215 MHz - RC Channel 26
  • 27.235 MHz - RC Channel 28
  • 27.245 MHz - RC Channel 29
  • 27.265 MHz - RC Channel 31
  • 34.950 MHz - Channel 55
  • 34.960 MHz - Channel 56
  • 34.970 MHz - Channel 57
  • 34.980 MHz - Channel 58
  • 34.990 MHz - Channel 59
  • 35.000 MHz - Channel 60
  • 35.010 MHz - Channel 61
  • 35.020 MHz - Channel 62
  • 35.030 MHz - Channel 63
  • 35.040 MHz - Channel 64
  • 35.050 MHz - Channel 65
  • 35.060 MHz - Channel 66
  • 35.070 MHz - Channel 67
  • 35.080 MHz - Channel 68
  • 35.090 MHz - Channel 69
  • 35.100 MHz - Channel 70
  • 35.110 MHz - Channel 71
  • 35.120 MHz - Channel 72
  • 35.130 MHz - Channel 73
  • 35.140 MHz - Channel 74
  • 35.150 MHz - Channel 75
  • 35.160 MHz - Channel 76
  • 35.170 MHz - Channel 77
  • 35.180 MHz - Channel 78
  • 35.190 MHz - Channel 79
  • 35.200 MHz - Channel 80
  • 35.210 MHz - Channel 81
  • 35.220 MHz - Channel 82
  • 35.230 MHz - Channel 83
  • 35.240 MHz - Channel 84
  • 35.250 MHz - Channel 85
  • 35.260 MHz - Channel 86
  • 35.270 MHz - Channel 87
  • 35.280 MHz - Channel 88
  • 35.290 MHz - Channel 89
  • 35.300 MHz - Channel 90
459 MHz Band - UHF
  • 458.525 MHz - Channel 1
  • 458.550 MHz - Channel 2
  • 458.575 MHz - Channel 3
  • 458.600 MHz - Channel 4
  • 458.625 MHz - Channel 5
  • 458.650 MHz - Channel 6
  • 458.675 MHz - Channel 7
  • 458.700 MHz - Channel 8
  • 458.725 MHz - Channel 9
  • 458.750 MHz - Channel 10
  • 458.775 MHz - Channel 11
  • 458.800 MHz - Channel 12
  • 458.825 MHz - Channel 13
  • 458.850 MHz - Channel 14
  • 458.875 MHz - Channel 15
  • 458.900 MHz - Channel 16
  • 458.925 MHz - Channel 17
  • 458.950 MHz - Channel 18
  • 458.975 MHz - Channel 19
  • 459.000 MHz - Channel 20
  • 459.025 MHz - Channel 21
  • 459.050 MHz - Channel 22
  • 459.075 MHz - Channel 23
  • 459.100 MHz - Channel 24
  • 459.125 MHz - Channel 25
  • 459.150 MHz - Channel 26
  • 459.175 MHz - Channel 27
  • 459.200 MHz - Channel 28
  • 459.225 MHz - Channel 29
  • 459.250 MHz - Channel 30
  • 459.275 MHz - Channel 31
  • 459.300 MHz - Channel 32
  • 459.325 MHz - Channel 33
  • 459.350 MHz - Channel 34
  • 459.375 MHz - Channel 35
  • 459.400 MHz - Channel 36
  • 459.425 MHz - Channel 37
  • 459.450 MHz - Channel 38
  • 459.475 MHz - Channel 39
  • 2.4 GHz Band
  • 5.8 GHz Band
  • CEPT ETSI SRD Bands
  • 26.957 MHz to 27.283 MHz
  • 138.200 MHz to 138.450 MHz
  • 169.400 MHz to 169.8125 MHz
  • 863 MHz to 876 MHz
  • 35.820 MHz - Channel 182
  • 35.830 MHz - Channel 183
  • 35.840 MHz - Channel 184
  • 35.850 MHz - Channel 185
  • 35.860 MHz - Channel 186
  • 35.870 MHz - Channel 187
  • 35.880 MHz - Channel 188
  • 35.890 MHz - Channel 189
  • 35.900 MHz - Channel 190
  • 35.910 MHz - Channel 191
Czech Republic
  • 25,670 kHz - 26,100 kHz
  • 26,100 kHz - 26,175 kHz
  • 26,175 kHz - 26,200 kHz
  • 26,200 kHz - 26,350 kHz
  • 26,350 kHz - 26,957 kHz
  • 26,560 kHz - 27,410 kHz
  • 26,957 kHz - 27,405 kHz
  • 27,405 kHz - 27,500 kHz
  • 27,500 kHz - 28,000 kHz
  • 32.875 MHz
  • 32.900 MHz
  • 32.925 MHz
  • 32.950 MHz
  • 32.975 MHz
  • 34.050 MHz
  • 34.075 MHz
  • 34.150 MHz
  • 34.175 MHz
  • 35.000 MHz - C1
  • 35.010 MHz - C2
  • 35.020 MHz - C3
  • 35.030 MHz - C4
  • 35.040 MHz - C5
  • 35.050 MHz - C6
  • 35.060 MHz - C7
  • 35.070 MHz - C8
  • 35.080 MHz - C9
  • 35.090 MHz - C10
  • 35.100 MHz - C11
  • 35.110 MHz - C12
  • 35.120 MHz - C13
  • 35.130 MHz - C14
  • 35.140 MHz - C15
  • 35.150 MHz - C16
  • 35.160 MHz - C17
  • 35.170 MHz - C18
  • 35.180 MHz - C19
  • 35.190 MHz - C20
  • 35.200 MHz - C21
  • 35.210 MHz - C22
  • 35.220 MHz - C23
  • 35.820 MHz - D1
  • 35.830 MHz - D2
  • 35.840 MHz - D3
  • 35.850 MHz - D4
  • 35.860 MHz - D5
  • 35.870 MHz - D6
  • 35.880 MHz - D7
  • 35.890 MHz - D8
  • 35.900 MHz - D9
  • 35.910 MHz - D10
57 MHz Low Power Data Links:
  • 57.225 MHz
  • 57.250 MHz
  • 57.275 MHz
  • 57.300 MHz
  • 77.025 MHz
  • 77.050 MHz
  • 77.075 MHz
  • 77.100 MHz
  • 77.725 MHz
  • 78.000 MHz
  • 81.725 MHz
  • 81.750 MHz
VHF High Band
France
  • 26.815 MHz - 26815 kHz
  • 26.825 MHz - 26825 kHz
  • 26.835 MHz - 26835 kHz
  • 26.845 MHz - 26845 kHz
  • 26.855 MHz - 26855 kHz
  • 26.865 MHz - 26865 kHz
  • 26.875 MHz - 26875 kHz
  • 26.885 MHz - 26885 kHz
  • 26.895 MHz - 26895 kHz
  • 26.905 MHz - 26905 kHz
  • 26.915 MHz - 26915 kHz
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.820 MHz
  • 35.830 MHz
  • 35.840 MHz
  • 35.850 MHz
  • 35.860 MHz
  • 35.870 MHz
  • 35.880 MHz
  • 35.890 MHz
  • 35.900 MHz
  • 35.910 MHz
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
Italy
  • 26.995 MHz
  • 27.045 MHz
  • 27.095 MHz
  • 27.145 MHz
  • 27.195 MHz
Door openers, limited to 5mW ERP, 10 kHz channel spacing, 10% duty cycle
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
  • 40.705 MHz
  • 40.715 MHz
  • 40.725 MHz
  • 40.735 MHz
  • 40.745 MHz
  • 40.755 MHz
  • 40.765 MHz
  • 40.775 MHz
  • 40.785 MHz
  • 40.795 MHz
  • 40.805 MHz
  • 40.815 MHz
  • 40.825 MHz
  • 40.835 MHz
  • 40.845 MHz
  • 40.855 MHz
  • 40.865 MHz
  • 40.875 MHz
72 MHz Band - model control
  • 72.080 MHz
  • 72.240 MHz
Spain
  • 27.505 MHz
  • 27.515 MHz
  • 27.525 MHz
  • 27.535 MHz
  • 27.545 MHz
  • 27.555 MHz
  • 27.565 MHz
  • 27.575 MHz
  • 27.585 MHz
  • 27.595 MHz
  • 27.845 MHz
  • 27.855 MHz
  • 29.710 MHz
  • 29.720 MHz
  • 29.730 MHz
  • 29.740 MHz
  • 29.750 MHz
  • 29.760 MHz
  • 29.770 MHz
  • 29.780 MHz
  • 29.790 MHz
  • 29.800 MHz
  • 29.810 MHz
  • 29.820 MHz
  • 29.830 MHz
  • 29.840 MHz
  • 29.850 MHz
  • 29.860 MHz
  • 29.870 MHz
  • 29.880 MHz
  • 29.890 MHz
  • 29.900 MHz
  • 29.910 MHz
  • 29.920 MHz
  • 29.930 MHz
  • 29.940 MHz
  • 29.950 MHz
  • 29.960 MHz
  • 29.970 MHz
  • 29.980 MHz
  • 29.990 MHz
  • 30.035 MHz
  • 30.045 MHz
  • 30.055 MHz
  • 30.065 MHz
  • 30.075 MHz
  • 30.085 MHz - Yellow 38
  • 30.095 MHz - Yellow 39
  • 30.105 MHz - Yellow 40
  • 30.115 MHz - Yellow 41
  • 30.125 MHz
  • 30.135 MHz
  • 30.145 MHz
  • 30.155 MHz
  • 30.165 MHz
  • 30.175 MHz
  • 30.185 MHz - Yellow 48
  • 30.195 MHz - Yellow 49
  • 30.205 MHz
  • 30.215 MHz
  • 30.225 MHz
  • 30.235 MHz
  • 30.245 MHz
  • 30.255 MHz
  • 30.265 MHz
  • 30.275 MHz
  • 30.285 MHz
  • 30.295 MHz
  • 40 MHz Band
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
  • 40.875 MHz
  • 40.900 MHz
  • 40.925 MHz
  • 40.950 MHz
Switzerland
RIR1007 specifications
27 MHz SRDs 27 MHz RC
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.210 MHz
  • 35.220 MHz
  • 40.665 MHz - Channel A
  • 40.675 MHz - Channel B
  • 40.685 MHz - Channel C
  • 40.695 MHz - Channel D
  • 40.715 MHz
  • 40.725 MHz
  • 40.735 MHz
  • 40.745 MHz
  • 40.755 MHz
  • 40.765 MHz
  • 40.775 MHz
  • 40.785 MHz
  • 40.795 MHz
  • 40.805 MHz
  • 40.815 MHz
  • 40.825 MHz
  • 40.835 MHz
  • 40.845 MHz
  • 40.855 MHz
  • 40.865 MHz
  • 40.875 MHz
  • 40.885 MHz
  • 40.895 MHz
  • 40.905 MHz
  • 40.915 MHz
  • 40.925 MHz
  • 40.935 MHz
  • 40.945 MHz
  • 40.955 MHz
  • 40.965 MHz
  • 40.975 MHz
  • 40.985 MHz
2.4 GHz band
2.4 GHz band
5.8 GHz band
Sweden
  • 35.000 MHz - RC Channel 60
  • 35.010 MHz - RC Channel 61
  • 35.020 MHz - RC Channel 62
  • 35.030 MHz - RC Channel 63
  • 35.040 MHz - RC Channel 64
  • 35.050 MHz - RC Channel 65
  • 35.060 MHz - RC Channel 66
  • 35.070 MHz - RC Channel 67
  • 35.080 MHz - RC Channel 68
  • 35.090 MHz - RC Channel 69
  • 35.100 MHz - RC Channel 70
  • 35.110 MHz - RC Channel 71
  • 35.120 MHz - RC Channel 72
  • 35.130 MHz - RC Channel 73
  • 35.140 MHz - RC Channel 74
  • 35.150 MHz - RC Channel 75
  • 35.160 MHz - RC Channel 76
  • 35.170 MHz - RC Channel 77
  • 35.180 MHz - RC Channel 78
  • 35.190 MHz - RC Channel 79
  • 35.200 MHz - RC Channel 80
  • 35.210 MHz - RC Channel 81
  • 35.220 MHz - RC Channel 82
  • 35.230 MHz - RC Channel 83
  • 35.240 MHz - RC Channel 84
  • 35.250 MHz - RC Channel 85
  • 35.260 MHz - RC Channel 86
  • 35.270 MHz - RC Channel 87
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
  • 40.705 MHz
  • 40.715 MHz
  • 40.725 MHz
  • 40.735 MHz
  • 40.745 MHz
  • 40.755 MHz
  • 40.765 MHz
  • 40.775 MHz
  • 40.785 MHz
  • 40.795 MHz
Finland
  • 26825 kHz 26.825 MHz
  • 26845 kHz 26.845 MHz
  • 26865 kHz 26.865 MHz
  • 26885 kHz 26.885 MHz
  • 26905 kHz 26.905 MHz
  • 26925 kHz 26.925 MHz
  • 26935 kHz 26.935 MHz
  • 26945 kHz 26.945 MHz
  • 26995 kHz 26.995 MHz
  • 27095 kHz 27.045 MHz
  • 27095 kHz 27.095 MHz
  • 27145 kHz 27.145 MHz
  • 27195 kHz 27.195 MHz
  • 27255 kHz 27.255 MHz
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.210 MHz
  • 35.220 MHz
Norway
30 MHz band, 100mW power output limit, 10 kHz bandwidth limit. Standard EC (EU) 35 MHz band also permitted, 100mW power limit.
  • 30.010 MHz
  • 30.020 MHz
  • 30.030 MHz
  • 30.040 MHz
  • 30.050 MHz
  • 30.060 MHz
  • 30.070 MHz
  • 30.080 MHz
  • 30.090 MHz
  • 30.100 MHz
  • 30.110 MHz
  • 30.120 MHz
  • 30.130 MHz
  • 30.140 MHz
  • 30.150 MHz
  • 30.160 MHz
  • 30.170 MHz
  • 30.180 MHz
  • 30.190 MHz
  • 30.200 MHz
  • 30.210 MHz
  • 30.220 MHz
  • 30.230 MHz
  • 30.240 MHz
  • 30.250 MHz
  • 30.260 MHz
  • 30.270 MHz
  • 30.280 MHz
  • 30.290 MHz
  • 30.290 MHz
  • 30.300 MHz
Denmark
  • Frequencies
  • 138.650 MHz - 500mW ERP
  • Bands
Russia
  • 26.995 MHz - unknown power limit - standard model control, short range device and data link frequency
  • 27.045 MHz - unknown power limit - standard model control, short range device and data link frequency
  • 27.095 MHz - unknown power limit - standard model control, short range device and data link frequency
  • 27.145 MHz - unknown power limit - standard model control, short range device and data link frequency
  • 27.195 MHz - unknown power limit - standard model control, short range device and data link frequency
  • 27.255 MHz - unknown power limit - standard model control, short range device and data link frequency
27 MHz
  • 26.975 MHz - Channel 01
  • 26.995 MHz - Channel 02
  • 27.025 MHz - Channel 03
  • 27.075 MHz - Channel 05
  • 27.095 MHz - Channel 06
  • 27.145 MHz - Channel 08
  • 27.175 MHz - Channel 09
  • 27.195 MHz - Channel 10
  • 27.225 MHz - Channel 11
  • 27.255 MHz - Channel 12
  • 72.130 MHz - Aircraft only
  • 72.150 MHz - Aircraft only
  • 72.170 MHz - Aircraft only
  • 72.190 MHz - Aircraft only
  • 72.210 MHz - Aircraft only
  • 72.790 MHz - Aircraft only
  • 72.810 MHz - Aircraft only
  • 72.830 MHz - Aircraft only
  • 72.850 MHz - Aircraft only
  • 72.870 MHz - Aircraft only
  • 73.220 MHz - General RC use
  • 73.230 MHz - General RC use
  • 73.240 MHz - General RC use
  • 73.250 MHz - General RC use
  • 73.260 MHz - General RC use
  • 73.270 MHz - General RC use
  • 73.280 MHz - General RC use
  • 73.290 MHz - General RC use
  • 73.300 MHz - General RC use
  • 73.310 MHz - General RC use
  • 73.320 MHz - General RC use
  • 2441.75 MHz
  • 2484 MHz
  • 426.028125 MHz
  • 426.034375 MHz
  • 426.040625 MHz
  • 426.046875 MHz
  • 426.053125 MHz
  • 426.059375 MHz
  • 426.065625 MHz
  • 426.071875 MHz
  • 426.078125 MHz
  • 426.084375 MHz
  • 426.090625 MHz
  • 426.096875 MHz
  • 426.103125 MHz
  • 426.109375 MHz
  • 426.115625 MHz
  • 426.121875 MHz
  • 426.128125 MHz
  • 426.134375 MHz
  • 429.178125 MHz
  • 429.184375 MHz
  • 429.190625 MHz
  • 429.196875 MHz
  • 429.203125 MHz
  • 429.209375 MHz
  • 429.215625 MHz
  • 429.221875 MHz
  • 429.228125 MHz
  • 429.234375 MHz
  • 429.240625 MHz
  • 429.246875 MHz
  • 429.253125 MHz
  • 429.259375 MHz
  • 429.265625 MHz
  • 429.271875 MHz
  • 429.278125 MHz
  • 429.284375 MHz
  • 429.290625 MHz
  • 429.296875 MHz
  • 429.303125 MHz
  • 429.409375 MHz
  • 429.415625 MHz
  • 429.421875 MHz
  • 429.428125 MHz
  • 429.434375 MHz
  • 429.440625 MHz
  • 429.446875 MHz
  • 429.453125 MHz
  • 429.459375 MHz
  • 429.465625 MHz
  • 429.471875 MHz
  • 429.478125 MHz
  • 429.484375 MHz
  • 429.490625 MHz
  • 429.496875 MHz
  • 429.503125 MHz
  • 429.509375 MHz
  • 429.515625 MHz
  • 429.521875 MHz
  • 429.528125 MHz
  • 429.534375 MHz
  • 429.540625 MHz
  • 429.546875 MHz
  • 429.553125 MHz
  • 429.559375 MHz
  • 429.565625 MHz
  • 429.571875 MHz
  • 429.578125 MHz
  • 429.584375 MHz
  • 429.590625 MHz
  • 429.596875 MHz
  • 429.603125 MHz
  • 429.609375 MHz
  • 429.615625 MHz
  • 429.621875 MHz
  • 429.628125 MHz
  • 429.634375 MHz
  • 429.640625 MHz
  • 429.646875 MHz
  • 429.653125 MHz
  • 429.659375 MHz
  • 429.665625 MHz
  • 429.671875 MHz
  • 429.678125 MHz
  • 429.684375 MHz
  • 429.690625 MHz
  • 429.696875 MHz
  • 429.703125 MHz
  • 429.709375 MHz
  • 429.715625 MHz
  • 429.721875 MHz
  • 429.728125 MHz
  • 429.734375 MHz
  • 429.815625 MHz
  • 429.821875 MHz
  • 429.828125 MHz
  • 429.834375 MHz
  • 429.840625 MHz
  • 429.846875 MHz
  • 429.853125 MHz
  • 429.859375 MHz
  • 429.865625 MHz
  • 429.871875 MHz
  • 429.878125 MHz
  • 429.884375 MHz
  • 429.890625 MHz
  • 429.896875 MHz
  • 429.903125 MHz
  • 429.909375 MHz
  • 429.915625 MHz
  • 429.921875 MHz
  • 449.715625 MHz
  • 449.721875 MHz
  • 449.734375 MHz
  • 449.740625 MHz
  • 449.746875 MHz
  • 449.753125 MHz
  • 449.759375 MHz
  • 449.765625 MHz
  • 449.771875 MHz
  • 449.778125 MHz
  • 449.784375 MHz
  • 449.790625 MHz
  • 449.796875 MHz
  • 449.803125 MHz
  • 449.809375 MHz
  • 449.815625 MHz
  • 449.821875 MHz
  • 426.0250 MHz
  • 426.0375 MHz
  • 426.0500 MHz
  • 426.0625 MHz
  • 426.0750 MHz
  • 426.0875 MHz
  • 426.1000 MHz
  • 426.1125 MHz
  • 426.1250 MHz
  • 426.1375 MHz
  • 429.1750 MHz
  • 429.1875 MHz
  • 429.2000 MHz
  • 429.2125 MHz
  • 429.2250 MHz
  • 429.2375 MHz
  • 429.2500 MHz
  • 429.2625 MHz
  • 429.2750 MHz
  • 429.2875 MHz
  • 429.3000 MHz
  • 429.3125 MHz
  • 429.3250 MHz
  • 429.3375 MHz
  • 429.3500 MHz
  • 429.3625 MHz
  • 429.3750 MHz
  • 429.3875 MHz
  • 429.4000 MHz
  • 429.4125 MHz
  • 429.4250 MHz
  • 429.4375 MHz
  • 429.4500 MHz
  • 429.4625 MHz
  • 429.4750 MHz
  • 429.4875 MHz
  • 429.5000 MHz
  • 429.5125 MHz
  • 429.5250 MHz
  • 429.5375 MHz
  • 429.5500 MHz
  • 429.5625 MHz
  • 429.5750 MHz
  • 429.5875 MHz
  • 429.6000 MHz
  • 429.6125 MHz
  • 429.6250 MHz
  • 429.6375 MHz
  • 429.6500 MHz
  • 429.6625 MHz
  • 429.6750 MHz
  • 429.6875 MHz
  • 429.7000 MHz
  • 429.7125 MHz
  • 429.7250 MHz
  • 429.7375 MHz
  • 429.8125 MHz
  • 429.9250 MHz
  • 449.7125 MHz
  • 449.7250 MHz
  • 449.7375 MHz
  • 449.7500 MHz
  • 449.7625 MHz
  • 449.7750 MHz
  • 449.7875 MHz
  • 449.8000 MHz
  • 449.8125 MHz
  • 449.8250 MHz
  • 449.8375 MHz
  • 449.8500 MHz
  • 449.8625 MHz
  • 449.8750 MHz
  • 449.8875 MHz
  • 449.8000 MHz
  • 449.8125 MHz
  • 449.8250 MHz
  • 449.8375 MHz
  • 449.8500 MHz
  • 449.8625 MHz
  • 449.8750 MHz
  • 449.8875 MHz
  • 469.7375 MHz
  • 469.7500 MHz
  • 469.7625 MHz
  • 469.7750 MHz
  • 469.7875 MHz
  • 469.8000 MHz
  • 469.8125 MHz
  • 469.8250 MHz
  • 469.8375 MHz
  • 469.8500 MHz
  • 469.8625 MHz
  • 469.8750 MHz
  • 469.8875 MHz
People's Republic of China
  • 40.610 MHz
  • 40.630 MHz
  • 40.650 MHz
  • 40.670 MHz
  • 40.690 MHz
  • 40.710 MHz
  • 40.730 MHz
  • 40.750 MHz
  • 40.770 MHz
  • 40.790 MHz
  • 40.810 MHz
  • 40.830 MHz
  • 40.850 MHz
  • 72.130 MHz
  • 72.150 MHz
  • 72.170 MHz
  • 72.190 MHz
  • 72.210 MHz
  • 72.790 MHz
  • 72.810 MHz
  • 72.830 MHz
  • 72.850 MHz
  • 72.870 MHz
  • 223.100 MHz
  • 223.700 MHz
  • 223.975 MHz
  • 224.600 MHz
  • 225.025 MHz
  • 225.325 MHz
  • 230.100 MHz
  • 230.700 MHz
  • 230.975 MHz
  • 231.600 MHz
  • 232.025 MHz
  • 232.325 MHz
  • 418.950 MHz
  • 418.975 MHz
  • 419.000 MHz
  • 419.025 MHz
  • 419.050 MHz
  • 419.075 MHz
  • 419.100 MHz
  • 419.125 MHz
  • 419.150 MHz
  • 419.175 MHz
  • 419.200 MHz
  • 419.225 MHz
  • 419.250 MHz
  • 419.275 MHz
Korea
Republic of Korea South Korea
  • 16K0A1D
  • 16K0A2D
  • 16K0F1D
  • 16K0F2D
  • 16K0G1D
  • 16K0G2D
Field strength limited to 200 uV/m at 500 meters or 10 mV/m at 10m or 333 uW 333 microwatts ERP - sources conflict regarding the field strength limits vs. output power and antenna limits for the 27 MHz and 40 MHz bands
  • 26.958 MHz - 27.282 MHz - telecommand, remote control for toys, security alarm radio links
  • 40.656 MHz - 40.704 MHz - telecommand, remote control for toys, security alarm radio links
  • 219.150 MHz
  • 219.175 MHz
  • 219.200 MHz
  • 219.225 MHz
India
"New" channel plan:
Old (???) channel plan:
Several bands available.
  • 27 MHz band - 27MHz AM
  • 29 MHz band - 29MHz FM
  • 35 MHz band - 35MHz FM
  • 36 MHz band - 36MHz FM
  • 40 MHz band - 40MHz FM
  • 72 MHz band - 72MHz FM
  • 2.4 GHz band
  • Channel 22 - 476.9500 MHz
  • Channel 23 - 476.9750 MHz
  • Channel 61 - 476.9375 MHz
  • Channel 62 - 476.9625 MHz
  • Channel 63 - 476.9875 MHz
  • 35.000 MHz - RC Channel 500
  • 35.010 MHz - RC Channel 501
  • 35.020 MHz - RC Channel 502
  • 35.030 MHz - RC Channel 503
  • 35.040 MHz - RC Channel 504
  • 35.050 MHz - RC Channel 505
  • 35.060 MHz - RC Channel 506
  • 35.070 MHz - RC Channel 507
  • 35.080 MHz - RC Channel 508
  • 35.090 MHz - RC Channel 509
  • 35.100 MHz - RC Channel 510
  • 35.110 MHz - RC Channel 511
  • 35.120 MHz - RC Channel 512
  • 35.130 MHz - RC Channel 513
  • 35.140 MHz - RC Channel 514
  • 35.150 MHz - RC Channel 515
  • 35.160 MHz - RC Channel 516
  • 35.170 MHz - RC Channel 517
  • 35.180 MHz - RC Channel 518
  • 35.190 MHz - RC Channel 519
  • 35.200 MHz - RC Channel 520
  • 35.210 MHz - RC Channel 521
  • 35.220 MHz - RC Channel 522
  • 35.230 MHz - RC Channel 523
  • 35.240 MHz - RC Channel 524
  • 35.250 MHz - RC Channel 525
  • 35.260 MHz - RC Channel 526
  • 35.270 MHz - RC Channel 527
  • 35.280 MHz - RC Channel 528
  • 35.290 MHz - RC Channel 529
  • 35.300 MHz - RC Channel 530
  • 36.250 MHz - RC Channel 625
  • 36.260 MHz - RC Channel 626
  • 36.270 MHz - RC Channel 627
  • 36.280 MHz - RC Channel 628
  • 36.290 MHz - RC Channel 629
  • 36.300 MHz - RC Channel 630
  • 36.310 MHz - RC Channel 631
  • 36.320 MHz - RC Channel 632
  • 36.330 MHz - RC Channel 633
  • 36.340 MHz - RC Channel 634
  • 36.350 MHz - RC Channel 635
  • 36.360 MHz - RC Channel 636
  • 36.370 MHz - RC Channel 637
  • 36.380 MHz - RC Channel 638
  • 36.390 MHz - RC Channel 639
  • 36.400 MHz - RC Channel 640
  • 36.410 MHz - RC Channel 641
  • 36.420 MHz - RC Channel 642
  • 36.430 MHz - RC Channel 643
  • 36.440 MHz - RC Channel 644
  • 36.450 MHz - RC Channel 645
  • 36.460 MHz - RC Channel 646
  • 36.470 MHz - RC Channel 647
  • 36.480 MHz - RC Channel 648
  • 36.490 MHz - RC Channel 649
  • 36.500 MHz - RC Channel 650
  • 36.510 MHz - RC Channel 651
  • 36.520 MHz - RC Channel 652
  • 36.530 MHz - RC Channel 653
  • 36.540 MHz - RC Channel 654
  • 36.550 MHz - RC Channel 655
  • 36.560 MHz - RC Channel 656
  • 36.570 MHz - RC Channel 657
  • 36.580 MHz - RC Channel 658
  • 36.590 MHz - RC Channel 659
  • 72.010 MHz - RC Channel 701
  • 72.030 MHz - RC Channel 703
  • 72.050 MHz - RC Channel 705
  • 72.070 MHz - RC Channel 707
  • 72.090 MHz - RC Channel 709
  • 72.110 MHz - RC Channel 711
  • 72.130 MHz - RC Channel 713
  • 72.150 MHz - RC Channel 715
  • 72.170 MHz - RC Channel 717
  • 72.190 MHz - RC Channel 719
  • 72.210 MHz - RC Channel 721
  • 72.230 MHz - RC Channel 723
  • 72.250 MHz - RC Channel 725
  • 72.270 MHz - RC Channel 727
  • 72.290 MHz - RC Channel 729
  • 72.310 MHz - RC Channel 731
  • 72.330 MHz - RC Channel 733
  • 72.350 MHz - RC Channel 735
  • 72.370 MHz - RC Channel 737
  • 72.390 MHz - RC Channel 739
  • 72.410 MHz - RC Channel 741
  • 72.430 MHz - RC Channel 743
  • 72.450 MHz - RC Channel 745
  • 72.470 MHz - RC Channel 747
  • 72.490 MHz - RC Channel 749
  • 72.510 MHz - RC Channel 751
  • 72.530 MHz - RC Channel 753
  • 72.550 MHz - RC Channel 755
  • 72.570 MHz - RC Channel 757
  • 72.590 MHz - RC Channel 759
  • 72.610 MHz - RC Channel 761
  • 72.630 MHz - RC Channel 763
  • 72.650 MHz - RC Channel 765
  • 72.670 MHz - RC Channel 767
  • 72.690 MHz - RC Channel 769
  • 72.710 MHz - RC Channel 771
  • 72.730 MHz - RC Channel 773
  • 72.750 MHz - RC Channel 775
  • 72.770 MHz - RC Channel 777
  • 72.790 MHz - RC Channel 779
  • Channel 22 - 476.950 MHz
  • Channel 23 - 476.975 MHz
  • 36.010 MHz - RC Channel 601
  • 36.020 MHz - RC Channel 602
  • 36.030 MHz - RC Channel 603
  • 36.040 MHz - RC Channel 604
  • 36.050 MHz - RC Channel 605
  • 36.060 MHz - RC Channel 606
  • 36.070 MHz - RC Channel 607
  • 36.080 MHz - RC Channel 608
  • 36.090 MHz - RC Channel 609
  • 36.100 MHz - RC Channel 610
  • 36.110 MHz - RC Channel 611
  • 36.120 MHz - RC Channel 612
  • 36.130 MHz - RC Channel 613
  • 36.140 MHz - RC Channel 614
  • 36.150 MHz - RC Channel 615
  • 36.160 MHz - RC Channel 616
  • 36.170 MHz - RC Channel 617
  • 36.180 MHz - RC Channel 618
  • 36.190 MHz - RC Channel 619
  • 36.200 MHz - RC Channel 620
  • 36.210 MHz - RC Channel 621
  • 36.220 MHz - RC Channel 622
  • 36.230 MHz - RC Channel 623
  • 36.240 MHz - RC Channel 624
  • 40.665 MHz - RC Channel 50
  • 40.675 MHz - RC Channel 51
  • 40.685 MHz - RC Channel 52
  • 40.695 MHz - RC Channel 53
Swaziland / Eswatini
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.210 MHz
  • 35.220 MHz
  • 40 MHz band, shared with ISM and land mobile radio.
  • 54 MHz band, model control.
  • 54.4500 MHz
  • 54.4625 MHz
  • 54.4750 MHz
  • 54.4875 MHz
  • 54.5000 MHz
  • 54.5125 MHz
  • 54.5250 MHz
  • 54.5375 MHz
  • 54.5500 MHz
European regulations
  • 2.4 GHz band
