Military ISR
Revision as of 16:31, 14 November 2024 by R4002 (Talk | contribs)
UHF IISR - not to be confused with the similar British Army UK military Personal Role Radio (PRR) that uses frequency hopping spread spectrum (FHSS) in the higher UHF band 2.4 GHz band with 50mW power.
  • Channel 1 - 396.875 MHz
  • Channel 2 - 397.125 MHz
  • Channel 3 - 397.175 MHz
  • Channel 4 - 397.375 MHz
  • Channel 5 - 397.425 MHz
  • Channel 6 - 397.475 MHz
  • Channel 7 - 397.550 MHz
  • Channel 8 - 397.950 MHz
  • Channel 9 - 398.050 MHz
  • Channel 10 - 399.425 MHz
  • Channel 11 - 399.475 MHz
  • Channel 12 - 399.725 MHz
  • Channel 13 - 399.925 MHz
  • Channel 14 - 399.975 MHz
14 channels, with the FRS-standard 38 CTCSS tones to reduce interference from weak/distant signals. Originally intended to be a military only FRS type intra squad radio service." Use of CTCSS (PL) tones (subchannels) is optional, with some users simply leaving the radios in carrier squelch (CSQ) mode.
Designed to be low probability of intercept and reduce the very short range comms on the military FM band (30-88 MHz). ISR or IISR. 380 MHz-430 MHz. Limited adoption (apparently?). Special version of the Icom IC-4008A series / Icom IC-446S FRS/PMR446 radios called the Icom IC-4008M - apparently designed for the US Marine Corps. The Civil Air Patrol (CAP) apparently also at one point expressed interest. Because CAP is part of the USAF, CAP is prohibited from using civilian radio services such as FRS, GMRS, MURS and regular old 11 meter band CB Radio.
Not to be confused with VHF/UHF militia patriot radio channel plans squad radio and 16 channel UHF low power intra-squad radio (Baofeng UV-5R, UV-82, VHF/UHF handheld COTS radios, etc.)
