Revision as of 23:48, 1 June 2025 by R4002 (Talk | contribs)
Interop guides recommend programming in the FRS, MURS, oil spill cleanup frequencies and select VHF marine band frequencies (generally VHF marine channels 06, 13, 16, 21A, 22A, 23A, 81A, 82A and 83A) and "color dot" VHF/UHF itinerant business band frequencies into radios as part of interoperability planning. The (likely correct) presumption is that during an emergency those frequencies will also be used. Many emergency management agencies maintain caches of CB equipment as part of their HF radio capability (see also: SHARES and SECURE) for that same reason. This practice is akin to state DOT or Department of Highways motorist assistance agencies having CB radios installed in their trucks for direct communication with and monitoring of trucker and highway chatter on CB radio channel 19.
VHF low band VHF-low
  • 39.4600 MHz - LLAW1D - Simplex (156.7 Hz PL transmit tone only)
  • 39.4600 MHz - LLAW1 - Repeater, paired with 45.8600 MHz (input) (156.7 Hz PL)
  • 39.4800 MHz - LFIRE2D - Simplex (156.7 Hz PL transmit tone only)
  • 39.4800 MHz - LFIRE2 - Repeater, paired with 45.8800 MHz (input) (156.7 Hz PL)
  • 45.8600 MHz - LLAW3D - Simplex (156.7 Hz PL transmit tone only)
  • 45.8600 MHz - LLAW3 - Repeater, paired with 39.4600 MHz (input) (156.7 Hz PL)
  • 45.8800 MHz - LFIRE4D - Simplex (156.7 Hz PL transmit tone only)
  • 45.8800 MHz - LFIRE4 - Repeater, paired with 39.4800 MHz (input) (156.7 Hz PL
VHF high band VHF band
  • 155.1600 MHz - VSAR16 or NATSAR - Search and Rescue - simplex CTCSS 127.3 Hz (CSQ receive recommended)
  • 155.3400 MHz - VMED28 - Ambulance to Hospital/Hospital to Hospital, medical interop - HEAR or HEAR340 (various CTCSS tones)
  • 154.2800 MHz - VFIRE21 - Fire Interop - Primary, other designations (such as F-MARS) frequently used
UHF band
Use of 156.7 Hz PL tone transmit with CSQ (carrier squelch) receive recommended if possible. Full transmit and receive tone squelch may be used depending on local requirements.
  • 462.9500 MHz - MED-9 - Calling/Dispatch, repeater paired with 467.9500 MHz
  • 462.9750 MHz - MED-10 - Calling/Dispatch, repeater paired with 467.9750 MHz
  • 463.0000 MHz - MED-1 - EMS Operations, repeater paired with 468.0000 MHz
  • 463.0250 MHz - MED-2 - EMS Operations, repeater paired with 468.0250 MHz
  • 463.0500 MHz - MED-3 - EMS Operations, repeater paired with 468.0500 MHz
  • 463.0750 MHz - MED-4 - EMS Operations, repeater paired with 468.0750 MHz
  • 463.1000 MHz - MED-5 - EMS Operations, repeater paired with 468.1000 MHz
  • 463.1250 MHz - MED-6 - EMS Operations, repeater paired with 468.1250 MHz
  • 463.1500 MHz - MED-7 - EMS Operations, repeater paired with 468.1500 MHz
  • 463.1750 MHz - MED-8 - EMS Operations, repeater paired with 468.1750 MHz
  • 462.9625 MHz - MED-92 - Calling/Dispatch, repeater paired with 467.9625 MHz
  • 462.9875 MHz - MED-102 - Calling/Dispatch, repeater paired with 467.9875 MHz
  • 463.0125 MHz - MED-12 - EMS Operations, repeater paired with 468.0125 MHz
  • 463.0375 MHz - MED-22 - EMS Operations, repeater paired with 468.0375 MHz
  • 463.0625 MHz - MED-32 - EMS Operations, repeater paired with 468.0625 MHz
  • 463.0875 MHz - MED-42 - EMS Operations, repeater paired with 468.0875 MHz
  • 463.1125 MHz - MED-52 - EMS Operations, repeater paired with 468.1125 MHz
  • 463.1375 MHz - MED-62 - EMS Operations, repeater paired with 468.1375 MHz
  • 463.1625 MHz - MED-72 - EMS Operations, repeater paired with 468.1625 MHz
  • 463.1875 MHz - MED-82 - EMS Operations, repeater paired with 468.1875 MHz
  • 462.95625 MHz - MED-91 - EMS Operations, repeater paired with 467.95625 MHz
  • 462.96875 MHz - MED-93 - EMS Operations, repeater paired with 467.96875 MHz
  • 462.98125 MHz - MED-101 - EMS Operations, repeater paired with 467.98125 MHz
  • 462.99375 MHz - MED-103 - EMS Operations, repeater paired with 467.99375 MHz
  • 463.00625 MHz - MED-11 - EMS Operations, repeater paired with 468.00625 MHz
  • 463.01875 MHz - MED-13 - EMS Operations, repeater paired with 468.01875 MHz
  • 463.03125 MHz - MED-21 - EMS Operations, repeater paired with 468.03125 MHz
  • 463.04375 MHz - MED-23 - EMS Operations, repeater paired with 468.04375 MHz
  • 463.05625 MHz - MED-31 - EMS Operations, repeater paired with 468.05625 MHz
  • 463.06875 MHz - MED-33 - EMS Operations, repeater paired with 468.06875 MHz
  • 463.08125 MHz - MED-41 - EMS Operations, repeater paired with 468.08125 MHz
  • 463.09375 MHz - MED-43 - EMS Operations, repeater paired with 468.09375 MHz
  • 463.10625 MHz - MED-51 - EMS Operations, repeater paired with 468.10625 MHz
  • 463.11875 MHz - MED-53 - EMS Operations, repeater paired with 468.11875 MHz
  • 463.13125 MHz - MED-61 - EMS Operations, repeater paired with 468.13125 MHz
  • 463.14375 MHz - MED-63 - EMS Operations, repeater paired with 468.14375 MHz
  • 463.15625 MHz - MED-71 - EMS Operations, repeater paired with 468.15625 MHz
  • 463.16875 MHz - MED-73 - EMS Operations, repeater paired with 468.16875 MHz
  • 463.18125 MHz - MED-81 - EMS Operations, repeater paired with 468.18125 MHz
  • 463.19375 MHz - MED-83 - EMS Operations, repeater paired with 468.19375 MHz
700 MHz band
  • 769.24375 MHz - 7CALL50/7CALL50D - Calling, simplex or repeater (input: 799.24375 MHz) TX 293 NAC, RX F7E NAC
  • 773.25625 MHz - 7CALL70/7CALL70D - Calling (secondary), simplex or repeater (input: 803.25625 MHz) TX 293 NAC, RX F7E NAC
  • 769.14375 MHz - 7TAC51/7TAC51D - General Use, simplex or repeater (input: 799.14375 MHz) TX 293 NAC, RX F7E NAC
  • 769.64375 MHz - 7TAC52/7TAC52D - General Use, simplex or repeater (input: 799.64375 MHz) TX 293 NAC, RX F7E NAC
  • 770.14375 MHz - 7TAC53/7TAC53D - General Use, simplex or repeater (input: 800.14375 MHz) TX 293 NAC, RX F7E NAC
  • 770.64375 MHz - 7TAC54/7TAC54D - General Use, simplex or repeater (input: 800.64375 MHz) TX 293 NAC, RX F7E NAC
  • 769.74375 MHz - 7TAC55/7TAC55D - General Use, simplex or repeater (input: 799.74375 MHz) TX 293 NAC, RX F7E NAC
  • 770.24375 MHz - 7TAC56/7TAC56D - General Use, simplex or repeater (input: 800.24375 MHz) TX 293 NAC, RX F7E NAC
  • 770.99375 MHz - 7TAC57/7TAC57D - General Use, simplex or repeater (input: 800.99375 MHz) TX 293 NAC, RX F7E NAC
  • 770.89375 MHz - 7MOB59/7MOB59D - Mobile Repeater, simplex or repeater (input: 800.89375 MHz) TX 293 NAC, RX F7E NAC
  • 770.39375 MHz - 7LAW61/7LAW61D - Law Enforcement, simplex or repeater (input: 800.39375 MHz) TX 293 NAC, RX F7E NAC
  • 770.49375 MHz - 7LAW62/7LAW62D - Law Enforcement, simplex or repeater (input: 800.49375 MHz) TX 293 NAC, RX F7E NAC
  • 769.89375 MHz - 7FIRE63/7FIRE63D - Fire, simplex or repeater (input: 799.89375 MHz) TX 293 NAC, RX F7E NAC
  • 769.99375 MHz - 7FIRE64/7FIRE64D - Fire, simplex or repeater (input: 799.99375 MHz) TX 293 NAC, RX F7E NAC
  • 769.39375 MHz - 7MED65/7MED65D - EMS, simplex or repeater (input: 799.39375 MHz) TX 293 NAC, RX F7E NAC
  • 769.49375 MHz - 7MED66/7MED66D - EMS, simplex or repeater (input: 799.49375 MHz) TX 293 NAC, RX F7E NAC
  • 770.74375 MHz - 7DATA69/7DATA69D - Data, simplex or repeater (input: 800.74375 MHz) TX 293 NAC, RX F7E NAC
  • 773.10625 MHz - 7TAC71/7TAC71D - General Use, simplex or repeater (input: 803.10625 MHz) TX 293 NAC, RX F7E NAC
  • 773.60625 MHz - 7TAC72/7TAC72D - General Use, simplex or repeater (input: 803.60625 MHz) TX 293 NAC, RX F7E NAC
  • 774.10625 MHz - 7TAC73/7TAC73D - General Use, simplex or repeater (input: 804.10625 MHz) TX 293 NAC, RX F7E NAC
  • 774.60625 MHz - 7TAC74/7TAC74D - General Use, simplex or repeater (input: 804.60625 MHz) TX 293 NAC, RX F7E NAC
  • 773.75625 MHz - 7TAC75/7TAC75D - General Use, simplex or repeater (input: 803.75625 MHz) TX 293 NAC, RX F7E NAC
  • 774.25625 MHz - 7TAC76/7TAC76D - General Use, simplex or repeater (input: 804.25625 MHz) TX 293 NAC, RX F7E NAC
  • 774.85625 MHz - 7TAC77/7TAC77D - General Use, simplex or repeater (input: 804.85625 MHz) TX 293 NAC, RX F7E NAC
  • 774.50625 MHz - 7MOB79/7MOB79D - Mobile Repeater, simplex or repeater (input: 804.50625 MHz) TX 293 NAC, RX F7E NAC
  • 774.00625 MHz - 7LAW81/7LAW81D - Law Enforcement, simplex or repeater (input: 804.00625 MHz) TX 293 NAC, RX F7E NAC
  • 774.35625 MHz - 7LAW82/7LAW82D - Law Enforcement, simplex or repeater (input: 804.35625 MHz) TX 293 NAC, RX F7E NAC
  • 773.50625 MHz - 7FIRE83/7FIRE83D - Fire, simplex or repeater (input: 803.50625 MHz) TX 293 NAC, RX F7E NAC
  • 773.85625 MHz - 7FIRE84/7FIRE84D - Fire, simplex or repeater (input: 803.85625 MHz) TX 293 NAC, RX F7E NAC
  • 773.00625 MHz - 7MED86/7MED86D - EMS, simplex or repeater (input: 803.00625 MHz) TX 293 NAC, RX F7E NAC
  • 773.35625 MHz - 7MED87/7MED87D - EMS, simplex or repeater (input: 803.35625 MHz) TX 293 NAC, RX F7E NAC
  • 774.75625 MHz - 7DATA89/7DATA89D - Data, simplex or repeater (input: 804.75625 MHz) TX 293 NAC, RX F7E NAC
  • 769.13125 MHz - 7AG58/7AG58D - Air-to-Ground, simplex or repeater (input: 799.13125 MHz) TX 293 NAC, RX F7E NAC
  • 769.63125 MHz - 7AG60/7AG60D - Air-to-Ground, simplex or repeater (input: 799.63125 MHz) TX 293 NAC, RX F7E NAC
  • 770.13125 MHz - 7AG67/7AG67D - Air-to-Ground, simplex or repeater (input: 800.13125 MHz) TX 293 NAC, RX F7E NAC
  • 770.63125 MHz - 7AG68/7AG68D - Air-to-Ground, simplex or repeater (input: 800.63125 MHz) TX 293 NAC, RX F7E NAC
  • 773.11875 MHz - 7AG78/7AG78D - Air-to-Ground, simplex or repeater (input: 803.11875 MHz) TX 293 NAC, RX F7E NAC
  • 773.61875 MHz - 7AG80/7AG80D - Air-to-Ground, simplex or repeater (input: 803.61875 MHz) TX 293 NAC, RX F7E NAC
  • 774.11875 MHz - 7AG85/7AG85D - Air-to-Ground, simplex or repeater (input: 804.11875 MHz) TX 293 NAC, RX F7E NAC
  • 774.61875 MHz - 7AG88/7AG88D - Air-to-Ground, simplex or repeater (input: 804.61875 MHz) TX 293 NAC, RX F7E NAC
800 MHz band
  • 851.0125 MHz - 8CALL90D/8CALL90 - Calling, simplex or repeater (input: 806.0125 MHz) both with 156.7 Hz CTCSS
  • 851.5125 MHz - 8TAC91D/8TAC91 - Tac 1, simplex or repeater (input: 806.5125 MHz) both with 156.7 Hz CTCSS
  • 852.0125 MHz - 8TAC92D/8TAC92 - Tac 2, simplex or repeater (input: 807.0125 MHz) both with 156.7 Hz CTCSS
  • 852.5125 MHz - 8TAC93D/8TAC93 - Tac 3, simplex or repeater (input: 807.5125 MHz) both with 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 808.5125 MHz) both with 156.7 Hz CTCSS
  • 853.4875 MHz - old 800 MHz itinerant channel, may be used for simplex, tactical or talkaround purposes.
UHF band
See section above regarding use of analog (NFM) and/or digital voice (P25) and the associated selective calling tone squelch and/or NAC codes for Project 25 digital voice
  • Law Enforcement Plan
  • LE A Calling - 167.0875 MHz
  • LE B Calling - 414.0375 MHz
  • LE 01 Tactical - 162.0875 MHz
  • LE 02 Tactical - 162.2625 MHz
  • LE 03 Tactical - 162.8375 MHz
  • LE 04 Tactical - 163.2875 MHz
  • LE 05 Tactical - 163.4250 MHz
  • LE 06 Tactical - 167.2500 MHz
  • LE 07 Tactical - 167.7500 MHz
  • LE 08 Tactical - 168.1125 MHz
  • LE 09 Tactical - 168.4625 MHz
  • LE 10 Tactical - 418.9875 MHz
  • LE 11 Tactical - 419.1875 MHz
  • LE 12 Tactical - 419.6125 MHz
  • LE 13 Tactical - 414.0625 MHz
  • LE 14 Tactical - 414.3125 MHz
  • LE 15 Tactical - 414.3375 MHz
  • LE 16 Tactical - 409.9875 MHz
  • LE 17 Tactical - 410.1875 MHz
  • LE 18 Tactical - 410.6125 MHz
  • Incident Response Plan
  • NC 1 Calling - 164.7125 MHz
  • NC 2 Calling - 419.2375 MHz
  • IR 01 - 165.2500 MHz
  • IR 02 - 165.9625 MHz
  • IR 03 - 166.5750 MHz
  • IR 04 - 167.3250 MHz
  • IR 05 - 169.5375 MHz
  • IR 06 - 170.0125 MHz
  • IR 07 - 170.4125 MHz
  • IR 08 - 170.6875 MHz
  • IR 09 - 173.0375 MHz
  • IR 10 - 419.4375 MHz
  • IR 11 - 419.6375 MHz
  • IR 12 - 419.8375 MHz
  • IR 13 - 413.1875 MHz
  • IR 14 - 413.2125 MHz
  • IR 15 - 410.2375 MHz
  • IR 16 - 410.4375 MHz
  • IR 17 - 410.6375 MHz
  • IR 18 - 410.8375 MHz
  • 2182 kHz - USB voice - SAR operations - marine distress/calling
  • 3023 kHz - USB voice - SAR operations - marine, military
  • 4125 kHz - USB voice - SAR operations - marine distress/calling
  • 5680 kHz - USB voice - SAR operations
  • 6215 kHz - USB voice - SAR operations - marine distress/calling
  • 8291 kHz - USB voice - SAR operations - marine distress/calling
  • 8364 kHz - USB voice - SAR operations
  • 10003 kHz - USB voice - SAR operations
  • 12290 kHz - USB voice - SAR operations - marine distress/calling
  • 14993 kHz - USB voice - SAR operations
  • 16420 kHz - USB voice - SAR operations - marine distress/calling
  • 19993 kHz - USB voice - SAR operations
  • 40.5000 MHz - FM Guard - FM SINCGARS military emergency use only - Fox Guard or Fox Mike Guard 40.5 MHz
  • 121.5000 MHz - VHF Guard - VHF aircraft emergency use only - Victor Guard 121.5 MHz
  • 243.0000 MHz - UHF Guard - UHF aircraft emergency use only - Uniform Guard 243.0 MHz
  • 155.1600 MHz - SAR Ground Operations (127.3 Hz CTCSS transmit recommended, CSQ receive strongly recommended)
  • 155.3400 MHz - EMS/Medical Support
  • 123.1000 MHz - AM air-to-air (civilian)
  • 282.8000 MHz - AM air-to-air military SAR scene of action working channel
  • 345.0000 MHz - AM military USCG SAR calling
  • 156.8000 MHz - Marine hailing/calling DISTRESS ONLY (VHF marine channel 16)
  • 157.0500 MHz - Ground-to-marine assets SAR working channel (VHF marine channel 21A)
  • 157.0500 MHz - Marine operations, under authority of USCG Sector Commander (VHF marine channel 21A)
  • 157.1500 MHz - Marine operations, under authority of USCG Sector Commander (VHF marine channel 23A)
  • 157.1750 MHz - Ground-to-air SAR working channel (VHF marine channel 83A)
  • 122.8500 MHz - AM air rescue asset coordination
  • 122.9000 MHz - AM air rescue asset coordination
  • 123.0250 MHz - AM air rescue asset coordination
  • 123.0500 MHz - AM air rescue asset coordination
  • 123.0750 MHz - AM air rescue asset coordination - fixed-wing aircraft
  • 156.8500 MHz - SAR Command interop (VHF marine channel 17) - with USCG Sector Commander
  • 410.8375 MHz - IR 12 - SAR Command Federal/Non-Federal repeater (paired with 419.8375 MHz) - 167.9 Hz CTCSS
  • 159.4725 MHz - VTAC14 - SAR Command interop (VHF) - 156.7 Hz CTCSS
  • 453.8625 MHz - UTAC43D - SAR Command interop simplex (UHF) - 156.7 Hz CTCSS
  • 453.8625 MHz - UTAC43 - SAR Command interop repeater (paired with 458.8625 MHz) - 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94D - SAR Command interop simplex - 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94 - SAR Command interop repeater (paired with 808.0125 MHz) - 156.7 Hz CTCSS
  • 168.6250 MHz - Nationwide AIR GUARD - Must be included for emergency air-to-ground communications - 110.9 Hz CTCSS required
  • 168.6500 MHz - Nationwide Flight Following - National Flight Following frequency, interagency aircraft contact - 110.9 Hz CTCSS required
  • 170.9750 MHz - Command Repeater 1
  • 170.4500 MHz - Command Repeater 2
  • 170.4250 MHz - Command Repeater 3
  • 170.0000 MHz - Command Repeater 4
  • 169.7500 MHz - Command Repeater 5
  • 173.8125 MHz - Command Repeater 6
  • 168.7000 MHz - Command Simplex 1
  • 168.1000 MHz - Command Simplex 2
  • 168.0750 MHz - Command Simplex 3
  • 166.6750 MHz - Command Simplex 4
  • 167.1000 MHz - Command Simplex 5
  • 168.4750 MHz - Command Simplex 6
  • 166.6125 MHz - Air Tactics 1
  • 169.1500 MHz - Air Tactics 2
  • 169.2000 MHz - Air Tactics 3
  • 168.4000 MHz - Air Tactics 4
  • 167.9500 MHz - Air Tactics 5
  • 168.0500 MHz - Tactical 1
  • 168.2000 MHz - Tactical 2
  • 168.6000 MHz - Tactical 3
  • 166.7250 MHz - Tactical 4
  • 166.7750 MHz - Tactical 5
  • 168.2500 MHz - Tactical 6
  • 163.7125 MHz - Intra-Crew Base and Travel Net - Nationwide Mobilization - Handheld Portable Radios Only - NFM or P25 digital
  • 167.1375 MHz - Primary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
  • 168.6125 MHz - Secondary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
  • 173.6250 MHz - Tertiary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
  • 168.3500 MHz - Government Wide Tactical/Simplex
  • 163.1000 MHz - Government Wide Tactical/Simplex
  • 163.7125 MHz - Government Wide Tactical Simplex
  • 167.1375 MHz - Government Wide Tactical Simplex
  • 168.6125 MHz - Government Wide Tactical Simplex
  • 173.6250 MHz - Government Wide Tactical Simplex
  • 168.3500 MHz - Government Wide Tactical Repeater (163.1000 MHz input) - Portable Repeaters
  • 122.9250 MHz - Air A1 - Multicom - Natural Resources Aircraft
  • 122.9000 MHz - Air A2 - Multicom
  • 122.8500 MHz - Air A3 - Multicom
  • 122.7500 MHz - Air A4 - Fixed Wing Aircraft Air to Air
  • 123.0250 MHz - Air A5 - Helicopter Aircraft Air to Air
  • 406.4000 MHz - Logistics 1 (Repeater or simplex)
  • 406.5875 MHz - Logistics 2 (Repeater or simplex)
  • 407.7875 MHz - Logistics 3 (Repeater or simplex)
  • 410.2750 MHz - Logistics 4 (Repeater or simplex)
  • 410.7750 MHz - Logistics 5 (Repeater or simplex)
  • 408.6875 MHz - Logistics 6 (Repeater or simplex)
  • 408.5000 MHz - Logistics 7 (Repeater or simplex)
  • 411.4000 MHz - Logistics 8/ UHF Special Use 1 Simplex
  • 412.2250 MHz - Logistics 9/ UHF Special Use 2 Simplex
  • 27.575 MHz
  • 27.585 MHz
  • 6K00A2A - Tone-modulated AM (modulated Morse code, MCW, tone modulated CW). Just like VOR and NDB IDs.
  • 6K00A2D - Data or digital transmission, telecommand, telemetry, one or two subcarriers - amplitude shift keying or audio-frequency shift keying over an AM voice radio circuit
  • 6K00A3E - AM voice (full carrier AM with both sidebands), regular AM radiotelephony
From the NTIA "Red Book"
4.2.1 FREQUENCY ALLOTMENTS Allotment of 27575 and 27585 kHz for Short-Distance Low-Power Service These allotments are to provide for intermittent miscellaneous U.S. Government short-distance low-power radio communications, radio signaling, and the control of remote objects or devices by means of radio (where the radiated power exceeds the limit established under Part 7.9). The designated frequencies are allotted for use by U.S. Government agencies and may be authorized for use by agencies as required upon application. All stations operating on these frequencies shall meet the conditions and standards established for this service. The designated frequencies are available on a shared basis only and will not be authorized for exclusive use of any one agency. No protection from interference can be assured to any station operating in this service. Services involving safety of life and property should not employ these frequencies in view of their unprotected status. All transmissions are to be restricted to official U.S. Government business that requires the use of radio. Stations in this service shall utilize FCC type-accepted or type-approved Citizens Radio Band equipment or the equivalent. The maximum transmitter output power shall be five watts. Stations shall be identified in accordance with the regulations of each agency. The only class of station authorized is Mobile (including portable-type operation). Frequencies 27575 and 27585 kHz with 6KA2A, 6KA2D and 6KA3E emission are designated for the U.S. Government short-distance low-power radio service. All applications for the use of these frequencies must bear the note S159 which reads, “U.S. Government short-distance low-power service.” The emission designators should be rendered as 6K00A2A, 6K00A2D and 6K00A3E.
  • 163.1000 MHz - Simplex or repeater output
  • 168.3500 MHz - Simplex or repeater input
  • 409.0500 MHz - Simplex or repeater output (paired with 418.05 MHz if used for repeater operation)
  • 409.3375 MHz - Simplex or repeater output (paired with 418.3375 MHz if used for repeater operation)
  • 412.8250 MHz - Simplex only
  • 412.8375 MHz - Simplex only
  • 412.8500 MHz - Simplex only
  • 412.8625 MHz - Simplex only
  • 418.0500 MHz - Simplex or repeater input (if used as input, output is 409.050 MHz)
  • 418.3375 MHz - Simplex or repeater input (if used as input, output is 409.3375 MHz)
  • 163.7125 MHz - Simplex only
  • 168.6125 MHz - Simplex only
  • 412.8750 MHz - Simplex only
  • 412.8875 MHz - Simplex only
  • 412.9000 MHz - Simplex only
  • 412.9125 MHz - Simplex only
  • 173.6250 MHz - Repeater output (input: 167.1375 MHz)
  • 407.5250 MHz - Repeater output (input: 416.5250 MHz)
  • 409.0750 MHz - Repeater output (input: 418.0750 MHz)
Full list:
  • 27.5750 MHz - Short Distance Low Power Service - Simplex
  • 27.5850 MHz - Short Distance Low Power Service - Simplex
  • 163.1000 MHz - Wide Area Common Use - Simplex or repeater output
  • 163.7125 MHz - Local Area Common Use - Simplex
  • 168.3500 MHz - Wide Area Common Use - Simplex or repeater input
  • 168.6125 MHz - Local Area Common Use - Simplex
  • 409.0500 MHz - Wide Area Common Use - Simplex or repeater output (paired with 418.05 MHz if used for repeater operation)
  • 409.3375 MHz - Wide Area Common Use - Simplex or repeater output (paired with 418.3375 MHz if used for repeater operation)
  • 412.8250 MHz - Wide Area Common Use - Simplex
  • 412.8375 MHz - Wide Area Common Use - Simplex
  • 412.8500 MHz - Wide Area Common Use - Simplex
  • 412.8625 MHz - Wide Area Common Use - Simplex
  • 412.8750 MHz - Local Area Common Use - Simplex
  • 412.8875 MHz - Local Area Common Use - Simplex
  • 412.9000 MHz - Local Area Common Use - Simplex
  • 412.9125 MHz - Local Area Common Use - Simplex
  • 418.0500 MHz - Wide Area Common Use - Simplex or repeater input (if used as input, output is 409.050 MHz)
  • 418.3375 MHz - Wide Area Common Use - Simplex or repeater input (if used as input, output is 409.3375 MHz)
Oil Spill Cleanup
