FRS
Revision as of 20:57, 26 November 2018 by R4002 (Talk | contribs)
Family Radio Service
UHF replacement (or rather supplement) to the CB service. License free two-way radio service regulated under Part 95 of the FCC rules - Personal Radio Services. FRS is widely used nationwide - 22 channels available, 15 of which are shared with the GMRS service. See also MURS. FRS is heavily used by private individuals, traveling groups for car-to-car communications, businesses, at construction sites and for various other purposes, including illegal activities and criminal enterprises.
The easy accessibility to low cost FRS equipment, simple-to-use radios and short range mean that drug dealers have been confirmed to use FRS to communicate with lookouts, etc. in several cities in the USA. In urban areas it is often possible to hear several different groups using several of the FRS frequencies at once with a respectable listening setup or even with a handheld VHF/UHF scanner located in a good spot high up for improved line of sight coverage. In urban areas, street-level handheld FRS range is often only around 1 mile. In rural areas or in high-up locations the range can increase significantly to dozens of miles.
Ch Freq MHz - Notes -
1 462.5625 Shared with GMRS - FRS Calling Channel 2 watts maximum TX power
2 462.5875 Shared with GMRS 2 watts maximum TX power
3 462.6125 Shared with GMRS 2 watts maximum TX power
4 462.6375 Shared with GMRS 2 watts maximum TX power
5 462.6625 Shared with GMRS 2 watts maximum TX power
6 462.6875 Shared with GMRS 2 watts maximum TX power
7 462.7125 Shared with GMRS 2 watts maximum TX power
8 467.5625 FRS only 0.5 watt 500mw maximum TX power
9 467.5875 FRS only 0.5 watt 500mw maximum TX power
10 467.6125 FRS only 0.5 watt 500mw maximum TX power
11 467.6375 FRS only 0.5 watt 500mw maximum TX power
12 467.6625 FRS only 0.5 watt 500mw maximum TX power
13 467.6875 FRS only 0.5 watt 500mw maximum TX power
14 467.7125 FRS only 0.5 watt 500mw maximum TX power
15 462.5500 Shared with GMRS 2 watts maximum TX power
16 462.5750 Shared with GMRS 2 watts maximum TX power
17 462.6000 Shared with GMRS 2 watts maximum TX power
18 462.6250 Shared with GMRS 2 watts maximum TX power
19 462.6500 Shared with GMRS 2 watts maximum TX power
20 462.6750 Shared with GMRS - GMRS Calling Channel 2 watts maximum TX power
21 462.7000 Shared with GMRS 2 watts maximum TX power
22 462.7250 Shared with GMRS 2 watts maximum TX power
