FRS
Revision as of 18:24, 29 March 2019 by R4002 (Talk | contribs)
Family Radio Service
UHF replacement (or rather supplement) to the CB service. Created in the late 1990s by the FCC after intense lobbying by RadioShack.
Ch Freq MHz - Notes -
1 462.5625 Shared with GMRS - FRS Calling Channel 2 watts maximum TX power
2 462.5875 Shared with GMRS 2 watts maximum TX power
3 462.6125 Shared with GMRS 2 watts maximum TX power
4 462.6375 Shared with GMRS 2 watts maximum TX power
5 462.6625 Shared with GMRS 2 watts maximum TX power
6 462.6875 Shared with GMRS 2 watts maximum TX power
7 462.7125 Shared with GMRS 2 watts maximum TX power
8 467.5625 FRS only 0.5 watt 500mw maximum TX power
9 467.5875 FRS only 0.5 watt 500mw maximum TX power
10 467.6125 FRS only 0.5 watt 500mw maximum TX power
11 467.6375 FRS only 0.5 watt 500mw maximum TX power
12 467.6625 FRS only 0.5 watt 500mw maximum TX power
13 467.6875 FRS only 0.5 watt 500mw maximum TX power
14 467.7125 FRS only 0.5 watt 500mw maximum TX power
15 462.5500 Shared with GMRS 2 watts maximum TX power
16 462.5750 Shared with GMRS 2 watts maximum TX power
17 462.6000 Shared with GMRS 2 watts maximum TX power
18 462.6250 Shared with GMRS 2 watts maximum TX power
19 462.6500 Shared with GMRS 2 watts maximum TX power
20 462.6750 Shared with GMRS - GMRS Calling Channel 2 watts maximum TX power
21 462.7000 Shared with GMRS 2 watts maximum TX power
22 462.7250 Shared with GMRS 2 watts maximum TX power
  • FRS channel 3 (462.6125 MHz) is the recommend "prepper" or emergency preparedness/response channel with MURS channel 3 and CB channel 3
  • FRS channel 1 (462.5625 MHz) is the recommended "calling" frequency, along it is often the busiest calling
  • FRS channel 20 (462.6750 MHz) is the recommended GMRS calling/travel channel, with CTCSS or PL tone 141.3 Hz
  • Crossband repeaters, patching FRS/GMRS with CB or MURS, is becoming more and more popular. Use of PL tones 156.7 Hz and 167.9 Hz is recommended. use of 67.0 Hz (the default tone for many radios) is not recommended. The GMRS "default" tone is 141.3 Hz.
