VHF marine
Revision as of 15:15, 12 May 2020 by R4002 (Talk | contribs)
Channel Frequency Purpose/Use (USA)
00 156.000 MHz Not allocated for marine use in the United States
01 156.050 MHz VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only
02 156.100 MHz Not allocated for marine use in the United States
03 156.150 MHz Not allocated for marine use in the United States
04 156.200 MHz Not allocated for marine use in the United States
05 156.250 MHz VTS/Port Ops/Commercial, Houston, Seattle, and New Orleans/Lower Mississippi River areas only
06 156.300 MHz Intership Safety
07 156.350 MHz Commercial
08 156.400 MHz Commercial (Intership only)
09 156.450 MHz Boater Calling (Commercial/Non-Commercial)
10 156.500 MHz Commercial
11 156.550 MHz Commercial, VTS in certain areas
12 156.600 MHz Port Ops, VTS in certain areas
13 156.650 MHz Bridge-to-bridge/Intership Navigation Safety
14 156.700 MHz Port Ops, VTS in certain areas
15 156.750 MHz Environmental (Receive Only), US Government Use, Class C EPIRBs
16 156.800 MHz International Distress, Safety and Calling. USCG, coast stations, and ships maintain watch on this channel
17 156.850 MHz State and/or Local Government Maritime Control
18 156.900 MHz Commercial
19 156.950 MHz Commercial
20 157.000 MHz Port Ops
21 157.050 MHz US Coast Guard Only
22 157.100 MHz US Coast Guard Liaison and Safety Information Broadcasts
23 157.150 MHz US Coast Guard Only
24 157.200 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
25 157.250 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
26 157.300 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
27 157.350 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
28 157.400 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
29 157.450 MHz Not allocated for marine use in the United States
60 156.025 MHz Not allocated for marine use in the United States
61 156.075 MHz Not allocated for marine use in the United States
62 156.125 MHz Not allocated for marine use in the United States
63 156.175 MHz VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only
64 156.225 MHz Not allocated for marine use in the United States
65 156.275 MHz Port Ops
66 156.325 MHz Port Ops
67 156.375 MHz Commercial (Intership Only)
68 156.425 MHz Non-Commercial, Recreational Boaters
69 156.475 MHz Non-Commercial, Recreational Boaters
70 156.525 MHz DSC (No voice transmissions permitted)
71 156.575 MHz Non-Commercial, Recreational Boaters
72 156.625 MHz Non-Commercial (Intership Only), Recreational Boaters
73 156.675 MHz Port Ops
74 156.725 MHz Port Ops
75 156.775 MHz Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA
76 156.825 MHz Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA
77 156.875 MHz Port Ops (Intership Only)
78 156.925 MHz Non-Commercial, Recreational Boaters
79 156.975 MHz Commercial. Non-Commercial in Great Lakes only.
80 157.025 MHz Commercial. Non-Commercial in Great Lakes only.
81 157.075 MHz US Coast Guard/US Government Only/Environmental Protection
82 157.125 MHz US Coast Guard Only
83 157.175 MHz US Coast Guard Only
84 157.225 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
85 157.275 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
86 157.325 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
87 157.375 MHz VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted
88 157.425 MHz Commercial/Non-Commercial (Intership Only), Recreational Boaters
AIS 1 87B 161.975 MHz Automatic Identification System (AIS Channel 1/Channel 87B)
AIS 2 88B 162.025 MHz Automatic Identification System (AIS Channel 2/Channel 88B)
AIS 3 75 / 75A / 1075 156.775 MHz Automatic Identification System (AIS Channel 3/Channel 75)
AIS 4 76 / 76A / 1076 156.825 MHz Automatic Identification System (AIS Channel 4/Channel 76)
WX 1 162.550 MHz NOAA Weather Radio (Receive Only)
WX 2 162.400 MHz NOAA Weather Radio (Receive Only)
WX 3 162.475 MHz NOAA Weather Radio (Receive Only)
WX 4 162.425 MHz NOAA Weather Radio (Receive Only)
WX 5 162.450 MHz NOAA Weather Radio (Receive Only)
WX 6 162.500 MHz NOAA Weather Radio (Receive Only)
WX 7 162.525 MHz NOAA Weather Radio (Receive Only)
WX 8 162.525 MHz NOAA Weather Radio (Receive Only)
WX 9 162.525 MHz NOAA Weather Radio (Receive Only)
WX 710 162.525 MHz NOAA Weather Radio (Receive Only)
The WX channels may be in order from lowest frequency to highest frequency, the original 3 NOAA Weather Radio frequencies (162.55 MHz, 162.4 MHz and 162.475 MHz) were supplanted by the 4 additional frequencies later on. Weather channels 8, 9 and 10 are only used in Canada.
00 156.000 MHz Private Ship to Ship/Ship to Shore Simplex
29 157.450 MHz Private Ship to Ship/Ship to Shore Simplex
30 157.500 MHz Private Ship to Ship/Ship to Shore Simplex
31 157.550 MHz Private Ship to Ship/Ship to Shore Simplex
32 157.600 MHz Private Ship to Ship/Ship to Shore Simplex
33 157.650 MHz Private Ship to Ship/Ship to Shore Simplex
34 157.700 MHz Private Ship to Ship/Ship to Shore Simplex
35 157.750 MHz Private Ship to Ship/Ship to Shore Simplex
36 157.800 MHz Private Ship to Ship/Ship to Shore Simplex
37 157.850 MHz Private Ship to Ship/Ship to Shore Simplex
38A 157.900 MHz Private Ship to Ship/Ship to Shore Simplex
38B 162.500 MHz Private Ship to Ship/Ship to Shore Simplex
39 157.950 MHz Private Ship to Ship/Ship to Shore Simplex
40 158.000 MHz Private Ship to Ship/Ship to Shore Simplex
41 158.050 MHz Private Ship to Ship/Ship to Shore Simplex
42 158.100 MHz Private Ship to Ship/Ship to Shore Simplex
43 158.150 MHz Private Ship to Ship/Ship to Shore Simplex
44 158.200 MHz Private Ship to Ship/Ship to Shore Simplex
45 158.250 MHz Private Ship to Ship/Ship to Shore Simplex
46 158.300 MHz Private Ship to Ship/Ship to Shore Simplex
47 158.350 MHz Private Ship to Ship/Ship to Shore Simplex
48 158.400 MHz Private Ship to Ship/Ship to Shore Simplex
49 158.450 MHz Private Ship to Ship/Ship to Shore Simplex
M1 (UK) or M 157.850 MHz Private Marina Channel (private marinas, yacht clubs, etc), UK only - channel 37
M2 (UK) 161.425 MHz Private Marina Channel (private marinas, yacht clubs, etc), UK only
M3 (UK) 161.225 MHz Private Marina Channel (private marinas, yacht clubs, etc), UK only
P1 (UK) 161.350 MHz On board ship comms only (low power)
P2 (UK) 161.450 MHz On board ship comms only (low power)
P1 (Nordic) 155.500 MHz Private Marina/Yacht club channel, Nordic countries only
P2 (Nordic) 155.525 MHz Private Marina/Yacht club channel, Nordic countries only
P3 (Nordic) 155.650 MHz Private Marina/Yacht club channel, Nordic countries only
P4 (Nordic) 155.625 MHz Private Fishing Trawler channel, Nordic countries only
P5 (Nordic) 155.775 MHz Private Fishing Trawler channel, Nordic countries only
P6 (Nordic) 155.825 MHz Private Fishing Trawler channel, Nordic countries only
P1 (Denmark) 155.375 MHz Private Channel, Denmark only
P2 (Denmark) 155.575 MHz Private Channel, Denmark only
P3 (Denmark) 155.450 MHz Private Channel, Denmark only
P4 (Denmark) 155.800 MHz Private Channel, Denmark only
10 MHz offset (international plan) 10.225 MHz offset (US and Canada channel plan). Input frequencies may be used for simplex purposes as well. International channel plan frequencies interfere with US-allocated GMRS and FRS frequencies. Frequencies are shared with UHF business band in the United States. Elsewhere, other UHF on-board radio systems may be used, including PMR446 or other dedicated systems generally in the 400-512 MHz or 380-520 MHz UHF range.
Channel Frequency (repeater output or simplex) Frequency (repeater input or simplex)
1 (International) 457.5250 MHz 467.5250 MHz
2 (International) 457.5375 MHz 467.5375 MHz
3 (International) 457.5500 MHz 467.5500 MHz
4 (International) 457.5625 MHz 467.5625 MHz
5 (International) 457.5750 MHz 467.5750 MHz
1 (USA, Canada) 457.5250 MHz 467.7500 MHz
2 (USA, Canada) 457.5375 MHz 467.7625 MHz
3 (USA, Canada) 457.5500 MHz 467.7750 MHz
4 (USA, Canada) 457.5625 MHz 467.7875 MHz
5 (USA, Canada) 457.5750 MHz 467.8000 MHz
6 (USA, Canada) 457.5875 MHz 467.8125 MHz
7 (USA, Canada) 457.6000 MHz 467.8250 MHz
8 (USA, Canada) 457.6125 MHz 467.8375 MHz
VHF marine band equipment
Modern ICOM IC-M605 VHF marine band radio with built-in GPS and DSC capability. 156 MHz - 163 MHz simplex and duplex. This radio is tuned to the international distress and calling channel 16 frequency of 156.800 MHz
Older-generation Uniden MC635 VHF marine band radio without DSC capability 156-163 MHz simplex and duplex VHF-FM transceiver. This radio is tuned to the international distress and calling channel 16 frequency of 156.8 MHz.
