VHF marine
| Channel | Frequency | Purpose/Use (USA) |
| 00 | 156.000 MHz | Not allocated for marine use in the United States |
| 01 | 156.050 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only |
| 02 | 156.100 MHz | Not allocated for marine use in the United States |
| 03 | 156.150 MHz | Not allocated for marine use in the United States |
| 04 | 156.200 MHz | Not allocated for marine use in the United States |
| 05 | 156.250 MHz | VTS/Port Ops/Commercial, Houston, Seattle, and New Orleans/Lower Mississippi River areas only |
| 06 | 156.300 MHz | Intership Safety |
| 07 | 156.350 MHz | Commercial |
| 08 | 156.400 MHz | Commercial (Intership only) |
| 09 | 156.450 MHz | Boater Calling (Commercial/Non-Commercial) |
| 10 | 156.500 MHz | Commercial |
| 11 | 156.550 MHz | Commercial, VTS in certain areas |
| 12 | 156.600 MHz | Port Ops, VTS in certain areas |
| 13 | 156.650 MHz | Bridge-to-bridge/Intership Navigation Safety |
| 14 | 156.700 MHz | Port Ops, VTS in certain areas |
| 15 | 156.750 MHz | Environmental (Receive Only), US Government Use, Class C EPIRBs |
| 16 | 156.800 MHz | International Distress, Safety and Calling. USCG, coast stations, and ships maintain watch on this channel |
| 17 | 156.850 MHz | State and/or Local Government Maritime Control |
| 18 | 156.900 MHz | Commercial |
| 19 | 156.950 MHz | Commercial |
| 20 | 157.000 MHz | Port Ops |
| 21 | 157.050 MHz | US Coast Guard Only |
| 22 | 157.100 MHz | US Coast Guard Liaison and Safety Information Broadcasts |
| 23 | 157.150 MHz | US Coast Guard Only |
| 24 | 157.200 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 25 | 157.250 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 26 | 157.300 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 27 | 157.350 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 28 | 157.400 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 29 | 157.450 MHz | Not allocated for marine use in the United States |
| 60 | 156.025 MHz | Not allocated for marine use in the United States |
| 61 | 156.075 MHz | Not allocated for marine use in the United States |
| 62 | 156.125 MHz | Not allocated for marine use in the United States |
| 63 | 156.175 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only |
| 64 | 156.225 MHz | Not allocated for marine use in the United States |
| 65 | 156.275 MHz | Port Ops |
| 66 | 156.325 MHz | Port Ops |
| 67 | 156.375 MHz | Commercial (Intership Only) |
| 68 | 156.425 MHz | Non-Commercial, Recreational Boaters |
| 69 | 156.475 MHz | Non-Commercial, Recreational Boaters |
| 70 | 156.525 MHz | DSC (No voice transmissions permitted) |
| 71 | 156.575 MHz | Non-Commercial, Recreational Boaters |
| 72 | 156.625 MHz | Non-Commercial (Intership Only), Recreational Boaters |
| 73 | 156.675 MHz | Port Ops |
| 74 | 156.725 MHz | Port Ops |
| 75 | 156.775 MHz | Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA |
| 76 | 156.825 MHz | Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA |
| 77 | 156.875 MHz | Port Ops (Intership Only) |
| 78 | 156.925 MHz | Non-Commercial, Recreational Boaters |
| 79 | 156.975 MHz | Commercial. Non-Commercial in Great Lakes only. |
| 80 | 157.025 MHz | Commercial. Non-Commercial in Great Lakes only. |
| 81 | 157.075 MHz | US Coast Guard/US Government Only/Environmental Protection |
| 82 | 157.125 MHz | US Coast Guard Only |
| 83 | 157.175 MHz | US Coast Guard Only |
| 84 | 157.225 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 85 | 157.275 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 86 | 157.325 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 87 | 157.375 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 88 | 157.425 MHz | Commercial/Non-Commercial (Intership Only), Recreational Boaters |
| AIS 1 87B | 161.975 MHz | Automatic Identification System (AIS Channel 1/Channel 87B) |
| AIS 2 88B | 162.025 MHz | Automatic Identification System (AIS Channel 2/Channel 88B) |
| AIS 3 75 / 75A / 1075 | 156.775 MHz | Automatic Identification System (AIS Channel 3/Channel 75) |
| AIS 4 76 / 76A / 1076 | 156.825 MHz | Automatic Identification System (AIS Channel 4/Channel 76) |
| WX 1 | 162.550 MHz | NOAA Weather Radio (Receive Only) |
| WX 2 | 162.400 MHz | NOAA Weather Radio (Receive Only) |
| WX 3 | 162.475 MHz | NOAA Weather Radio (Receive Only) |
| WX 4 | 162.425 MHz | NOAA Weather Radio (Receive Only) |
| WX 5 | 162.450 MHz | NOAA Weather Radio (Receive Only) |
| WX 6 | 162.500 MHz | NOAA Weather Radio (Receive Only) |
| WX 7 | 162.525 MHz | NOAA Weather Radio (Receive Only) |
| WX 8 | 161.650 MHz | Weather Radio Canada - VHF Channel 21B |
| WX 9 | 161.775 MHz | Weather Radio Canada - VHF Channel 83B |
| WX 10 | 163.275 MHz | Weather Radio Canada (Receive Only) |
The WX channels may be in order from lowest frequency to highest frequency, the original 3 NOAA Weather Radio frequencies (162.55 MHz, 162.4 MHz and 162.475 MHz) were supplanted by the 4 additional frequencies later on. Weather channels 8, 9 and 10 are only used in Canada.
| Channel | Frequency | Purpose/Use |
| 00 | 156.000 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 29 | 157.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 30 | 157.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 31 | 157.550 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 32 | 157.600 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 33 | 157.650 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 34 | 157.700 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 35 | 157.750 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 36 | 157.800 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 37 | 157.850 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 38A | 157.900 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 38B | 162.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 39 | 157.950 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 40 | 158.000 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 41 | 158.050 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 42 | 158.100 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 43 | 158.150 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 44 | 158.200 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 45 | 158.250 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 46 | 158.300 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 47 | 158.350 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 48 | 158.400 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 49 | 158.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
| M1 (UK) or M | 157.850 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only - channel 37 |
| M2 (UK) | 161.425 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
| M3 (UK) | 161.225 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
| P1 (UK) | 161.350 MHz | On board ship comms only (low power) |
| P2 (UK) | 161.450 MHz | On board ship comms only (low power) |
| P1 (Nordic) | 155.500 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P2 (Nordic) | 155.525 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P3 (Nordic) | 155.650 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P4 (Nordic) | 155.625 MHz | Private Fishing Trawler channel, Nordic countries only |
| P5 (Nordic) | 155.775 MHz | Private Fishing Trawler channel, Nordic countries only |
| P6 (Nordic) | 155.825 MHz | Private Fishing Trawler channel, Nordic countries only |
| P1 (Denmark) | 155.375 MHz | Private Channel, Denmark only |
| P2 (Denmark) | 155.575 MHz | Private Channel, Denmark only |
| P3 (Denmark) | 155.450 MHz | Private Channel, Denmark only |
| P4 (Denmark) | 155.800 MHz | Private Channel, Denmark only |
10 MHz offset (international plan) 10.225 MHz offset (US and Canada channel plan). Input frequencies may be used for simplex purposes as well. International channel plan frequencies interfere with US-allocated GMRS and FRS frequencies. Frequencies are shared with UHF business band in the United States. Elsewhere, other UHF on-board radio systems may be used, including PMR446 or other dedicated systems generally in the 400-512 MHz or 380-520 MHz UHF range.
| Channel | Frequency (repeater output or simplex) | Frequency (repeater input or simplex) |
| 1 (International) | 457.5250 MHz | 467.5250 MHz |
| 2 (International) | 457.5375 MHz | 467.5375 MHz |
| 3 (International) | 457.5500 MHz | 467.5500 MHz |
| 4 (International) | 457.5625 MHz | 467.5625 MHz |
| 5 (International) | 457.5750 MHz | 467.5750 MHz |
| 1 (USA, Canada) | 457.5250 MHz | 467.7500 MHz |
| 2 (USA, Canada) | 457.5375 MHz | 467.7625 MHz |
| 3 (USA, Canada) | 457.5500 MHz | 467.7750 MHz |
| 4 (USA, Canada) | 457.5625 MHz | 467.7875 MHz |
| 5 (USA, Canada) | 457.5750 MHz | 467.8000 MHz |
| 6 (USA, Canada) | 457.5875 MHz | 467.8125 MHz |
| 7 (USA, Canada) | 457.6000 MHz | 467.8250 MHz |
| 8 (USA, Canada) | 457.6125 MHz | 467.8375 MHz |
VHF marine band equipment
