Letter beacon
- "Letter beacons"
- Cluster beacons
History
Location of letter beacons
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| ID letter | Callsign | Location |
| A | Astrakhan, RUS (tentative) | |
| C | RIW | Moscow, RUS |
| D | RCV | Sevastopol, UKR |
| F | RJS | Vladivostok, RUS |
| K | RCC | Petropavlovsk-Kamchatsky, RUS |
| L | Unknown, appeared on July 1, 2011 | |
| M | RTS | Magadan, RUS |
| P | RMP | Kaliningrad, RUS |
| S | RIT | Severomorsk, RUS |
| L | Tirana, ALB (defunct) |
| V | Khiva, UZB or Almaty, KAZ (25) |
Types of letter beacons
Cluster beacons
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", "A", "M" and "K") have been regularly reported in small spectrum segments centered around 3594 kHz, 4558 kHz, 5154 kHz, 7509 kHz, 8495 kHz, 10872 kHz, 13528 kHz, 16332 kHz and 20048 kHz. The term "cluster beacons" is frequently used for them, as these beacons transmit in parallel on frequencies only 0.1 kHz apart. These beacons transmit only their single-letter identifier in standard CW (A1A) using morse code. The cluster centered on 7509.0 kHz in the past transmitted on 7039.0 kHz, within the 40m international amateur radio allocation.
| ID letter | Regular callsign | Channel | Frequencies (kHz) |
| L (21) | -0.8 | 5156.8, 7038.2, 7041.8(23), 8494.2, 8497.8 | |
| D | RCV | -0.3 | 3593.7, 4557.7, 5153.7, 7508.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
| P | RMP | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 10872.8 (21), 13527.8, 16331.8, 20047.8 |
| S | RIT | -0.1 | 3593.9, 4557.9, 5153.9, 7508.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
| C | RIW | 0.0 | 3594.0, 4558.0, 5154.0, 7509.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
| A | +0.1 | 3594.1, 4558.1, 5154.1, 7509.1, 8495.1, 10872.1 13528.1 16332.1 (10) | |
| F | RJS | +0.2 | 5156.8, 7039.2, 8495.2, 10872.2, 13528.2, 16332.2 |
| K | RCC | +0.3 | 4558.3, 5154.3, 7039.3, 8495.3, 10872.3, 16332.3 |
| M | RTS | +0.4 | 5154.4, 7039.4, 8495.4, 10872.4, 13528.4, 16332.4 |
| R (20) | 4325.9, 5465.9 | |
| V | 3227.0, 3657.0, 4031.0, 4205.0, 4338.0, 4977.0, 5094.0, 5466.0, 5590.0 | |
| V (historic) | 3335.0, 4028.0, 4108.0(18), 4150.0, 5141.0, 5342, 6430.7, 6498.0, 6809, 7027.5, 8103.5, 10202 | |
| C | RIW | 8000 |
| U | 7830.5(27) | |
| L | 5156.8, 6917.4, 8497.8 | |
| W | 8162.0, 8895.0 |
FSK beacons
| K | 4005, 7906, 8144, 8158, 9043, 10571, 11555, 12150, 14477, 14967, 18348 | |
| U | 7569, 9057, 10216, 12185, 12238, 15655 |
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
Purpose of letter beacons
Similar systems
- Spy Numbers Stations
- High Frequency Beacon
- ENIGMA
- Radio propagation beacon
- Fishing Net/Driftnet Beacons
Notes & References
- Spooks mailing list.
- Alan Gale, G4TMV: "An introduction to beacon DXing", Version 1.0, December 2012, pp. 36-38.
