Amateur radio
Amateur Radio Bands MF/HF
- 902-902 MHz - 33cm band or 900 MHz band (shared with Part 15 services, cordless phones, long-haul WiFi, mesh networks - LoRa, Meshtastic and telemetry links, long range drone remote control systems and backhaul video/data links, along with many other services in the USA, not available in many areas). Shared with ISM services and many other systems, center frequency 915 MHz.
US band plan. ITU Region 2.
- 146.415 MHz
- 146.430 MHz
- 146.445 MHz
- 146.460 MHz
- 146.475 MHz
- 146.490 MHz
- 146.505 MHz
- 146.520 MHz
- 146.535 MHz
- 146.550 MHz
- 146.565 MHz
- 146.580 MHz
- 146.595 MHz
- 147.405 MHz
- 147.420 MHz
- 147.435 MHz
- 147.450 MHz
- 147.465 MHz
- 147.480 MHz
- 147.495 MHz
- 147.510 MHz
- 147.525 MHz
- 147.540 MHz
- 147.555 MHz
- 147.570 MHz
- 147.585 MHz
- 70cm band
- 445.9125 MHz
- 445.9250 MHz
- 445.9375 MHz
- 445.9500 MHz
- 445.9625 MHz
- 445.9750 MHz
- 445.9875 MHz
- 446.0000 MHz
- 446.0125 MHz
- 446.0250 MHz
- 446.0375 MHz
- 446.0500 MHz
- 446.0625 MHz
- 446.0750 MHz
- 446.0875 MHz
- 446.1000 MHz
- 446.1125 MHz
- 446.1250 MHz
- 446.1375 MHz
- 446.1500 MHz
- 446.1625 MHz
- 446.1750 MHz
- 446.5000 MHz
- 446.5125 MHz
- 446.5375 MHz
- 446.5625 MHz
- 446.5875 MHz
- 446.6125 MHz
- 446.6375 MHz
- 446.6625 MHz
- 446.6875 MHz
- 446.7125 MHz
- 446.7375 MHz
- 446.7625 MHz
- 446.7875 MHz
- 440.9125 MHz
- 440.9250 MHz
- 440.9375 MHz
- 440.9500 MHz
- 440.9625 MHz
- 440.9750 MHz
- 440.9875 MHz
- 441.0000 MHz
- 441.0125 MHz
- 441.0250 MHz
- 441.0375 MHz
- 441.0500 MHz
- 441.0625 MHz
- 441.0750 MHz
- 441.0875 MHz
- 441.1000 MHz
- 441.1125 MHz
- 441.1250 MHz
- 441.1375 MHz
- 441.1500 MHz
- 441.1625 MHz
- 441.1750 MHz
- 441.5000 MHz
- 441.5125 MHz
- 441.5375 MHz
- 441.5625 MHz
- 441.5875 MHz
- 441.6125 MHz
- 441.6375 MHz
- 441.6625 MHz
- 441.6875 MHz
- 441.7125 MHz
- 441.7375 MHz
- 441.7625 MHz
- 441.7875 MHz
