PMR446
Revision as of 11:38, 30 June 2025 by R4002 (Talk | contribs)
Background Information
Private Mobile Radio 446 MHz, Portable Mobile Radio 446MHz 446MHz Professional Mobile Radio 446.0 MHz - 446.1 MHz (original allocation), 446.0 MHz - 446.2 MHz (current allocation). 0.5 watt 500 milliwatts TX power limit. PMR446 is the European version of the Family Radio Service (FRS) 22 channel license-free service available in the U.S. PMR446 is limited to 0.5 watt power on all 16 channels compared to the 2 watt power limit on FRS channels 1-7 and 15-22. Like FRS, PMR446 is simplex only. There is no variant where higher power and/or repeater operation is available with simple licensing like GMRS in the USA or the UHF CB service in Australia and New Zealand.
See also: the LPD433 very short range service on 433 MHz and 434 MHz (ITU Region 1 only). ETSI 303 405
PMR446 Frequencies PMR446 Frequency List
It is illegal and also stupid to use PMR446 in the U.S., it overlaps with the 70cm amateur band, the PMR446 channel 1 overlaps with the 70cm calling frequency, meaning it is much more likely that a ham operator will notice you. Digital TDMA voice (DMR) also allowed on these 16 channels - referred to as DMR Tier 1 or DPMR Tier 1 - wide band digital, 12.5 kHz bandwidth. 16 channels. Analog narrow band FM voice shared on the same 16 frequencies. Emissions 11K3F3E or more narrow used for analog FM. In dense urbanized areas of Europe, it is quite common to hear numerous signals on most or all of the PMR446 channels. Analog NFM uses CTCSS (PL) and DCS (DPL) selective calling extensively. DMR uses Color Code (CC) (CC1 to CC16) for selective calling, plus Talkgroup (TG).
Yes, you can program your Baofeng UV-5R or UV-82 or Baofeng AR-152 to operate on these exact frequencies. The Baofeng radios support 6.25 kHz offset frequencies. Manually entering "4-4-6-0-0-6" in VFO mode will automatically tune the radio to 446.00625MHz. It will display 446.00625 with the last 2 digits considerably smaller on the LCD display. Must be programmed in NFM / FMN mode (Baofeng Menu setting #5 "WN" set to NARR for NARROW).
PMR446 frequency list
PMR446 Channel Freq MHz Mode
1 446.00625 MHz NFM or DMR
2 446.01875 MHz NFM or DMR
3 446.03125 MHz NFM or DMR
4 446.04375 MHz NFM or DMR
5 446.05625 MHz NFM or DMR
6 446.06875 MHz NFM or DMR
7 446.08125 MHz NFM or DMR
8 446.09375 MHz NFM or DMR
9 446.10625 MHz NFM or DMR
10 446.11875 MHz NFM or DMR
11 446.13125 MHz NFM or DMR
12 446.14375 MHz NFM or DMR
13 446.15625 MHz NFM or DMR
14 446.16875 MHz NFM or DMR
15 446.18125 MHz NFM or DMR
16 446.19375 MHz NFM or DMR
Digital FDMA dPMR446
Channel Freq MHz
1 446.003125 MHz
2 446.009375 MHz
3 446.015625 MHz
4 446.021875 MHz
5 446.028125 MHz
6 446.034375 MHz
7 446.040625 MHz
8 446.046875 MHz
9 446.053125 MHz
10 446.059375 MHz
11 446.065625 MHz
12 446.071875 MHz
13 446.078125 MHz
14 446.084375 MHz
15 446.090625 MHz
16 446.096875 MHz
17 446.103125 MHz
18 446.109375 MHz
19 446.115625 MHz
20 446.121875 MHz
21 446.128125 MHz
22 446.134375 MHz
23 446.140625 MHz
24 446.146875 MHz
25 446.153125 MHz
26 446.159375 MHz
27 446.165625 MHz
28 446.171875 MHz
29 446.178125 MHz
30 446.184375 MHz
31 446.190625 MHz
32 446.196875 MHz
Technical Information and Additional Discussion
  • PMR446 Channel 1 - 446.00625 MHz - Emergency Calling Channel 1/0 (CSQ - carrier squelch, no tone)
  • PMR446 Channel 1 - 446.00625 MHz - Prepper Survivalist Emergency Analog Family Channel 1/1 (67.0 Hz CTCSS, code 1)
  • PMR446 Channel 1 - 446.00625 MHz - Emergency Calling Channel 1/12 (100.0 Hz CTCSS, code 12)
  • PMR446 Channel 1 - 446.00625 MHz - Truckers and Car-to-Car Channel 1/9 (91.5 Hz CTCSS, code 9)
  • PMR446 Channel 2 - 446.01875 MHz - Campers, Campsites, etc. Channel 2/0 (CSQ - carrier squelch, no tone)
  • PMR446 Channel 2 - 446.01875 MHz - Geocaching Channel 2/0 (CSQ - carrier squelch, no tone)
  • PMR446 Channel 2 - 446.01875 MHz - Mountain Channel (German-speaking countries) Channel 2/0 (CSQ - carrier squelch, no tone)
  • PMR446 Channel 3 - 446.03125 MHz - Prepper Survivalist Emergency Analog Channel 3/0 (CSQ - carrier squelch, no tone)
  • PMR446 Channel 3 - 446.03125 MHz - Prepper Survivalist Emergency Analog Survivalist Channel 3/1 (67.0 Hz CTCSS, code 1)
  • PMR446 Channel 3 - 446.03125 MHz - Prepper Survivalist Emergency Analog Channel 3/8 (88.5 Hz CTCSS, code 8)
  • PMR446 Channel 3 - 446.03125 MHz - Mountain Channel (Poland) Channel 3/14 (107.2 Hz CTCSS, code 14)
  • PMR446 Channel 4 - 446.04375 MHz - 4WD / 4X4 Off road Channel 4/4 (77.0 Hz CTCSS, code 4)
  • PMR446 Channel 4 - 446.04375 MHz - Drone/Pilot Communications Intercom Channel 4/14 (107.2 Hz CTCSS code 14)
  • PMR446 Channel 4 - 446.04375 MHz - Boat to Boat Channel 4/16 (114.8 Hz CTCSS code 16)
  • PMR446 Channel 5 - 446.05625 MHz - Scouts Channel 5/5 (79.7 Hz CTCSS, code 5)
  • PMR446 Channel 6 - 446.06875 MHz - Hunters Channel 6/12 (100.0 Hz CTCSS, code 10)
  • PMR446 Channel 6 - 446.06875 MHz - Free Radio Network Channel 6/20 (131.8 Hz CTCSS, code 20)
  • PMR446 Channel 7 - 446.08125 MHz - Prepper/Emergency Disaster Preparedness Channel - fallback
  • PMR446 Channel 7 - 446.08125 MHz - Mountain Channel Mountaineering Alpine Channel 7/7 (85.4 Hz CTCSS, code 7)
  • PMR446 Channel 8 - 446.09375 MHz - DX Calling Channel 8/0 (CSQ - carrier squelch, no tone)
  • PMR446 Channel 8 - 446.09375 MHz - Prepper Survivalist Emergency Analog Calling Channel 8/1 (67.0 Hz CTCSS, code 1)
  • PMR446 Channel 8 - 446.09375 MHz - DX Calling Channel 8/8 (88.5 Hz CTCSS, code 8)
  • PMR446 Channel 8 - 446.09375 MHz - Mountain Channel Italy Channel 8/16 (114.8 Hz CTCSS, code 16)
  • PMR446 Channel 9 - 446.10625 MHz
  • PMR446 Channel 10 - 446.11875 MHz
  • PMR446 Channel 11 - 446.13125 MHz
  • PMR446 Channel 12 - 446.14375 MHz
  • PMR446 Channel 13 - 446.15625 MHz
  • PMR446 Channel 14 - 446.16875 MHz
  • PMR446 Channel 15 - 446.18125 MHz
  • PMR446 Channel 16 - 446.19375 MHz
  • Channel 8 - 446.09375 MHz - TDMA digital 12.5 kHz - DMR Calling / DX Channel - digital DX frequency
  • Channel 9 - 446.10625 MHz - TDMA digital 12.5 kHz - DMR Calling Channel Color Code 1 Talkgroup 99 CC1 TG99
  • Channel 9 - 446.10625 MHz - TDMA digital 12.5 kHz - DMR Distress Channel Emergency Channel Color Code 1 Talkgroup 9112 CC1 TG9112
Authorized PMR446 Countries
  • Is PMR446 digital? - Yes, and no. (It depends). PMR446 radios with digital capability are legal, see the sections above about the 16 analog and digital shared channels and 32 digital only channels.
  • Is PMR446 analog? - Yes. The PMR446 standard includes 16 analog FM (narrow band FM) channels. All PMR446 radios are backward compatible in analog mode.
  • How many channels does PMR446 have? - Originally, the PMR446 service had 8 analog FM or NFM channels (channels 1 through 8). Channels 9-16 were added later on and the 16 channel band plan is now the standard.
  • Are all PMR446 radios compatible? Yes. As long as the radios are set to the same channel (frequency) and the same CTCSS (PL) tone or DCS (DPL) code, they will work with each other. Digital PMR446 radios are also compatible per the requirements of the PMR446 DPMR446 dPMR446 standards.
  • Is PMR446 legal in the USA? - No, it is not. PMR446 radios are not legal for use in the United States (and many other countries). Operating PMR446 equipment and/or operating equipment on the PMR446 frequencies in the United States is a violation of FCC regulations (US Federal law). The PMR446 service operates on frequencies that are allocated to the amateur radio (ham radio) service in the United States, specifically the 70cm ham radio band (420-450 MHz).
  • Analog and digital voice modes must be limited to 180 seconds of transmit time.
  • Analog 12.5 kHz channels
  • Maximum FM deviation: 2.5 kHz
  • Bandwidth limit - analog: 8.25 kHz 8K25F3E
  • Receiver adjacent channel rejection:
  • 60dB or more when using 12.5 kHz channel spaced analog / digital channels
  • 50 dB or better when operating on the 6.25 kHz spaced digital voice channels
EXPLANATORY MEMORANDUM 1 INTRODUCTION The free circulation of radio communication products and the provision of equipment in Europe for radio communications are only achievable if there are common regulations throughout Europe regarding the availability of frequency bands, harmonised technical conditions and border crossing procedures. The main requirements for fulfilling these objectives for analogue and digital PMR 446 radio equipment are the Europe- wide availability of a suitable frequency band, harmonised technical conditions and the implementation of national regulations based on the Harmonised European Standards EN 300 296-2, EN 300 113-2, and EN 301 166-2. PMR 446 is intended to operate on collective frequencies shared by many users on an uncoordinated basis. The equipment is hand portable (no base station or repeater use) and uses integral antennas only in order to maximise sharing and minimise interference. PMR 446 equipment operates in short range peer-to-peer mode and cannot be used neither as a part of infrastructure network nor as a repeater. The transition to digital technology in all sectors of radio communications is required in order to meet the user expectations whilst improving spectrum efficiency. PMR 446 applications typically have a simplified functionality with a set of channels and a specification that allows usage to be exempted from individual licensing. Industry research has indicated that the provision of digital equipment including a small number of key features would increase the value that the users can derive from the equipment, and a significant increase in demand could therefore be expected. Some of these key features are: 1. Improved audio quality; 2. Improved battery performance; 3. Improved quality of service extending out to the range limit (rather than greater absolute range); 4. Data communication, typically short message. Finally, it is important that the corresponding frequencies are harmonised throughout Europe for both analogue and digital PMR 446 applications. In addition, Class 1 equipment status is highly recommended in order to place PMR 446 equipment on the market and to be put into service without restrictions. In this context, this ECC Decision provides the necessary mechanism for CEPT administrations to continue their commitment to the frequency band 446.000-446.200 MHz for both analogue and digital PMR 446 radio equipment. A key driver in this proposed change is to improve spectral efficiency so that all the permitted equipment should be 6.25 kHz (or equivalent) per voice channel. This ECC Decision repeals the earlier ERC/DEC/(98)25 and ECC/DEC/(05)12. It gives clear advice to industry, retailers and users throughout Europe, that these changes should take place in Europe within a common timeframe.
2 BACKGROUND The frequency band 446.0-446.1 MHz has been designated for analogue PMR 446 by ERC/DEC/(98)25 of 23 November 1998 and was amended 1 June 2012 to include some additional features in order to reduce the risk of harmful interference. The frequency band 446.1-446.2 MHz has been designated for digital PMR 446 by ECC/DEC/(05)12 of 28 October 2005. The PMR 446 radio application is intended for radio communications with transmission and reception taking place on the same channel (single frequency, simplex traffic). PMR 446 radio equipment is exempted from individual licensing and anyone can use the radio equipment without any prior individual permission from the administration. The designation of a harmonised band has formed the basis for the free circulation and use of PMR 446 within Europe and has also facilitated the mutual recognition of conformity assessment. ETSI has already developed the harmonised European standards EN 300 113-2 and EN 300 296-2 (12.5 kHz bandwidth) and EN 301 166-2 (6.25 kHz bandwidth) for radio conformance purposes. 3 REQUIREMENT FOR AN ECC DECISION The allocation or designation of frequency bands for use by a service or system under specified conditions in CEPT administrations is laid down by law, regulation or administrative action. ECC Decisions are required to deal with the radio spectrum related matters and for free circulation and use of equipment throughout Europe. The free circulation and use of radio equipment and the provision of Pan European services will be greatly assisted when all CEPT administrations exempt the same categories of radio equipment from licensing and apply -to achieve that- the same criteria. The harmonisation on a European basis supports the Directive 1999/5/EC of the European Parliament and of the Council of 9 March 1999 on radio equipment and telecommunications terminal equipment and the mutual recognition of their conformity. A commitment by CEPT administrations to implement this ECC Decision will provide a clear indication that the required frequency bands are available on a European-wide basis, for both analogue and digital PMR 446 equipment. ERC/REC 01-07, revised in 2004, listed harmonised criteria for the administrations to decide whether an exemption from individual license should be applied. The aim of this Decision is also to exempt PMR 446 equipment from individual licensing as it fulfils the criteria for exemption listed in ERC/REC 01-07 and to allow the carriage and use of the equipment within CEPT countries. ECC/DEC/(15)05
ECC/DEC/(15)05 ECC DECISION OF 3 JULY 2015 ON THE HARMONISED FREQUENCY BAND TO BE DESIGNATED FOR ANALOGUE AND DIGITAL PMR 446 (ECC/DEC/(15)05) “The European Conference of Postal and Telecommunications Administrations, considering a) that there is an industry and user requirement for harmonised usage conditions for analogue and digital PMR 446 radio equipment throughout Europe; b) that it would be desirable for administrations to have common regulations at their disposal in order to control free carriage and use of PMR 446 radio equipment throughout Europe; c) that the European Telecommunications Standards Institute (ETSI) has developed the Harmonised European Standards ETSI EN 300 113-2, EN 301 166-2 and EN 300 296-2 which can be used for state- of-the-art PMR 446 radio equipment; d) that analogue and digital PMR 446 radio equipment is hand portable (no base station or repeater use) and uses integral antennas only in order to maximise sharing and minimise interference; e) that it is not recommended that applications requiring encrypted speech should be used with PMR 446 radio equipment; f) that PMR 446 radio equipment complying to ETSI EN 300 113-2, EN 301 166-2 and EN 300 296-2 also fulfil the recommended limits identified in ERC/REC 74-01 on unwanted emissions in the spurious domain; g) that in the EU/ EFTA countries the radio equipment that is under the scope of this Decision shall comply with the R&TTE Directive. Conformity with the essential requirements of the R&TTE Directive may be demonstrated by compliance with the applicable Harmonised European Standard(s) or by using the other conformity assessment procedures set out in the R&TTE Directive; h) that those administrations that are bound by EU Directive 1999/5/EC, the R&TTE Directive, as well as those countries that have implemented this Directive voluntarily, need to take account of the provisions of that Directive; i) that when implementing this Decision, CEPT administrations shall consider the need for transitional arrangements; j) that ETSI has developed ETSI Technical Specification TS 103 236 for more robust receivers using Continuous Tone Controlled Signalling System (CTCSS) and Digitally Coded Squelch Signalling System (DCSS), TS 102 490 for digital PMR 446 equipment with 6.25 kHz channel spacing and TS 102 361-1 for digital PMR 446 equipment with 12.5 kHz channel spacing; k) that new frequency usage opportunities for analogue and digital PMR 446 equipment should be introduced with due awareness of the probable continued use of the bands by existing analogue and digital PMR 446 equipment. It is therefore important for administrations to communicate the intended changes as soon as possible to industry, retailers and users throughout Europe; DECIDES 1. that the purpose of this ECC Decision is to harmonise the usage conditions for analogue and digital PMR 446 radio equipment throughout Europe; 2. that CEPT administrations shall designate the band 446.0-446.2 MHz for the use of analogue PMR 446 with a channel plan based on 12.5 kHz spacing where the lowest carrier frequency is 446.00625 MHz; 3. that CEPT administrations shall designate the band 446.1-446.2 MHz for the use of digital PMR 446 with a channel plan based on 6.25 kHz and 12.5 kHz spacing where the lowest carrier frequencies are 446.103125 MHz and 446.10625 MHz respectively; 4. that CEPT administrations shall designate the band 446.0-446.2 MHz for the use of digital PMR 446 with a channel plan based on 6.25 kHz and 12.5 kHz spacing where the lowest carrier frequencies are 446.003125 MHz and 446.00625 MHz respectively as of 1 January 2018;
5. that analogue PMR446 equipment operating in the frequency range 446.1-446.2 MHz should use more robust receivers, as specified in ETSI TS 103 236 or equivalent technical specifications; 6. that analogue PMR446 equipment operating in the frequency range 446.0-446.1 MHz should use more robust receivers, as specified in ETSI TS 103 236 or equivalent technical specifications when placed on the market as of 1 January 2017; 7. that subject to decides 8, 9 and 10 below, CEPT administrations shall permit free carriage and use of all analogue and digital PMR 446 radio equipment; 8. that CEPT administrations shall exempt analogue and digital PMR 446 radio equipment covered by the present Decision from individual licensing; 9. that all PMR 446 equipment is hand portable and shall use only integral antenna and an effective radiated power not exceeding 500 mW, while any base station, repeater or fixed infrastructure use is excluded; 10. that the following technical characteristics shall be applied for PMR 446 applications in order to reduce the risk of harmful interference: a) all PMR 446 radio equipment shall have reception capability; b) PMR 446 radio equipment having Push-To-Talk (PTT) functionality capable of being latched ‘on’ shall apply a 180 seconds maximum transmitter time-out; c) PMR 446 radio equipment having no Push-To-Talk (PTT) functionality shall apply a 180 seconds maximum transmitter time-out and VOX (Voice activation exchange) control; 11. that compliance of PMR 446 radio equipment with all technical requirements shall be demonstrated with the applicable Harmonised European Standards ETSI EN 300 113-2, EN 301 166-2, or EN 300 296-2; 12. that the definitions in the Annex 1 apply for the purpose of this Decision; 13. that this Decision replaces ERC/DEC/(98)25 and ECC/DEC/(05)12 which are withdrawn; 14. that this Decision enters into force by 3 July 2015; 15. that the preferred date for implementation of this ECC Decision shall be 3 January 2016; 16. that CEPT administrations shall communicate the national measures implementing this Decision to the ECC Chairman and the ECO when the Decision is nationally implemented.” Note: Please check the Office documentation database http://www.ecodocdb.dk for the up to date position on the implementation of this and other ECC Decisions. ECC/DEC/(15)05
