Letter beacon
- Cluster beacons
Location of letter beacons
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| C | Moscow, RUS |
| D | Sevastopol, UKR |
| F | Vladivostok, RUS |
| M | Magadan, RUS |
| S | Severomorsk, RUS |
| L | Tirana, ALB (defunct) |
| V | Khiva, UZB |
Types of letter beacons
Cluster beacons
| L | -0.8 | 7038.2, 8494.2 |
| P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8 |
| F | +0.2 | 7039.2, 10872.2, 16332.2 |
| K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
Letter beacon "L" started transmitting on July 1, 2011 and was reported by Boender on two channels. It is unlikely that this beacon is located in Tirana, Albania, given that Albania is now a member of NATO. At the same time, the 10 MHz "P" beacon moved 1 kHz up, from 10871.8 to 10872.8 kHz.
| R (20) | 4325.9, 5465.9 | |
| C | RIW | 8000 |
| L | inactive | |
| W | inactive |
FSK beacons
| K | 9043 | |
| U |
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
Similar systems
On September 7, 2010 a beacon was heard on 9111.7 kHz at 1546 UTC. It sent a slow marker "A", which did not sound like a Russian beacon (MX). It sounded like somebody was playing with the key sending letters "A" and "M". Transmission lasted untill at least 1630 UTC. (19)
Notes & References
- Spooks mailing list.
- William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
