Letter beacon
Revision as of 17:24, 1 August 2011 by Strange Attractor (Talk | contribs)
Letter Beacon D on 5153.7 kHz
Letter beacons, often called single letter beacons, are radio transmissions of uncertain origin, which consist of only a single repeating Morse Code letter.
  • SLHFB, or "Single Letter High Frequency Beacons", the original SPEEDX designation.
  • Cluster beacons
  • MX — an ENIGMA (1) and ENIGMA-2000 (2) designation.
History
Location of letter beacons
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
L Unknown, appeared on July 1, 2011
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (defunct)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
Cluster beacons
L (21)(23) -0.8 7038.2, 7041.6, 8494.2, 8497.9
P -0.2 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 10872.8 (21), 13527.8,
16331.8, 20047.8
F +0.2 7039.2, 10872.2, 16332.2
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier. (20)
R (20) 4325.9, 5465.9
C RIW 8000
L inactive
W inactive
FSK beacons
K 9043
U
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
Similar systems
Notes & References
  1. ENIGMA stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
  2. ENIGMA2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
  21. Letter beacon "L" started transmitting on July 1, 2011 on and was reported by Boender on two channels (7038.2 and 8494.2 kHz). On July 23, 2011 it moved to 7041.6 and 8497.9 kHz. It is unlikely that this beacon is located in Tirana, Albania, given that Albania is now a member of NATO. A location near Saint Petersburg was proposed in UDXF and is confirmed by IARU. At the same time, the 10 MHz "P" beacon moved 1 kHz up, from 10871.8 to 10872.8 kHz.
  22. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, page=K2.
  23. IARU R1 monitoring system: "Intruder News from: July 28th 2011"
  4. Spooks mailing list.
  10. William I. Orr, W6SAI: "The Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
  1. Moscow's "C" Single Letter Cluster Beacon 7.390MHz 40mtr ham band, using a FT-817 HF tranceiver (Youtube video).
  2. Letter Beacon "D" on 5153.7 kHz using a Sangean 909 portable receiver (Youtube video).
WP
