Letter beacon
A Letter beacon (or single letter beacon) is a radio transmission of uncertain origin, which consists of only a single repeating Morse Code letter.
- "Letter beacons"
- Cluster beacons
History
Location of letter beacons
ID letter | Location |
C | Moscow, RUS |
D | Odessa, UKR |
O | Moscow, RUS |
P | Kaliningrad, RUS |
S | Arkhangelsk, RUS |
Z | Mukachevo, UKR |
A | Astrakhan, RUS (tentative) |
C | Moscow, RUS |
D | Sevastopol, UKR |
F | Vladivostok, RUS |
K | Petropavlovsk-Kamchatsky, RUS |
L | Unknown, appeared on July 1, 2011 |
M | Magadan, RUS |
S | Severomorsk, RUS |
L | Tirana, ALB (defunct) |
R | Izhevsk (Ustinov), RUS |
V | Khiva, UZB |
Types of letter beacons
Cluster beacons
L (21) | -0.8 | 7038.2, 7041.8(23), 8494.2, 8497.9 |
D | -0.3 | 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 10872.8 (21), 13527.8, 16331.8, 20047.8 |
S | -0.1 | 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
C | 0.0 | 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
A | +0.1 | 3594.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 13528.1 16332.1 (10) |
F | +0.2 | 7039.2, 10872.2, 16332.2 |
K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
R (20) | 4325.9, 5465.9 | |
V | 3658.0, 4108.0(18), 4150.0, 5141.0, 5342, 6430.7, 6498.0, 6809, 7027.5, 8103.5, 10202 | |
C | RIW | 8000 |
L | inactive | |
W | inactive |
FSK beacons
K | 9043 | |
U |
ENIGMA designation
ENIGMA ID | Description |
MX | Cluster beacons |
Similar systems
Notes & References
- Spooks mailing list.
