Letter beacon
- "Letter beacons"
- Cluster beacons
History
Location of letter beacons
ID letter | Location |
C | Moscow, RUS |
D | Odessa, UKR |
O | Moscow, RUS |
P | Kaliningrad, RUS |
S | Arkhangelsk, RUS |
Z | Mukachevo, UKR |
A | Astrakhan, RUS (tentative) |
C | Moscow, RUS |
D | Sevastopol, UKR |
F | Vladivostok, RUS |
K | Petropavlovsk-Kamchatsky, RUS |
L | Unknown, appeared on July 1, 2011 |
M | Magadan, RUS |
S | Severomorsk, RUS |
L | Tirana, ALB (defunct) |
R | Izhevsk (Ustinov), RUS |
V | Khiva, UZB |
Types of letter beacons
Cluster beacons
L (21) | -0.8 | 7038.2, 7041.8(23), 8494.2, 8497.9 |
D | -0.3 | 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 10872.8 (21), 13527.8, 16331.8, 20047.8 |
S | -0.1 | 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
C | 0.0 | 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
A | +0.1 | 3594.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 13528.1 16332.1 (10) |
F | +0.2 | 7039.2, 10872.2, 16332.2 |
K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
R (20) | 4325.9, 5465.9 | |
V | 3658.0, 4108.0(18), 4150.0, 5141.0, 5342, 6430.7, 6498.0, 6809, 7027.5, 8103.5, 10202 | |
C | RIW | 8000 |
L | inactive | |
W | inactive |
FSK beacons
K | 9043 | |
U |
ENIGMA designation
ENIGMA ID | Description |
MX | Cluster beacons |
Similar systems
Notes & References
- A couple of years ago I had the chance to speak to a Russian naval radio operator who works on a Russian frigate. He confirmed to me that the channel markers are military stations, mostly used by the navy. His English was poor so I could not ask for more detailed info, and as I don't speak Russian, you can imagine that it was a really nice conversation. I had to write down the morse characters of the call signs of the stations and he told me the locations. It was really fun, believe me :-) A couple of the markers that he mentioned have now disappeared but still exist as cluster beacons. The radio operator identified 'L' as St.Petersburg, 'P' as Kaliningrad (HQ of the Baltic Fleet), 'S' as Arkhangelsk and 'C' as Moscow (naval HQ). He knew that there were more stations but didn't know which ones because they were not relevant for his vessel. Ary Boender: "32nd edition of the N&O column / Spooks newsletter", December 24, 2000 [1].
- Spooks mailing list.
- Enigma Control List [2], Enigma-2000, May 2005.
