CB is one of the most commonly used two-way and land mobile radio services worldwide, although for handheld walkie-talkie purposes it has mostly been depreciated in favor of VHF/UHF services such as FRS/GMRS and MURS. CB is still heavily used by trucking companies, hunting clubs, farmers, rednecks, doomsday preppers, for local and/or unlicensed paging or data link/telemetry systems,etc and as an inexpensive short-range alternative to licensed services such as the licensed Business Radio Services. Hunters are such a prolific user of CB equipment that export radio companies such as RCI/Ranger have produced radios designed specifically for hunters, such as the Connex Deer Hunter (26.065-27.405 MHz), Connex Coyote Hunter (25.615-27.405 MHz) and Superstar 121 (26.515-27.855 MHz) which cover the lower freeband frequencies often used by hunters.
![](/wiki/images/thumb/7/7e/L_team_mx10_2_%282%29.jpg/200px-L_team_mx10_2_%282%29.jpg)
![](/wiki/images/thumb/c/cd/Connex_Deer_Hunter.jpg/200px-Connex_Deer_Hunter.jpg)
![](/wiki/images/thumb/d/de/Superstar_121.jpg/200px-Superstar_121.jpg)
CB is generally license free worldwide, although frequency allocations, modes and power limits vary from country to country. However, these limits are often ignored and enforcement is extremely lax. Use of "10-meter" or "export" radios is common. These radios offer the user the option of 40 channels plus a band switch, the band switch going up or down 450 kHz (0.450 MHz, or 45 channels). Common export radio frequency coverage includes 25.615-28.305 MHz (standard 6-band export plan), 25.165 MHz - 28.755 MHz (Galaxy DX radios 8-band plan), 25.615 MHz - 30.105 MHz ("RU" or "export" plan, often included in European radios and Chinese 10 meter rigs such as the Anytone AT-5555 and its various clones), and 24.265 MHz - 29.655 MHz (12 meter/10 meter coverage radios such as the Superstar SS-158EDX and its various clones). Others include 25.165 MHz - 30.105 MHz, 25.615 MHz - 30.555 MHz, 26.000 MHz - 32.000 MHz (RCI-2950 and RCI-2970 series radios) and the "three band" or "uppers and lowers" coverage of 26.515 MHz - 27.855 MHz (see discussion regarding "hunting radios" above). Most exports at least have access to the high band of 27.415 MHz to 27.855 MHz and the low band of 26.515 MHz to 26.955 MHz, so the majority of out-of-band communications take place between 26.515 MHz and 27.855 MHz.
Frequency Range | Remarks |
Frequency | Remarks |
27.490 MHz | 63 active licenses, high power is authorized on this frequency |
27.470 MHz | 5 active licenses, specified for itinerant use only per FCC rules |
See the bottom of this page for R/C, radio control, remote control, RC, telecommand, telemetry, etc frequencies.
CB Channel | Frequency |
Channel 1 | 26.965 MHz |
Channel 2 | 26.975 MHz |
Channel 3 | 26.985 MHz |
Channel 4 | 27.005 MHz |
Channel 5 | 27.015 MHz |
Channel 6 | 27.025 MHz |
Channel 7 | 27.035 MHz |
Channel 8 | 27.055 MHz |
Channel 9 | 27.065 MHz |
Channel 10 | 27.075 MHz |
Channel 11 | 27.085 MHz |
Channel 12 | 27.105 MHz |
Channel 13 | 27.115 MHz |
Channel 14 | 27.125 MHz |
Channel 15 | 27.135 MHz |
Channel 16 | 27.155 MHz |
Channel 17 | 27.165 MHz |
Channel 18 | 27.175 MHz |
Channel 19 | 27.185 MHz |
Channel 20 | 27.205 MHz |
Channel 21 | 27.215 MHz |
Channel 22 | 27.225 MHz |
Channel 23 | 27.255 MHz |
Channel 24 | 27.235 MHz |
Channel 25 | 27.245 MHz |
Channel 26 | 27.265 MHz |
Channel 27 | 27.275 MHz |
Channel 28 | 27.285 MHz |
Channel 29 | 27.295 MHz |
Channel 30 | 27.305 MHz |
Channel 31 | 27.315 MHz |
Channel 32 | 27.325 MHz |
Channel 33 | 27.335 MHz |
Channel 34 | 27.345 MHz |
Channel 35 | 27.355 MHz |
Channel 36 | 27.365 MHz |
Channel 37 | 27.375 MHz |
Channel 38 | 27.385 MHz |
Channel 39 | 27.395 MHz |
Channel 40 | 27.405 MHz |
FM (Frequency Modulation)
Channel 1 | 27.60125 MHz |
Channel 2 | 27.61125 MHz |
Channel 3 | 27.62125 MHz |
Channel 4 | 27.63125 MHz |
Channel 5 | 27.64125 MHz |
Channel 6 | 27.65125 MHz |
Channel 7 | 27.66125 MHz |
Channel 8 | 27.67125 MHz |
Channel 9 | 27.68125 MHz |
Channel 10 | 27.69125 MHz |
Channel 11 | 27.70125 MHz |
Channel 12 | 27.71125 MHz |
Channel 13 | 27.72125 MHz |
Channel 14 | 27.73125 MHz |
Channel 15 | 27.74125 MHz |
Channel 16 | 27.75125 MHz |
Channel 17 | 27.76125 MHz |
Channel 18 | 27.77125 MHz |
Channel 19 | 27.78125 MHz |
Channel 20 | 27.79125 MHz |
Channel 21 | 27.80125 MHz |
Channel 22 | 27.81125 MHz |
Channel 23 | 27.82125 MHz |
Channel 24 | 27.83125 MHz |
Channel 25 | 27.84125 MHz |
Channel 26 | 27.85125 MHz |
Channel 27 | 27.86125 MHz |
Channel 28 | 27.87125 MHz |
Channel 29 | 27.88125 MHz |
Channel 30 | 27.89125 MHz |
Channel 31 | 27.90125 MHz |
Channel 32 | 27.91125 MHz |
Channel 33 | 27.92125 MHz |
Channel 34 | 27.93125 MHz |
Channel 35 | 27.94125 MHz |
Channel 36 | 27.95125 MHz |
Channel 37 | 27.96125 MHz |
Channel 38 | 27.97125 MHz |
Channel 39 | 27.98125 MHz |
Channel 40 | 27.99125 MHz |
WPAS Channel | Frequency MHz | Frequency kHz |
Channel LW01 | 27.60125 MHz | 27601.25 kHz |
Channel LW02 | 27.61125 MHz | 27611.25 kHz |
Channel LW03 | 27.62125 MHz | 27621.25 kHz |
Channel LW04 | 27.63125 MHz | 27631.25 kHz |
Channel LW05 | 27.64125 MHz | 27641.25 kHz |
Channel LW06 | 27.65125 MHz | 27651.25 kHz |
Channel LW07 | 27.66125 MHz | 27661.25 kHz |
Channel LW08 | 27.67125 MHz | 27671.25 kHz |
Channel LW09 | 27.68125 MHz | 27681.25 kHz |
Channel LW10 | 27.69125 MHz | 27691.25 kHz |
Channel LW11 | 27.70125 MHz | 27701.25 kHz |
Channel LW12 | 27.71125 MHz | 27711.25 kHz |
Channel LW13 | 27.72125 MHz | 27721.25 kHz |
Channel LW14 | 27.73125 MHz | 27731.25 kHz |
Channel LW15 | 27.74125 MHz | 27741.25 kHz |
Channel LW16 | 27.75125 MHz | 27751.25 kHz |
Channel LW17 | 27.76125 MHz | 27761.25 kHz |
Channel LW18 | 27.77125 MHz | 27771.25 kHz |
Channel LW19 | 27.78125 MHz | 27781.25 kHz |
Channel LW20 | 27.79125 MHz | 27791.25 kHz |
Channel LW21 | 27.80125 MHz | 27801.25 kHz |
Channel LW22 | 27.81125 MHz | 27811.25 kHz |
Channel LW23 | 27.82125 MHz | 27821.25 kHz |
Channel LW24 | 27.83125 MHz | 27831.25 kHz |
Channel LW25 | 27.84125 MHz | 27841.25 kHz |
Channel LW26 | 27.85125 MHz | 27851.25 kHz |
Channel LW27 | 27.86125 MHz | 27861.25 kHz |
Channel LW28 | 27.87125 MHz | 27871.25 kHz |
Channel LW29 | 27.88125 MHz | 27881.25 kHz |
Channel LW30 | 27.89125 MHz | 27891.25 kHz |
Channel LW31 | 27.90125 MHz | 27901.25 kHz |
Channel LW32 | 27.91125 MHz | 27911.25 kHz |
Channel LW33 | 27.92125 MHz | 27921.25 kHz |
Channel LW34 | 27.93125 MHz | 27931.25 kHz |
Channel LW35 | 27.94125 MHz | 27941.25 kHz |
Channel LW36 | 27.95125 MHz | 27951.25 kHz |
Channel LW37 | 27.96125 MHz | 27961.25 kHz |
Channel LW38 | 27.97125 MHz | 27971.25 kHz |
Channel LW39 | 27.98125 MHz | 27981.25 kHz |
Channel LW40 | 27.99125 MHz | 27991.25 kHz |
Channel UW01 | 27.605 MHz | 27605 kHz |
Channel UW02 | 27.615 MHz | 27615 kHz |
Channel UW03 | 27.625 MHz | 27625 kHz |
Channel UW04 | 27.635 MHz | 27635 kHz |
Channel UW05 | 27.645 MHz | 27645 kHz |
Channel UW06 | 27.655 MHz | 27655 kHz |
Channel UW07 | 27.665 MHz | 27665 kHz |
Channel UW08 | 27.675 MHz | 27675 kHz |
Channel UW09 | 27.685 MHz | 27685 kHz |
Channel UW10 | 27.695 MHz | 27695 kHz |
Channel UW11 | 27.705 MHz | 27705 kHz |
Channel UW12 | 27.715 MHz | 27715 kHz |
Channel UW13 | 27.725 MHz | 27725 kHz |
Channel UW14 | 27.735 MHz | 27735 kHz |
Channel UW15 | 27.745 MHz | 27745 kHz |
Channel UW16 | 27.755 MHz | 27755 kHz |
Channel UW17 | 27.765 MHz | 27765 kHz |
Channel UW18 | 27.775 MHz | 27775 kHz |
Channel UW19 | 27.785 MHz | 27785 kHz |
Channel UW20 | 27.795 MHz | 27795 kHz |
Channel UW21 | 27.805 MHz | 27805 kHz |
Channel UW22 | 27.815 MHz | 27815 kHz |
Channel UW23 | 27.825 MHz | 27825 kHz |
Channel UW24 | 27.835 MHz | 27835 kHz |
Channel UW25 | 27.845 MHz | 27845 kHz |
Channel UW26 | 27.855 MHz | 27855 kHz |
Channel UW27 | 27.865 MHz | 27865 kHz |
Channel UW28 | 27.875 MHz | 27875 kHz |
Channel UW29 | 27.885 MHz | 27885 kHz |
Channel UW30 | 27.895 MHz | 27895 kHz |
Channel UW31 | 27.905 MHz | 27905 kHz |
Channel UW32 | 27.915 MHz | 27915 kHz |
Channel UW33 | 27.925 MHz | 27925 kHz |
Channel UW34 | 27.935 MHz | 27935 kHz |
Channel UW35 | 27.945 MHz | 27945 kHz |
Channel UW36 | 27.955 MHz | 27955 kHz |
Channel UW37 | 27.965 MHz | 27965 kHz |
Channel UW38 | 27.975 MHz | 27975 kHz |
Channel UW39 | 27.985 MHz | 27985 kHz |
Channel UW40 | 27.995 MHz | 27995 kHz |
Channel 41 | 26.565 MHz |
Channel 42 | 26.575 MHz |
Channel 43 | 26.585 MHz |
Channel 44 | 26.595 MHz |
Channel 45 | 26.605 MHz |
Channel 46 | 26.615 MHz |
Channel 47 | 26.625 MHz |
Channel 48 | 26.635 MHz |
Channel 49 | 26.645 MHz |
Channel 50 | 26.655 MHz |
Channel 51 | 26.665 MHz |
Channel 52 | 26.675 MHz |
Channel 53 | 26.685 MHz |
Channel 54 | 26.695 MHz |
Channel 55 | 26.705 MHz |
Channel 56 | 26.715 MHz |
Channel 57 | 26.725 MHz |
Channel 58 | 26.735 MHz |
Channel 59 | 26.745 MHz |
Channel 60 | 26.755 MHz |
Channel 61 | 26.765 MHz |
Channel 62 | 26.775 MHz |
Channel 63 | 26.785 MHz |
Channel 64 | 26.795 MHz |
Channel 65 | 26.805 MHz |
Channel 66 | 26.815 MHz |
Channel 67 | 26.825 MHz |
Channel 68 | 26.835 MHz |
Channel 69 | 26.845 MHz |
Channel 70 | 26.855 MHz |
Channel 71 | 26.865 MHz |
Channel 72 | 26.875 MHz |
Channel 73 | 26.885 MHz |
Channel 74 | 26.895 MHz |
Channel 75 | 26.905 MHz |
Channel 76 | 26.915 MHz |
Channel 77 | 26.925 MHz |
Channel 78 | 26.935 MHz |
Channel 79 | 26.945 MHz |
Channel 80 | 26.955 MHz |
Channel 1 | 26.330 MHz |
Channel 2 | 26.340 MHz |
Channel 3 | 26.350 MHz |
Channel 4 | 26.370 MHz |
Channel 5 | 26.380 MHz |
Channel 6 | 26.390 MHz |
Channel 7 | 26.400 MHz |
Channel 8 | 26.420 MHz |
Channel 9 | 26.430 MHz |
Channel 10 | 26.440 MHz |
Channel 11 | 26.450 MHz |
Channel 12 | 26.470 MHz |
Channel 13 | 26.480 MHz |
Channel 14 | 26.490 MHz |
Channel 15 | 26.500 MHz |
Channel 16 | 26.520 MHz |
Channel 17 | 26.530 MHz |
Channel 18 | 26.540 MHz |
Channel 19 | 26.550 MHz |
Channel 20 | 26.570 MHz |
Channel 21 | 26.580 MHz |
Channel 22 | 26.590 MHz |
Channel 23 | 26.620 MHz |
Channel 24 | 26.600 MHz |
Channel 25 | 26.610 MHz |
Channel 26 | 26.630 MHz |
Channel 27 | 26.640 MHz |
Channel 28 | 26.650 MHz |
Channel 29 | 26.660 MHz |
Channel 30 | 26.670 MHz |
Channel 31 | 26.680 MHz |
Channel 32 | 26.690 MHz |
Channel 33 | 26.700 MHz |
Channel 34 | 26.710 MHz |
Channel 35 | 26.720 MHz |
Channel 36 | 26.730 MHz |
Channel 37 | 26.740 MHz |
Channel 38 | 26.750 MHz |
Channel 39 | 26.760 MHz |
Channel 40 | 26.770 MHz |
Channel 1 | 26.968 MHz |
Channel 2 | 26.976 MHz |
Channel 3 | 27.040 MHz |
Channel 4 | 27.080 MHz |
Channel 5 | 27.088 MHz |
Channel 6 | 27.112 MHz |
Channel 7 | 27.120 MHz |
Channel 8 | 27.144 MHz |
Channel 26760 | 26.760 MHz |
Channel 26768 | 26.768 MHz |
Channel 26776 | 26.776 MHz |
Channel 26824 | 26.824 MHz |
Channel 26840 | 26.840 MHz |
Channel 26848 | 26.848 MHz |
Channel 26856 | 26.856 MHz |
Channel 26864 | 26.864 MHz |
Channel 26872 | 26.872 MHz |
Channel 26880 | 26.880 MHz |
Channel 26888 | 26.888 MHz |
Channel 26896 | 26.896 MHz |
Channel 26912 | 26.912 MHz |
Channel 26920 | 26.920 MHz |
Channel 26928 | 26.928 MHz |
Channel 26936 | 26.936 MHz |
Channel 26944 | 26.944 MHz |
Channel 27016 | 27.016 MHz |
Channel 27524 | 27.524 MHz |
Channel 27532 | 27.532 MHz |
Channel 27540 | 27.540 MHz |
Channel 27548 | 27.548 MHz |
Channel 27556 | 27.556 MHz |
Channel 27572 | 27.572 MHz |
Channel 27580 | 27.580 MHz |
Channel 27628 | 27.628 MHz |
Channel 27636 | 27.636 MHz |
Channel 27644 | 27.644 MHz |
Channel 27652 | 27.652 MHz |
Channel 27660 | 27.660 MHz |
Channel 27668 | 27.668 MHz |
Channel 27676 | 27.676 MHz |
Channel 27724 | 27.724 MHz |
Channel 27732 | 27.732 MHz |
Channel 27740 | 27.740 MHz |
Channel 27748 | 27.748 MHz |
Channel 27756 | 27.756 MHz |
Channel 27764 | 27.764 MHz |
Channel 27772 | 27.772 MHz |
Channel 27780 | 27.780 MHz |
Channel 27828 | 27.828 MHz |
Channel 27836 | 27.836 MHz |
Channel 27852 | 27.852 MHz |
Channel 27860 | 27.860 MHz |
Channel 27884 | 27.884 MHz |
Channel 27892 | 27.892 MHz |
Channel 27908 | 27.908 MHz |
Channel 27916 | 27.916 MHz |
Channel 27932 | 27.932 MHz |
Channel 27940 | 27.940 MHz |
Channel 27956 | 27.956 MHz |
Channel 27964 | 27.964 MHz |
Channel 27980 | 27.980 MHz |
Channel 27988 | 27.988 MHz |
27310.5 kHz | 27.3105 MHz |
27334.5 kHz | 27.3345 MHz |
27338.5 kHz | 27.3385 MHz |
27342.5 kHz | 27.3425 MHz |
27346.5 kHz | 27.3465 MHz |
27350.5 kHz | 27.3505 MHz |
27354.5 kHz | 27.3545 MHz |
27358.5 kHz | 27.3585 MHz |
27362.5 kHz | 27.3625 MHz |
27366.5 kHz | 27.3665 MHz |
27370.5 kHz | 27.3705 MHz |
27378.5 kHz | 27.3785 MHz |
27382.5 kHz | 27.3825 MHz |
27386.5 kHz | 27.3865 MHz |
27388.5 kHz | 27.3885 MHz |
27398.5 kHz | 27.3985 MHz |
27404.5 kHz | 27.4045 MHz |
27418.5 kHz | 27.4185 MHz |
27426.5 kHz | 27.4265 MHz |
27434.5 kHz | 27.4345 MHz |
27442.5 kHz | 27.4425 MHz |
27452.5 kHz | 27.4525 MHz |
27458.5 kHz | 27.4585 MHz |
27466.5 kHz | 27.4665 MHz |
27470.5 kHz | 27.4705 MHz |
Channel 41 | 27.415 MHz |
Channel 42 | 27.425 MHz |
Channel 43 | 27.435 MHz |
Channel 44 | 27.455 MHz |
Channel 45 | 27.465 MHz |
Channel 46 | 27.475 MHz |
Channel 47 | 27.485 MHz |
Channel 48 | 27.505 MHz |
Channel 49 | 27.515 MHz |
Channel 50 | 27.525 MHz |
Channel 51 | 27.535 MHz |
Channel 52 | 27.555 MHz |
Channel 53 | 27.565 MHz |
Channel 54 | 27.575 MHz |
Channel 55 | 27.585 MHz |
Channel 56 | 27.605 MHz |
Channel 57 | 27.615 MHz |
Channel 58 | 27.625 MHz |
Channel 59 | 27.635 MHz |
Channel 60 | 27.655 MHz |
Channel 61 | 27.665 MHz |
Channel 62 | 27.675 MHz |
Channel 63 | 27.685 MHz |
Channel 64 | 27.695 MHz |
Channel 65 | 27.705 MHz |
Channel 66 | 27.715 MHz |
Channel 67 | 27.725 MHz |
Channel 68 | 27.735 MHz |
Channel 69 | 27.745 MHz |
Channel 70 | 27.755 MHz |
Channel 71 | 27.765 MHz |
Channel 72 | 27.775 MHz |
Channel 73 | 27.785 MHz |
Channel 74 | 27.795 MHz |
Channel 75 | 27.805 MHz |
Channel 76 | 27.815 MHz |
Channel 77 | 27.825 MHz |
Channel 78 | 27.835 MHz |
Channel 79 | 27.845 MHz |
Channel 80 | 27.855 MHz |
27.620 MHz | 27.820 MHz | Jamaica | Optional CTCSS tone: 88.5Hz (was part of a linked system, unknown if still on the air) |
26.575 MHz | Germany | ||
26.675 MHz | |||
26.915 MHz | |||
26.925 MHz | |||
26.935 MHz | |||
26.970 MHz | Lithuania | ||
27.070 MHz | |||
27.110 MHz | Poland | ||
27.110 MHz | Russia | ||
27.150 MHz | Poland | ||
27.170 MHz | Poland | ||
27.190 MHz | |||
27.205 MHz | Sweden | DTMF-activated playback | |
27.220 MHz | |||
27.230 MHz | |||
27.235 MHz | |||
27.250 MHz | Belarus | ||
27.300 MHz | |||
27.325 MHz | |||
27.430 MHz | |||
27.450 MHz | |||
27.470 MHz | |||
27.635 MHz | St. Petersburg, Russia | ||
27.675 MHz | Russia | ||
27.765 MHz | Germany | ||
27.840 MHz | Poland | ||
27.875 MHz | Rostov, Russia |
US "A" or "RC" channels
These frequencies are used throughout the world, often in conjunction with locally authorized frequencies. In the United States, 27.255 MHz (CB Channel 23) is shared with telecommand/telemetry systems in addition to RC. Paging and local telemetry systems often use 27.255 MHz because FCC rules permit high power transmission on this frequency. Ref FCC Rules Part 95 95.207 and 95.210 47CFR95.207 and 47CFR95.210 Local paging systems, on-site telemetry, lightning detector systems, and wireless PA systems have been reported to use 27.255 MHz. During band openings, paging and other FSK signals can often be heard on 27.255MHz. Most of these signals have a bandwidth of 6-8 kHz. FCC rules allow a maximum bandwidth of 8 kHz for data signals on frequencies from 26.995 to 27.255 MHz.
For example, the Linear Systems Xtended Range data transmitter system uses FM-FSK on 27.255 MHz with 10 watts carrier power and 8 kHz bandwidth under Part 95. Radioshack used to sell an on-site paging system that transmitted FM POCSAG on 27.255 MHz with 7 watts carrier power. 27.255 MHz (channel 23) offers surprisingly long range at higher power levels with quality antenna systems. With a 27255 kHz transmitter doing 10-20 watts carrier power and a strategically placed transmitter, one could cover a substantial portion of an urbanized area. Testing with 10 watt carrier power FSK transmitters on 27.255 MHz using base station CB antennas showed ranges of 20+ miles with very little loss in signal strength and no data loss.
FCC rules permit a maximum of 4 watts transmitter power on 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz and 27.195 MHz and 25 watts maximum transmitter power on 27.255 MHz FCC rules provide for FSK and FM modes (for data transmission) as well on 27.255 MHz. Due to the higher power allowed on 27.255 MHz, it is often used for unlicensed on-site paging and telemetry systems. FCC rules permit remote monitoring, status alerts, and one-way transmissions on the six RC frequencies, allowing for considerably more flexibility in designing license-free datalink systems that offer impressive range.
CB Channel | RC Channel | RC Color Code | Frequency |
Channel "3A" | Channel 1 | Brown | 26.995 MHz |
Channel "7A" | Channel 2 | Red | 27.045 MHz |
Channel "11A" | Channel 3 | Orange | 27.095 MHz |
Channel "15A" | Channel 4 | Yellow | 27.145 MHz |
Channel "19A" | Channel 5 | Green | 27.195 MHz |
Channel 23 | Channel 6 | Blue | 27.255 MHz |
UK RC Channels
Maximum power output 100mW
Black | 26.975 MHz |
Brown-Red | 27.025 MHz |
Red | 27.045 MHz |
Red-Orange | 27.075 MHz |
Orange-Yellow | 27.125 MHz |
Yellow-Green | 27.175 MHz |
Green-Blue | 27.225 MHz |
Blue | 27.245 MHz |
White (or Purple) | 27.275 MHz |
Australian 27 MHz RC and 29 MHz RC Channels
Australia RC Channel | Frequency |
Channel 1 | 26.995 MHz |
Channel 2 | 27.045 MHz |
Channel 3 | 27.095 MHz |
Channel 4 | 27.145 MHz |
Channel 6 | 27.195 MHz |
Channel 10 | 29.725 MHz |
Channel 11 | 29.735 MHz |
Channel 12 | 29.745 MHz |
Channel 13 | 29.755 MHz |
Channel 14 | 29.765 MHz |
Channel 15 | 29.775 MHz |
Channel 16 | 29.785 MHz |
Channel 17 | 29.795 MHz |
Channel 18 | 29.805 MHz |
Channel 19 | 29.815 MHz |
Channel 20 | 29.825 MHz |
Channel 21 | 29.835 MHz |
Channel 22 | 29.845 MHz |
Channel 23 | 29.855 MHz |
Channel 24 | 29.865 MHz |
Channel 25 | 29.875 MHz |
Channel 26 | 29.885 MHz |
Channel 27 | 29.895 MHz |
Channel 28 | 29.905 MHz |
Channel 29 | 29.915 MHz |
Channel 30 | 29.925 MHz |
Channel 31 | 29.935 MHz |
Channel 32 | 29.945 MHz |
Channel 33 | 29.955 MHz |
Channel 34 | 29.965 MHz |
Channel 35 | 29.975 MHz |
Channel 36 | 29.985 MHz |
New Zealand 27 MHz RC and 29 MHz RC Channels
Similar to American and Australian RC frequency allocations. Different channel numbering system. 26.975-27.280 MHz and 29.725-29.985 MHz. 20 kHz channel steps 29.7-30 MHz instead of 10 kHz steps like the Australian system. 100mW maximum output power under New Zealand law.
NZ RC Channel | Frequency |
Channel 197 | 26.975 MHz |
Channel 199 | 26.995 MHz |
Channel 102 | 27.020 MHz |
Channel 104 | 27.045 MHz |
Channel 107 | 27.070 MHz |
Channel 109 | 27.095 MHz |
Channel 112 | 27.120 MHz |
Channel 114 | 27.145 MHz |
Channel 117 | 27.170 MHz |
Channel 119 | 27.195 MHz |
Channel 122 | 27.220 MHz |
Channel 124 | 27.245 MHz |
Channel 128 | 27.280 MHz |
Channel 272 | 29.725 MHz |
Channel 274 | 29.745 MHz |
Channel 276 | 29.765 MHz |
Channel 278 | 29.785 MHz |
Channel 280 | 29.805 MHz |
Channel 282 | 29.825 MHz |
Channel 284 | 29.845 MHz |
Channel 286 | 29.865 MHz |
Channel 288 | 29.885 MHz |
Channel 290 | 29.905 MHz |
Channel 292 | 29.925 MHz |
Channel 294 | 29.945 MHz |
Channel 296 | 29.965 MHz |
Channel 298 | 29.985 MHz |
