Letter beacon
Revision as of 02:47, 3 September 2021 by SV1XV (Talk | contribs)
Letter Beacon D on 5153.7 kHz
  • "Letter beacons"
  • SLHFB, or "Single Letter High Frequency Beacons", the original SPEEDX designation.
  • Cluster beacons
  • MX — an ENIGMA (1) and ENIGMA-2000 (2) designation.
History
Location of letter beacons
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
The ENIGMA group also accepted these locations for cluster beacons "C", "D", "P" and "S", adding Vladivostok for beacon "F". (7) A recent source (2006) regarding locations was published on the Web by Ary Boender.(8) (24) This publication also contains an extensive list of frequencies of letter beacons, both current and historical. The following locations are stated for cluster beacons:
ID letter Callsign Location
A Astrakhan, RUS (tentative)
C RIW Moscow, RUS
D RCV Sevastopol, UKR
F RJS Vladivostok, RUS
K RCC Petropavlovsk-Kamchatsky, RUS
L Unknown, appeared on July 1, 2011
M RTS Magadan, RUS
P RMP Kaliningrad, RUS
S RIT Severomorsk, RUS
ID letter Location
L Tirana, ALB (defunct)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
or Almaty, KAZ (25)
Transmissions of the "P" beacon in December 2007, even on medium frequency (420 and 583 kHz) indicate the Russian Naval Base of Kaliningrad as a possible source. (9) Kaliningrad officially uses the ITU registered callsign RMP. The identity of "P" beacon as an alias for RMP was first discovered by Ary Boender in 1995, when it transmitted RTTY weather forecast for Baltic Sea using callsign RMP on 3262 kHz [1].
Types of letter beacons
Cluster beacons
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", "A", "M" and "K") have been regularly reported in small spectrum segments centered around 3594 kHz, 4558 kHz, 5154 kHz, 7509 kHz, 8495 kHz, 10872 kHz, 13528 kHz, 16332 kHz and 20048 kHz. The term "cluster beacons" is frequently used for them, as these beacons transmit in parallel on frequencies only 0.1 kHz apart. These beacons transmit only their single-letter identifier in standard CW (A1A) using morse code. The cluster centered on 7509.0 kHz in the past transmitted on 7039.0 kHz, within the 40m international amateur radio allocation.
ID letter Regular callsign Channel Frequencies (kHz)
L (21) -0.8 5156.8, 7038.2, 7041.8(23), 8494.2, 8497.8
D RCV -0.3 3593.7, 4557.7, 5153.7, 7508.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7
P RMP -0.2 3593.8, 4557.8, 5153.8, 7038.8, 7508.8, 8494.8, 10871.8, 10872.8 (21), 13527.8,
16331.8, 20047.8
S RIT -0.1 3593.9, 4557.9, 5153.9, 7508.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9
C RIW 0.0 3594.0, 4558.0, 5154.0, 7039.0, 7509.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0
A +0.1 3594.1, 4558.1, 5154.1, 7509.1, 8495.1, 10872.1 13528.1 16332.1 (10)
F RJS +0.2 5156.8, 7039.2, 8495.2, 10872.2, 13528.2, 16332.2
K RCC +0.3 4558.3, 5154.3, 7039.3, 8495.3, 10872.3, 16332.3
M RTS +0.4 5154.4, 7039.4, 8495.4, 10872.4, 13528.4, 16332.4
Notes
  • Occasionally some cluster beacons (especially "F" and "M") have been reported transmitting on frequencies different from their regular channel for short periods.
  • The cluster on 3594.0 kHz seems to be inactive in 2021.
A few solitary beacons, like "R" on 4325.9 kHz and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier. (20)
R (20) 4325.9, 5465.9
V 3227.0, 3657.0, 4031.0, 4205.0, 4338.0, 4977.0, 5094.0, 5466.0, 5590.0
V (historic) 3335.0, 4028.0, 4108.0(18), 4150.0, 5141.0, 5342, 6430.7, 6498.0,
6809, 7027.5, 8103.5, 10202
C RIW 8000
U 7830.5(27)
L 5156.8, 6917.4, 8497.8
W 8162.0, 8895.0
FSK beacons
K 4005, 7906, 8144, 8158, 9043,
10571, 11555, 12150, 14477, 14967,
18348
U 7569, 9057, 10216, 12185, 12238,
15655
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
Purpose of letter beacons
Similar systems
Notes & References
  1. ENIGMA stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
  2. ENIGMA2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
  3. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, page K1.
  4. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, pages K7-K10.
  5. Schimmel, D.W.: "The underground frequency guide", HighText Publications, Inc., ISBN 1-878707-17-5, 1994, pages 78–83.
  8. Ary Boender: "Channel Markers & Cluster Beacons", http://www.numbersoddities.nl/MX-profile.pdf , September 2006.
  16. Pleikys Rimantas: Jamming, Rimantas Pleikys, Vilnius 1998
  21. Cluster beacon "L" appeared on 7038.2 and 8494.2 kHz and was was first reported by the VERON Intruder Watch on June 29, 2011 at 1800 UTC. "L" was also active throughout July 2011. The first thoughts were that "L" transmitted from St Petersburg but so far there is no evidence to support this. It moved on July 23, 2011 to 7041.6 and 8497.9 kHz and again on July 24, 2011 to 7041.8 and 8497.8 kHz. (Ary Boender: "Number and Oddities", issue 166, pp.7). Cluster beacon "L" is not the solitary letter beacon "L" that transmitted in the past from Tirana, Albania, given that Albania is now a member of NATO. At the same time, the 10 MHz "P" beacon moved 1 kHz up, from 10871.8 to 10872.8 kHz.
  22. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, page=K2.
  23. IARU R1 monitoring system: "Intruder News from: July 28th 2011"
  24. A couple of years ago I had the chance to speak to a Russian naval radio operator who works on a Russian frigate. He confirmed to me that the channel markers are military stations, mostly used by the navy. His English was poor so I could not ask for more detailed info, and as I don't speak Russian, you can imagine that it was a really nice conversation. I had to write down the morse characters of the call signs of the stations and he told me the locations. It was really fun, believe me :-) A couple of the markers that he mentioned have now disappeared but still exist as cluster beacons. The radio operator identified 'L' as St.Petersburg, 'P' as Kaliningrad (HQ of the Baltic Fleet), 'S' as Arkhangelsk and 'C' as Moscow (naval HQ). He knew that there were more stations but didn't know which ones because they were not relevant for his vessel. Ary Boender: "32nd edition of the N&O column / Spooks newsletter", December 24, 2000 [2].
  25. IARU R1 monitoring system, September 2016 [3]
  26. William I. Orr, W6SAI: "High Frequency Single-Letter Beacons (SLBs); Part 1: The K- and U-Beacons, The Search Goes On", Popular Communications,CQ Communications, Inc, ISSN 0733-3315, December 1984, pages 28-31.
  27. ENIGMA-2000, Issue 109, November 2018, page 16.
  2. Harry L. Helms, W5HLH: How to tune the secret shortwave spectrum, Tab Books, Inc., ISBN 0-8306-1185-1, 1981, pp. 141–143.
  4. Spooks mailing list.
  8. William I. Orr, W6SAI: "Those Mysterious High Frequency Single-Letter Beacons (SLBs); Part 2: The Cluster Beacons – A Soviet Riddle!", Popular Communications,CQ Communications, Inc, ISSN 0733-3315, January 1985, pages 22-24.
  9. William I. Orr, W6SAI: "The Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
  10. Enigma Control List [4], Enigma-2000, May 2005.
  11. Fritz Nusser: "Channel Markers and Cluster Beacons", Fascinatning Shortwaves (2001-2009)
  12. Alan Gale, G4TMV: "An introduction to beacon DXing", Version 1.0, December 2012, pp. 36-38.
  1. Moscow's "C" Single Letter Cluster Beacon 7.390MHz 40mtr ham band, using a FT-817 HF tranceiver (Youtube video).
  2. Letter Beacon "D" on 5153.7 kHz using a Sangean 909 portable receiver (Youtube video).
WP
