Amateur radio
Amateur Radio Bands MF/HF
- 902-902 MHz - 33cm band or 900 MHz band (shared with Part 15 services, cordless phones, long-haul WiFi, mesh networks - LoRa, Meshstastic and telemetry links, long range drone remote control systems and backhaul video/data links, along with many other services in the USA, not available in many areas). Shared with ISM services and many other systems, center frequency 915 MHz.
Calling frequencies for different modes may vary in different parts of the world.
