Amateur radio
Revision as of 13:19, 8 July 2023 by R4002 (Talk | contribs)
Amateur Radio Bands MF/HF
  • 50-54 MHz - 6 meter band (50-51 MHz or 50-52 MHz in some countries)
  • 222-225 MHz - 1.25 meter band (220-225 MHz in some areas), only available in some countries, shared service in others
  • 902-902 MHz - 33cm band or 900 MHz band (shared with Part 15 services, cordless phones, long-haul WiFi, mesh networks - LoRa, Meshtastic and telemetry links, long range drone remote control systems and backhaul video/data links, along with many other services in the USA, not available in many areas). Shared with ISM services and many other systems, center frequency 915 MHz.
  • 2400-2500 MHz - 2.4 GHz or 2.45 GHz band. 2.4 GHz to 2.5 GHz shared with Part 15, WiFi, data links, RC remote control systems, drone remote control and telemetry systems, video senders, and about six dozen other services, including Part 18 ISM devices (center frequency: 2450 MHz or 2.45GHz or 2.4 GHz or simply 2.4G).
  • 28-29.7 MHz band - 10 meter band (28 MHz band) - United States 10 Meter FM Calling: 29.600 MHz FM.
  • 50-54 MHz band - 6 meter band (50 MHz band) - United States 6 Meter SSB DX Calling: 50.125 MHz USB
  • 50-54 MHz band - 6 meter band (50 MHz band) - United States 6 Meter SSB Calling: 50.200 MHz USB
  • 50-54 MHz band - 6 meter band (50 MHz band) - United States 6 Meter AM Calling: 50.400 MHz AM
  • 50-54 MHz band - 6 meter band (50 MHz band) - United States 6 Meter FM Military Radio (Surplus Radios) 51.0 MC Calling: 51.000 MHz FM or "51.00 FM"
  • 50-54 MHz band - 6 meter band (50 MHz band) - United States 6 Meter FM Calling: 52.525 MHz FM
  • 144-148 MHz band - 2 meter band (144 MHz band) - United States 2 Meter SSB Calling: 144.200 MHz USB
  • 144-148 MHz band - 2 meter band (144 MHz band) - United States 2 Meter FM Calling: 146.520 MHz FM. Often called "14652", "520", "52" or "National Calling"
  • 144-146 MHz band - 2 meter band (144 MHz band) - European 2 Meter FM Calling: 145.500 MHz FM
  • 222-225 MHz band - 1.25 meter band (222 MHz band) - United States 1.25 Meter SSB CW Calling: 222.100 MHz USB/CW
  • 222-225 MHz band - 1.25 meter band (222 MHz band) - United States 1.25 Meter FM Calling: 223.500 MHz FM
  • 420-450 MHz band - 70cm band (440 MHz band) - United States 70CM FM Calling: 446.000 MHz FM.
  • 902-928 MHz band - 33cm band (900 MHz band) - United States 33CM FM Calling: 902.500 MHz FM, 927.500 MHz FM and 906.500 MHz (906.5 MHz FM is the old 900 MHz FM calling frequency)
US band plan. ITU Region 2.
WORK IN PROGRESS
  • 2 meter band 144MHz band 144-148 MHz
  • 146.400 MHz
  • 146.415 MHz
  • 146.430 MHz
  • 146.445 MHz
  • 146.460 MHz
  • 146.475 MHx
