| Frequency (MHz) | Remarks/Restrictions on usage | |
| 25.020 MHz | Petroleum companies | |
| 25.040 MHz | Primarily available for oil spill containment and cleanup, other uses secondary | |
| 25.060 MHz | Petroleum exploration | |
| 25.080 MHz | Primarily available for oil spill containment and cleanup, other uses secondary | |
| 25.100 MHz | Petroleum companies | |
| 25.120 MHz | Secondary to HF marine mobile | |
| 25.140 MHz | Petroleum companies | |
| 25.160 MHz | ||
| 25.180 MHz | Petroleum companies | |
| 25.200 MHz | ||
| 25.220 MHz | Petroleum companies | |
| 25.240 MHz | ||
| 25.260 MHz | Petroleum companies | |
| 25.280 MHz | ||
| 25.300 MHz | Petroleum companies | |
| 25.320 MHz | ||
| 27.430 MHz | ||
| 27.450 MHz | ||
| 27.470 MHz | ||
| 27.490 MHz | Itinerant use only | |
| 27.510 MHz | Mobile use only, 2 watts maximum power | |
| 27.530 MHz | Mobile use only, 2 watts maximum power | |
| 29.710 MHz | ||
| 29.730 MHz | ||
| 29.750 MHz | ||
| 29.770 MHz | ||
| 29.790 MHz | ||
| 30.580 MHz | ||
| 30.600 MHz | ||
| 30.620 MHz | ||
| 30.640 MHz | ||
| 30.660 MHz | ||
| 30.680 MHz | ||
| 30.700 MHz | May be used for SCADA and other data/signaling purposes in addition to voice | |
| 30.720 MHz | ||
| 30.740 MHz | ||
| 30.760 MHz | ||
| 30.780 MHz | May be used for SCADA and other data/signaling purposes in addition to voice | |
| 30.800 MHz | ||
| 30.820 MHz | ||
| 30.840 MHz | Mobile use only, 2 watts maximum power | |
| 30.860 MHz | Shared with Public Safety | |
| 30.880 MHz | ||
| 30.900 MHz | Shared with Public Safety | |
| 30.920 MHz | ||
| 30.940 MHz | Shared with Public Safety | |
| 30.960 MHz | ||
| 30.980 MHz | Shared with Public Safety | |
| 31.000 MHz | ||
| 31.020 MHz | Shared with Public Safety | |
| 31.040 MHz | ||
| 31.060 MHz | Shared with Public Safety | |
| 31.080 MHz | ||
| 31.100 MHz | Shared with Public Safety | |
| 31.120 MHz | ||
| 31.140 MHz | Shared with Public Safety | |
| 31.160 MHz | ||
| 31.200 MHz | ||
| 31.240 MHz | ||
| 31.280 MHz | ||
| 31.320 MHz | ||
| 31.360 MHz | ||
| 31.400 MHz | ||
| 31.440 MHz | ||
| 31.480 MHz | ||
| 31.520 MHz | ||
| 31.560 MHz | ||
| 31.600 MHz | ||
| 31.640 MHz | ||
| 31.680 MHz | ||
| 31.720 MHz | ||
| 31.760 MHz | ||
| 31.800 MHz | ||
| 31.840 MHz | ||
| 31.880 MHz | ||
| 31.920 MHz | ||
| 31.960 MHz | ||
| 33.120 MHz | Mobile use only, 2 watts maximum power | |
| 33.140 MHz | Mobile use only, 2 watts maximum power | |
| 33.160 MHz | ||
| 33.180 MHz | Primarily assigned to petroleum companies | |
| 33.200 MHz | Primarily assigned to petroleum companies | |
| 33.220 MHz | Primarily assigned to petroleum companies | |
| 33.240 MHz | Primarily assigned to petroleum companies | |
| 33.260 MHz | Primarily assigned to petroleum companies | |
| 33.280 MHz | Primarily assigned to petroleum companies | |
| 33.300 MHz | Primarily assigned to petroleum companies | |
| 33.320 MHz | Primarily assigned to petroleum companies | |
| 33.340 MHz | Primarily assigned to petroleum companies | |
| 33.360 MHz | Primarily assigned to petroleum companies | |
| 33.380 MHz | Primarily assigned to petroleum companies | |
| 33.400 MHz | Mobile use only, 1 watt maximum power | |
| 35.020 MHz | Mobile use only, 2 watts maximum power, shared with Public Safety | |
| 35.040 MHz | Itinerant use only | |
| 35.060 MHz | ||
| 35.080 MHz | ||
| 35.100 MHz | ||
| 35.120 MHz | ||
| 35.160 MHz | ||
| 35.180 MHz | Shared with on-site paging | |
| 35.200 MHz | On site paging, wide area paging | |
| 35.220 MHz | On site paging, wide area paging | |
| 35.240 MHz | On site paging, wide area paging | |
| 35.260 MHz | On site paging, wide area paging | |
| 35.280 MHz | ||
| 35.300 MHz | On site paging, wide area paging | |
| 35.320 MHz | ||
| 35.340 MHz | On site paging, wide area paging | |
| 35.360 MHz | ||
| 35.380 MHz | On site paging, wide area paging | |
| 35.400 MHz | ||
| 35.420 MHz | On site paging, wide area paging | |
| 35.440 MHz | ||
| 35.460 MHz | On site paging, wide area paging | |
| 35.480 MHz | ||
| 35.500 MHz | On site paging, wide area paging | |
| 35.520 MHz | ||
| 35.540 MHz | On site paging, wide area paging | |
| 35.560 MHz | On site paging, wide area paging | |
| 35.580 MHz | On site paging, wide area paging | |
| 35.600 MHz | On site paging, wide area paging | |
| 35.620 MHz | On site paging, wide area paging | |
| 35.640 MHz | Paging only - may be used for on-site hospital paging | |
| 35.660 MHz | On site paging, wide area paging | |
| 35.680 MHz | On site paging, wide area paging | |
| 35.700 MHz | ||
| 35.720 MHz | ||
| 35.740 MHz | ||
| 35.760 MHz | ||
| 35.780 MHz | ||
| 35.820 MHz | ||
| 35.840 MHz | ||
| 35.860 MHz | ||
| 35.880 MHz | ||
| 35.900 MHz | ||
| 35.920 MHz | ||
| 35.940 MHz | ||
| 35.960 MHz | ||
| 35.980 MHz | ||
| 36.250 MHz | Oil companies, oil spill cleanup operations, shared with federal/military users, may be used as repeater input/output if paired with 41.71 MHz | |
| 37.440 MHz | ||
| 37.460 MHz | Water, power, sewage, etc. utilities | |
| 37.480 MHz | Water, power, sewage, etc. utilities | |
| 37.500 MHz | Water, power, sewage, etc. utilities | |
| 37.520 MHz | Water, power, sewage, etc. utilities | |
| 37.560 MHz | Water, power, sewage, etc. utilities | |
| 37.580 MHz | Water, power, sewage, etc. utilities | |
| 37.600 MHz | Designated for interconnection of public utility systems | |
| 37.620 MHz | Water, power, sewage, etc. utilities | |
| 37.640 MHz | Water, power, sewage, etc. utilities | |
| 37.660 MHz | Water, power, sewage, etc. utilities | |
| 37.680 MHz | Water, power, sewage, etc. utilities | |
| 37.700 MHz | Water, power, sewage, etc. utilities | |
| 37.720 MHz | Water, power, sewage, etc. utilities | |
| 37.760 MHz | Water, power, sewage, etc. utilities | |
| 37.780 MHz | Water, power, sewage, etc. utilities | |
| 37.800 MHz | Water, power, sewage, etc. utilities | |
| 37.820 MHz | Water, power, sewage, etc. utilities | |
| 37.840 MHz | Base, mobile or fixed (SCADA, etc.) | |
| 37.860 MHz | Water, power, sewage, etc. utilities | |
| 37.880 MHz | Water, power, sewage, etc. utilities | |
| 40.670 MHz | SNOTEL Weather Telemetry system (Nationwide, data bursts often heard during VHF low band openings) | |
| 41.710 MHz | Oil companies, oil spill cleanup operations, shared with federal/military users, may be used as repeater input/output if paired with 36.25 MHz | |
| 42.960 MHz | ||
| 42.980 MHz | Mobile use only, 2 watts maximum power | |
| 43.000 MHz | ||
| 43.020 MHz | ||
| 43.040 MHz | Itinerant use only | |
| 43.060 MHz | ||
| 43.080 MHz | ||
| 43.100 MHz | ||
| 43.120 MHz | ||
| 43.140 MHz | ||
| 43.160 MHz | Mobile use only | |
| 43.180 MHz | ||
| 43.200 MHz | ||
| 43.260 MHz | Old IMTS Mobile Channel ZO (paired with 35.26 MHz) | |
| 43.280 MHz | ||
| 43.300 MHz | Old IMTS Mobile Channel ZF (paired with 35.30 MHz) | |
| 43.320 MHz | ||
| 43.340 MHz | Old IMTS Mobile Channel ZH (paired with 35.34 MHz) | |
| 43.360 MHz | ||
| 43.380 MHz | Old IMTS Mobile Channel ZM (paired with 35.38 MHz) | |
| 43.400 MHz | ||
| 43.420 MHz | Old IMTS Mobile Channel ZA (paired with 35.42 MHz) | |
| 43.440 MHz | ||
| 43.460 MHz | Old IMTS Base Channel ZY (paired with 35.46 MHz) | |
| 43.480 MHz | ||
| 43.500 MHz | Old IMTS Mobile Channel ZY (paired with 35.50 MHz) | |
| 43.520 MHz | ||
| 43.540 MHz | Old IMTS Mobile Channel ZR (paired with 35.54 MHz) | |
| 43.560 MHz | Also used for paging - including on site paging | |
| 43.580 MHz | ||
| 43.600 MHz | ||
| 43.620 MHz | Old IMTS Mobile Channel ZW (paired with 35.62 MHz) | |
| 43.640 MHz | ||
| 43.660 MHz | Old IMTS Mobile Channel ZL (paired with 35.66 MHz) | |
| 43.680 MHz | ||
| 43.700 MHz | ||
| 43.720 MHz | shared with low power cordless phones (base - paired with 48.76 MHz) | |
| 43.740 MHz | shared with low power cordless phones (base - paired with 48.84 MHz) | |
| 43.760 MHz | ||
| 43.780 MHz | ||
| 43.800 MHz | ||
| 43.820 MHz | shared with low power cordless phones (base - paired with 48.86 MHz) | |
| 43.840 MHz | shared with low power cordless phones (base - paired with 48.92 MHz) | |
| 43.860 MHz | ||
| 43.880 MHz | ||
| 43.900 MHz | ||
| 43.920 MHz | shared with low power cordless phones (base - paired with 49.00 MHz) | |
| 43.940 MHz | ||
| 43.960 MHz | shared with low power cordless phones (base - paired with 49.08 MHz) | |
| 43.980 MHz | ||
| 44.000 MHz | ||
| 44.020 MHz | ||
| 44.040 MHz | ||
| 44.060 MHz | ||
| 44.080 MHz | ||
| 44.100 MHz | also used for meteor burst communications (Alaska only) | |
| 44.120 MHz | shared with low power cordless phones (base - paired with 49.10 MHz) | |
| 44.140 MHz | ||
| 44.160 MHz | shared with low power cordless phones (base - paired with 49.16 MHz) | |
| 44.180 MHz | shared with low power cordless phones (base - paired with 49.20 MHz) | |
| 44.200 MHz | shared with low power cordless phones (base - paired with 49.24 MHz) | |
| 44.220 MHz | ||
| 44.240 MHz | ||
| 44.260 MHz | ||
| 44.280 MHz | ||
| 44.300 MHz | ||
| 44.320 MHz | shared with low power cordless phones (base - paired with 49.28 MHz) | |
| 44.340 MHz | ||
| 44.360 MHz | shared with low power cordless phones (base - paired with 49.36 MHz) | |
| 44.380 MHz | ||
| 44.400 MHz | shared with low power cordless phones (base - paired with 49.40 MHz) | |
| 44.420 MHz | ||
| 44.440 MHz | ||
| 44.460 MHz | shared with low power cordless phones (base - paired with 49.48 MHz) | |
| 44.480 MHz | shared with low power cordless phones (base - paired with 49.50 MHz) | |
| 44.500 MHz | ||
| 44.520 MHz | ||
| 44.540 MHz | ||
| 44.560 MHz | ||
| 44.580 MHz | BNSF Railroad telemetry datalink system (good band opening indicator) | |
| 44.600 MHz | ||
| 47.440 MHz | ||
| 47.480 MHz | ||
| 47.520 MHz | ||
| 47.560 MHz | ||
| 47.600 MHz | ||
| 47.640 MHz | ||
| 47.680 MHz | ||
| 47.700 MHz | Water, power, sewage, etc. utilities | |
| 47.720 MHz | Water, power, sewage, etc. utilities | |
| 47.740 MHz | Water, power, sewage, etc. utilities | |
| 47.760 MHz | Water, power, sewage, etc. utilities | |
| 47.780 MHz | Water, power, sewage, etc. utilities | |
| 47.800 MHz | Water, power, sewage, etc. utilities | |
| 47.820 MHz | Water, power, sewage, etc. utilities | |
| 47.840 MHz | Water, power, sewage, etc. utilities | |
| 47.860 MHz | Water, power, sewage, etc. utilities | |
| 47.880 MHz | Water, power, sewage, etc. utilities | |
| 47.900 MHz | Water, power, sewage, etc. utilities | |
| 47.920 MHz | Water, power, sewage, etc. utilities | |
| 47.940 MHz | Water, power, sewage, etc. utilities | |
| 47.960 MHz | Water, power, sewage, etc. utilities | |
| 47.980 MHz | Water, power, sewage, etc. utilities | |
| 48.000 MHz | Water, power, sewage, etc. utilities | |
| 48.020 MHz | Water, power, sewage, etc. utilities | |
| 48.040 MHz | Water, power, sewage, etc. utilities | |
| 48.060 MHz | Water, power, sewage, etc. utilities | |
| 48.080 MHz | Water, power, sewage, etc. utilities | |
| 48.100 MHz | Water, power, sewage, etc. utilities | |
| 48.120 MHz | Water, power, sewage, etc. utilities | |
| 48.140 MHz | Water, power, sewage, etc. utilities | |
| 48.160 MHz | Water, power, sewage, etc. utilities | |
| 48.180 MHz | Water, power, sewage, etc. utilities | |
| 48.200 MHz | Water, power, sewage, etc. utilities | |
| 48.220 MHz | Water, power, sewage, etc. utilities | |
| 48.240 MHz | Water, power, sewage, etc. utilities | |
| 48.260 MHz | Water, power, sewage, etc. utilities | |
| 48.280 MHz | Water, power, sewage, etc. utilities | |
| 48.300 MHz | Water, power, sewage, etc. utilities | |
| 48.320 MHz | Water, power, sewage, etc. utilities | |
| 48.340 MHz | Water, power, sewage, etc. utilities | |
| 48.360 MHz | Water, power, sewage, etc. utilities | |
| 48.380 MHz | Water, power, sewage, etc. utilities | |
| 48.400 MHz | Water, power, sewage, etc. utilities | |
| 48.420 MHz | Water, power, sewage, etc. utilities | |
| 48.440 MHz | Water, power, sewage, etc. utilities | |
| 48.480 MHz | Water, power, sewage, etc. utilities | |
| 48.500 MHz | Water, power, sewage, etc. utilities | |
| 48.520 MHz | Water, power, sewage, etc. utilities | |
| 48.540 MHz | Water, power, sewage, etc. utilities | |
| 48.560 MHz | ||
| 48.580 MHz | ||
| 48.600 MHz | ||
| 48.620 MHz | ||
| 48.640 MHz | ||
| 48.660 MHz | ||
| 48.680 MHz | ||
| 48.700 MHz | ||
| 48.720 MHz | ||
| 48.740 MHz | ||
| 48.760 MHz | ||
| 48.780 MHz | ||
| 48.800 MHz | ||
| 48.820 MHz | ||
| 48.840 MHz | ||
| 48.860 MHz | ||
| 48.880 MHz | ||
| 48.900 MHz | ||
| 48.920 MHz | ||
| 48.940 MHz | ||
| 48.960 MHz | ||
| 48.980 MHz | ||
| 49.000 MHz | ||
| 49.020 MHz | ||
| 49.040 MHz | ||
| 49.060 MHz | ||
| 49.080 MHz | ||
| 49.100 MHz | ||
| 49.120 MHz | ||
| 49.140 MHz | ||
| 49.160 MHz | ||
| 49.180 MHz | ||
| 49.200 MHz | ||
| 49.220 MHz | ||
| 49.240 MHz | ||
| 49.260 MHz | ||
| 49.280 MHz | ||
| 49.300 MHz | ||
| 49.320 MHz | ||
| 49.340 MHz | ||
| 49.360 MHz | ||
| 49.380 MHz | ||
| 49.400 MHz | ||
| 49.420 MHz | ||
| 49.440 MHz | ||
| 49.460 MHz | ||
| 49.480 MHz | ||
| 49.500 MHz | ||
| 49.520 MHz | ||
| 49.540 MHz | ||
| 49.560 MHz | ||
| 49.580 MHz |
Special purpose use only. See section 90.205 (power limits), 90.257 and 90.241. The 72-76 MHz band is shared with 72/75 MHz remote control frequencies under Part 95, operational fixed stations in the maritime mobile service (marine radio service). It is also shared with very low power assisted listening audio transmitter Part 15 systems operating in the 72.0 MHz - 73.0 MHz, 74.6 MHz - 74.8 MHz and 75.2 MHz - 76.0 MHz bands per 47 CFR 15.237.
Part FCC Part 90.35, 72-76 MHz is not used for traditional land mobile purposes like the other bands are. 20K0F3D, 20K0F2D, 20K0F1D emissions are commonly found for fixed telemetry links. 20K0F3E regular 25 kHz FM voice emission is found for operational fixed links using voice and/or mixed voice/data. 1 watt power limit for "fixed stations". Note that fixed, base and mobile stations are all licensed as "mobile" stations even if they are fixed stations. Actual fixed stations are limited to 300 watts ERP.
This frequency is shared with the Radio Control (R/C) Service, of the part 95 Personal Radio Services, where it is used solely for the radio control of models.
| Frequency (MHz) |
| 72.020 MHz |
| 72.040 MHz |
| 72.060 MHz |
| 72.080 MHz |
| 72.100 MHz |
| 72.120 MHz |
| 72.140 MHz |
| 72.160 MHz |
| 72.180 MHz |
| 72.200 MHz |
| 72.220 MHz |
| 72.240 MHz |
| 72.260 MHz |
| 72.280 MHz |
| 72.300 MHz |
| 72.320 MHz |
| 72.340 MHz |
| 72.360 MHz |
| 72.380 MHz |
| 72.400 MHz |
| 72.420 MHz - operational fixed service |
| 72.460 MHz - operational fixed service |
| 72.500 MHz - operational fixed service |
| 72.540 MHz - operational fixed service |
| 72.580 MHz - operational fixed service |
| 72.620 MHz - operational fixed service |
| 72.640 MHz - operational fixed service |
| 72.660 MHz - operational fixed service |
| 72.680 MHz - operational fixed service |
| 72.700 MHz - operational fixed service |
| 72.720 MHz - operational fixed service |
| 72.740 MHz - operational fixed service |
| 72.760 MHz - operational fixed service |
| 72.780 MHz - operational fixed service |
| 72.800 MHz - operational fixed service |
| 72.820 MHz - operational fixed service |
| 72.840 MHz - operational fixed service |
| 72.860 MHz - operational fixed service |
| 72.880 MHz - operational fixed service |
| 72.900 MHz - operational fixed service |
| 72.920 MHz - operational fixed service |
| 72.940 MHz - operational fixed service |
| 72.960 MHz - operational fixed service |
| 72.980 MHz - operational fixed service |
| 75.420 MHz - operational fixed service |
| 75.460 MHz - operational fixed service |
| 75.500 MHz - operational fixed service |
| 75.540 MHz - operational fixed service |
| 75.580 MHz - operational fixed service |
| 75.620 MHz - operational fixed service |
| 75.640 MHz - operational fixed service |
| 75.660 MHz - operational fixed service |
| 75.680 MHz - operational fixed service |
| 75.700 MHz - operational fixed service |
| 75.720 MHz - operational fixed service |
| 75.740 MHz - operational fixed service |
| 75.760 MHz - operational fixed service |
| 75.780 MHz - operational fixed service |
| 75.800 MHz - operational fixed service |
| 75.820 MHz - operational fixed service |
| 75.840 MHz - operational fixed service |
| 75.860 MHz - operational fixed service |
| 75.880 MHz - operational fixed service |
| 75.900 MHz - operational fixed service |
| 75.920 MHz - operational fixed service |
| 75.940 MHz - operational fixed service |
| 75.960 MHz - operational fixed service |
| 75.980 MHz - operational fixed service |
| 150.8225 MHz | |
| 150.8375 MHz | |
| 152.4725 MHz | |
| 154.4825 MHz | |
| 154.490 MHz | |
| 154.4975 MHz | |
| 154.515 MHz | |
| 154.540 MHz | |
| 154.5475 MHz | |
| 157.7325 MHz | |
| 158.4525 MHz | |
| 158.460 MHz | |
| 173.2375 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.250 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.2625 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.275 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.2875 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.300 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.3125 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.325 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.3375 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.350 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.3625 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.390 MHz | |
UHF Band 406-413 MHz
- Group A1 - Simplex operations or paired operations. If the system uses a pair (5 MHz offset), the fixed station or base station operates on the low side (451 MHz, 452 MHz, 462 MHz) and the mobile / portable stations operate on the high side (456 MHz, 457 MHz, 467 MHz) as per UHF band plan. 20 watt ERP power limit for fixed stations / base stations. 6 watt ERP power limit for portable or mobile stations. Fixed station antennas may be up to 75 feet above the ground. Voice users are primary users, non-voice users are secondary. Single-frequency simplex systems are very common and may be found on the low or high side frequencies. Group A1 frequencies are only available for assignment within an 80 km radius (50 mile radius) of metropolitan areas.
- Group A2 - Simplex operations or paired operations. If the system uses a pair (5 MHz offset), the fixed station or base station operates on the low side (451 MHz, 452 MHz, 462 MHz) and the mobile / portable stations operate on the high side (456 MHz, 457 MHz, 467 MHz) as per UHF band plan. 20 watt ERP power limit for fixed stations / base stations. 6 watt ERP power limit for portable or mobile stations. Fixed station antennas may be up to 75 feet above the ground. Voice users are primary users, non-voice users are secondary. Single-frequency simplex systems are very common and may be found on the low or high side frequencies.
- Group B - Data and telemetry (including telecommand - remote control) are the primary users of these frequencies. Voice is permitted, but only on a secondary basis to non-voice uses. 6 watt ERP power limit for fixed stations, 2 watt ERP power limit for mobile and portable stations. Base stations (fixed stations) may be licensed as mobile stations. Fixed station antennas may be up to 20 feet above ground.
- Group C - Telemetry / data (non-voice) and voice systems, shared. 6 watt ERP power limit for fixed stations, 2 watt ERP power limit for mobile and portable stations. Fixed station antennas may be up to 20 feet above ground.
- Group D - Alarm system telemetry, wireless links back to central office control station. 2 watt power limit, antenna at the central alarm control station may be up to 20 feet above ground.
UHF Band 450-470 MHz Low Power Frequencies
- 451.18125 MHz
- 451.1875 MHz
- 451.19375 MHz
- 451.28125 MHz
- 451.2875 MHz
- 451.29375 MHz
- 451.30625 MHz
- 451.3125 MHz
- 451.31875 MHz
- 451.35625 MHz
- 451.3625 MHz
- 451.36875 MHz
- 451.38125 MHz
- 451.3875 MHz
- 451.39375 MHz
- 451.40625 MHz
- 451.41875 MHz
- 451.45625 MHz
- 451.4625 MHz
- 451.46875 MHz
- 451.48125 MHz
- 451.4875 MHz
- 451.49375 MHz
- 451.50625 MHz
- 451.5125 MHz
- 451.51875 MHz
- 451.55625 MHz
- 451.5625 MHz
- 451.56875 MHz
- 451.58125 MHz
- 451.5875 MHz
- 451.59375 MHz
- 451.60625 MHz
- 451.6125 MHz
- 451.61875 MHz
- 451.65625 MHz
- 451.6625 MHz
- 451.66875 MHz
- 451.68125 MHz
- 451.6875 MHz
- 451.69375 MHz
- 451.70625 MHz
- 451.7125 MHz
- 451.71875 MHz
- 451.73125 MHz
- 451.7375 MHz
- 451.74375 MHz
- 451.75625 MHz
- 451.7625 MHz
- 451.76875 MHz
- 452.03125 MHz
- 452.0375 MHz
- 452.04375 MHz
- 452.05625 MHz
- 452.0625 MHz
- 452.06875 MHz
- 452.08125 MHz
- 452.0875 MHz
- 452.09375 MHz
- 452.10625 MHz
- 452.1125 MHz
- 452.11875 MHz
- 452.13125 MHz
- 452.1375 MHz
- 452.14375 MHz
- 452.15625 MHz
- 452.1625 MHz
- 452.16875 MHz
- 452.18125 MHz
- 452.1875 MHz
- 452.19375 MHz
- 452.28125 MHz
- 452.2875 MHz
- 452.29375 MHz
- 452.48125 MHz
- 452.4875 MHz
- 452.49375 MHz
- 452.53125 MHz
- 452.5375 MHz
- 452.54375 MHz
- 452.63125 MHz
- 452.6375 MHz
- 452.64375 MHz
- 452.65625 MHz
- 452.6625 MHz
- 452.66875 MHz
- 452.68125 MHz
- 452.6875 MHz
- 452.69375 MHz
- 452.70625 MHz
- 452.7125 MHz
- 452.71875 MHz
- 452.78125 MHz
- 452.7875 MHz
- 452.79375 MHz
- 452.80625 MHz
- 452.8125 MHz
- 452.81875 MHz
- 452.83125 MHz
- 452.8375 MHz
- 452.84375 MHz
- 452.88125 MHz
- 452.8875 MHz
- 452.89375 MHz
- 452.98125 MHz
- 452.9875 MHz
- 452.99375 MHz
- 456.18125 MHz
- 456.1875 MHz
- 456.19375 MHz
- 456.28125 MHz
- 456.2875 MHz
- 456.29375 MHz
- 456.30625 MHz
- 456.3125 MHz
- 456.31875 MHz
- 456.35625 MHz
- 456.3625 MHz
- 456.36875 MHz
- 456.38125 MHz
- 456.3875 MHz
- 456.39375 MHz
- 456.40625 MHz
- 456.41875 MHz
- 456.45625 MHz
- 456.4625 MHz
- 456.46875 MHz
- 456.48125 MHz
- 456.4875 MHz
- 456.49375 MHz
- 456.50625 MHz
- 456.5125 MHz
- 456.51875 MHz
- 456.55625 MHz
- 456.5625 MHz
- 456.56875 MHz
- 456.58125 MHz
- 456.5875 MHz
- 456.59375 MHz
- 456.60625 MHz
- 456.6125 MHz
- 456.61875 MHz
- 456.65625 MHz
- 456.6625 MHz
- 456.66875 MHz
- 456.68125 MHz
- 456.6875 MHz
- 456.69375 MHz
- 456.70625 MHz
- 456.7125 MHz
- 456.71875 MHz
- 456.73125 MHz
- 456.7375 MHz
- 456.74375 MHz
- 456.75625 MHz
- 456.7625 MHz
- 456.76875 MHz
- 457.03125 MHz
- 457.0375 MHz
- 457.04375 MHz
- 457.05625 MHz
- 457.0625 MHz
- 457.06875 MHz
- 457.08125 MHz
- 457.0875 MHz
- 457.09375 MHz
- 457.10625 MHz
- 457.1125 MHz
- 457.11875 MHz
- 457.13125 MHz
- 457.1375 MHz
- 457.14375 MHz
- 457.15625 MHz
- 457.1625 MHz
- 457.16875 MHz
- 457.18125 MHz
- 457.1875 MHz
- 457.19375 MHz
- 457.28125 MHz
- 457.2875 MHz
- 457.29375 MHz
- 457.48125 MHz
- 457.4875 MHz
- 457.49375 MHz
- 457.63125 MHz
- 457.6375 MHz
- 457.64375 MHz
- 457.65625 MHz
- 457.6625 MHz
- 457.66875 MHz
- 457.68125 MHz
- 457.6875 MHz
- 457.69375 MHz
- 457.70625 MHz
- 457.7125 MHz
- 457.71875 MHz
- 457.78125 MHz
- 457.7875 MHz
- 457.79375 MHz
- 457.80625 MHz
- 457.8125 MHz
- 457.81875 MHz
- 457.83125 MHz
- 457.8375 MHz
- 457.84375 MHz
- 457.88125 MHz
- 457.8875 MHz
- 457.89375 MHz
- 457.98125 MHz
- 457.9875 MHz
- 457.99375 MHz
- 462.18125 MHz
- 462.1875 MHz
- 462.19375 MHz
- 462.45625 MHz
- 462.4625 MHz
- 462.46875 MHz
- 462.48125 MHz
- 462.4875 MHz
- 462.49375 MHz
- 462.50625 MHz
- 462.5125 MHz
- 462.51875 MHz
- 467.18125 MHz
- 467.1875 MHz
- 467.19375 MHz
- 467.45625 MHz
- 467.4625 MHz
- 467.46875 MHz
- 467.48125 MHz
- 467.4875 MHz
- 467.49375 MHz
- 467.50625 MHz
- 467.5125 MHz
- 467.51875 MHz
- 451.23125 MHz
- 451.2375 MHz
- 451.24375 MHz
- 451.33125 MHz
- 451.3375 MHz
- 451.34375 MHz
- 451.43125 MHz
- 451.4375 MHz
- 451.44375 MHz
- 451.53125 MHz
- 451.5375 MHz
- 451.54375 MHz
- 451.63125 MHz
- 451.6375 MHz
- 451.64375 MHz
- 452.30625 MHz
- 452.3125 MHz
- 452.31875 MHz
- 452.40625 MHz
- 452.4125 MHz
- 452.41875 MHz
- 452.50625 MHz
- 452.5125 MHz
- 452.51875 MHz
- 452.75625 MHz
- 452.7625 MHz
- 452.76875 MHz
- 452.85625 MHz
- 452.8625 MHz
- 452.86875 MHz
- 456.23125 MHz
- 456.2375 MHz
- 456.24375 MHz
- 456.33125 MHz
- 456.3375 MHz
- 456.34375 MHz
- 456.43125 MHz
- 456.4375 MHz
- 456.44375 MHz
- 456.53125 MHz
- 456.5375 MHz
- 456.54375 MHz
- 456.63125 MHz
- 456.6375 MHz
- 456.64375 MHz
- 457.30625 MHz
- 457.3125 MHz
- 457.31875 MHz
- 457.40625 MHz
- 457.4125 MHz
- 457.41875 MHz
- 457.50625 MHz
- 457.5125 MHz
- 457.51875 MHz
- 457.75625 MHz
- 457.7625 MHz
- 457.76875 MHz
- 457.85625 MHz
- 457.8625 MHz
- 457.86875 MHz
- 462.20625 MHz
- 462.2125 MHz
- 462.21875 MHz
- 462.23125 MHz
- 462.2375 MHz
- 462.24375 MHz
- 462.25625 MHz
- 462.2625 MHz
- 462.26875 MHz
- 462.28125 MHz
- 462.2875 MHz
- 462.29375 MHz
- 462.30625 MHz
- 462.3125 MHz
- 462.31875 MHz
- 462.33125 MHz
- 462.3375 MHz
- 462.34375 MHz
- 462.35625 MHz
- 462.3625 MHz
- 462.36875 MHz
- 462.38125 MHz
- 462.3875 MHz
- 462.39375 MHz
- 462.40625 MHz
- 462.4125 MHz
- 462.41875 MHz
- 462.43125 MHz
- 462.4375 MHz
- 462.44375 MHz
- 467.20625 MHz
- 467.2125 MHz
- 467.21875 MHz
- 467.23125 MHz
- 467.2375 MHz
- 467.24375 MHz
- 467.25625 MHz
- 467.2625 MHz
- 467.26875 MHz
- 467.28125 MHz
- 467.2875 MHz
- 467.29375 MHz
- 467.30625 MHz
- 467.3125 MHz
- 467.31875 MHz
- 467.33125 MHz
- 467.3375 MHz
- 467.34375 MHz
- 467.35625 MHz
- 467.3625 MHz
- 467.36875 MHz
- 467.38125 MHz
- 467.3875 MHz
- 467.39375 MHz
- 467.40625 MHz
- 467.4125 MHz
- 467.41875 MHz
- 467.43125 MHz
- 467.4375 MHz
- 467.44375 MHz
- 461.03125 MHz
- 461.0375 MHz
- 461.04375 MHz
- 461.05625 MHz
- 461.0625 MHz
- 461.06875 MHz
- 461.08125 MHz
- 461.0875 MHz
- 461.09375 MHz
- 461.10625 MHz
- 461.1125 MHz
- 461.11875 MHz
- 461.13125 MHz
- 461.1375 MHz
- 461.14375 MHz
- 461.15625 MHz
- 461.1625 MHz
- 461.16875 MHz
- 461.18125 MHz
- 461.1875 MHz
- 461.19375 MHz
- 461.20625 MHz
- 461.2125 MHz
- 461.21875 MHz
- 461.23125 MHz
- 461.2375 MHz
- 461.24375 MHz
- 461.25625 MHz
- 461.2625 MHz
- 461.26875 MHz
- 461.28125 MHz
- 461.2875 MHz
- 461.29375 MHz
- 461.30625 MHz
- 461.3125 MHz
- 461.31875 MHz
- 461.33125 MHz
- 461.3375 MHz
- 461.34375 MHz
- 461.35625 MHz
- 461.3625 MHz
- 461.36875 MHz
- 462.7625 MHz
- 462.7875 MHz
- 462.8125 MHz
- 462.8375 MHz
- 462.8625 MHz
- 462.8875 MHz
- 462.9125 MHz
- 464.4875 MHz
- 464.48125 MHz
- 464.5125 MHz
- 464.51875 MHz
- 464.53125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 464.56875 MHz
- 466.03125 MHz
- 466.0375 MHz
- 466.04375 MHz
- 466.05625 MHz
- 466.0625 MHz
- 466.06875 MHz
- 466.08125 MHz
- 466.0875 MHz
- 466.09375 MHz
- 466.10625 MHz
- 466.1125 MHz
- 466.11875 MHz
- 466.13125 MHz
- 466.1375 MHz
- 466.14375 MHz
- 466.15625 MHz
- 466.1625 MHz
- 466.16875 MHz
- 466.18125 MHz
- 466.1875 MHz
- 466.19375 MHz
- 466.20625 MHz
- 466.2125 MHz
- 466.21875 MHz
- 466.23125 MHz
- 466.2375 MHz
- 466.24375 MHz
- 466.25625 MHz
- 466.2625 MHz
- 466.26875 MHz
- 466.28125 MHz
- 466.2875 MHz
- 466.29375 MHz
- 466.30625 MHz
- 466.3125 MHz
- 466.31875 MHz
- 466.33125 MHz
- 466.3375 MHz
- 466.34375 MHz
- 466.35625 MHz
- 466.3625 MHz
- 466.36875 MHz
- 467.8625 MHz
- 467.8875 MHz
- 467.9125 MHz
- 469.4875 MHz
- 469.48125 MHz
- 469.5125 MHz
- 469.51875 MHz
- 469.53125 MHz
- 469.5375 MHz
- 469.5625 MHz
- 469.56875 MHz
- 460.90625 MHz
- 460.9125 MHz
- 460.91875 MHz
- 460.93125 MHz
- 460.9375 MHz
- 460.94375 MHz
- 460.95625 MHz
- 460.9625 MHz
- 460.96875 MHz
- 460.98125 MHz
- 460.9875 MHz
- 460.99375 MHz
- 461.00625 MHz
- 461.0125 MHz
- 461.01875 MHz
- 465.90625 MHz
- 465.9125 MHz
- 465.91875 MHz
- 465.93125 MHz
- 465.9375 MHz
- 465.94375 MHz
- 465.95625 MHz
- 465.9625 MHz
- 465.96875 MHz
- 465.98125 MHz
- 465.9875 MHz
- 465.99375 MHz
- 466.00625 MHz
- 466.0125 MHz
- 466.01875 MHz
- one set of 68 channel pairs
- 160 available channel pairs
- 22 available channel pairs
| 902-928 MHz | 900 MHz ISM, Part 15 and ham radio band, subject to restrictions of this band, on-site 900 MHz ISM FHSS radios 1 watt power output |
Common Itinerant and Low Power Business Frequencies - Official Itinerant Business Frequencies List
This is the official list.
Unless otherwise specified, all itinerant frequencies are simplex only. Some frequencies may be used as part of a portable repeater or temporary repeater (station class FB2I), however, those frequencies may also be used for simplex operations. See the unofficial list for lowband VHF, the regular VHF band or VHF high band and UHF band.
- 151.5125 MHz - Itinerant
- 158.4000 MHz - Itinerant
- 158.4075 MHz - Itinerant
- 457.5125 MHz - Itinerant, simplex
- 457.5250 MHz - Itinerant, simplex
- 457.5375 MHz - Itinerant, simplex
- 457.5500 MHz - Itinerant, simplex
- 457.5625 MHz - Itinerant, simplex
- 457.5750 MHz - Itinerant, simplex
- 461.0375 MHz - Itinerant, simplex
- 461.0625 MHz - Itinerant, simplex
- 461.0875 MHz - Itinerant, simplex
- 461.1125 MHz - Itinerant, simplex
- 461.1375 MHz - Itinerant, simplex
- 461.1625 MHz - Itinerant, simplex
- 461.1875 MHz - Itinerant, simplex
- 461.2125 MHz - Itinerant, simplex
- 461.2375 MHz - Itinerant, simplex
- 461.2625 MHz - Itinerant, simplex
- 461.2875 MHz - Itinerant, simplex
- 461.3125 MHz - Itinerant, simplex
- 461.3375 MHz - Itinerant, simplex
- 461.3625 MHz - Itinerant, simplex
- 462.1625 MHz - Itinerant, simplex
- 462.1875 MHz - Itinerant, simplex
- 462.4625 MHz - Itinerant, simplex
- 462.4875 MHz - Itinerant, simplex
- 462.5125 MHz - Itinerant, simplex
- 462.7625 MHz - Itinerant, simplex
- 462.7875 MHz - Itinerant, simplex
- 462.8125 MHz - Itinerant, simplex
- 462.8375 MHz - Itinerant, simplex
- 462.8625 MHz - Itinerant, simplex
- 462.8875 MHz - Itinerant, simplex
- 462.9125 MHz - Itinerant, simplex
- 466.0375 MHz - Itinerant, simplex
- 466.0625 MHz - Itinerant, simplex
- 466.0875 MHz - Itinerant, simplex
- 466.1125 MHz - Itinerant, simplex
- 466.1375 MHz - Itinerant, simplex
- 466.1625 MHz - Itinerant, simplex
- 466.1875 MHz - Itinerant, simplex
- 466.2125 MHz - Itinerant, simplex
- 466.2375 MHz - Itinerant, simplex
- 466.2625 MHz - Itinerant, simplex
- 466.2875 MHz - Itinerant, simplex
- 466.3125 MHz - Itinerant, simplex
- 466.3375 MHz - Itinerant, simplex
- 466.3625 MHz - Itinerant, simplex
- 467.1625 MHz - Itinerant, simplex
- 467.1875 MHz - Itinerant, simplex
- 467.4625 MHz - Itinerant, simplex
- 467.4875 MHz - Itinerant, simplex
- 467.5125 MHz - Itinerant, simplex
- 467.7500 MHz - Itinerant, simplex - also used for short range on site paging
- 467.7625 MHz - Itinerant, simplex
- 467.7750 MHz - Itinerant, simplex
- 467.7875 MHz - Itinerant, simplex
- 467.8000 MHz - Itinerant, simplex
- 467.8125 MHz - Itinerant, simplex
- 467.8250 MHz - Itinerant, simplex
- 467.8375 MHz - Itinerant, simplex
- 467.8500 MHz - Itinerant, simplex
- 467.8625 MHz - Itinerant, simplex
- 467.8750 MHz - Itinerant, simplex
- 467.8875 MHz - Itinerant, simplex
- 467.9000 MHz - Itinerant, simplex
- 467.9125 MHz - Itinerant, simplex
- 467.9250 MHz - Itinerant, simplex
Common Itinerant and Low Power Business Frequencies - Low Power, "de facto itinerant" and Itinerant Frequencies List - VHF Low Band
- 27.5100 MHz - Low Power
- 27.5300 MHz - Low Power
- 33.4000 MHz - Low Power
- 35.0200 MHz - Low Power
- 42.9800 MHz - Low Power
Common Itinerant and Low Power Business Frequencies - Low Power, "de facto itinerant" and Itinerant Frequencies List - VHF High Band
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8050 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz - Purple Dot
- 152.8850 MHz
- 152.9000 MHz
- 152.9150 MHz
- 152.9450 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- 154.5475 MHz
Common Itinerant and Low Power Business Frequencies - Low Power, "de facto itinerant" and Itinerant Frequencies List - UHF Band
Including unlicensed use because the frequencies are the factory default out of the box frequencies for radios somebody bought on Amazon.
- 450.0000 MHz - Unlicensed use, CSQ, 67.0 Hz, 69.3 Hz, 82.5 Hz, 88.5 Hz and 100.0 Hz PL tones reported
- 450.0750 MHz - Unlicensed use, CSQ logged
- 450.2250 MHz - Unlicensed use, 023 DPL D023N logged (likely BF-888S Baofeng type handhelds)
- 450.4500 MHz - Unlicensed use
- 450.5000 MHz - Short range inter squad radio / intra squad radio use
- 451.1875 MHz
- 451.2375 MHz
- 451.2875 MHz
- 451.3125 MHz
- 451.3375 MHz
- 451.3625 MHz
- 451.3875 MHz
- 451.4375 MHz
- 451.4625 MHz
- 451.4875 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5625 MHz
- 451.5875 MHz
- 451.6125 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 451.7125 MHz
- 451.7375 MHz
- 451.7625 MHz
- 452.0375 MHz
- 452.0625 MHz
- 452.0875 MHz
- 452.1125 MHz
- 452.1375 MHz
- 452.1625 MHz
- 452.1875 MHz
- 452.2875 MHz
- 452.3125 MHz
- 452.4125 MHz
- 452.4875 MHz
- 452.5125 MHz
- 452.5375 MHz
- 452.6375 MHz
- 452.6625 MHz
- 452.6875 MHz
- 452.7125 MHz
- 452.7625 MHz
- 452.7875 MHz
- 452.8125 MHz
- 452.8375 MHz
- 452.8625 MHz
- 452.8875 MHz
- 452.9875 MHz
- 456.1875 MHz
- 456.2375 MHz
- 456.2875 MHz
- 456.3125 MHz
- 456.3375 MHz
- 456.3625 MHz
- 456.3875 MHz
- 456.4375 MHz
- 456.4625 MHz
- 456.4875 MHz
- 456.5125 MHz
- 456.5375 MHz
- 456.5625 MHz
- 456.5875 MHz
- 456.6125 MHz
- 456.6375 MHz
- 456.6625 MHz
- 456.6875 MHz
- 456.7125 MHz
- 456.7375 MHz
- 456.7625 MHz
- 457.0375 MHz
- 457.0625 MHz
- 457.0875 MHz
- 457.1125 MHz
- 457.1375 MHz
- 457.1625 MHz
- 457.1875 MHz
- 457.2875 MHz
- 457.3125 MHz
- 457.4125 MHz
- 457.4875 MHz
- 457.5125 MHz
- 457.6375 MHz
- 457.6625 MHz
- 457.7125 MHz
- 457.7375 MHz
- 457.7625 MHz
- 457.7875 MHz
- 457.8125 MHz
- 457.8375 MHz
- 457.8625 MHz
- 457.8875 MHz
- 457.9875 MHz
- 461.0375 MHz
- 461.0625 MHz
- 461.0875 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.1625 MHz
- 461.1875 MHz
- 461.2125 MHz
- 461.2375 MHz
- 461.2625 MHz
- 461.2875 MHz
- 461.3125 MHz
- 461.3375 MHz
- 461.3625 MHz
- 462.1875 MHz
- 462.4625 MHz
- 462.4875 MHz
- 462.5125 MHz
- 466.0375 MHz
- 466.0625 MHz
- 466.0875 MHz
- 466.1125 MHz
- 466.1375 MHz
- 466.1625 MHz
- 466.1875 MHz
- 466.2125 MHz
- 466.2375 MHz
- 466.2625 MHz
- 466.2875 MHz
- 466.3125 MHz
- 466.3375 MHz
- 466.3625 MHz
- 467.1875 MHz
- 467.4625 MHz
- 467.4875 MHz
- 467.5125 MHz
- 467.7875 MHz - 2 watts
- 467.8375 MHz - 2 watts
- 467.8875 MHz - 2 watts
- 467.9125 MHz - 2 watts
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3375 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.5875 MHz
- 468.6125 MHz
- 468.6375 MHz
- 468.6625 MHz
- 464.5500 MHz
- 464.5000 MHz
- 467.9250 MHz
- 467.9000 MHz
- 467.8750 MHz
- 467.8500 MHz
- 469.5500 MHz
- 469.5000 MHz
- 461.0375 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.2375 MHz
- 467.8125 MHz
- 467.7625 MHz
- 451.8000 MHz
- 456.8000 MHz
- 451.8125 MHz
- 456.8125 MHz
- 151.6250 MHz
- 154.5700 MHz
- 154.6000 MHz
- 151.9550 MHz
- 151.5125 MHz
- 151.5050 MHz
- 151.7000 MHz
- 151.7600 MHz
- 151.8200 MHz
- 151.9400 MHz
- 151.8800 MHz
- 151.9250 MHz
- 151.8050 MHz
- 158.4000 MHz
- 158.4075 MHz
- 151.6550 MHz
- 151.8650 MHz
- 152.9000 MHz
This now has its own page here: Factory default channel frequencies plans list programming.
*Academy Sports and Outdoors
- 467.8750 MHz - 265 DPL
- 467.9000 MHz - 265 DPL
*Ace Hardware
- 464.5000 MHz - 67.0 Hz PL
- 464.5500 MHz - 67.0 Hz PL
- 467.9000 MHz - 85.4 Hz PL
*American Eagle
- 461.0625 MHz - 67.0 Hz PL
- 461.3625 MHz - 67.0 Hz PL
- 466.3375 MHz - 67.0 Hz PL
- 467.7625 MHz - 67.0 Hz PL
- 467.8500 MHz - 67.0 Hz PL
- 467.8750 MHz - 67.0 Hz PL
- 469.5625 MHz - 67.0 Hz PL
*Ann Taylor
Nationwide license WQKL423
- 464.5625 MHz - 94.8 Hz PL
- 466.0375 MHz - 94.8 Hz PL - Ann Taylor LOFT
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
*Anthropologie
- 467.8750 MHz 192.8 Hz PL
*Apple
The Apple Store
- 461.1875 MHz - 67.0 Hz PL
- 461.1875 MHz - 85.4 Hz PL
- 462.8625 MHz - 167.9 Hz PL
- 467.8500 MHz - 79.7 Hz PL
- 467.8750 MHz - 85.4 Hz PL
- 467.9000 MHz - 67.0 Hz PL
- 467.9000 MHz - 71.9 Hz PL
- 467.9000 MHz - 203.5 Hz PL
- 467.9250 MHz - 156.7 Hz PL
*Ashley Home Store
- 462.8125 MHz 67.0 Hz PL
- 462.8375 MHz 67.0 Hz PL
- 462.8625 MHz 67.0 Hz PL
- 462.8875 MHz 67.0 Hz PL
*Bath and Body Works
- 461.0625 MHz D632 632 DPL
- 461.1125 MHz 67.0 Hz PL
- 461.1625 MHz 67.0 Hz PL
- 467.9000 MHz D632 632 DPL
*Bass Pro
- 451.5875 MHz 073 DPL
- 464.5000 MHz 466 DPL
- 468.9375 MHz 703 DPL
- 469.6000 MHz 606 DPL
- 469.8875 MHz 703 DPL
- 461.0375 MHz 445 DPL
- 467.7625 MHz 743 DPL
- 467.9000 MHz 743 DPL
*BJ's Wholesale Club
- 469.4875 MHz - 413 DPL
*Buffalo Wild Wings
*CarMax
- 462.5750 MHz - 026 DPL
- 462.6250 MHz - 127.3 Hz PL
- 462.6250 MHz - 026 DPL
- 462.6750 MHz - 071 DPL
- 462.6750 MHz - 606 DPL
- 462.7250 MHz - 136.5 Hz PL
- 462.7250 MHz - 026 DPL
- 464.3250 MHz - 026 DPL
- 464.5000 MHz - 023 DPL
- 464.5000 MHz - 026 DPL
- 464.5500 MHz - 026 DPL
- 464.8250 MHz - 026 DPL
- 467.8500 MHz - 071 DPL
- 467.8750 MHz - 026 DPL
- 467.8750 MHz - 071 DPL
- 467.9250 MHz - 071 DPL
- 469.5625 MHz - 026 DPL
*Chick-Fil-A
- 462.5500 MHz - 127.3 Hz PL
- 462.5625 MHz - 67.0 Hz PL
- 462.5750 MHz - 654 DPL
- 462.5875 MHz - 118.8 Hz PL
- 462.5875 MHz - 026 DPL
- 462.6000 MHz - 455 DPL
- 462.6125 MHz - 127.3 Hz PL
- 462.6375 MHz - 131.8 Hz PL
- 462.6500 MHz - 351 DPL
- 462.6625 MHz - 88.5 Hz PL
- 462.6625 MHz - 136.5 Hz PL
- 462.6875 MHz - 141.3 Hz PL
- 462.7000 MHz - 192.8 Hz PL
- 462.7000 MHz - 155 DPL
- 462.7125 MHz - 146.2 Hz PL
- 462.7250 MHz - 252 DPL
- 462.7250 MHz - 462 DPL
- 467.5625 MHz - 243 DPL
- 467.5875 MHz - 032 DPL
- 467.6125 MHz - 047 DPL
- 467.6375 MHz - 051 DPL
- 467.6625 MHz - 053 DPL
- 467.6875 MHz - 065 DPL
- 467.7125 MHz - 116 DPL
*Costco
- 462.5500 MHz - 123.0 Hz PL
- 462.6000 MHz - 241.8 Hz PL
- 462.7250 MHz - 250.3 Hz PL
- VHF:
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz
- 151.9850 MHz
- 152.8850 MHz
- 152.9150 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- UHF - license WQLL302, 2w portables narrow FM voice 11K2F3E emission 67.0 Hz PL and 74.4 Hz PL noted in use on these frequencies. 67.0 Hz use confirmed on 468.2125 MHz, 468.3125 MHz.
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.6125 MHz
- 468.6625 MHz
- 451.4125 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5875 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 452.7625 MHz
- 456.4125 MHz
- 456.5125 MHz
- 456.6125 MHz
- 456.6875 MHz
- 457.7625 MHz
- 467.7625 MHz
- 467.8125 MHz
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
- 467.8500 MHz Channel 1
- 467.8750 MHz Channel 2
- 467.9000 MHz Channel 3
- 467.9250 MHz Channel 4
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.6125 MHz
- 468.6625 MHz - 127.3 Hz PL
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
*DSW
- 450.0000 MHz - 82.5 Hz PL
- 450.0000 MHz - 88.5 Hz PL
- 456.8250 MHz - 127.3 Hz PL
- 457.5750 MHz - 107.2 Hz PL
- 461.0375 MHz - 023 DPL
- 461.1125 MHz - 025 DPL
- 462.4250 MHz - 103.5 Hz PL
- 462.5250 MHz - 114.8 Hz PL
- 462.8250 MHz - 162.2 Hz PL
- 462.9250 MHz - 025 DPL
- 464.3250 MHz - 023 DPL
- 466.0875 MHz - 464 DPL
- 467.8375 MHz - 88.5 Hz PL
- 467.9000 MHz - 145 DPL
- 469.5000 MHz - 023 DPL
*Fresh Market
There appears to be significant variation in the frequencies and/or tones used, depending on local conditions, other nearby stores using the same frequency and/or PL/DPL tone/code.
- 464.5500 MHz - 77.0 Hz PL
- 467.8500 MHz - 88.5 Hz PL
- 467.9250 MHz - 100.0 Hz PL
- 467.7625 MHz - 205 DPL
- 467.8125 MHz - 205 DPL
- 467.8500 MHz - 205 DPL
- 467.9250 MHz - 205 DPL
*Giant Foods
- 467.8500 MHz - 412 DPL
- 467.9000 MHz - 412 DPL
*H & M
- 450.2250 MHz - 023 DPL
- 466.2875 MHz - 155 DPL
- 467.1375 MHz - 155 DPL
- 468.8375 MHz - 155 DPL
- 469.0000 MHz - 103.5 Hz PL
- 469.7625 MHz - 155 DPL
- 469.9500 MHz - 203.5 Hz PL
- 467.7625 MHz - 107.2 Hz PL
- 467.8125 MHz - 346 DPL
- 467.8500 MHz - 343 DPL
- 467.8500 MHz - 411 DPL
- 467.8500 MHz - 631 DPL
- 467.8750 MHz - 343 DPL
- 467.8750 MHz - 411 DPL
- 467.9000 MHz - 343 DPL
- 467.9000 MHz - 346 DPL
- 467.9250 MHz - 67.0 Hz PL
- 467.9250 MHz - 85.4 Hz PL
- 467.9250 MHz - 88.5 Hz PL
- 467.9250 MHz - 343 DPL
*Hard Rock Cafe
- 462.8875 MHz - 205 DPL
- 467.8375 MHz - 205 DPL
- 467.8500 MHz 146.2 Hz PL
- 458.6625 MHz 186.2 Hz PL
- 464.5000 MHz 186.2 Hz PL
- 464.5500 MHz 186.2 Hz PL
- 469.2625 MHz 186.2 Hz PL
- 469.5000 MHz 186.2 Hz PL
- 469.5500 MHz 186.2 Hz PL
- Nationwide UHF on-site channel plan below. FRS frequencies are in use at numerous stores. Some stores use different CTCSS (PL) tones and/or different DCS (DPL) codes.
*Home Goods
- 467.8750 MHz 100.0 Hz PL
- 469.4875 MHz 210.7 Hz PL
*JC Penny
- 467.2250 MHz 365 DPL - Nationwide Channel 1 (simplex)
- 461.1750 MHz
- 461.5875 MHz
- 461.7125 MHz
- 461.8375 MHz
- 461.9375 MHz 732 DPL / 732 DCS
- 463.6375 MHz 179.9 Hz PL
- 463.7250 MHz 85.4 Hz PL
- 464.7375 MHz 179.9 Hz PL
- 466.2625 MHz 85.4 Hz PL
- 466.9625 MHz 85.4 Hz PL
- 468.7250 MHz 85.4 Hz PL
- 467.8750 MHz - 100.0 Hz PL
- 467.9000 MHz - 100.0 Hz PL
*Loft
- 151.6250 MHz - 110.9 Hz PL
- 151.8200 MHz - 110.9 Hz PL
- 151.8800 MHz - 110.9 Hz PL
- 151.9400 MHz - 110.9 Hz PL
- 151.9550 MHz - 110.9 Hz PL
- 154.4900 MHz - 110.9 Hz PL
- 154.5700 MHz - 110.9 Hz PL
- 154.6000 MHz - 110.9 Hz PL
- 461.0375 MHz
- 461.1125 MHz
- 461.2125 MHz
- 462.7625 MHz
- 462.8125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 466.0375 MHz
- 466.1125 MHz
- 466.1375 MHz
- 469.4875 MHz
- 469.5375 MHz
*Marshall's
- 461.2375 MHz 100.0 Hz
*Northern Tool + Equipment
- 462.5500 MHz 71.9 Hz
- 462.5500 MHz 123.0 Hz
- 462.6000 MHz 241.8 Hz
- 462.6250 MHz 127.3 Hz
- 462.6500 MHz 218.1 Hz
- 462.7000 MHz 118.8 Hz
- 462.7000 MHz 192.8 Hz
- 467.8750 MHz - 131 DPL
- 467.9000 MHz - 131 DPL
*Party City
- 467.8125 MHz - 67.0 Hz PL
- 464.5000 MHz - 162.2 Hz PL
- 464.5500 MHz - 162.2 Hz PL
*PetCo
Nationwide license WQKY366
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
*Pottery Barn
- 467.8750 MHz - 165 DPL
- 151.625 MHz - 97.4 Hz PL
- 151.700 MHz - 71.9 Hz PL
- 151.700 MHz - 79.7 Hz PL
*Regal Cinemas
- 464.3250 MHz - 100.0 Hz PL
- 464.8250 MHz - 100.0 Hz PL
- 464.8750 MHz - 100.0 Hz PL
*Sears
- 461.1625 MHz - 413 DPL
- 464.5250 MHz - 131.8 Hz PL
- 464.5500 MHz - 118.8 Hz PL
- 468.4875 MHz - 103.5 Hz PL
*Sephora
- 461.1125 MHz - 412 DPL
- 461.2125 MHz - 412 DPL
- 461.3125 MHz - 412 DPL
- 464.5000 MHz - 413 DPL
- 464.5500 MHz - 413 DPL
- 467.8500 MHz - 225.7 Hz PL
- 467.8500 MHz - D047 047 DPL
- 467.8500 MHz - D306 306 DPL
- 467.8500 MHz - D331 331 DPL
- 467.9000 MHz - 225.7 Hz PL - Primary nationwide frequency and tone
- 467.9250 MHz - 225.7 Hz PL
- 467.7500 MHz D115 115 DPL - Channel 1
- 467.7750 MHz D072 072 DPL - Channel 2
- 467.9000 MHz D115 115 DPL - Channel 3
- 467.4875 MHz D072 072 DPL - Channel 4
- 467.5125 MHz D115 115 DPL - Channel 5
- 151.6250 MHz 179.9 Hz PL
- 151.9550 MHz 179.9 Hz PL
- 151.9250 MHz 506 DPL
- 151.8950 MHz 506 DPL
*Texas Roadhouse
- 464.5500 MHz 67.0 Hz PL
- 467.8500 MHz 67.0 Hz PL
- 467.8750 MHz 67.0 Hz PL
- 467.9250 MHz 67.0 Hz PL
- 467.7625 MHz 71.9 Hz PL
- 467.8500 MHz D047 047 DPL - Old Navy - Appears to be primary UHF
- 467.9250 MHz D311 311 DPL
*TJ Maxx
- 467.8500 MHz 100.0 Hz PL
- 469.4875 MHz 210.7 Hz PL - shared with Home Goods (same parent company - TJX Companies, see also: Marshall's)
*Tractor Supply
- 450.2250 MHz 023 DPL
*Urban Outfitters
- 467.9250 MHz 218.1 Hz PL
*Victoria’s Secret
- 467.7625 MHz - 743 DPL
- 467.8125 MHz - 743 DPL
- 467.8500 MHz - 743 DPL
- 467.9000 MHz - 743 DPL
- 467.9250 MHz - 743 DPL - Possible Primary
- 469.4875 MHz - 743 DPL
- 469.5375 MHz - 743 DPL - Possible Secondary / Alternate
- 151.5050 MHz
- 151.6250 MHz
- 151.7000 MHz
- 151.8200 MHz - 413 DPL
- 151.8800 MHz
- 151.9250 MHz
- 151.9400 MHz - 174 DPL
- 151.9550 MHz
- 154.5700 MHz - 413 DPL
- 154.6000 MHz - 074 DPL, 174 DPL, 413 DPL
- 158.4000 MHz - 174 DPL
- 451.8000 MHz
- 451.8125 MHz - 306 DPL, 506 DPL, 612 DPL, 654 DPL, 664 DPL
- 456.8125 MHz - 506 DPL, 662 DPL
- 074 DPL, 174 DPL, 306 DPL, 413 DPL, 423 DPL, 432 DPL, 445 DPL, 506 DPL, 612 DPL, 654 DPL, and 664 DPL reported, others likely in use. WAWA was licensed under callsign WQQU922 for:
- 154.5700 MHz - Primary
- 154.6000 MHz - Primary
- 151.8200 MHz
- 151.8800 MHz
- 151.9400 MHz
- 151.6250 MHz
- 151.7600 MHz
- 151.7750 MHz
- 151.8200 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.9550 MHz
- 461.0375 MHz 172 DPL
- 461.0875 MHz 223 DPL
- 461.1125 MHz 172 DPL
- 461.1875 MHz 172 DPL
- 461.3625 MHz 172 DPL
- 464.5000 MHz 172 DPL
- 464.5500 MHz 172 DPL
- 464.5500 MHz 223 DPL
- 469.5000 MHz 172 DPL
- 469.5500 MHz 172 DPL
- 469.5500 MHz 223 DPL
*Whole Foods
- 464.5000 MHz 67.0 Hz PL
- 464.5000 MHz 97.4 Hz PL
- 464.5500 MHz 466 DPL / 466 DCS
- 467.8500 MHz 351 DPL / 351 DCS
- 467.9000 MHz 67.0 Hz PL
- 467.9250 MHz 74.4 Hz PL
- 467.9250 MHz 351 DPL / 351 DCS
