Letter beacon
Revision as of 21:05, 15 June 2011 by Strange Attractor (Talk | contribs)
Letter Beacon D on 5153.7 kHz
  • Cluster beacons
Location of letter beacons
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (defunct)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
Cluster beacons
F +0.2 7039.2, 10872.2, 16332.2
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier. (20)
R (20) 4325.9, 5465.9
C RIW 8000
L inactive
W inactive
FSK beacons
K 9043
U
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
Similar systems
On September 7, 2010 a beacon was heard on 9111.7 kHz at 1546 UTC. It sent a slow marker "A", which did not sound like a Russian beacon (MX). It sounded like somebody was playing with the key sending letters "A" and "M". Transmission lasted untill at least 1630 UTC. (19)
Notes & References
  1. ENIGMA stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
  2. ENIGMA2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
  4. Spooks mailing list.
  10. William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
WP
