Letter beacon
Revision as of 19:39, 17 November 2011 by Strange Attractor (Talk | contribs)
Letter Beacon D on 5153.7 kHz
  • "Letter beacons"
  • SLHFB, or "Single Letter High Frequency Beacons", the original SPEEDX designation.
  • Cluster beacons
  • MX — an ENIGMA (1) and ENIGMA-2000 (2) designation.
History
Location of letter beacons
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
The ENIGMA group also accepted these locations for cluster beacons "C", "D", "P" and "S", adding Vladivostok for beacon "F". (7) A recent source (2006) regarding locations was published on the Web by Ary Boender.(8) (24) This publication also contains an extensive list of frequencies of letter beacons, both current and historical. The following locations are stated for cluster beacons:
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
L Unknown, appeared on July 1, 2011
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (defunct)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
Cluster beacons
L (21) -0.8 7038.2, 7041.8(23), 8494.2, 8497.9
P -0.2 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 10872.8 (21), 13527.8,
16331.8, 20047.8
F +0.2 7039.2, 10872.2, 16332.2
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier. (20)
R (20) 4325.9, 5465.9
C RIW 8000
L inactive
W inactive
FSK beacons
K 9043
U
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
Similar systems
Notes & References
  1. ENIGMA stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
  2. ENIGMA2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
  3. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, page K1.
  4. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, pages K7-K10.
  5. Schimmel, D.W.: "The underground frequency guide", HighText Publications, Inc., ISBN 1-878707-17-5, 1994, pages 78–83.
  21. Cluster beacon "L" appeared on 7038.2 and 8494.2 kHz and was was first reported by the VERON Intruder Watch on June 29, 2011 at 1800 UTC. "L" was also active throughout July 2011. The first thoughts were that "L" transmitted from St Petersburg but so far there is no evidence to support this. It moved on July 23, 2011 to 7041.6 and 8497.9 kHz and again on July 24, 2011 to 7041.8 and 8497.8 kHz. (Ary Boender: "Number and Oddities", issue 166, pp.7). Cluster beacon "L" is not the solitary letter beacon "L" that transmitted in the past from Tirana, Albania, given that Albania is now a member of NATO. At the same time, the 10 MHz "P" beacon moved 1 kHz up, from 10871.8 to 10872.8 kHz.
  22. "SLHFB (Single letter high frequency beacons)", The SPEEDX reference guide to the Utilities, SPEEDX, 1984, page=K2.
  23. IARU R1 monitoring system: "Intruder News from: July 28th 2011"
  24. A couple of years ago I had the chance to speak to a Russian naval radio operator who works on a Russian frigate. He confirmed to me that the channel markers are military stations, mostly used by the navy. His English was poor so I could not ask for more detailed info, and as I don't speak Russian, you can imagine that it was a really nice conversation. I had to write down the morse characters of the call signs of the stations and he told me the locations. It was really fun, believe me :-) A couple of the markers that he mentioned have now disappeared but still exist as cluster beacons. The radio operator identified 'L' as St.Petersburg, 'P' as Kaliningrad (HQ of the Baltic Fleet), 'S' as Arkhangelsk and 'C' as Moscow (naval HQ). He knew that there were more stations but didn't know which ones because they were not relevant for his vessel. Ary Boender: "32nd edition of the N&O column / Spooks newsletter", December 24, 2000 [1].
  4. Spooks mailing list.
  10. William I. Orr, W6SAI: "The Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
  11. Enigma Control List [2], Enigma-2000, May 2005.
  1. Moscow's "C" Single Letter Cluster Beacon 7.390MHz 40mtr ham band, using a FT-817 HF tranceiver (Youtube video).
  2. Letter Beacon "D" on 5153.7 kHz using a Sangean 909 portable receiver (Youtube video).
WP
