FRS
Family Radio Service
Ch | Freq MHz | - Notes - |
1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
20 | 462.6750 | Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power |
21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
Midland GXT 50 channel walkie talkies. These are FRS radios sold with extra channels or additional channels. Instead of 22 channels, they come with 50 channels. Channels 1-22 are FRS channels 1-22. Channel 23 to Channel 50 are FRS channels with CTCSS / PL or DCS / DPL tones or codes hard-programmed with each channel. Like most FRS radios, the CTCSS/DCS subchannel or “subcode” is user-selectable on channels 1-22. On channels 23-50, only the channel may be selected, the option to set a sub-channel or “privacy code” is disabled. This feature allows users to quickly change to a different channel and PL or DPL code to escape interference without having to change channel and then change code. Instead, all users would simply “go to channel 46” instead of “go to channel 15, subchannel 2” on their walkie talkies.
- Channel 1 - 462.5625 MHz
- Channel 2 - 462.5875 MHz
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 -
- Channel 9
- Channel 10
- Channel 11
- Channel 12
- Channel 13
- Channel 14
- Channel 15
- Channel 16
- Channel 17
- Channel 18
- Channel 19
- Channel 20
- Channel 21
- Channel 22 - 462.7250 MHz
- Channel 23 - 462.5625 MHz 250.3 Hz PL [FRS 1, code 38] - channel 1-38
- Channel 24 - 462.6125 MHz 225.7 Hz PL [FRS 3, code 35] - channel 3-35
- Channel 25 - 462.6625 MHz 203.5 Hz PL [FRS 5, code 32] - channel 5-32
- Channel 26 - 462.7125 MHz 179.9 Hz PL [FRS 7, code 29] - channel 7-29
- Channel 27 - 462.5500 MHz 162.2 Hz PL [FRS 15, code 26] - channel 15-26
- Channel 28 - 462.6000 MHz 146.2 Hz PL [FRS 17, code 23] - channel 17-23
- Channel 29 - 462.6500 MHz 131.8 Hz PL [FRS 19, code 20] - channel 19-20
- Channel 30 - 462.7000 MHz 118.8 Hz PL [FRS 21, code 17] - channel 21-17
- Channel 31 - 462.5875 MHz 023 DCS [FRS 2, code 39] - channel 2-39
- Channel 32 - 462.6375 MHz 032 DCS [FRS 4, code 42] - channel 4-42
- Channel 33 - 462.6875 MHz 047 DCS [FRS 6, code 45] - channel 6-45
- Channel 34 - 467.5625 MHz 065 DCS [FRS 8, code 48] - channel 8-48
- Channel 35 - 467.6125 MHz 073 DCS [FRS 10, code 51] - channel 10-51
- Channel 36 - 467.6625 MHz 115 DCS [FRS 12, code 54] - channel 12-54
- Channel 37 - 467.7125 MHz 131 DCS [FRS 14, code 57] - channel 14-57
- Channel 38 - 462.5750 MHz 143 DCS [FRS 16, code 60] - channel 16-60
- Channel 39 - 462.6250 MHz 156 DCS [FRS 18, code 63] - channel 18-63
- Channel 40 - 462.6750 MHz 172 DCS [FRS 20, code 66] - channel 20-66
- Channel 41 - 462.7250 MHz 223 DCS [FRS 22, code 69] - channel 22-69
- Channel 42 - 462.5625 MHz 107.2 Hz PL [FRS 1, code 14] - channel 1-14
- Channel 43 - 462.6125 MHz 97.4 Hz PL [FRS 3, code 11] - channel 3-11
- Channel 44 - 462.6625 MHz 88.5 Hz PL [FRS 5, code 8] - channel 5-8
- Channel 45 - 462.7125 MHz 79.7 Hz PL [FRS 7, code 5] - channel 7-5
- Channel 46 - 462.5500 MHz 71.9 Hz PL [FRS 15, code 2] - channel 15-2
- Channel 47 - 462.6000 MHz 241.8 Hz PL [FRS 17, code 37] - channel 17-37
- Channel 48 - 462.6500 MHz 218.1 Hz PL [FRS 19, code 34] - channel 19-34
- Channel 49 - 462.7000 MHz 192.8 Hz PL [FRS 21, code 31] - channel 21-31
- Channel 50 - 462.5875 MHz 025 DCS [FRS 2, code 40] - channel 2-40
- Channels 1, 2, 3, 5, 7, 15, 17, 19 and 21 are used twice as part of the extra channels
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a "monitor" or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours).
These wireless intercom systems generally include a GROUP CALL or HOME channel feature, that switches all intercoms to a dedicated channel/code combination.
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
- Code 2 - 69.3 Hz PL
- Code 3 - 67.0 Hz PL
- CHANNEL 1 - 462.5625 MHz
- Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- Calford Technology Ltd. AF333 wireless intercom
234mw power output, 11K0F3E emission
- Calford Technology Ltd. AF411 wireless intercom
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- SAMCOM / SANCON FTAN10AA 10 channel wireless intercom
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
- Code B - 136.5 Hz PL
- Code C - 186.2 Hz PL
- SAMCOM / SANCON FTAN20AA 20 channel wireless intercom
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same code.
- Shenzhen Macros Industrial Co. Ltd. WL666 or LD666 wireless intercom
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
- PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
- LPD433 - Europe and numerous other countries, very low power short-range voice and data service 433 MHz
- 245 MHz VHF CB Service - Thailand only, 80 channel license free FM CB service
