VHF marine
The 156.000 MHz to 156.250 MHz region is shared with Part 90 land mobile in certain parts of the United States. This comprises public safety allocations from 155.9925 MHz to 156.240 MHz (7.5 kHz steps). In some areas, land mobile allocations are prohibited above 156 MHz to prevent interference with VHF marine communications (for example, in the New Orleans area, in certain Canadian border regions, etc.)
VHF Marine Channels - USA Channels - US Channels New and Old Channel Numbering
4-digit channel numbers for simplex frequencies
New Channel Number | Old Channel Number | Frequency | Purpose/Use (USA) |
01 | 156.050 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only | |
05 | 156.250 MHz | VTS/Port Ops/Commercial, Houston, Seattle, and New Orleans/Lower Mississippi River areas only | |
06 | 156.300 MHz | Intership Safety | |
07 | 156.350 MHz | Commercial | |
08 | 156.400 MHz | Commercial (Intership only) | |
09 | 156.450 MHz | Boater Calling (Commercial/Non-Commercial) | |
10 | 156.500 MHz | Commercial | |
11 | 156.550 MHz | Commercial, VTS in certain areas | |
12 | 156.600 MHz | Port Ops, VTS in certain areas | |
13 | 156.650 MHz | Bridge-to-bridge/Intership Navigation Safety | |
14 | 156.700 MHz | Port Ops, VTS in certain areas | |
15 | 156.750 MHz | Environmental (Receive Only), US Government Use, Class C EPIRBs | |
16 | 156.800 MHz | International Distress, Safety and Calling. USCG, coast stations, and ships maintain watch on this channel | |
17 | 156.850 MHz | State and/or Local Government Maritime Control | |
18 | 156.900 MHz | Commercial | |
19 | 156.950 MHz | Commercial | |
20 | 157.000 MHz | Port Ops | |
21 | 157.050 MHz | US Coast Guard Only | |
22 | 157.100 MHz | US Coast Guard Liaison and Safety Information Broadcasts | |
23 | 157.150 MHz | US Coast Guard Only | |
24 | 157.200 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
25 | 157.250 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
26 | 157.300 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
27 | 157.350 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
28 | 157.400 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
63 | 156.175 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only | |
65 | 156.275 MHz | Port Ops | |
66 | 156.325 MHz | Port Ops | |
67 | 156.375 MHz | Commercial (Intership Only) | |
68 | 156.425 MHz | Non-Commercial, Recreational Boaters | |
69 | 156.475 MHz | Non-Commercial, Recreational Boaters | |
70 | 156.525 MHz | DSC (No voice transmissions permitted) | |
71 | 156.575 MHz | Non-Commercial, Recreational Boaters | |
72 | 156.625 MHz | Non-Commercial (Intership Only), Recreational Boaters | |
73 | 156.675 MHz | Port Ops | |
74 | 156.725 MHz | Port Ops | |
75 | 156.775 MHz | Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA | |
76 | 156.825 MHz | Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA | |
77 | 156.875 MHz | Port Ops (Intership Only) | |
78 | 156.925 MHz | Non-Commercial, Recreational Boaters | |
79 | 156.975 MHz | Commercial. Non-Commercial in Great Lakes only. | |
80 | 157.025 MHz | Commercial. Non-Commercial in Great Lakes only. | |
81 | 157.075 MHz | US Coast Guard/US Government Only/Environmental Protection | |
82 | 157.125 MHz | US Coast Guard Only | |
83 | 157.175 MHz | US Coast Guard Only | |
84 | 157.225 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
85 | 157.275 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
86 | 157.325 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
87 | 157.375 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | |
88 | 157.425 MHz | Commercial/Non-Commercial (Intership Only), Recreational Boaters | |
AIS 1 87B | 161.975 MHz | Automatic Identification System (AIS Channel 1/Channel 87B) | |
AIS 2 88B | 162.025 MHz | Automatic Identification System (AIS Channel 2/Channel 88B) | |
AIS 3 75 / 75A / 1075 | 156.775 MHz | Automatic Identification System (AIS Channel 3/Channel 75) | |
AIS 4 76 / 76A / 1076 | 156.825 MHz | Automatic Identification System (AIS Channel 4/Channel 76) | |
WX 1 | 162.550 MHz | NOAA Weather Radio (Receive Only) | |
WX 2 | 162.400 MHz | NOAA Weather Radio (Receive Only) | |
WX 3 | 162.475 MHz | NOAA Weather Radio (Receive Only) | |
WX 4 | 162.425 MHz | NOAA Weather Radio (Receive Only) | |
WX 5 | 162.450 MHz | NOAA Weather Radio (Receive Only) | |
WX 6 | 162.500 MHz | NOAA Weather Radio (Receive Only) | |
WX 7 | 162.525 MHz | NOAA Weather Radio (Receive Only) | |
WX 8 | 161.650 MHz | Weather Radio Canada - VHF Channel 21B | |
WX 9 | 161.775 MHz | Weather Radio Canada - VHF Channel 83B | |
WX 10 | 163.275 MHz | Weather Radio Canada (Receive Only) |
Channel | Frequency | Purpose/Use (USA) |
00 | 156.000 MHz | Not allocated for marine use in the United States |
02 | 156.100 MHz | Not allocated for marine use in the United States |
03 | 156.150 MHz | Not allocated for marine use in the United States |
04 | 156.200 MHz | Not allocated for marine use in the United States |
29 | 157.450 MHz | Not allocated for marine use in the United States |
60 | 156.025 MHz | Not allocated for marine use in the United States |
61 | 156.075 MHz | Not allocated for marine use in the United States |
62 | 156.125 MHz | Not allocated for marine use in the United States |
64 | 156.225 MHz | Not allocated for marine use in the United States |
The WX channels may be in order from lowest frequency to highest frequency, the original 3 NOAA Weather Radio frequencies (162.55 MHz, 162.4 MHz and 162.475 MHz) were supplanted by the 4 additional frequencies later on. Weather channels 8, 9 and 10 are only used in Canada.
In some countries (including the UK for some channels) semi-duplex is used for ship-to-shore communications, even though no operational benefit is gained using duplex vs. regular simplex.
Channel | Frequency | Purpose/Use |
00 | 156.000 MHz | Private Ship to Ship/Ship to Shore Simplex, used for Search and Rescue (SAR) services in the UK, other services elsewhere |
29 | 157.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
30 | 157.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
31 or 31A | 157.550 MHz | Private Ship to Ship/Ship to Shore Simplex |
31 or 31B | 162.150 MHz | Marina/Leisure Use (Netherlands Only) |
32 | 157.600 MHz | Private Ship to Ship/Ship to Shore Simplex |
33 | 157.650 MHz | Private Ship to Ship/Ship to Shore Simplex |
34 | 157.700 MHz | Private Ship to Ship/Ship to Shore Simplex |
35 | 157.750 MHz | Private Ship to Ship/Ship to Shore Simplex |
36 | 157.800 MHz | Private Ship to Ship/Ship to Shore Simplex |
37 | 157.850 MHz | Private Ship to Ship/Ship to Shore Simplex |
38A | 157.900 MHz | Private Ship to Ship/Ship to Shore Simplex |
38B | 162.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
39 | 157.950 MHz | Private Ship to Ship/Ship to Shore Simplex |
40 | 158.000 MHz | Private Ship to Ship/Ship to Shore Simplex |
41 | 158.050 MHz | Private Ship to Ship/Ship to Shore Simplex |
42 | 158.100 MHz | Private Ship to Ship/Ship to Shore Simplex |
43 | 158.150 MHz | Private Ship to Ship/Ship to Shore Simplex |
44 | 158.200 MHz | Private Ship to Ship/Ship to Shore Simplex |
45 | 158.250 MHz | Private Ship to Ship/Ship to Shore Simplex |
46 | 158.300 MHz | Private Ship to Ship/Ship to Shore Simplex |
47 | 158.350 MHz | Private Ship to Ship/Ship to Shore Simplex |
48 | 158.400 MHz | Private Ship to Ship/Ship to Shore Simplex |
49 | 158.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
96 | 162.425 MHz | Marina Use Only (Belgium only, same frequency as Weather Radio in US and Canada) |
M1 (UK) or M | 157.850 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only - channel 37 |
M2 (UK) | 161.425 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
M3 (UK) | 161.225 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
P1 (UK) | 161.350 MHz | On board ship comms only (low power) |
P2 (UK) | 161.450 MHz | On board ship comms only (low power) |
P1 (Nordic) | 155.500 MHz | Private Marina/Yacht club channel, Nordic countries only |
P2 (Nordic) | 155.525 MHz | Private Marina/Yacht club channel, Nordic countries only |
P3 (Nordic) | 155.650 MHz | Private Marina/Yacht club channel, Nordic countries only |
P4 (Nordic) | 155.625 MHz | Private Fishing Trawler channel, Nordic countries only |
P5 (Nordic) | 155.775 MHz | Private Fishing Trawler channel, Nordic countries only |
P6 (Nordic) | 155.825 MHz | Private Fishing Trawler channel, Nordic countries only |
L1 (Denmark) | 155.500 MHz | Private Channel, Denmark only, Leisure Use Only |
L2 (Denmark) | 155.525 MHz | Private Channel, Denmark only, Leisure Use Only |
F1 | 155.625 MHz | Fishing Use Only, Denmark, Finland, Norway and Sweden |
F2 | 155.775 MHz | Fishing Use Only, Denmark, Finland, Norway and Sweden |
F3 | 155.825 MHz | Fishing Use Only, Denmark, Finland, Norway and Sweden |
P1 (Denmark) | 155.375 MHz | Private Channel, Denmark only |
P2 (Denmark) | 155.575 MHz | Private Channel, Denmark only |
P3 (Denmark) | 155.450 MHz | Private Channel, Denmark only |
P4 (Denmark) | 155.800 MHz | Private Channel, Denmark only |
10 MHz offset (international plan) 10.225 MHz offset (US and Canada channel plan). Input frequencies may be used for simplex purposes as well. International channel plan frequencies interfere with US-allocated GMRS and FRS frequencies. Frequencies are shared with UHF business band in the United States. Elsewhere, other UHF on-board radio systems may be used, including PMR446 or other dedicated systems generally in the 400-512 MHz or 380-520 MHz UHF range.
Channel | Frequency (repeater output or simplex) | Frequency (repeater input or simplex) |
1 (International) | 457.5250 MHz | 467.5250 MHz |
2 (International) | 457.5375 MHz | 467.5375 MHz |
3 (International) | 457.5500 MHz | 467.5500 MHz |
4 (International) | 457.5625 MHz | 467.5625 MHz |
5 (International) | 457.5750 MHz | 467.5750 MHz |
1 (USA, Canada) | 457.5250 MHz | 467.7500 MHz |
2 (USA, Canada) | 457.5375 MHz | 467.7625 MHz |
3 (USA, Canada) | 457.5500 MHz | 467.7750 MHz |
4 (USA, Canada) | 457.5625 MHz | 467.7875 MHz |
5 (USA, Canada) | 457.5750 MHz | 467.8000 MHz |
6 (USA, Canada) | 457.5875 MHz | 467.8125 MHz |
7 (USA, Canada) | 457.6000 MHz | 467.8250 MHz |
8 (USA, Canada) | 457.6125 MHz | 467.8375 MHz |
VHF marine band equipment
