VHF marine
In the United States, the Public Correspondence channel pairs (the old marine radiotelephone full duplex pairs) - channels 24, 25, 26, 27, 28, 84, 85, 86 and 87 have been reassigned in large portions of the country for land mobile radio. Public Correspondence radio phone services have long been discontinued. However, as of 2021, marine radios set to USA mode still have channels 24-28 programmed for duplex operation. Most radios now include channel 87 as 87A (simplex) in USA mode.
Some radios also include channels 84, 85 and 86 as 84A, 85A and 86A as additional simplex channels. Since some radios do not have access to all these frequencies in simplex mode, they are often used by boaters looking for a clear channel when other non-commercial channels are congested. The same is true with channels 02, 03, 04, 60A, 61A, 62A and 64A. Older radios (for example, the Uniden Solara) allow the user to use channels 60, 61, 62 and 64 in simplex mode but do not allow the user to use channels 84-87 in simplex mode. Because there's so much variation with respect to these sometimes-simplex channels and only-allowed-in-some-areas Vessel Traffic Service (VTS) channels, they are sometimes used as "general purpose" channels. The commercial, port operations and non-commercial channels are often used by recreational boaters.
The 156.000 MHz to 156.250 MHz region is shared with Part 90 land mobile in certain parts of the United States. This comprises public safety allocations from 155.9925 MHz to 156.240 MHz (7.5 kHz steps) - Public Safety Radio Pool frequencies 155.9925 MHz, 156.000 MHz, 156.0075 MHz, 156.015 MHz, 156.0225 MHz, 156.030 MHz, 156.0375 MHz, 156.045 MHz, 156.0525 MHz, 156.060 MHz, 156.0675 MHz, 156.075 MHz, 156.0825 MHz, 156.090 MHz, 156.0975 MHz, 156.105 MHz, 156.1125 MHz, 156.120 MHz, 156.1275 MHz, 156.135 MHz, 156.1425 MHz, 156.150 MHz, 156.1575 MHz, 156.165 MHz, 156.1725 MHz, 156.180 MHz, 156.1875 MHz, 156.1925 MHz, 156.2025 MHz, 156.210 MHz, 156.2175 MHz, 156.225 MHz, 156.2325 MHz and 156.240 MHz. This allocation overlaps with VHF marine channels 01A, 02, 03A, 04A, 05A, 60A, 61A, 62A, and 63A. Several public safety frequencies exactly match with VHF marine channels and numerous others are only offset by 2.5 kHz or 5 kHz.
The duplex side 160.600 MHz to 162.000 MHz is allocated to various services in the United States. 160.600-161.610 MHz overlap with the railroad frequencies and 161.640 MHz to 161.790 MHz overlaps with remote broadcast pickup (STLs) and the 161.800 MHz to 162.000 MHz band is used for land mobile. 161.975 MHz and 162.025 MHz are used for the AIS system.
In some areas, land mobile allocations are prohibited above 156.000 MHz to prevent interference with VHF marine communications (for example, in the New Orleans area, lower Mississippi River, Houston, Seattle, and in certain parts of the Canadian border regions, etc.). These areas use VHF marine frequencies in the 156 to 156.25 MHz sub band for the Vessel Traffic Service (VTS). In other parts of the country, port operations and commercial channels (VHF marine channels 11, 12, 14 and 63A) are assigned for VTS use. Outside the designated VTS control area those channels may be used for their standard purposes.
VHF Marine Channels - USA Channels - US Channels New and Old Channel Numbering
4-digit channel numbers for simplex frequencies...some channels are still two-digit. USCG recommends use of the 10xx channel designators for the old A designators for simplex channels (for example, 22A becomes 1022). Under the 4 digit channel numbering system, the B channels are re-designated under 20xx series. In other words, channel 27B becomes channel 2027. Since the vast majority of US marine traffic is simplex, it's simply a question of renaming the "A" simplex-only channels. Channels that have always been simplex - such as channel 16, etc. retain their two digit designators.
| New Channel Number | Old Channel Number | Frequency | Purpose/Use (USA) |
| 1001 | 01A | 156.050 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only |
| 1005 | 05A | 156.250 MHz | VTS/Port Ops/Commercial, Houston, Seattle, and New Orleans/Lower Mississippi River areas only |
| 06 | 06 | 156.300 MHz | Intership Safety |
| 1007 | 07A | 156.350 MHz | Commercial |
| 08 | 08 | 156.400 MHz | Commercial (Intership only) |
| 09 | 09 | 156.450 MHz | Boater Calling - Supplement to VHF 16 (Commercial/Non-Commercial) |
| 10 | 10 | 156.500 MHz | Commercial |
| 11 | 11 | 156.550 MHz | Commercial, VTS in certain areas |
| 12 | 12 | 156.600 MHz | Port Ops, VTS in certain areas |
| 13 | 13 | 156.650 MHz | Bridge-to-bridge/Intership Navigation Safety |
| 14 | 14 | 156.700 MHz | Port Ops, VTS in certain areas |
| 15 | 15 | 156.750 MHz | Environmental (Receive Only), US Government Use, Class C EPIRBs |
| 16 | 16 | 156.800 MHz | International Distress, Safety and Calling. USCG, coast stations, and ships maintain watch on this channel |
| 17 | 17 | 156.850 MHz | State and/or Local Government Maritime Control |
| 1018 | 18A | 156.900 MHz | Commercial |
| 1019 | 19A | 156.950 MHz | Commercial |
| 1020 | 20A | 157.000 MHz | Port Ops |
| 1021 | 21A | 157.050 MHz | US Coast Guard Only |
| 1022 | 22A | 157.100 MHz | US Coast Guard Liaison and Safety Information Broadcasts |
| 1023 | 23A | 157.150 MHz | US Coast Guard Only |
| 24 | 24 | 157.200 MHz - DUPLEX | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 25 | 25 | 157.250 MHz - DUPLEX | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 26 | 26 | 157.300 MHz - DUPLEX | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 27 | 27 | 157.350 MHz - DUPLEX | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 28 | 28 | 157.400 MHz - DUPLEX | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 1063 | 63A | 156.175 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only |
| 1065 | 65A | 156.275 MHz | Port Ops |
| 1066 | 66A | 156.325 MHz | Port Ops |
| 67 | 67 | 156.375 MHz | Commercial (Intership Only) |
| 68 | 68 | 156.425 MHz | Non-Commercial, Recreational Boaters |
| 69 | 69 | 156.475 MHz | Non-Commercial, Recreational Boaters |
| 70 | 70 | 156.525 MHz | DSC (No voice transmissions permitted) |
| 71 | 71 | 156.575 MHz | Non-Commercial, Recreational Boaters |
| 72 | 72 | 156.625 MHz | Non-Commercial (Intership Only), Recreational Boaters |
| 73 | 73 | 156.675 MHz | Port Ops |
| 74 | 74 | 156.725 MHz | Port Ops |
| 77 | 77 | 156.875 MHz | Port Ops (Intership Only) |
| 1078 | 78A | 156.925 MHz | Non-Commercial, Recreational Boaters |
| 1079 | 79A | 156.975 MHz | Commercial. Non-Commercial in Great Lakes only. |
| 1080 | 80A | 157.025 MHz | Commercial. Non-Commercial in Great Lakes only. |
| 1081 | 81A | 157.075 MHz | US Coast Guard/US Government Only/Environmental Protection |
| 1082 | 82A | 157.125 MHz | US Coast Guard Only |
| 1083 | 83A | 157.175 MHz | US Coast Guard Only |
| 84 | 84 | 157.225 MHz - DUPLEX - some radios include 84A/1084!as simplex | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 85 | 85 | 157.275 MHz - DUPLEX - some radios include 85A/1085 as simplex | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 86 | 86 | 157.325 MHz - DUPLEX - some radios include 86A/1086 as simplex | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 87 | 87 | 157.375 MHz - some older radios only allow duplex use of 87 | Commercial/Non-Commercial (Intership Only), Recreational Boaters |
| 88 | 88 | 157.425 MHz | Commercial/Non-Commercial (Intership Only), Recreational Boaters |
| AIS 1 | AIS 1 | 161.975 MHz | Automatic Identification System (AIS Channel 1/Channel 87B) |
| AIS 2 | AIS 2 | 162.025 MHz | Automatic Identification System (AIS Channel 2/Channel 88B) |
VHF Marine Channels USA Channels - Simplex and Duplex
Note that channels 02A, 04A, 60A, 61A, 62A and 64A are not available for legal use in the USA. However, some or all of these channels are available in USA mode in many VHF marine radios as simplex channels. Use is usually commercial or non-commercial ship to ship / intership. Channels 84, 85 and 86 are still technically and legally allocated for duplex use only, but many radios sold in the United States include 84A, 85A and 86A as simplex channels in addition to 87A and 88 (or 88A) as simplex ship-to-ship channels. These channels - 84A, 85A and 86A, as well as 87A and 88 (or 88A) are often used by recreational boaters, fishing fleets and various other non-commercial and commercial uses.
Older-generation VHF marine radios may only allow simplex use of channel 88. Other radios allow simplex use of channels 88 and 87. Older-generation VHF marine equipment is also more likely to have channels 60, 61, 62 and 64 available as simplex channels. Newer equipment may or may not include channels 84, 85 and 86 as simplex channels in USA mode.
Channel 01A (1001) and 05A (1005) are only available for use in very specific areas. These channels are used nationwide for commercial and non-commercial (recreational boats) intership communications outside the VTS zones.
| Channel | Frequency | Purpose/Use (USA) | Simplex or Duplex |
| 01A | 156.050 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only - often used outside these areas | Simplex |
| 03A | 156.150 MHz | "Not allocated for marine use in the United States, but available in some radios in USA mode" | Simplex |
| 05A | 156.250 MHz | VTS/Port Ops/Commercial, Houston, Seattle, and New Orleans/Lower Mississippi River areas only | Simplex |
| 06 | 156.300 MHz | Intership Safety | Simplex |
| 07A | 156.350 MHz | Commercial | Simplex |
| 08 | 156.400 MHz | Commercial (Intership only) | Simplex |
| 09 | 156.450 MHz | Calling (Commercial/Non-Commercial) - secondary to VHF 16 | Simplex |
| 10 | 156.500 MHz | Commercial | Simplex |
| 11 | 156.550 MHz | Commercial, VTS in certain areas | Simplex |
| 12 | 156.600 MHz | Port Ops, VTS in certain areas | Simplex |
| 13 | 156.650 MHz | Bridge-to-bridge/Intership Navigation Safety | Simplex, low power only - 1 watt |
| 14 | 156.700 MHz | Port Operations, VTS in some areas | Simplex |
| 15 | 156.750 MHz | Environmental (Receive Only), US Government Use, Class C EPIRBs | Receive Only |
| 16 | 156.800 MHz | International Distress, Safety and Calling. USCG, coast stations, and ships maintain watch on this channel | Simplex |
| 17 | 156.850 MHz | State and/or Local Government Maritime Control | Simplex, low power only - 1 watt |
| 18A | 156.900 MHz | Commercial | Simplex |
| 19 | 156.950 MHz | Commercial | Simplex |
| 20 | 157.000 MHz | Port Operations | Duplex, Shore TX 161.600 MHz |
| 20A | 157.000 MHz | Port Operations | Simplex |
| 21A | 157.050 MHz | US Coast Guard Only | Simplex |
| 22A | 157.100 MHz | US Coast Guard Liaison and Safety Information Broadcasts | Simplex |
| 23A | 157.150 MHz | US Coast Guard Only | Simplex |
| 24 | 157.200 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.800 MHz |
| 24A | 157.200 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 25 | 157.200 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.850 MHz |
| 25A | 157.250 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 26 | 157.300 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.900 MHz |
| 27 | 157.350 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.950 MHz |
| 27A | 157.350 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 28 | 157.400 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 162.000 MHz |
| 28A | 157.400 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 60A | 156.025 MHz | "Not allocated for marine use in the United States, but available in some radios in USA mode" | Simplex |
| 61A | 156.075 MHz | Intership (East Coast only) Fishing, Commercial and Non-Commercial | Simplex |
| 62A | 156.125 MHz | "Not allocated for marine use in the United States, but available in some radios in USA mode" | Simplex |
| 63A | 156.175 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only | Simplex |
| 64A | 156.225 MHz | "Not allocated for marine use in the United States, but available in some radios in USA mode" | Simplex |
| 65A | 156.275 MHz | Port Ops | Simplex |
| 66A | 156.325 MHz | Port Ops | Simplex |
| 67 | 156.375 MHz | Commercial (Intership Only) | Simplex |
| 68 | 156.425 MHz | Non-Commercial, Recreational Boaters | Simplex |
| 69 | 156.475 MHz | Non-Commercial, Recreational Boaters | Simplex |
| 70 | 156.525 MHz | DSC (No voice transmissions permitted) | Simplex |
| 71 | 156.575 MHz | Non-Commercial, Recreational Boaters | Simplex |
| 72 | 156.625 MHz | Non-Commercial (Intership Only), Recreational Boaters | Simplex |
| 73 | 156.675 MHz | Port Ops | Simplex |
| 74 | 156.725 MHz | Port Ops | Simplex |
| 77 | 156.875 MHz | Port Ops (Intership Only) | Simplex |
| 78A | 156.925 MHz | Non-Commercial, Recreational Boaters | Simplex |
| 79A | 156.975 MHz | Commercial. Non-Commercial in Great Lakes only. | Simplex |
| 80A | 157.025 MHz | Commercial. Non-Commercial in Great Lakes only. | Simplex |
| 81A | 157.075 MHz | US Coast Guard/US Government Only/Environmental Protection | Simplex |
| 82A | 157.125 MHz | US Coast Guard Only | Simplex |
| 83A | 157.175 MHz | US Coast Guard Only | Simplex |
| 84 | 157.225 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.825 MHz |
| 84A | 157.225 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 85 | 157.275 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.875 MHz |
| 85A | 157.275 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 86 | 157.325 MHz | Public Correspondence (service discontinued) | Duplex, Shore TX 161.925 MHz |
| 86A | 157.325 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted | Simplex - only available on some radios (others only allow use of this as a duplex channel) |
| 87 | 157.425 MHz | Commercial/Non-Commercial (Intership Only), Recreational Boaters | Simplex |
| 88 | 157.425 MHz | Commercial/Non-Commercial (Intership Only), Recreational Boaters | Simplex |
| AIS 1 87B | 161.975 MHz | Automatic Identification System (AIS Channel 1/Channel 87B) | Simplex |
| AIS 2 88B | 162.025 MHz | Automatic Identification System (AIS Channel 2/Channel 88B) | Simplex |
| AIS 3 75 / 75A / 1075 | 156.775 MHz | Automatic Identification System (AIS Channel 3/Channel 75) | Simplex |
| AIS 4 76 / 76A / 1076 | 156.825 MHz | Automatic Identification System (AIS Channel 4/Channel 76) | Simplex |
| WX 1 | 162.550 MHz | NOAA Weather Radio | Receive Only |
| WX 2 | 162.400 MHz | NOAA Weather Radio | Receive Only |
| WX 3 | 162.475 MHz | NOAA Weather Radio | Receive Only |
| WX 4 | 162.425 MHz | NOAA Weather Radio | Receive Only |
| WX 5 | 162.450 MHz | NOAA Weather Radio | Receive Only |
| WX 6 | 162.500 MHz | NOAA Weather Radio (Receive Only) | Receive Only |
| WX 7 | 162.525 MHz | NOAA Weather Radio (Receive Only) | Receive Only |
| WX 8 | 161.650 MHz | Weather Radio Canada - VHF Channel 21B | Receive Only |
| WX 9 | 161.775 MHz | Weather Radio Canada - VHF Channel 83B | Receive Only |
| WX 10 | 163.275 MHz | Weather Radio Canada | Receive Only |
The WX channels may be in order from lowest frequency to highest frequency, the original 3 NOAA Weather Radio frequencies (162.55 MHz, 162.4 MHz and 162.475 MHz) were supplanted by the 4 additional frequencies later on. Weather channels 8, 9 and 10 are only used in Canada.
In some countries (including the UK for some channels) semi-duplex is used for ship-to-shore communications, even though no operational benefit is gained using duplex vs. regular simplex.
| Channel | Frequency | Purpose/Use |
| 00 | 156.000 MHz | Private Ship to Ship/Ship to Shore Simplex, used for Search and Rescue (SAR) services in the UK, other services elsewhere |
| 29 | 157.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 30 | 157.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 31 or 31A | 157.550 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 31 or 31B | 162.150 MHz | Marina/Leisure Use (Netherlands Only) |
| 32 | 157.600 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 33 | 157.650 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 34 | 157.700 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 35 | 157.750 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 36 | 157.800 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 37 | 157.850 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 38A | 157.900 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 38B | 162.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 39 | 157.950 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 40 | 158.000 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 41 | 158.050 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 42 | 158.100 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 43 | 158.150 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 44 | 158.200 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 45 | 158.250 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 46 | 158.300 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 47 | 158.350 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 48 | 158.400 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 49 | 158.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 96 | 162.425 MHz | Marina Use Only (Belgium only, same frequency as Weather Radio in US and Canada) |
| M1 (UK) or M | 157.850 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only - channel 37 |
| M2 (UK) | 161.425 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
| M3 (UK) | 161.225 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
| P1 (UK) | 161.350 MHz | On board ship comms only (low power) |
| P2 (UK) | 161.450 MHz | On board ship comms only (low power) |
| P1 (Nordic) | 155.500 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P2 (Nordic) | 155.525 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P3 (Nordic) | 155.650 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P4 (Nordic) | 155.625 MHz | Private Fishing Trawler channel, Nordic countries only |
| P5 (Nordic) | 155.775 MHz | Private Fishing Trawler channel, Nordic countries only |
| P6 (Nordic) | 155.825 MHz | Private Fishing Trawler channel, Nordic countries only |
| L1 (Denmark) | 155.500 MHz | Private Channel, Denmark only, Leisure Use Only |
| L2 (Denmark) | 155.525 MHz | Private Channel, Denmark only, Leisure Use Only |
| F1 | 155.625 MHz | Fishing Use Only, Denmark, Finland, Norway and Sweden |
| F2 | 155.775 MHz | Fishing Use Only, Denmark, Finland, Norway and Sweden |
| F3 | 155.825 MHz | Fishing Use Only, Denmark, Finland, Norway and Sweden |
| P1 (Denmark) | 155.375 MHz | Private Channel, Denmark only |
| P2 (Denmark) | 155.575 MHz | Private Channel, Denmark only |
| P3 (Denmark) | 155.450 MHz | Private Channel, Denmark only |
| P4 (Denmark) | 155.800 MHz | Private Channel, Denmark only |
10 MHz offset (international plan) 10.225 MHz offset (US and Canada channel plan). Input frequencies may be used for simplex purposes as well. International channel plan frequencies interfere with US-allocated GMRS and FRS frequencies. Frequencies are shared with UHF business band in the United States. Elsewhere, other UHF on-board radio systems may be used, including PMR446 or other dedicated systems generally in the 400-512 MHz or 380-520 MHz UHF range.
| Channel | Frequency (repeater output or simplex) | Frequency (repeater input or simplex) |
| 1 (International) | 457.5250 MHz | 467.5250 MHz |
| 2 (International) | 457.5375 MHz | 467.5375 MHz |
| 3 (International) | 457.5500 MHz | 467.5500 MHz |
| 4 (International) | 457.5625 MHz | 467.5625 MHz |
| 5 (International) | 457.5750 MHz | 467.5750 MHz |
| 1 (USA, Canada) | 457.5250 MHz | 467.7500 MHz |
| 2 (USA, Canada) | 457.5375 MHz | 467.7625 MHz |
| 3 (USA, Canada) | 457.5500 MHz | 467.7750 MHz |
| 4 (USA, Canada) | 457.5625 MHz | 467.7875 MHz |
| 5 (USA, Canada) | 457.5750 MHz | 467.8000 MHz |
| 6 (USA, Canada) | 457.5875 MHz | 467.8125 MHz |
| 7 (USA, Canada) | 457.6000 MHz | 467.8250 MHz |
| 8 (USA, Canada) | 457.6125 MHz | 467.8375 MHz |
VHF marine band equipment
