Part 15
Revision as of 14:28, 23 October 2024 by R4002 (Talk | contribs)
Not to be confused with ISM (Part 18 of the FCC rules - although the ISM bands and Part 15 bands often overlap), various license-free Part 95 services and/or any number of similar services outside the United States, including, but not limited to Short Range Devices (SRD or SRDs such as SRD860) or Low Power Devices (LPD or LPDs such as LPD433).
For additional information about 13.56 MHz 22 meter beacons, see the HiFER page.
RC frequencies:
  • 26.995 MHz
  • 27.045 MHz
  • 27.095 MHz
  • 27.145 MHz
  • 27.195 MHz
  • 27.255 MHz
15.231 Periodic operation in the band 40.66–40.70 MHz and above 70 MHz.
Many of the devices operating in the 433MHz or 433.92 MHz region, as well as the various 310 MHz, 315 MHz, 330 MHz and so on bands (garage door openers, etc.) actually operate under 15.231.
The provisions of this section are restricted to periodic operation within the band 40.66–40.70 MHz (ISM shared |band 40.68 MHz) and above 70 MHz. Except as shown in paragraph (e) of this section, the intentional radiator is restricted to the transmission of a control signal such as those used with alarm systems, door openers, garage door openers, remote switches, etc. Continuous transmissions, voice, video and the radio control of toys are not permitted. Data is permitted to be sent with a control signal. The following conditions shall be met to comply with the provisions for this periodic operation:
(1) A manually operated transmitter shall employ a switch that will automatically deactivate the transmitter within not more than 5 seconds of being released.
(2) A transmitter activated automatically shall cease transmission within 5 seconds after activation.
(3) Periodic transmissions at regular predetermined intervals are not permitted. However, polling or supervision transmissions, including data, to determine system integrity of transmitters used in security or safety applications are allowed if the total duration of transmissions does not exceed more than two seconds per hour for each transmitter. There is no limit on the number of individual transmissions, provided the total transmission time does not exceed two seconds per hour.
(4) Intentional radiators which are employed for radio control purposes during emergencies involving fire, security, and safety of life, when activated to signal an alarm, may operate during the pendency of the alarm condition
(5) Transmission of set-up information for security systems may exceed the transmission duration limits in paragraphs (a)(1) and (a)(2) of this section, provided such transmissions are under the control of a professional installer and do not exceed ten seconds after a manually operated switch is released or a transmitter is activated automatically. Such set-up information may include data.
(b) In addition to the provisions of § 15.205, the field strength of emissions from intentional radiators operated under this section shall not exceed the following:
  • Frequency band 40.66 MHz - 40.70 MHz: 2,250 microvolts/meter
  • Frequency band 70 MHz - 130 MHz: 1,250 microvolts/meter
  • Frequency band 130 MHz - 174 MHz: 1,250 microvolts/meter to 3,750 microvolts/meter
  • Frequency band 174 MHz - 260 MHz: 3,750 microvolts/meter to 12,500 microvolts/meter
  • Frequency band above 470 MHz: 12,500 microvolts/meter
  • 49.850 MHz - Channel 2
  • 49.870 MHz - Channel 3
  • 49.890 MHz - Channel 4
  • 49.875 MHZ - Channel 4
  • 49.850 MHz - Channel 1A
  • 49.870 MHz - Channel 2A
  • 49.830 MHz - Channel 1B
  • 49.890 MHz - Channel 2B
  • 49.845 MHz - Channel X
  • 49.875 MHz - Channel Y
Or,
  • 49.830 MHz - Channel A
  • 49.860 MHz - Channel B
Or,
  • 49.845 MHz - Channel A
  • 49.890 MHz - Channel B
Or,
  • 49.840 MHz - Channel A
  • 49.870 MHz - Channel B
Or,
  • 49.850 MHz - Channel I
  • 49.870 MHz - Channel II
Or,
  • 49.825 MHz - Channel 1
Or,
  • 49.870 MHz - Channel 1
Or,
  • 49.840 MHz - Channel 1
  • 49.860 MHz - Channel 2
Or,
Or,
  • 49.885 MHz - Channel B
Or,
  • 49.875 MHz - Channel B
Or,
Or,
  • 49.850 MHz - Channel X
  • 49.880 MHz - Channel Y
  • 49.870 MHz - Channel 4
  • 49.880 MHz - Channel 5
  • 49.890 MHz - Channel 6
  • 49.835 MHz - Channel A
  • 49.850 MHz - Channel B
  • 49.865 MHz - Channel C
Or,
  • 49.890 MHz - Channel C
  • 49.835 MHz - Channel 1/A
  • 49.860 MHz - Channel 2/B
  • 49.885 MHz - Channel 3/C
See also: Wireless networking services such as Wi-Fi, WANs, etc., LoRa and other mesh networks, ISM devices such as microwave ovens, cordless phone systems - 900 MHz band, 2.4 GHz band and 5.8 GHz band digital cordless phones may operate under 15.247.
Other uses include half-duplex (simplex) 900 MHz wireless intercom systems, audio backhaul links, full duplex headset comms systems, long-range telemetry, not Part 95 remote control, datalink, video backhaul systems for UAV systems, drones, etc. Line of sight (air to ground) radio links on 900 MHz are capable of very long range, often 40 km or more. See page for drone radio link (data link) for more information. These bands are also shared with amateur radio service (ham radio) under Part 97 of the FCC rules. Older analog 900 MHz equipment often includes frequency agility in the form of user-selectable channels and selective calling (often in the form of subaudible tone/code systems like CTCSS and DCS). Examples include the RadioShack 900 MHz wireless intercom system 43-142 (FCC ID: AAO430124) with 4 channels, 8 “subcodes”. Channel 1 is 910.000 MHz Channsl 2 is 911.000 MHz , Channel 3 is 912.000 MHz and Channel 4 is 913.000 MHz.
Model 43-3102 (FCC ID: AAO4303102) operates on the same 4 channels and uses the same DIP switch settings to set the operating channel and anti-interference code (CTCSS tone/DCS code, identified as 1, 2, 3 4, 5, 6, 7 and 8. Confirmed use of CTCSS tones, main IC pin 31 is labeled CTCSS Tone and the DIP switches to set the “subcode” and identified as “tone set” on the schematic.
Both intercom systems use wide FM deviation, 180 kHz bandwidth +/- 40 kHz
  • 902 MHz - 928 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
  • 2400 MHz - 2483.5 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
  • 5725 MHz - 5875 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
  • 24.0 GHz - 24.25 GHz - 250 millivolts/meter at 3 meters or 250mV/m at 3 meters (250,000 microvolts/meter at 3 meters)
(b) [Reserved]
