Part 15
Not to be confused with ISM (Part 18 of the FCC rules - although the ISM bands and Part 15 bands often overlap), various license-free Part 95 services and/or any number of similar services outside the United States, including, but not limited to Short Range Devices (SRD or SRDs such as SRD860) or Low Power Devices (LPD or LPDs such as LPD433).
Part 15 is one of the sections of FCC regulations (47 C.F.R.) dealing with unlicensed low-power radio operation. The FCC defines these low-power transmitters as intentional radiators.  See also:  Part 15 beacons.  Operation in several bands is allowed, including low frequency 160-190 kHz, medium frequency/medium wave (AM broadcast band), HF frequencies and various VHF/UHF bands.  The list below is not exhaustive list and does not include of all bands/frequencies available under Part 15.
For additional information about 13.56 MHz 22 meter beacons, see the HiFER page.
(a) The field strength of any emission within this band shall not exceed 10,000
microvolts/meter at 3 meters. The emission limit in this paragraph is
based on measurement instrumentation employing an average detector.
The provisions in 15.35 for limiting peak emissions apply.
RC frequencies:
- 26.995 MHz
 - 27.045 MHz
 - 27.095 MHz
 - 27.145 MHz
 - 27.195 MHz
 - 27.255 MHz
15.231 Periodic operation in the band 40.66–40.70 MHz and above 70 MHz.
Many of the devices operating in the 433MHz or 433 MHz ballpark - 433.92 MHz, 433.925 MHz, etc., as well as the various 310 MHz, 315 MHz, 330 MHz and so on bands (garage door openers, etc.) actually operate under 15.231 (this section). This section is used for many non-voice purposes, including most alarm radio links and other so-called Short Range Devices or SRDs. The provisions of this section are restricted to periodic operation within the band 40.66–40.70 MHz (ISM shared band 40.68 MHz) and above 70 MHz. Except as shown in paragraph (e) of this section, the intentional radiator is restricted to the transmission of a control signal such as those used with alarm systems, door openers, garage door openers, remote switches, etc. Continuous transmissions, voice, video and the radio control of toys are not permitted. Data is permitted to be sent with a control signal. The following conditions shall be met to comply with the provisions for this periodic operation:
(1) A manually operated transmitter shall employ a switch that will automatically deactivate the transmitter within not more than 5 seconds of being released.
(2) A transmitter activated automatically shall cease transmission within 5 seconds after activation.
(3) Periodic transmissions at regular predetermined intervals are not permitted. However, polling or supervision transmissions, including data, to determine system integrity of transmitters used in security or safety applications are allowed if the total duration of transmissions does not exceed more than two seconds per hour for each transmitter. There is no limit on the number of individual transmissions, provided the total transmission time does not exceed two seconds per hour.
(4) Intentional radiators which are employed for radio control purposes during emergencies involving fire, security, and safety of life, when activated to signal an alarm, may operate during the pendency of the alarm condition
(5) Transmission of set-up information for security systems may exceed the transmission duration limits in paragraphs (a)(1) and (a)(2) of this section, provided such transmissions are under the control of a professional installer and do not exceed ten seconds after a manually operated switch is released or a transmitter is activated automatically. Such set-up information may include data.
(b) In addition to the provisions of § 15.205, the field strength of emissions from intentional radiators operated under this section shall not exceed the following:
- Frequency band 40.66 MHz - 40.70 MHz: 2,250 microvolts/meter
 - Frequency band 70 MHz - 130 MHz: 1,250 microvolts/meter
 - Frequency band 130 MHz - 174 MHz: 1,250 microvolts/meter to 3,750 microvolts/meter
 - Frequency band 174 MHz - 260 MHz: 3,750 microvolts/meter to 12,500 microvolts/meter
 - Frequency band above 470 MHz: 12,500 microvolts/meter
43.71 MHz to 44.49 MHz (43.72 MHz to 44.48 MHz), 46.60 MHz to 46.98 MHz (46.61 MHz to 46.97 MHz), 48.75 MHz to 49.51 MHz (48.76 MHz to 49.50 MHz and 49.66 MHz to 50.0 MHz (49.67 MHz to 49.9 MHz).  Note that the frequencies overlap with the VHF low band business radio band, the military bands, the 49 MHz RC 49 MHz remote control device frequencies and 49 MHz short range devices (walkie-talkies, baby monitors, etc.)  The original 10 channel cordless phones used the 46.6 MHz - 47.0 MHz and 49.6 MHz to 50.0 MHz ranges only (46.610 MHz - 46.970 MHz and 46.670 MHz - 49.990 MHz).
 - 49.850 MHz - Channel 2
 - 49.870 MHz - Channel 3
 - 49.890 MHz - Channel 4
 - 49.875 MHZ - Channel 4
- 49.850 MHz - Channel 1A
 - 49.870 MHz - Channel 2A
 - 49.830 MHz - Channel 1B
 - 49.890 MHz - Channel 2B
Modern equipment generally uses 2 switchable channels.  Some of these transmitters use a simple 16.6xxx MHz crystal with a frequency tripler circuit (16.610 MHz x3 = 49.830 MHz - 16.61415 MHz x3 = 49.8425 MHz, 16.615 MHz x3 = 49.845 MHz, 16.61575 MHz x3 = 49.84725 MHz, 16.616 MHz x3 = 49.848 MHz, 16.1616 MHz x3 = 49.8484 MHz, 16.61667 MHz x3 = 49.850 MHz, 16.620 MHz x3 = 49.860 MHz etc.) and simple FM modulation.  Frequency steps, channel plans and channel spacing is random and channel labeling or naming is arbitrary and not consistent from manufacturer to manufacturer or even model number to model number - including:
- 49.845 MHz - Channel X
 - 49.875 MHz - Channel Y
Or,
- 49.830 MHz - Channel A
 - 49.860 MHz - Channel B
Or,
- 49.845 MHz - Channel A
 - 49.890 MHz - Channel B
Or,
- 49.840 MHz - Channel A
 - 49.870 MHz - Channel B
Or,
- 49.850 MHz - Channel I
 - 49.870 MHz - Channel II
Or,
- 49.825 MHz - Channel 1
Or,
- 49.870 MHz - Channel 1
Or,
- 49.840 MHz - Channel 1
 - 49.860 MHz - Channel 2
Or,
- 49.8425 MHz - Channel 1 (49.842 MHz or 49.843 MHz offset)
 - 49.8625 MHz - Channel 2 (49.862 MHz or 49.863 MHz offset)
Or,
 - 49.885 MHz - Channel B
Or,
 - 49.875 MHz - Channel B
Or,
 - 49.876 MHz - Channel B (specifically designed to operate off-frequency from 49.875 MHz - 49.876 MHz per FCC ID documentation)
Or,
 - 49.850 MHz - Channel X
 - 49.880 MHz - Channel Y
- 49.870 MHz - Channel A (actually closer to 49.885 MHz, 49.8875 MHz, 49.888 MHz or 49.890 MHz)
 - 49.810 MHz - Channel B - actual center frequency 49.8225 MHz (49.820 MHz or 49.825 MHz on 5 kHz step receivers)
 - 49.870 MHz - Channel 4
 - 49.880 MHz - Channel 5
 - 49.890 MHz - Channel 6
- 49.835 MHz - Channel A
 - 49.850 MHz - Channel B
 - 49.865 MHz - Channel C
Or,
 - 49.890 MHz - Channel C
- 49.835 MHz - Channel 1/A
 - 49.860 MHz - Channel 2/B
 - 49.885 MHz - Channel 3/C
49 MHz R/C transmitters usually use 49.830 MHz, 49.860 MHz or 49.890 MHz.  As noted earlier, frequencies may vary +/- several kHz.  Baby monitors are usually found on 49.83 MHz, 49.86 MHz or 49.89 MHz.  It's common for a set of R/C toys to be sold with one toy using a 49 MHz RC frequency and the other using a 26 MHz or 27 MHz RC frequency.
§ 15.235 Operation within the band
49.82–49.90 MHz.
The provisions in §15.35 for limiting
(b) The field strength of any emissions appearing between the band edges
and up to 10 kHz above and below the
band edges shall be attenuated at least
26 dB below the level of the
unmodulated carrier or to the general
limits in §15.209, whichever permits the
higher emission levels. The field
strength of any emissions removed by
more than 10 kHz from the band edges
emission limits in §15.209. All signals
exceeding 20 microvolts/meter at 3 meters shall be reported in the application for certification.
(c) For a home-built intentional radiator, as defined in §15.23(a), operating
within the band 49.82–49.90 MHz, the
following standards may be employed:
(1) The RF carrier and modulation
products shall be maintained within
the band 49.82–49.90 MHz.
(2) The total input power to the device measured at the battery or the
power line terminals shall not exceed
100 milliwatts under any condition of
modulation.
(3) The antenna shall be a single element, one meter or less in length, permanently mounted on the enclosure
containing the device.
(4) Emissions outside of this band
(5) The regulations contained in
§15.23 of this part apply to intentional
radiators constructed under the provisions of this paragraph.
(d) Cordless telephones are not permitted to operate under the provisions
of this section.
Note that the vast majority of 433 MHz devices operating in the 433MHz or 433 MHz ballpark - 433.92 MHz, 433.925 MHz, etc., as well as the various 310 MHz, 315 MHz, 330 MHz and so on bands (garage door openers, etc.) actually operate under 15.231.
- 902 MHz - 928 MHz - 500 millivolts/meter at 3 meters
 - 2435 MHz - 2465 MHz - 500 millivolts/meter at 3 meters - 2.435 GHz - 2.465 GHz
 - 5785 MHz - 5815 MHz - 500 millivolts/meter at 3 meters - 5.785 GHz - 5.815 GHz
 - 10500 MHz - 10550 MHz - 2500 millivolts/meter at 3 meters - 10.5 GHz - 10.55 GHz
 - 24075 MHz - 24175 MHz - 2500 millivolts/meter at 3 meters - 24.075 GHz - 24.175 GHz
See also: Wireless networking services such as Wi-Fi, WANs, etc., LoRa and other mesh networks, ISM devices such as microwave ovens, cordless phone systems - 900 MHz band, 2.4 GHz band and 5.8 GHz band digital cordless phones may operate under 15.247.
Other uses include half-duplex (simplex) 900 MHz wireless intercom systems, audio backhaul links, full duplex headset comms systems, long-range telemetry, not Part 95 remote control, datalink, video backhaul systems for UAV systems, drones, etc. Line of sight (air to ground) radio links on 900 MHz are capable of very long range, often 40 km or more. See page for drone radio link (data link) for more information. These bands are also shared with amateur radio service (ham radio) under Part 97 of the FCC rules. Older analog 900 MHz equipment often includes frequency agility in the form of user-selectable channels and selective calling (often in the form of subaudible tone/code systems like CTCSS and DCS). Examples include the RadioShack 900 MHz wireless intercom system 43-142 (FCC ID: AAO430124) with 4 channels, 8 “subcodes”. Channel 1 is 910.000 MHz Channsl 2 is 911.000 MHz , Channel 3 is 912.000 MHz and Channel 4 is 913.000 MHz.
Model 43-3102 (FCC ID: AAO4303102) operates on the same 4 channels and uses the same DIP switch settings to set the operating channel and anti-interference code (CTCSS tone/DCS code, identified as 1, 2, 3 4, 5, 6, 7 and 8. Confirmed use of CTCSS tones, main IC pin 31 is labeled CTCSS Tone and the DIP switches to set the “subcode” and identified as “tone set” on the schematic.
Both intercom systems use wide FM deviation, 180 kHz bandwidth +/- 40 kHz
Numerous systems operate under the provisions of Part 15.247, especially in the 900 MHz band and the 2.4 GHz band.  Examples include video senders, baby monitors, cordless phones (see also: DECT) and others.
- 902 MHz - 928 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
 - 2400 MHz - 2483.5 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
 - 5725 MHz - 5875 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
 - 24.0 GHz - 24.25 GHz - 250 millivolts/meter at 3 meters or 250mV/m at 3 meters (250,000 microvolts/meter at 3 meters)
(b) [Reserved]
