Letter beacon
- Cluster beacons
Location of letter beacons
In 1982 in was reported by SPEEDX, supposedly based on HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at 48° 30' N - 134° 58' E, near the city of Khabarovsk in the USSR. (4), (5) A few years later, it was suggested that the "K" beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the "U" beacons were located at the Barents Sea coast, between Murmansk and Amderma. (6)
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| C | Moscow, RUS |
| D | Sevastopol, UKR |
| F | Vladivostok, RUS |
| M | Magadan, RUS |
| S | Severomorsk, RUS |
| L | Tirana, ALB (inactive) |
| V | Khiva, UZB |
Types of letter beacons
Cluster beacons
| P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8 |
| A | +0.1 | 3595.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 13528.1 16332.1 (10) |
| F | +0.2 | 7039.2, 16332.2 |
| K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier.
| R | 4325.9, 5465.9 | |
| V | RIW | 3658.0, 4150.0, 5141.0, 5342, 6430.7, 6498.0, 6809, 7027.5, 8103.5, 10202 |
| P (12) | RMP | 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079 |
| C | 8000 |
FSK beacons
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
Similar systems
Notes & References
- E.N.I.G.M.A. stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
- ENIGMA-2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
- Poundstone Willian: Big Secrets, Quill, New York, 1983, ISBN 0688048307, pages 191-193
- Spooks mailing list.
- William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications,CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
