Letter beacon
Revision as of 13:44, 29 August 2010 by Strange Attractor (Talk | contribs)
  • Cluster beacons
Location of letter beacons
In 1982 SPEEDX reported], supposedly on the basis of HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at 48° 30' N - 134° 58' E, near the city of Khabarovsk in the USSR. (4), (5) A few years later, W. Orr, W6SAI, suggested that the "K" beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the "U" beacons were located at the Barents Sea coast, between Murmansk and Amderma. (6)
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (inactive)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
Cluster beacons
F +0.2 7039.2, 16332.2
R 4325.9, 5465.9
V RIW 3658.0, 4150.0, 5141.0, 5342, 6430.7, 6498.0, 6809, 7027.5, 8103.5, 10202
P (12) RMP 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079
C 8000
FSK beacons
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
Similar systems
Notes & References
  15. Poundstone Willian: Big Secrets, Quill, New York, 1983, ISBN 0688048307, pages 191-193
  4. Spooks mailing list.
Wikipedia article: {{{1}}}
WP
