Letter beacon
- Cluster beacons
Location of letter beacons
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| C | Moscow, RUS |
| D | Sevastopol, UKR |
| F | Vladivostok, RUS |
| M | Magadan, RUS |
| S | Severomorsk, RUS |
| L | Tirana, ALB (defunct) |
| V | Khiva, UZB |
Types of letter beacons
Cluster beacons
| P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8 |
| F | +0.2 | 7039.2, 16332.2 |
| K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier.
| R | 4325.9, 5465.9 | |
| C | RIW | 8000 |
FSK beacons
| K | 9043 | |
| U |
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
Similar systems
Notes & References
- E.N.I.G.M.A. stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
- ENIGMA-2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
- Spooks mailing list.
- William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
