Letter beacon
- Cluster beacons
Location of letter beacons
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| C | Moscow, RUS |
| D | Sevastopol, UKR |
| F | Vladivostok, RUS |
| M | Magadan, RUS |
| S | Severomorsk, RUS |
| L | Tirana, ALB (defunct) |
| V | Khiva, UZB |
Types of letter beacons
Cluster beacons
| P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8 |
| F | +0.2 | 7039.2, 10872.2, 16332.2 |
| K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
| R (20) | 4325.9, 5465.9 | |
| C | RIW | 8000 |
| L | inactive | |
| W | inactive |
FSK beacons
| K | 9043 | |
| U |
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
Similar systems
On September 7, 2010 a beacon was heard on 9111.7 kHz at 1546 UTC. It sent a slow marker "A", which did not sound like a Russian beacon (MX). It sounded like somebody was playing with the key sending letters "A" and "M". Transmission lasted untill at least 1630 UTC. (19)
Notes & References
- Spooks mailing list.
- William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
