Letter beacon
Letter beacons, often called single letter beacons, are radio transmissions of uncertain origin, which consist of only a single repeating Morse Code letter.
- Cluster beacons
History
Location of letter beacons
ID letter | Location |
C | Moscow, RUS |
D | Odessa, UKR |
O | Moscow, RUS |
P | Kaliningrad, RUS |
S | Arkhangelsk, RUS |
Z | Mukachevo, UKR |
A | Astrakhan, RUS (tentative) |
C | Moscow, RUS |
D | Sevastopol, UKR |
F | Vladivostok, RUS |
K | Petropavlovsk-Kamchatsky, RUS |
L | Unknown, appeared on July 1, 2011 |
M | Magadan, RUS |
S | Severomorsk, RUS |
L | Tirana, ALB (defunct) |
R | Izhevsk (Ustinov), RUS |
V | Khiva, UZB |
Types of letter beacons
Cluster beacons
L (21) | -0.8 | 7038.2, 7041.6, 8494.2, 8497.9 |
D | -0.3 | 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10872.8 (21), 13527.8, 16331.8, 20047.8 |
S | -0.1 | 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
C | 0.0 | 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
A | +0.1 | 3594.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 13528.1 16332.1 (10) |
F | +0.2 | 7039.2, 10872.2, 16332.2 |
K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
R (20) | 4325.9, 5465.9 | |
V | 3658.0, 4108.0(18), 4150.0, 5141.0, 5342, 6430.7, 6498.0, 6809, 7027.5, 8103.5, 10202 | |
C | RIW | 8000 |
L | inactive | |
W | inactive |
FSK beacons
K | 9043 | |
U |
ENIGMA designation
ENIGMA ID | Description |
MX | Cluster beacons |
Similar systems
Notes & References
- Letter beacon "L" started transmitting on July 1, 2011 on and was reported by Boender on two channels (7038.2 and 8494.2 kHz). On July 23, 2011 it moved to 7041.6 and 8497.9 kHz. It is unlikely that this beacon is located in Tirana, Albania, given that Albania is now a member of NATO. A location near Saint Petersburg was proposed in UDXF. At the same time, the 10 MHz "P" beacon moved 1 kHz up, from 10871.8 to 10872.8 kHz.
- Spooks mailing list.
