Letter beacon
- "Letter beacons"
- Cluster beacons
History
Location of letter beacons
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| C | Moscow, RUS |
| D | Sevastopol, UKR |
| F | Vladivostok, RUS |
| L | Unknown, appeared on July 1, 2011 |
| M | Magadan, RUS |
| S | Severomorsk, RUS |
| L | Tirana, ALB (defunct) |
| V | Khiva, UZB |
Types of letter beacons
Cluster beacons
| L (21) | -0.8 | 7038.2, 7041.8(23), 8494.2, 8497.9 |
| D | -0.3 | 3593.7, 4557.7, 5153.7, 7038.7, 7508.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
| P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 10872.8 (21), 13527.8, 16331.8, 20047.8 |
| S | -0.1 | 3593.9, 4557.9, 5153.9, 7038.9, 7508.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
| C | 0.0 | 3594.0, 4558.0, 5154.0, 7039.0, 7509.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
| F | +0.2 | 7039.2, 8495.2, 10872.2, 13528.2, 16332.2 |
| K | +0.3 | 4558.3, 5154.3, 7039.3, 8495.3, 10872.3, 16332.3 |
| R (20) | 4325.9, 5465.9 | |
| C | RIW | 8000 |
| L | 6917.4, 8497.8 | |
| W | 8162.0 |
FSK beacons
| K | 9043 | |
| U |
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
Purpose of letter beacons
Similar systems
Notes & References
- Spooks mailing list.
- Enigma Control List [3], Enigma-2000, May 2005.
