Citizen's Band Radio, or "CB Radio" for short. Known by pejorative names such as "Chicken Band", "Children's Band" and several others. Short-range license free (or simple license requirement) two-way radio service for personal or business purposes in the 25-30 MHz (25000-30000 kHz) range that makes up the shortest wavelength portions of the HF band. De facto standard frequency allocation based on 40 channel American CB band 26.965-27.405 MHz. In radio hobbyist circles, the CB band and adjacent frequencies are often referred to as "11 meters".
CB is one of the most commonly used two-way and land mobile radio services worldwide, although for handheld walkie-talkie purposes it has mostly been depreciated in favor of VHF/UHF services such as FRS, [GMRS]] and MURS. CB is still heavily used by trucking companies, hunting clubs, farmers, rednecks, doomsday preppers, etc and as an inexpensive short-range business radio service. Many ham radio operators look down on CB with absolute disdain, while others view it as a useful tool.
German AM equipment operated at 50 kHz channel steps (27050, 27100, 27150, etc). The US Army also pioneered the concept of using channel numbers in place of frequencies. For example, 25900 kHz would be referred to as "channel 259". American military equipment provided for 10 crystals to be installed at once and selected "on-the-fly" to allow for rapid frequency agility.
The CB service as we know it today started in the United States in the 1950s as a licensed service in the 26.965-27.255 MHz band (23 channels). When the service was created, the original 26.96 - 27.26 MHz band was taken from the 11 meter amateur radio band. Because of this, CB and its adjacent frequencies are often referred to as "11 meters". CB was expanded in 1977 to 40 channels. It is this 40 channel plan that became the "standard" CB plan that most countries have since adopted.
| Frequency Range | Remarks |
| Frequency | Remarks |
The so-called "A channels" are also heavily used, especially when a band opening makes finding a clear frequency difficult. The A channels are assigned to R/C and telemetry purposes in most countries (the USA included). These six frequencies fall under a different section of Part 95 of the FCC rules. 27.255 MHz (CB Channel 23) is also one of the R/C channels, but it is shared with CB. FCC rules permit a maximum of 4 watts carrier power on 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz and 27.195 MHz. FCC rules permit a maximum of 25 watts carrier power on 27.255 MHz (this translates to 100 watts PEP at 100% AM modulation). FCC rules provide for FSK and FM modes (for data transmission) as well on 27.255 MHz. Due to the higher power allowed on 27.255 MHz, it is often used for unlicensed on-site paging and telemetry systems. See the bottom of this page for R/C, radio control, remote control, RC, telecommand, telemetry, etc frequencies.
| CB Channel | Frequency |
| Channel 1 | 26.965 MHz |
| Channel 2 | 26.975 MHz |
| Channel 3 | 26.985 MHz |
| Channel 4 | 27.005 MHz |
| Channel 5 | 27.015 MHz |
| Channel 6 | 27.025 MHz |
| Channel 7 | 27.035 MHz |
| Channel 8 | 27.055 MHz |
| Channel 9 | 27.065 MHz |
| Channel 10 | 27.075 MHz |
| Channel 11 | 27.085 MHz |
| Channel 12 | 27.105 MHz |
| Channel 13 | 27.115 MHz |
| Channel 14 | 27.125 MHz |
| Channel 15 | 27.135 MHz |
| Channel 16 | 27.155 MHz |
| Channel 17 | 27.165 MHz |
| Channel 18 | 27.175 MHz |
| Channel 19 | 27.185 MHz |
| Channel 20 | 27.205 MHz |
| Channel 21 | 27.215 MHz |
| Channel 22 | 27.225 MHz |
| Channel 23 | 27.255 MHz |
| Channel 24 | 27.235 MHz |
| Channel 25 | 27.245 MHz |
| Channel 26 | 27.265 MHz |
| Channel 27 | 27.275 MHz |
| Channel 28 | 27.285 MHz |
| Channel 29 | 27.295 MHz |
| Channel 30 | 27.305 MHz |
| Channel 31 | 27.315 MHz |
| Channel 32 | 27.325 MHz |
| Channel 33 | 27.335 MHz |
| Channel 34 | 27.345 MHz |
| Channel 35 | 27.355 MHz |
| Channel 36 | 27.365 MHz |
| Channel 37 | 27.375 MHz |
| Channel 38 | 27.385 MHz |
| Channel 39 | 27.395 MHz |
| Channel 40 | 27.405 MHz |
FM (Frequency Modulation)
The UK allows use of the CEPT "mid band" allocation (same as US frequencies) in addition to the frequencies listed below. AM, FM and SSB are allowed on 26.965-27.405 MHz. FM is the only mode allowed on 27.60125-27.99125 MHz. In the UK, these frequencies are shared with the Community Audio Distribution Service (CADS) and the Republic of Ireland's similar service the Wireless Public Address System (WPAS). There does not appear to be specific rules regarding FM deviation or bandwidth. Modern FM CB radios use narrowband FM deviation while older sets may use 5 kHz "wideband" FM.
The 27.6 MHz to 28.0 MHz allocation overlaps with CADS/WPAS and other services in various countries outside the UK.
| Channel 1 | 27.60125 MHz |
| Channel 2 | 27.61125 MHz |
| Channel 3 | 27.62125 MHz |
| Channel 4 | 27.63125 MHz |
| Channel 5 | 27.64125 MHz |
| Channel 6 | 27.65125 MHz |
| Channel 7 | 27.66125 MHz |
| Channel 8 | 27.67125 MHz |
| Channel 9 | 27.68125 MHz |
| Channel 10 | 27.69125 MHz |
| Channel 11 | 27.70125 MHz |
| Channel 12 | 27.71125 MHz |
| Channel 13 | 27.72125 MHz |
| Channel 14 | 27.73125 MHz |
| Channel 15 | 27.74125 MHz |
| Channel 16 | 27.75125 MHz |
| Channel 17 | 27.76125 MHz |
| Channel 18 | 27.77125 MHz |
| Channel 19 | 27.78125 MHz |
| Channel 20 | 27.79125 MHz |
| Channel 21 | 27.80125 MHz |
| Channel 22 | 27.81125 MHz |
| Channel 23 | 27.82125 MHz |
| Channel 24 | 27.83125 MHz |
| Channel 25 | 27.84125 MHz |
| Channel 26 | 27.85125 MHz |
| Channel 27 | 27.86125 MHz |
| Channel 28 | 27.87125 MHz |
| Channel 29 | 27.88125 MHz |
| Channel 30 | 27.89125 MHz |
| Channel 31 | 27.90125 MHz |
| Channel 32 | 27.91125 MHz |
| Channel 33 | 27.92125 MHz |
| Channel 34 | 27.93125 MHz |
| Channel 35 | 27.94125 MHz |
| Channel 36 | 27.95125 MHz |
| Channel 37 | 27.96125 MHz |
| Channel 38 | 27.97125 MHz |
| Channel 39 | 27.98125 MHz |
| Channel 40 | 27.99125 MHz |
| Channel 41 | 26.565 MHz |
| Channel 42 | 26.575 MHz |
| Channel 43 | 26.585 MHz |
| Channel 44 | 26.595 MHz |
| Channel 45 | 26.605 MHz |
| Channel 46 | 26.615 MHz |
| Channel 47 | 26.625 MHz |
| Channel 48 | 26.635 MHz |
| Channel 49 | 26.645 MHz |
| Channel 50 | 26.655 MHz |
| Channel 51 | 26.665 MHz |
| Channel 52 | 26.675 MHz |
| Channel 53 | 26.685 MHz |
| Channel 54 | 26.695 MHz |
| Channel 55 | 26.705 MHz |
| Channel 56 | 26.715 MHz |
| Channel 57 | 26.725 MHz |
| Channel 58 | 26.735 MHz |
| Channel 59 | 26.745 MHz |
| Channel 60 | 26.755 MHz |
| Channel 61 | 26.765 MHz |
| Channel 62 | 26.775 MHz |
| Channel 63 | 26.785 MHz |
| Channel 64 | 26.795 MHz |
| Channel 65 | 26.805 MHz |
| Channel 66 | 26.815 MHz |
| Channel 67 | 26.825 MHz |
| Channel 68 | 26.835 MHz |
| Channel 69 | 26.845 MHz |
| Channel 70 | 26.855 MHz |
| Channel 71 | 26.865 MHz |
| Channel 72 | 26.875 MHz |
| Channel 73 | 26.885 MHz |
| Channel 74 | 26.895 MHz |
| Channel 75 | 26.905 MHz |
| Channel 76 | 26.915 MHz |
| Channel 77 | 26.925 MHz |
| Channel 78 | 26.935 MHz |
| Channel 79 | 26.945 MHz |
| Channel 80 | 26.955 MHz |
AM mode. 4 watt TX power. Same specifications as AM CB radio. Modern Australian "27 Meg" 27 MHz marine radio equipment usually includes regular US 40-channels in addition to the frequencies below.
| Channel 1 | 26.330 MHz |
| Channel 2 | 26.340 MHz |
| Channel 3 | 26.350 MHz |
| Channel 4 | 26.370 MHz |
| Channel 5 | 26.380 MHz |
| Channel 6 | 26.390 MHz |
| Channel 7 | 26.400 MHz |
| Channel 8 | 26.420 MHz |
| Channel 9 | 26.430 MHz |
| Channel 10 | 26.440 MHz |
| Channel 11 | 26.450 MHz |
| Channel 12 | 26.470 MHz |
| Channel 13 | 26.480 MHz |
| Channel 14 | 26.490 MHz |
| Channel 15 | 26.500 MHz |
| Channel 16 | 26.520 MHz |
| Channel 17 | 26.530 MHz |
| Channel 18 | 26.540 MHz |
| Channel 19 | 26.550 MHz |
| Channel 20 | 26.570 MHz |
| Channel 21 | 26.580 MHz |
| Channel 22 | 26.590 MHz |
| Channel 23 | 26.620 MHz |
| Channel 24 | 26.600 MHz |
| Channel 25 | 26.610 MHz |
| Channel 26 | 26.630 MHz |
| Channel 27 | 26.640 MHz |
| Channel 28 | 26.650 MHz |
| Channel 29 | 26.660 MHz |
| Channel 30 | 26.670 MHz |
| Channel 31 | 26.680 MHz |
| Channel 32 | 26.690 MHz |
| Channel 33 | 26.700 MHz |
| Channel 34 | 26.710 MHz |
| Channel 35 | 26.720 MHz |
| Channel 36 | 26.730 MHz |
| Channel 37 | 26.740 MHz |
| Channel 38 | 26.750 MHz |
| Channel 39 | 26.760 MHz |
| Channel 40 | 26.770 MHz |
| Channel 1 | 26.968 MHz |
| Channel 2 | 26.976 MHz |
| Channel 3 | 27.040 MHz |
| Channel 4 | 27.080 MHz |
| Channel 5 | 27.088 MHz |
| Channel 6 | 27.112 MHz |
| Channel 7 | 27.120 MHz |
| Channel 8 | 27.144 MHz |
| 27310.5 kHz | 27.3105 MHz |
| 27334.5 kHz | 27.3345 MHz |
| 27338.5 kHz | 27.3385 MHz |
| 27342.5 kHz | 27.3425 MHz |
| 27346.5 kHz | 27.3465 MHz |
| 27350.5 kHz | 27.3505 MHz |
| 27354.5 kHz | 27.3545 MHz |
| 27358.5 kHz | 27.3585 MHz |
| 27362.5 kHz | 27.3625 MHz |
| 27366.5 kHz | 27.3665 MHz |
| 27370.5 kHz | 27.3705 MHz |
| 27378.5 kHz | 27.3785 MHz |
| 27382.5 kHz | 27.3825 MHz |
| 27386.5 kHz | 27.3865 MHz |
| 27388.5 kHz | 27.3885 MHz |
| 27398.5 kHz | 27.3985 MHz |
| 27404.5 kHz | 27.4045 MHz |
| 27418.5 kHz | 27.4185 MHz |
| 27426.5 kHz | 27.4265 MHz |
| 27434.5 kHz | 27.4345 MHz |
| 27442.5 kHz | 27.4425 MHz |
| 27452.5 kHz | 27.4525 MHz |
| 27458.5 kHz | 27.4585 MHz |
| 27466.5 kHz | 27.4665 MHz |
| 27470.5 kHz | 27.4705 MHz |
| Channel 41 | 27.415 MHz |
| Channel 42 | 27.425 MHz |
| Channel 43 | 27.435 MHz |
| Channel 44 | 27.455 MHz |
| Channel 45 | 27.465 MHz |
| Channel 46 | 27.475 MHz |
| Channel 47 | 27.485 MHz |
| Channel 48 | 27.505 MHz |
| Channel 49 | 27.515 MHz |
| Channel 50 | 27.525 MHz |
| Channel 51 | 27.535 MHz |
| Channel 52 | 27.555 MHz |
| Channel 53 | 27.565 MHz |
| Channel 54 | 27.575 MHz |
| Channel 55 | 27.585 MHz |
| Channel 56 | 27.605 MHz |
| Channel 57 | 27.615 MHz |
| Channel 58 | 27.625 MHz |
| Channel 59 | 27.635 MHz |
| Channel 60 | 27.655 MHz |
| Channel 61 | 27.665 MHz |
| Channel 62 | 27.675 MHz |
| Channel 63 | 27.685 MHz |
| Channel 64 | 27.695 MHz |
| Channel 65 | 27.705 MHz |
| Channel 66 | 27.715 MHz |
| Channel 67 | 27.725 MHz |
| Channel 68 | 27.735 MHz |
| Channel 69 | 27.745 MHz |
| Channel 70 | 27.755 MHz |
| Channel 71 | 27.765 MHz |
| Channel 72 | 27.775 MHz |
| Channel 73 | 27.785 MHz |
| Channel 74 | 27.795 MHz |
| Channel 75 | 27.805 MHz |
| Channel 76 | 27.815 MHz |
| Channel 77 | 27.825 MHz |
| Channel 78 | 27.835 MHz |
| Channel 79 | 27.845 MHz |
| Channel 80 | 27.855 MHz |
| 26.575 MHz | Germany | ||
| 26.675 MHz | |||
| 26.915 MHz | |||
| 26.925 MHz | |||
| 26.935 MHz | |||
| 26.970 MHz | Lithuania | ||
| 27.070 MHz | |||
| 27.110 MHz | Poland | ||
| 27.110 MHz | Russia | ||
| 27.150 MHz | Poland | ||
| 27.170 MHz | Poland | ||
| 27.190 MHz | |||
| 27.220 MHz | |||
| 27.230 MHz | |||
| 27.235 MHz | |||
| 27.250 MHz | Belarus | ||
| 27.300 MHz | |||
| 27.325 MHz | |||
| 27.430 MHz | |||
| 27.450 MHz | |||
| 27.470 MHz | |||
| 27.675 MHz | Russia | ||
| 27.765 MHz | Germany | ||
| 27.840 MHz | Poland | ||
US "A" or "RC" channels
UK RC Channels
| Black | 26.975 MHz |
| Brown-Red | 27.025 MHz |
| Red | 27.045 MHz |
| Red-Orange | 27.075 MHz |
| Yellow-Green | 27.175 MHz |
| Green-Blue | 27.225 MHz |
| Blue | 27.245 MHz |
| Channel 1 | 26.995 MHz |
| Channel 2 | 27.045 MHz |
| Channel 3 | 27.095 MHz |
| Channel 4 | 27.145 MHz |
| Channel 6 | 27.195 MHz |
| Channel 10 | 29.725 MHz |
| Channel 11 | 29.735 MHz |
| Channel 12 | 29.745 MHz |
| Channel 13 | 29.755 MHz |
| Channel 14 | 29.765 MHz |
| Channel 15 | 29.775 MHz |
| Channel 16 | 29.785 MHz |
| Channel 17 | 29.795 MHz |
| Channel 18 | 29.805 MHz |
| Channel 19 | 29.815 MHz |
| Channel 20 | 29.825 MHz |
| Channel 21 | 29.835 MHz |
| Channel 22 | 29.845 MHz |
| Channel 23 | 29.855 MHz |
| Channel 24 | 29.865 MHz |
| Channel 25 | 29.875 MHz |
| Channel 26 | 29.885 MHz |
| Channel 27 | 29.895 MHz |
| Channel 28 | 29.905 MHz |
| Channel 29 | 29.915 MHz |
| Channel 30 | 29.925 MHz |
| Channel 31 | 29.935 MHz |
| Channel 32 | 29.945 MHz |
| Channel 33 | 29.955 MHz |
| Channel 34 | 29.965 MHz |
| Channel 35 | 29.975 MHz |
| Channel 36 | 29.985 MHz |
| NZ RC Channel | Frequency |
| Channel 197 | 26.975 MHz |
| Channel 199 | 26.995 MHz |
| Channel 102 | 27.020 MHz |
| Channel 104 | 27.045 MHz |
| Channel 107 | 27.070 MHz |
| Channel 109 | 27.095 MHz |
| Channel 112 | 27.120 MHz |
| Channel 114 | 27.145 MHz |
| Channel 117 | 27.170 MHz |
| Channel 119 | 27.195 MHz |
| Channel 122 | 27.220 MHz |
| Channel 124 | 27.245 MHz |
| Channel 128 | 27.280 MHz |
| Channel 272 | 29.725 MHz |
| Channel 274 | 29.745 MHz |
| Channel 276 | 29.765 MHz |
| Channel 278 | 29.785 MHz |
| Channel 280 | 29.805 MHz |
| Channel 282 | 29.825 MHz |
| Channel 284 | 29.845 MHz |
| Channel 286 | 29.865 MHz |
| Channel 288 | 29.885 MHz |
| Channel 290 | 29.905 MHz |
| Channel 292 | 29.925 MHz |
| Channel 294 | 29.945 MHz |
| Channel 296 | 29.965 MHz |
| Channel 298 | 29.985 MHz |
