FRS
Revision as of 14:08, 8 May 2020 by R4002 (Talk | contribs)
Family Radio Service
Ch Freq MHz - Notes -
1 462.5625 Shared with GMRS - FRS Calling Channel 2 watts maximum TX power
2 462.5875 Shared with GMRS 2 watts maximum TX power
3 462.6125 Shared with GMRS 2 watts maximum TX power
4 462.6375 Shared with GMRS 2 watts maximum TX power
5 462.6625 Shared with GMRS 2 watts maximum TX power
6 462.6875 Shared with GMRS 2 watts maximum TX power
7 462.7125 Shared with GMRS 2 watts maximum TX power
8 467.5625 FRS only 0.5 watt 500mw maximum TX power
9 467.5875 FRS only 0.5 watt 500mw maximum TX power
10 467.6125 FRS only 0.5 watt 500mw maximum TX power
11 467.6375 FRS only 0.5 watt 500mw maximum TX power
12 467.6625 FRS only 0.5 watt 500mw maximum TX power
13 467.6875 FRS only 0.5 watt 500mw maximum TX power
14 467.7125 FRS only 0.5 watt 500mw maximum TX power
15 462.5500 Shared with GMRS 2 watts maximum TX power
16 462.5750 Shared with GMRS 2 watts maximum TX power
17 462.6000 Shared with GMRS 2 watts maximum TX power
18 462.6250 Shared with GMRS 2 watts maximum TX power
19 462.6500 Shared with GMRS 2 watts maximum TX power
20 462.6750 Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power
21 462.7000 Shared with GMRS 2 watts maximum TX power
22 462.7250 Shared with GMRS 2 watts maximum TX power
  • Channel 1 - 462.5625 MHz
  • Channel 2 - 462.5875 MHz
  • Channel 3 - 462.6125 MHz
  • Channel 4 - 462.6375 MHz
  • Channel 5 - 462.6625 MHz
  • Channel 6 - 462.6875 MHz
  • Channel 7 - 462.7125 MHz
  • Channel 8 - 467.5625 MHz
  • Channel 9 - 467.5875 MHz
  • Channel 10 - 467.6125 MHz
  • Channel 11 - 467.6375 MHz
  • Channel 12 - 467.6625 MHz
  • Channel 13 - 467.6875 MHz
  • Channel 14 - 467.7125 MHz
  • Channel 15 - 462.5500 MHz
  • Channel 16 - 462.5750 MHz
  • Channel 17 - 462.6000 MHz
  • Channel 18 - 462.6250 MHz
  • Channel 19 - 462.6500 MHz
  • Channel 20 - 462.6750 MHz
  • Channel 21 - 462.7000 MHz
  • Channel 22 - 462.7250 MHz
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a "monitor" or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours).
These wireless intercom systems generally include a GROUP CALL or HOME channel feature, that switches all intercoms to a dedicated channel/code combination.
  • CHANNEL 1 - 467.6375 MHz
  • CHANNEL 2 - 462.5875 MHz
  • CHANNEL 3 - 462.6125 MHz
  • CHANNEL 4 - 462.6375 MHz
  • CHANNEL 5 - 462.6625 MHz
  • CHANNEL 6 - 462.6875 MHz
  • CHANNEL 7 - 467.7125 MHz
  • CHANNEL 8 - 462.5500 MHz
  • CHANNEL 9 - 462.5750 MHz
  • Code 1 - 162.2 Hz PL
  • Code 2 - 69.3 Hz PL
  • Code 3 - 67.0 Hz PL
  • CHANNEL 1 - 462.5625 MHz
  • Code 3 - 67.0 PL
  • Code 1 - 743 DCS / 743 DPL
  • Code 2 - 732 DCS / 732 DPL
  • Code 3 - 731 DCS / 731 DPL
234mw power output, 11K0F3E emission. Unknown which CTCSS or DCS / PL or DPL code or tone is used on these frequencies.
  • CHANNEL A - 462.5625 MHz
  • CHANNEL B - 462.5875 MHz
  • CHANNEL C - 462.6125 MHz
  • CHANNEL D - 462.6375 MHz
  • CHANNEL 0 - 462.6625 MHz
  • CHANNEL 1 - 467.7125 MHz
  • CHANNEL 2 - 467.6875 MHz
  • CHANNEL 3 - 467.6625 MHz
  • CHANNEL 4 - 467.6375 MHz
  • CHANNEL 5 - 467.6125 MHz
  • CHANNEL 6 - 467.5875 MHz
  • CHANNEL 7 - 467.5625 MHz
  • CHANNEL 8 - 462.7125 MHz
  • CHANNEL 9 - 462.6875 MHz
  • Code A - 110.9 Hz PL
  • Code B - 136.5 Hz PL
  • Code C - 186.2 Hz PL
  • CHANNEL 10 - 462.6375 MHz
  • CHANNEL 11 - 462.6125 MHz
  • CHANNEL 12 - 462.5875 MHz
  • CHANNEL 13 - 462.5625 MHz
  • CHANNEL 14 - 462.7250 MHz
  • CHANNEL 15 - 462.7000 MHz
  • CHANNEL 16 - 462.6750 MHz
  • CHANNEL 17 - 462.6500 MHz
  • CHANNEL 18 - 462.6250 MHz
  • CHANNEL 19 - 462.6000 MHz
  • Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same code.
  • CHANNEL 0 - 467.6125 MHz
  • CHANNEL 1 - 462.7250 MHz
  • CHANNEL 8 - 467.5625 MHz
  • CHANNEL 9 - 467.5875 MHz
  • Code A - 754 DCS / 754 DPL
  • Code B - 743 DCS / 743 DPL
  • Code C - 734 DCS / 734 DPL
  • Wuloo 22 channel 100 code Wuloo WL888 888 TD-888 wireless intercom
  • GROUP CALL - 467.7125 MHz 743 DCS / 743 DPL
  • CHANNEL 2 - 21 are regular FRS channels 2-21
  • CHANNEL 22 - 462.5625 MHz
  • Code 01 - 754 DCS / 754 DPL
  • Code 02 - 743 DCS / 743 DPL
  • Code 03 - 734 DCS / 734 DPL
  • Code 04 - 77.0 Hz PL
  • Code 05 - 79.7 Hz PL
  • Code 06 - Code 38 - 82.5 Hz PL to 250.3 Hz PL (standard 38 CTCSS codes 4-38)
  • Code 39 - 023 DCS / 023 DPL
  • Code 40 - 025 DCS / 025 DPL
  • Code 41 - Code 99 - 032 DCS to 503 DCS (straight sequence through standard DCS/DPL codes)
  • 462.5500 MHz 731 DCS - HOSMART HY810 wireless intercom channel 8, group code 3
  • 462.5500 MHz 732 DCS - HOSMART HY810 wireless intercom channel 8, group code 2
  • 462.5500 MHz 743 DCS - HOSMART HY810 wireless intercom channel 8, group code 1
  • 462.5625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 3
  • 462.5625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 2
  • 462.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code A
  • 462.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code B
  • 462.5625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 1
  • 462.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code C
  • 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
  • 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS)
  • 462.5750 MHz 731 DCS - HOSMART HY810 wireless intercom channel 9, group code 3
  • 462.5750 MHz 732 DCS - HOSMART HY810 wireless intercom channel 9, group code 2
  • 462.5750 MHz 743 DCS - HOSMART HY810 wireless intercom channel 9, group code 1
  • 462.5875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 3
  • 462.5875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 2
  • 462.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code A
  • 462.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code B
  • 462.5875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 1
  • 462.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code C
  • 462.5875 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
  • 462.5875 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
  • 462.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 2, group code C
  • 462.5875 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
  • 462.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 2, group code B
  • 462.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 2, group code A
  • 462.6000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code A
  • 462.6000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code B
  • 462.6000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code C
  • 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS)
  • 462.6125 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 3
  • 462.6125 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 2
  • 462.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code A
  • 462.6125 MHz 118.8 Hz - HOSMART HY806 / HY810 wireless intercom channel 0
  • 462.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code B
  • 462.6125 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 1
  • 462.6125 MHz 165.5 Hz - HOSMART HY777 / HY787 wireless intercom group call channel
  • 462.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code C
  • 462.6125 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 3
  • 462.6125 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 2
  • 462.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 3, group code C
  • 462.6125 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 1
  • 462.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 3, group code B
  • 462.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 3, group code A
  • 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
  • 462.6250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code A
  • 462.6250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code B
  • 462.6250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code C
  • 462.6375 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 3
  • 462.6375 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 2
  • 462.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code A
  • 462.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code B
  • 462.6375 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 1
  • 462.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code C
  • 462.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 3
  • 462.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 2
  • 462.6375 MHz 734 DCS - Wuloo WL666 wireless intercom channel 4, group code C
  • 462.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 1
  • 462.6375 MHz 743 DCS - Wuloo WL666 wireless intercom channel 4, group code B
  • 462.6375 MHz 754 DCS - Wuloo WL666 wireless intercom channel 4, group code A
  • 462.6500 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code A
  • 462.6500 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code B
  • 462.6500 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code C
  • 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS)
  • 462.6625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 3
  • 462.6625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 2
  • 462.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code A
  • 462.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code B
  • 462.6625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 1
  • 462.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code C
  • 462.6625 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 3
  • 462.6625 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 2
  • 462.6625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 5, group code C
  • 462.6625 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 1
  • 462.6625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 5, group code B
  • 462.6625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 5, group code A
  • 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
  • 462.6750 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code A
  • 462.6750 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code B
  • 462.6750 MHz 141.3 Hz - GMRS Calling / Travel Channel "GMRS 675"
  • 462.6750 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code C
  • 462.6875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 3
  • 462.6875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 2
  • 462.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code A
  • 462.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code B
  • 462.6875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 1
  • 462.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code C
  • 462.6875 MHz 731 DCS - HOSMART HY810 wireless intercom channel 6, group code 3
  • 462.6875 MHz 732 DCS - HOSMART HY810 wireless intercom channel 6, group code 2
  • 462.6875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 6, group code C
  • 462.6875 MHz 743 DCS - HOSMART HY810 wireless intercom channel 6, group code 1
  • 462.6875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 6, group code B
  • 462.6875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 6, group code A
  • 462.7000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code A
  • 462.7000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code B
  • 462.7000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code C
  • 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS)
  • 462.7000 MHz 743 DCS - HOSMART (and others) 10 channel wireless intercom group call channel
  • 462.7000 MHz 743 DCS - Wuloo WL666 wireless intercom group call channel
  • 462.7125 MHz 97.4 Hz - Channel "7-11" - commonly used channel
  • 462.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code A
  • 462.7125 MHz 118.8 Hz - HOSMART HY777 / HY787 wireless intercom channel 7
  • 462.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code B
  • 462.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code C
  • 462.7125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 7, group code C
  • 462.7125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 7, group code B
  • 462.7125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 7, group code A
  • 462.7250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code A
  • 462.7250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code B
  • 462.7250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code C
  • 462.7250 MHz 250.3 Hz - Highest channel/privacy code combination possible (on CTCSS only radios)
  • 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS)
  • 462.7250 MHz 734 DCS - Wuloo WL666 wireless intercom channel 1, group code C
  • 462.7250 MHz 743 DCS - Wuloo WL666 wireless intercom channel 1, group code B
  • 462.7250 MHz 754 DCS - Wuloo WL666 wireless intercom channel 1, group code A
  • 462.7250 MHz 754 DCS - Highest channel/privacy code combination possible (on radios with DCS)
  • 467.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code A
  • 467.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code B
  • 467.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code C
  • 467.5625 MHz 065 DCS - Midland FRS extra channel channel 34
  • 467.5625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 8, group code C
  • 467.5625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 8, group code B
  • 467.5625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 8, group code A
  • 467.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code A
  • 467.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code B
  • 467.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code C
  • 467.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 9, group code C
  • 467.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 9, group code B
  • 467.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 9, group code A
  • 467.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code A
  • 467.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code B
  • 467.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code C
  • 467.6125 MHz 073 DCS - Midland FRS extra channel channel 35
  • 467.6125 MHz 627 DCS - HOSMART HY806 / HY810 wireless intercom group call channel
  • 467.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 0, group code C
  • 467.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 0, group code B
  • 467.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 0, group code A
  • 467.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code A
  • 467.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code B
  • 467.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code C
  • 467.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
  • 467.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
  • 467.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
  • 467.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code A
  • 467.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code B
  • 467.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code C
  • 467.6625 MHz 115 DCS - Midland FRS extra channel channel 36
  • 467.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code A
  • 467.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code B
  • 467.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code C
  • 467.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code A
  • 467.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code B
  • 467.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code C
  • 467.7125 MHz 131 DCS - Midland FRS extra channel channel 37
  • 467.7125 MHz 731 DCS - HOSMART HY810 wireless intercom channel 7, group code 3
  • 467.7125 MHz 732 DCS - HOSMART HY810 wireless intercom channel 7, group code 2
  • 467.7125 MHz 743 DCS - HOSMART HY810 wireless intercom channel 7, group code 1
  • PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
