FRS
Revision as of 15:16, 9 May 2020 by R4002 (Talk | contribs)
Family Radio Service
  • FRS Channel 01 -
  • FRS Channel 02 -
  • FRS Channel 03 -
  • FRS Channel 04 -
  • FRS Channel 05 -
  • FRS Channel 06 -
  • FRS Channel 07 -
  • FRS Channel 08 -
  • FRS Channel 09 -
  • FRS Channel 10 -
  • FRS Channel 11 -
  • FRS Channel 12 -
  • FRS Channel 13 -
  • FRS Channel 14 -
  • FRS Channel 15 -
  • FRS Channel 16 -
  • FRS Channel 17 -
  • FRS Channel 18 -
  • FRS Channel 19 -
  • FRS Channel 20 -
  • FRS Channel 21 -
  • FRS Channel 22 -
  • Channel 1 - 462.5625 MHz
  • Channel 2 - 462.5875 MHz
  • Channel 3 - 462.6125 MHz
  • Channel 4 - 462.6375 MHz
  • Channel 5 - 462.6625 MHz
  • Channel 6 - 462.6875 MHz
  • Channel 7 - 462.7125 MHz
  • Channel 8 - 467.5625 MHz
  • Channel 9 - 467.5875 MHz
  • Channel 10 - 467.6125 MHz
  • Channel 11 - 467.6375 MHz
  • Channel 12 - 467.6625 MHz
  • Channel 13 - 467.6875 MHz
  • Channel 14 - 467.7125 MHz
  • Channel 15 - 462.5500 MHz
  • Channel 16 - 462.5750 MHz
  • Channel 17 - 462.6000 MHz
  • Channel 18 - 462.6250 MHz
  • Channel 19 - 462.6500 MHz
  • Channel 20 - 462.6750 MHz
  • Channel 21 - 462.7000 MHz
  • Channel 22 - 462.7250 MHz
  • CHANNEL 1 - 467.6375 MHz
  • CHANNEL 2 - 462.5875 MHz
  • CHANNEL 3 - 462.6125 MHz
  • CHANNEL 4 - 462.6375 MHz
  • CHANNEL 5 - 462.6625 MHz
  • CHANNEL 6 - 462.6875 MHz
  • CHANNEL 7 - 467.7125 MHz
  • CHANNEL 8 - 462.5500 MHz
  • CHANNEL 9 - 462.5750 MHz
  • Code 1 - 162.2 Hz PL
  • Code 2 - 69.3 Hz PL
  • Code 3 - 67.0 Hz PL
  • CHANNEL 1 - 462.5625 MHz
  • Code 3 - 67.0 PL
  • Code 1 - 743 DCS / 743 DPL
  • Code 2 - 732 DCS / 732 DPL
  • Code 3 - 731 DCS / 731 DPL
  • CHANNEL 2 - 462.6125 MHz
  • CHANNEL 3 - 462.6375 MHz
  • CHANNEL A - 462.5625 MHz
  • CHANNEL B - 462.5875 MHz
  • CHANNEL C - 462.6125 MHz
  • CHANNEL D - 462.6375 MHz
  • CHANNEL 0 - 462.6625 MHz
  • CHANNEL 1 - 467.7125 MHz
  • CHANNEL 2 - 467.6875 MHz
  • CHANNEL 3 - 467.6625 MHz
  • CHANNEL 4 - 467.6375 MHz
  • CHANNEL 5 - 467.6125 MHz
  • CHANNEL 6 - 467.5875 MHz
  • CHANNEL 7 - 467.5625 MHz
  • CHANNEL 8 - 462.7125 MHz
  • CHANNEL 9 - 462.6875 MHz
  • Code A - 110.9 Hz PL
  • Code B - 136.5 Hz PL
  • Code C - 186.2 Hz PL
  • CHANNEL 10 - 462.6375 MHz
  • CHANNEL 11 - 462.6125 MHz
  • CHANNEL 12 - 462.5875 MHz
  • CHANNEL 13 - 462.5625 MHz
  • CHANNEL 14 - 462.7250 MHz
  • CHANNEL 15 - 462.7000 MHz
  • CHANNEL 16 - 462.6750 MHz
  • CHANNEL 17 - 462.6500 MHz
  • CHANNEL 18 - 462.6250 MHz
  • CHANNEL 19 - 462.6000 MHz
  • CHANNEL 0 - 467.6125 MHz
  • CHANNEL 1 - 462.7250 MHz
  • CHANNEL 8 - 467.5625 MHz
  • CHANNEL 9 - 467.5875 MHz
  • Code A - 754 DCS / 754 DPL
  • Code B - 743 DCS / 743 DPL
  • Code C - 734 DCS / 734 DPL
  • CHANNEL 7 - 462.7125 MHz
  • CHANNEL 10 - 467.6125 MHz
  • CHANNEL 11 - 467.6375 MHz
  • CHANNEL 12 - 467.6625 MHz
  • CHANNEL 13 - 467.6875 MHz
  • CHANNEL 14 - 467.7125 MHz
  • CHANNEL 15 - 462.5500 MHz
  • CHANNEL 16 - 462.5750 MHz
  • CHANNEL 17 - 462.6000 MHz
  • CHANNEL 19 - 462.6500 MHz
  • CHANNEL 20 - 462.6750 MHz
  • CHANNEL 21 - 462.7000 MHz
  • CHANNEL 22 - 462.5625 MHz
  • Code 01 - 754 DCS / 754 DPL
  • Code 02 - 743 DCS / 743 DPL
  • Code 03 - 734 DCS / 734 DPL
  • Code 04 - 77.0 Hz PL
  • Code 05 - 79.7 Hz PL
  • Code 06 - 82.5 Hz PL
  • Code 07 - 85.4 Hz PL
  • Code 08 - 88.5 Hz PL
  • Code 09 - 91.5 Hz PL
  • Code 10 - 94.8 Hz PL
  • Code 11 - 97.4 Hz PL
  • Code 12 - 100.0 Hz PL
  • Code 13 - 103.5 Hz PL
  • Code 14 - 107.2 Hz PL
  • Code 15 - 110.9 Hz PL
  • Code 16 - 114.8 Hz PL
  • Code 17 - 118.8 Hz PL
  • Code 18 - 123.0 Hz PL
  • Code 19 - 127.3 Hz PL
  • Code 20 - 131.8 Hz PL
  • Code 21 - 136.5 Hz PL
  • Code 22 - 141.3 Hz PL
  • Code 23 - 146.2 Hz PL
  • Code 24 - 151.4 Hz PL
  • Code 25 - 156.7 Hz PL
  • Code 26 - 162.2 Hz PL
  • Code 27 - 167.9 Hz PL
  • Code 28 - 173.8 Hz PL
  • Code 29 - 179.9 Hz PL
  • Code 30 - 186.2 Hz PL
  • Code 31 - 192.8 Hz PL
  • Code 32 - 203.5 Hz PL
  • Code 33 - 210.7 Hz PL
  • Code 34 - 218.1 Hz PL
  • Code 35 - 225.7 Hz PL
  • Code 36 - 233.6 Hz PL
  • Code 37 - 241.8 Hz PL
  • Code 38 - 250.3 Hz PL
  • Code 39 - 023 DCS / 023 DPL
  • Code 40 - 025 DCS / 025 DPL
  • Code 41 - 026
  • Code 42 - 031
  • Code 43 - 032
  • Code 44 - 043
  • Code 45 - 047
  • Code 46 - 051
  • 054
  • 065
  • 071
  • 072
  • 073
  • 074
  • 114
  • 115
  • 116
  • 125
  • 131
  • 132
  • 143
  • Code 60 - 143 DCS / 143 DPL
  • 152
  • 155
  • 156
  • 162
  • 165
  • 172
  • 174
  • 205
  • 223
  • Code 70 - 226 DCS / 226 DPL
  • 243
  • 244
  • 245
  • 251
  • 261
  • 263
  • 265
  • 271
  • 306
  • Code 80 - 311 DCS / 311 DPL
  • 315
  • 331
  • 343
  • 346
  • 351
  • 364
  • 365
  • 371
  • 411
  • Code 90 - 412 DCS / 412 DPL
  • 413
  • 423
  • 431
  • 432
  • 445
  • 464
  • 465
  • 466
  • Code 99 - 503 DCS / 503 DPL
  • 462.5500 MHz 731 DCS - HOSMART HY810 wireless intercom channel 8, group code 3
  • 462.5500 MHz 732 DCS - HOSMART HY810 wireless intercom channel 8, group code 2
  • 462.5500 MHz 743 DCS - HOSMART HY810 wireless intercom channel 8, group code 1
  • 462.5625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 3
  • 462.5625 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 1, group code A
  • 462.5625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 2
  • 462.5625 MHz 69.3 Hz - Calford NTC688 wireless intercom channel 1, group code B
  • 462.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code A
  • 462.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code B
  • 462.5625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 1
  • 462.5625 MHz 165.5 Hz - Calford NTC688 wireless intercom channel 1, group code C
  • 462.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code C
  • 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
  • 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS)
  • 462.5750 MHz 731 DCS - HOSMART HY810 wireless intercom channel 9, group code 3
  • 462.5750 MHz 732 DCS - HOSMART HY810 wireless intercom channel 9, group code 2
  • 462.5750 MHz 743 DCS - HOSMART HY810 wireless intercom channel 9, group code 1
  • 462.5875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 3
  • 462.5875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 2
  • 462.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code A
  • 462.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code B
  • 462.5875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 1
  • 462.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code C
  • 462.5875 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
  • 462.5875 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
  • 462.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 2, group code C
  • 462.5875 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
  • 462.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 2, group code B
  • 462.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 2, group code A
  • 462.6000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code A
  • 462.6000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code B
  • 462.6000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code C
  • 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS)
  • 462.6125 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 3
  • 462.6125 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 2, group code A
  • 462.6125 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 2
  • 462.6125 MHz 69.3 Hz - Calford NCT688 wireless intercom channel 2, group code B
  • 462.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code A
  • 462.6125 MHz 118.8 Hz - HOSMART HY806 / HY810 wireless intercom channel 0
  • 462.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code B
  • 462.6125 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 1
  • 462.6125 MHz 165.5 Hz - HOSMART HY777 / HY787 wireless intercom group call channel
  • 462.6125 MHz 165.5 Hz - Calford NCT688 wireless intercom channel 2, group code C
  • 462.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code C
  • 462.6125 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 3
  • 462.6125 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 2
  • 462.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 3, group code C
  • 462.6125 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 1
  • 462.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 3, group code B
  • 462.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 3, group code A
  • 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
  • 462.6250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code A
  • 462.6250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code B
  • 462.6250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code C
  • 462.6375 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 3
  • 462.6375 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 3, group code A
  • 462.6375 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 2
  • 462.6375 MHz 69.3 Hz - Calford NCT688 wireless intercom channel 3, group code B
  • 462.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code A
  • 462.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code B
  • 462.6375 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 1
  • 462.6375 MHz 165.5 Hz - Calford NCT688 wireless intercom channel 3, group code C
  • 462.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code C
  • 462.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 3
  • 462.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 2
  • 462.6375 MHz 734 DCS - Wuloo WL666 wireless intercom channel 4, group code C
  • 462.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 1
  • 462.6375 MHz 743 DCS - Wuloo WL666 wireless intercom channel 4, group code B
  • 462.6375 MHz 754 DCS - Wuloo WL666 wireless intercom channel 4, group code A
  • 462.6500 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code A
  • 462.6500 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code B
  • 462.6500 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code C
  • 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS)
  • 462.6625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 3
  • 462.6625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 2
  • 462.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code A
  • 462.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code B
  • 462.6625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 1
  • 462.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code C
  • 462.6625 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 3
  • 462.6625 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 2
  • 462.6625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 5, group code C
  • 462.6625 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 1
  • 462.6625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 5, group code B
  • 462.6625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 5, group code A
  • 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
  • 462.6750 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code A
  • 462.6750 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code B
  • 462.6750 MHz 141.3 Hz - GMRS Calling / Travel Channel "GMRS 675"
  • 462.6750 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code C
  • 462.6875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 3
  • 462.6875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 2
  • 462.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code A
  • 462.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code B
  • 462.6875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 1
  • 462.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code C
  • 462.6875 MHz 731 DCS - HOSMART HY810 wireless intercom channel 6, group code 3
  • 462.6875 MHz 732 DCS - HOSMART HY810 wireless intercom channel 6, group code 2
  • 462.6875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 6, group code C
  • 462.6875 MHz 743 DCS - HOSMART HY810 wireless intercom channel 6, group code 1
  • 462.6875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 6, group code B
  • 462.6875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 6, group code A
  • 462.7000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code A
  • 462.7000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code B
  • 462.7000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code C
  • 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS)
  • 462.7000 MHz 743 DCS - HOSMART (and others) 10 channel wireless intercom group call channel
  • 462.7000 MHz 743 DCS - Wuloo WL666 wireless intercom group call channel
  • 462.7125 MHz 97.4 Hz - Channel "7-11" - commonly used channel
  • 462.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code A
  • 462.7125 MHz 118.8 Hz - HOSMART HY777 / HY787 wireless intercom channel 7
  • 462.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code B
  • 462.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code C
  • 462.7125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 7, group code C
  • 462.7125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 7, group code B
  • 462.7125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 7, group code A
  • 462.7250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code A
  • 462.7250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code B
  • 462.7250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code C
  • 462.7250 MHz 250.3 Hz - Highest channel/privacy code combination possible (on CTCSS only radios)
  • 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS)
  • 462.7250 MHz 734 DCS - Wuloo WL666 wireless intercom channel 1, group code C
  • 462.7250 MHz 743 DCS - Wuloo WL666 wireless intercom channel 1, group code B
  • 462.7250 MHz 754 DCS - Wuloo WL666 wireless intercom channel 1, group code A
  • 462.7250 MHz 754 DCS - Highest channel/privacy code combination possible (on radios with DCS)
  • 467.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code A
  • 467.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code B
  • 467.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code C
  • 467.5625 MHz 065 DCS - Midland FRS extra channel channel 34
  • 467.5625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 8, group code C
  • 467.5625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 8, group code B
  • 467.5625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 8, group code A
  • 467.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code A
  • 467.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code B
  • 467.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code C
  • 467.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 9, group code C
  • 467.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 9, group code B
  • 467.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 9, group code A
  • 467.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code A
  • 467.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code B
  • 467.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code C
  • 467.6125 MHz 073 DCS - Midland FRS extra channel channel 35
  • 467.6125 MHz 627 DCS - HOSMART HY806 / HY810 wireless intercom group call channel
  • 467.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 0, group code C
  • 467.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 0, group code B
  • 467.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 0, group code A
  • 467.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code A
  • 467.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code B
  • 467.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code C
  • 467.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
  • 467.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
  • 467.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
  • 467.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code A
  • 467.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code B
  • 467.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code C
  • 467.6625 MHz 115 DCS - Midland FRS extra channel channel 36
  • 467.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code A
  • 467.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code B
  • 467.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code C
  • 467.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code A
  • 467.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code B
  • 467.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code C
  • 467.7125 MHz 131 DCS - Midland FRS extra channel channel 37
  • 467.7125 MHz 731 DCS - HOSMART HY810 wireless intercom channel 7, group code 3
  • 467.7125 MHz 732 DCS - HOSMART HY810 wireless intercom channel 7, group code 2
  • 467.7125 MHz 743 DCS - HOSMART HY810 wireless intercom channel 7, group code 1
  • 467.7125 MHz 743 DCS - Wuloo 22 channel 100 code wireless intercom group call channel code
  • PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
