Revision as of 11:33, 18 June 2021 by R4002 (Talk | contribs)
Frequency Remarks
27.470 MHz 5 active licenses
25.950 MHz 5 active licenses
25.200 MHz 0 active licenses, one marine license for 25.2085 MHz 25208.5 kHz data FSK NBDP WPTM574
25.160 MHz 0 active licenses
25.120 MHz 0 active licenses
CB Channel Frequency Remarks
Channel 2 26.975 MHz
Channel 5 27.015 MHz
Channel 7 27.035 MHz
Channel 12 27.105 MHz
Channel 15 27.135 MHz
Channel 18 27.175 MHz
Channel 22 27.225 MHz
Channel 27 27.275 MHz
Channel 29 27.295 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
FM (Frequency Modulation)
Channel 1 27.60125 MHz
Channel 2 27.61125 MHz
Channel 3 27.62125 MHz
Channel 4 27.63125 MHz
Channel 5 27.64125 MHz
Channel 6 27.65125 MHz
Channel 7 27.66125 MHz
Channel 8 27.67125 MHz
Channel 9 27.68125 MHz
Channel 10 27.69125 MHz
Channel 11 27.70125 MHz
Channel 12 27.71125 MHz
Channel 13 27.72125 MHz
Channel 14 27.73125 MHz
Channel 15 27.74125 MHz
Channel 16 27.75125 MHz
Channel 17 27.76125 MHz
Channel 18 27.77125 MHz
Channel 19 27.78125 MHz
Channel 20 27.79125 MHz
Channel 21 27.80125 MHz
Channel 22 27.81125 MHz
Channel 23 27.82125 MHz
Channel 24 27.83125 MHz
Channel 25 27.84125 MHz
Channel 26 27.85125 MHz
Channel 27 27.86125 MHz
Channel 28 27.87125 MHz
Channel 29 27.88125 MHz
Channel 30 27.89125 MHz
Channel 31 27.90125 MHz
Channel 32 27.91125 MHz
Channel 33 27.92125 MHz
Channel 34 27.93125 MHz
Channel 35 27.94125 MHz
Channel 36 27.95125 MHz
Channel 37 27.96125 MHz
Channel 38 27.97125 MHz
Channel 39 27.98125 MHz
Channel 40 27.99125 MHz
Channel 41 26.565 MHz
Channel 42 26.575 MHz
Channel 43 26.585 MHz
Channel 44 26.595 MHz
Channel 45 26.605 MHz
Channel 46 26.615 MHz
Channel 47 26.625 MHz
Channel 48 26.635 MHz
Channel 49 26.645 MHz
Channel 50 26.655 MHz
Channel 51 26.665 MHz
Channel 52 26.675 MHz
Channel 53 26.685 MHz
Channel 54 26.695 MHz
Channel 55 26.705 MHz
Channel 56 26.715 MHz
Channel 57 26.725 MHz
Channel 58 26.735 MHz
Channel 59 26.745 MHz
Channel 60 26.755 MHz
Channel 61 26.765 MHz
Channel 62 26.775 MHz
Channel 63 26.785 MHz
Channel 64 26.795 MHz
Channel 65 26.805 MHz
Channel 66 26.815 MHz
Channel 67 26.825 MHz
Channel 68 26.835 MHz
Channel 69 26.845 MHz
Channel 70 26.855 MHz
Channel 71 26.865 MHz
Channel 72 26.875 MHz
Channel 73 26.885 MHz
Channel 74 26.895 MHz
Channel 75 26.905 MHz
Channel 76 26.915 MHz
Channel 77 26.925 MHz
Channel 78 26.935 MHz
Channel 79 26.945 MHz
Channel 80 26.955 MHz
26 MHz AM Public Channels:
Channel 1 26.330 MHz
Channel 2 26.340 MHz
Channel 3 26.350 MHz
Channel 4 26.370 MHz
Channel 5 26.380 MHz
Channel 6 26.390 MHz
Channel 7 26.400 MHz
Channel 8 26.420 MHz
Channel 9 26.430 MHz
Channel 10 26.440 MHz
Channel 11 26.450 MHz
Channel 12 26.470 MHz
Channel 13 26.480 MHz
Channel 14 26.490 MHz
Channel 15 26.500 MHz
Channel 16 26.520 MHz
Channel 17 26.530 MHz
Channel 18 26.540 MHz
Channel 19 26.550 MHz
Channel 20 26.570 MHz
Channel 21 26.580 MHz
Channel 22 26.590 MHz
Channel 23 26.620 MHz
Channel 24 26.600 MHz
Channel 25 26.610 MHz
Channel 26 26.630 MHz
Channel 27 26.640 MHz
Channel 28 26.650 MHz
Channel 29 26.660 MHz
Channel 30 26.670 MHz
Channel 31 26.680 MHz
Channel 32 26.690 MHz
Channel 33 26.700 MHz
Channel 34 26.710 MHz
Channel 35 26.720 MHz
Channel 36 26.730 MHz
Channel 37 26.740 MHz
Channel 38 26.750 MHz
Channel 39 26.760 MHz
Channel 40 26.770 MHz
Channel 1 26.960 MHz
Channel 2 26.970 MHz
Channel 3 26.980 MHz
Channel 4 27.000 MHz
Channel 5 27.010 MHz
Channel 6 27.020 MHz
Channel 7 27.030 MHz
Channel 8 27.050 MHz
Channel 9 27.060 MHz
Channel 10 27.070 MHz
Channel 11 27.080 MHz
Channel 12 27.100 MHz
Channel 13 27.110 MHz
Channel 14 27.120 MHz
Channel 15 27.130 MHz
Channel 16 27.150 MHz
Channel 17 27.160 MHz
Channel 18 27.170 MHz
Channel 19 27.180 MHz
Channel 20 27.200 MHz
Channel 21 27.210 MHz
Channel 22 27.220 MHz
Channel 23 27.250 MHz
Channel 24 27.230 MHz
Channel 25 27.240 MHz
Channel 26 27.260 MHz
Channel 27 27.270 MHz
Channel 28 27.280 MHz
Channel 29 27.290 MHz
Channel 30 27.300 MHz
Channel 31 27.310 MHz
Channel 32 27.320 MHz
Channel 33 27.330 MHz
Channel 34 27.340 MHz
Channel 36 27.360 MHz
Channel 37 27.370 MHz
Channel 38 27.380 MHz
Channel 39 27.390 MHz
Channel 40 27.400 MHz
For example,
The related Superstar 120 and Superstar 121 style radios (120 channel radios) use the same form factor with either LOW-MID-HIGH band switch or C-D-E covering 26.515 MHz to 27.855 MHz. Modified CB radios with additional channels may or may not follow the alphanumeric band + channel designation system, depending on the particular modification and radio in question. Many modern modification kits or extra channel expansion kits aim to track the same channel plan to provide for interoperability between modified 40 channel CB radios and 10 meter radios that have been converted to the 11 meter band. Not all legal 40 channel CB radios are capable of operating outside of the legal band but many are, and a thriving market for channel expansion kits and modifications continues to exist for those who wish to use "traditional" type CB radios and still have access to additional channels/frequencies. Because of this, and antenna considerations, the most active 11 meter frequencies tend to be the low channels (26.515 MHz to 26.955 MHz) and the high channels (27.415 MHz to 27.855 MHz) - with the frequencies closest to the legal 40 CB channels generally being more popular (again due to antenna tuning considerations).
Channel 1 26.968 MHz
Channel 2 26.976 MHz
Channel 3 27.040 MHz
Channel 4 27.080 MHz
Channel 5 27.088 MHz
Channel 6 27.112 MHz
Channel 7 27.120 MHz
Channel 8 27.144 MHz
Channel 26760 26.760 MHz
Channel 26768 26.768 MHz
Channel 26776 26.776 MHz
Channel 26824 26.824 MHz
Channel 26840 26.840 MHz
Channel 26848 26.848 MHz
Channel 26856 26.856 MHz
Channel 26864 26.864 MHz
Channel 26872 26.872 MHz
Channel 26880 26.880 MHz
Channel 26888 26.888 MHz
Channel 26896 26.896 MHz
Channel 26912 26.912 MHz
Channel 26920 26.920 MHz
Channel 26928 26.928 MHz
Channel 26936 26.936 MHz
Channel 26944 26.944 MHz
Channel 27016 27.016 MHz
Channel 27524 27.524 MHz
Channel 27532 27.532 MHz
Channel 27540 27.540 MHz
Channel 27548 27.548 MHz
Channel 27556 27.556 MHz
Channel 27572 27.572 MHz
Channel 27580 27.580 MHz
Channel 27628 27.628 MHz
Channel 27636 27.636 MHz
Channel 27644 27.644 MHz
Channel 27652 27.652 MHz
Channel 27660 27.660 MHz
Channel 27668 27.668 MHz
Channel 27676 27.676 MHz
Channel 27724 27.724 MHz
Channel 27732 27.732 MHz
Channel 27740 27.740 MHz
Channel 27748 27.748 MHz
Channel 27756 27.756 MHz
Channel 27764 27.764 MHz
Channel 27772 27.772 MHz
Channel 27780 27.780 MHz
Channel 27828 27.828 MHz
Channel 27836 27.836 MHz
Channel 27852 27.852 MHz
Channel 27860 27.860 MHz
Channel 27884 27.884 MHz
Channel 27892 27.892 MHz
Channel 27908 27.908 MHz
Channel 27916 27.916 MHz
Channel 27932 27.932 MHz
Channel 27940 27.940 MHz
Channel 27956 27.956 MHz
Channel 27964 27.964 MHz
Channel 27980 27.980 MHz
Channel 27988 27.988 MHz
27310.5 kHz 27.3105 MHz
27334.5 kHz 27.3345 MHz
27338.5 kHz 27.3385 MHz
27342.5 kHz 27.3425 MHz
27346.5 kHz 27.3465 MHz
27350.5 kHz 27.3505 MHz
27354.5 kHz 27.3545 MHz
27358.5 kHz 27.3585 MHz
27362.5 kHz 27.3625 MHz
27366.5 kHz 27.3665 MHz
27370.5 kHz 27.3705 MHz
27378.5 kHz 27.3785 MHz
27382.5 kHz 27.3825 MHz
27386.5 kHz 27.3865 MHz
27388.5 kHz 27.3885 MHz
27398.5 kHz 27.3985 MHz
27404.5 kHz 27.4045 MHz
27418.5 kHz 27.4185 MHz
27426.5 kHz 27.4265 MHz
27434.5 kHz 27.4345 MHz
27442.5 kHz 27.4425 MHz
27452.5 kHz 27.4525 MHz
27458.5 kHz 27.4585 MHz
27466.5 kHz 27.4665 MHz
27470.5 kHz 27.4705 MHz
Unlike the Japanese 27 MHz fisheries radio systems (which uses direct frequencies as to reference the channels), this system uses a channelized system with integer channel numbering. Straight channel numbering sequence (channel 1 - 27.500 MHz, channel 2 - 27.525 MHz, channel 3 - 27.550 MHz, channel 3 - 27.575 MHz, channel 5 - 27.600 MHz, etc. through to 39.425 MHz (channel 477) , 39.450 MHz (channel 478) and 39.475 MHz as channel 480) for a total of 480 channels. Radios appear to come with channels 221 [xxxx MHz], 231 [xxxxxx MHz], 236 [xxxx MHz] and 238 [xxxxxxxxx MHz] as "dual watch" channels (likely for calling purposes).
  • SPECIFICATIONS
  • 25 kHz channel spacing
  • 480 channels
  • FEATURES
Channel Frequency (MHz) Designated Use China Fishery Radio
1 27.500 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
2 27.525 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
3 27.550 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
4 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
5 27.600 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
6 27.625 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
7 27.650 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
8 27.675 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
9 27.725 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
10 27.750 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
11 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
12 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
13 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
14 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
15 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
16 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
17 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
18 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
19 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
20 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
21 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
22 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
23 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
24 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
25 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
26 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
27 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
28 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
29 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
30 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
31 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
32 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
33 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
34 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
35 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
36 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
38 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
39 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
40 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
41 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
42 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
43 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
44 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
45 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
46 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
47 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
48 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
49 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
50 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
51 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
52 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
53 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
54 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
55 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
56 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
57 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
58 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
59 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
60 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
61 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
62 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
63 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
64 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
65 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
66 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
67 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
68 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
69 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
70 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
71 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
72 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
73 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
74 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
75 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
76 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
77 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
78 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
79 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
80 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
81 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
82 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
83 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
84 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
85 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
86 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
87 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
88 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
89 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
90 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
91 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
92 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
93 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
94 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
95 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
96 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
97 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
98 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
99 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
100 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
101 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
102 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
103 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
104 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
105 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
106 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
107 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
108 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
109 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
110 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
111 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
112 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
113 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
114 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
115 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
116 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
117 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
118 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
119 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
120 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
121 27.500 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
122 27.525 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
123 27.550 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
124 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
125 27.600 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
126 27.625 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
127 27.650 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
128 27.675 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
129 27.725 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
130 27.750 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
131 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
132 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
133 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
134 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
135 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
136 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
137 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
138 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
139 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
140 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
141 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
142 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
143 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
144 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
145 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
146 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
147 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
148 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
149 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
150 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
151 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
152 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
153 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
154 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
155 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
156 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
158 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
159 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
160 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
161 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
162 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
163 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
164 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
165 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
166 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
167 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
168 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
169 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
170 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
171 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
172 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
173 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
174 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
175 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
176 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
177 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
178 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
179 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
180 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
181 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
182 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
183 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
184 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
185 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
186 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
187 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
188 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
189 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
190 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
191 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
192 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
193 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
194 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
195 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
196 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
197 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
198 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
199 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
200 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
201 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
202 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
203 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
204 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
205 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
206 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
207 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
208 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
209 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
210 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
211 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
212 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
213 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
214 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
215 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
216 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
217 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
218 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
219 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
220 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
221 33.075 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
222 33.100 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
223 33.075 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
224 33.100 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
225 33.125 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
226 33.150 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
227 33.175 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
228 33.200 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
229 33.225 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
230 33.250 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
231 33.275 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
232 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
233 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
234 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
235 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
236 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
237 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
238 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
239 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
240 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
241 27.500 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
242 27.525 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
243 27.550 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
244 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
245 27.600 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
246 27.625 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
247 27.650 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
248 27.675 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
249 27.725 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
250 27.750 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
251 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
252 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
253 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
254 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
255 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
256 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
257 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
258 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
259 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
359 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
360 27.575 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
472 39.275 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
473 39.300 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
474 39.325 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
475 39.350 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
476 39.375 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
477 39.400 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
478 39.425 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
479 39.450 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
480 39.475 MHz Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed
  • SPECIFICATIONS
  • 20 channels
  • AM modulation
  • FEATURES
Channel 41 27.415 MHz
Channel 42 27.425 MHz
Channel 43 27.435 MHz
Channel 44 27.455 MHz
Channel 45 27.465 MHz
Channel 46 27.475 MHz
Channel 47 27.485 MHz
Channel 48 27.505 MHz
Channel 49 27.515 MHz
Channel 50 27.525 MHz
Channel 51 27.535 MHz
Channel 52 27.555 MHz
Channel 53 27.565 MHz
Channel 54 27.575 MHz
Channel 55 27.585 MHz
Channel 56 27.605 MHz
Channel 57 27.615 MHz
Channel 58 27.625 MHz
Channel 59 27.635 MHz
Channel 60 27.655 MHz
Channel 61 27.665 MHz
Channel 62 27.675 MHz
Channel 63 27.685 MHz
Channel 64 27.695 MHz
Channel 65 27.705 MHz
Channel 66 27.715 MHz
Channel 67 27.725 MHz
Channel 68 27.735 MHz
Channel 69 27.745 MHz
Channel 70 27.755 MHz
Channel 71 27.765 MHz
Channel 72 27.775 MHz
Channel 73 27.785 MHz
Channel 74 27.795 MHz
Channel 75 27.805 MHz
Channel 76 27.815 MHz
Channel 77 27.825 MHz
Channel 78 27.835 MHz
Channel 79 27.845 MHz
Channel 80 27.855 MHz
27.600 MHz 27.800 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air
27.620 MHz 27.820 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air
27.640 MHz 27.840 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air
27.660 MHz 27.860 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air
26.575 MHz Germany
26.675 MHz
26.685 MHz Western Russia
26.915 MHz
26.925 MHz
26.970 MHz Lithuania
26.985 MHz Tver, Russia
27.000 MHz Kiev, Ukraine
27.030 MHz Minsk, Belarus
27.040 MHz Minsk, Belarus
27.060 MHz Kiev, Ukraine
27.075 MHz Eastern Russia
27.100 MHz Krasnodar, Russia
27.105 MHz Astana, Kazakhstan
27.110 MHz Poland
27.110 MHz Russia
27.135 MHz Moscow, Russia
27.150 MHz Poland
27.165 MHz Issyk, Kazakhstan
27.170 MHz Poland
27.175 MHz Taraz, Kazakhstan
27.190 MHz
27.200 MHz Zaykova, Russia
27.215 MHz Almaty, Kazakhstan
27.220 MHz
27.230 MHz
27.235 MHz
27.250 MHz Belarus
27.270 MHz Saratov, Russia
27.270 MHz Kiev, Ukraine
27.290 MHz Minsk, Belarus
27.295 MHz Tyumen, Russia
27.300 MHz
27.305 MHz Western Europe
27.325 MHz
27.335 MHz Almaty, Kazakhstan
27.370 MHz Western Russia
27.430 MHz
27.450 MHz
27.470 MHz
27.505 MHz Moscow, Russia
27.580 MHz Moscow, Russia
27.605 MHz Moscow, Russia
27.630 MHz Moscow, Russia
27.635 MHz Moscow, Russia
27.650 MHz Western Europe
27.675 MHz Russia
27.765 MHz Germany
27.840 MHz Poland
27.875 MHz Rostov, Russia
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band 27.9 MHz 27.900 MHz 20-27.9 MHz 27-38.9 MHz 20-28 mc megacycle 27.8 MHz, 27.4 MHz, 27.41 MHz what are the freeband CB frequencies survivalist CB frequencies emergency frequencies near me emergency channels near me UHF emergency frequency VHF emergency frequency 4125 kHz 4417 kHz 6215 kHz 6200 kHz 6212 kHz 6516 kHz 8255 kHz 8779 kHz 12290 kHz 12359 kHz 11175 kHz 13200 kHz 13137 kHz 16420 kHz 16537 kHz 17302 kHz 18795 kHz 19770 kHz 22060 kHz 22756 kHz 25097 kHz 26.097 MHz R4002 26172 kHz 26.172 MHz 2045 kHz 2638 kHz 2003 kHz 6765 kHz 6770 kHz 2048 kHz 2635 kHz ship-to-shore international frequencies radiotelephone emergency calling frequencies GMDSS DSC 2182 kHz 2187.5 kHz 4207.5 kHz 6312 kHz 8414.4 kHz 12577 kHz 16804.5 kHz 156.525 MHz 156.3 MHz 156.8 MHz 156.800 MHz telegraphy distress safety narrow band direct printing 2174.5 kHz 4177.5 kHz 6268 kHz 8376.5 kHz 12520 kHz 16695 kHz 8291 kHz 16420 kHz 4125kHz 3023 kHz 5680 kHz 8364 kHz 10003 kHz 14993 kHz 19993 kHz 19.993 MHz 10.003 MHz 14.993 MHz 123.025 MHz 123.1 MHz 122.9 MHz 455.5 kHz 458.5 kHz 16805.5 kHz 16805 kHz 25208 kHz 25.208 MHz 26121 kHz 26122 kHz 26.840 MHz
