350 MHz Short Range Radio
Revision as of 15:28, 30 October 2023 by R4002 (Talk | contribs)
India 350 MHz Short Range Radio SRR or 350 MHz SRR. More popular than the 27 channel Indian 27 MHz CB radio service.
The 350MHz SRR service in India is not to be confused with the 325 MHz band Short Range Radio Service in the Philippines, the 409 MHz Public Radio Service in China, the 446 MHz PMR446 service used in numerous European, Asian and African countries, the 476 MHz/477 MHz UHF CB service in Australia and New Zealand, the 448 MHz PRRS service in South Korea, or the 462 MHz and 467 MHz FRS and GMRS services in the United States.).
350 MHz band, FM and FSK. 12.5 kHz channel spacing with narrowband FM deviation 11K0F3E. 2 watt maximum transmitter power output. 350.225 MHz to 350.400 MHz UHF band. 13 channels.
  • Channel 1 - 350.2250 MHz
  • Channel 2 - 350.2625 MHz
  • Channel 3 - 350.2750 MHz
  • Channel 4 - 350.2875 MHz
  • Channel 5 - 350.3000 MHz
  • Channel 6 - 350.3125 MHz
  • Channel 7 - 350.3250 MHz
  • Channel 8 - 350.3375 MHz
  • Channel 9 - 350.3500 MHz
  • Channel 10 - 350.3625 MHz
  • Channel 11 - 350.3750 MHz
  • Channel 12 - 350.3875 MHz
  • Channel 13 - 350.4000 MHz
Much like FRS, PMR446, 245 MHz CB, UHF CB and numerous other personal radio services, the 350 MHz service is used by businesses and for private or family communications. Short range walkie talkie portable transceivers. The frequency band this service operates in is used mostly for military aircraft purposes, however the 200 MHz / 300 MHz range is often used for similar services, civilian and military.
