- 27.405-27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
| Frequency | Remarks |
AM and SSB Modulation in the Americas, Australia, Asia, FM allowed in Europe and elsewhere. Most communications heard on CB radio are in AM mode. Yes, truckers (and lots of other people) still use CB radio in 2019. These are the de facto standard CB channel frequencies. Depending on where you're located they're the American CB radio channels, 27 MHz CB channels, the mid band channels, the CEPT channels or the European/EU channels...
Channel usage is mostly focused on US or American CB radio habits, although information relating to the rest of North America as well as Central America, South America and the Caribbean has been included where available. CB radio, freebanding and radio in general is very popular in Latin America and that accounts for the large amount of Spanish language traffic heard during band openings.
| Channel 2 | 26.975 MHz | |
| Channel 5 | 27.015 MHz | |
| Channel 7 | 27.035 MHz | |
| Channel 8 | 27.055 MHz | |
| Channel 12 | 27.105 MHz | |
| Channel 13 | 27.115 MHz | |
| Channel 15 | 27.135 MHz | |
| Channel 16 | 27.155 MHz | 4x4 and off-roader common channel |
| Channel 18 | 27.175 MHz | |
| Channel 20 | 27.205 MHz | While 27.185 MHz is the middle of the band, CB ch.20 is often used for radio testing to avoid causing interference on channel 19 |
| Channel 22 | 27.225 MHz | |
| Channel 24 | 27.235 MHz | Used for ROS and other digital modes in some parts of Europe |
| Channel 25 | 27.245 MHz | Used for ROS and other digital modes in some parts of Europe |
| Channel 27 | 27.275 MHz | |
| Channel 29 | 27.295 MHz | |
| Channel 32 | 27.325 MHz | |
| Channel 33 | 27.335 MHz | |
| Channel 34 | 27.345 MHz | |
| Channel 35 | 27.355 MHz | |
| Channel 36 | 27.365 MHz | |
FM (Frequency Modulation)
The UK allows use of the CEPT "mid band" allocation (same as US frequencies) in addition to the frequencies listed below. The UK 27/81 FM band is defined under UK law as 27.59625 MHz to 27.99625 MHz (indicating maximum 5 kHz deviation from center frequencies, regular two-way radio or land mobile FM). AM, FM and SSB are allowed on 26.965-27.405 MHz. FM with 5 kHz deviation is the only mode allowed on 27.60125-27.99125 MHz - straight 10 kHz channel steps, no gaps or odd sequence like the mid band 40 channel CB band. In the UK, these frequencies are shared with the Community Audio Distribution Service (CADS) and the Republic of Ireland's similar service the Wireless Public Address System (WPAS).
| Channel 1 | 27.60125 MHz |
| Channel 2 | 27.61125 MHz |
| Channel 3 | 27.62125 MHz |
| Channel 4 | 27.63125 MHz |
| Channel 5 | 27.64125 MHz |
| Channel 6 | 27.65125 MHz |
| Channel 7 | 27.66125 MHz |
| Channel 8 | 27.67125 MHz |
| Channel 9 | 27.68125 MHz |
| Channel 10 | 27.69125 MHz |
| Channel 11 | 27.70125 MHz |
| Channel 12 | 27.71125 MHz |
| Channel 13 | 27.72125 MHz |
| Channel 14 | 27.73125 MHz |
| Channel 15 | 27.74125 MHz |
| Channel 16 | 27.75125 MHz |
| Channel 17 | 27.76125 MHz |
| Channel 18 | 27.77125 MHz |
| Channel 19 | 27.78125 MHz |
| Channel 20 | 27.79125 MHz |
| Channel 21 | 27.80125 MHz |
| Channel 22 | 27.81125 MHz |
| Channel 23 | 27.82125 MHz |
| Channel 24 | 27.83125 MHz |
| Channel 25 | 27.84125 MHz |
| Channel 26 | 27.85125 MHz |
| Channel 27 | 27.86125 MHz |
| Channel 28 | 27.87125 MHz |
| Channel 29 | 27.88125 MHz |
| Channel 30 | 27.89125 MHz |
| Channel 31 | 27.90125 MHz |
| Channel 32 | 27.91125 MHz |
| Channel 33 | 27.92125 MHz |
| Channel 34 | 27.93125 MHz |
| Channel 35 | 27.94125 MHz |
| Channel 36 | 27.95125 MHz |
| Channel 37 | 27.96125 MHz |
| Channel 38 | 27.97125 MHz |
| Channel 39 | 27.98125 MHz |
| Channel 40 | 27.99125 MHz |
| Channel 41 | 26.565 MHz |
| Channel 42 | 26.575 MHz |
| Channel 43 | 26.585 MHz |
| Channel 44 | 26.595 MHz |
| Channel 45 | 26.605 MHz |
| Channel 46 | 26.615 MHz |
| Channel 47 | 26.625 MHz |
| Channel 48 | 26.635 MHz |
| Channel 49 | 26.645 MHz |
| Channel 50 | 26.655 MHz |
| Channel 51 | 26.665 MHz |
| Channel 52 | 26.675 MHz |
| Channel 53 | 26.685 MHz |
| Channel 54 | 26.695 MHz |
| Channel 55 | 26.705 MHz |
| Channel 56 | 26.715 MHz |
| Channel 57 | 26.725 MHz |
| Channel 58 | 26.735 MHz |
| Channel 59 | 26.745 MHz |
| Channel 60 | 26.755 MHz |
| Channel 61 | 26.765 MHz |
| Channel 62 | 26.775 MHz |
| Channel 63 | 26.785 MHz |
| Channel 64 | 26.795 MHz |
| Channel 65 | 26.805 MHz |
| Channel 66 | 26.815 MHz |
| Channel 67 | 26.825 MHz |
| Channel 68 | 26.835 MHz |
| Channel 69 | 26.845 MHz |
| Channel 70 | 26.855 MHz |
| Channel 71 | 26.865 MHz |
| Channel 72 | 26.875 MHz |
| Channel 73 | 26.885 MHz |
| Channel 74 | 26.895 MHz |
| Channel 75 | 26.905 MHz |
| Channel 76 | 26.915 MHz |
| Channel 77 | 26.925 MHz |
| Channel 78 | 26.935 MHz |
| Channel 79 | 26.945 MHz |
| Channel 80 | 26.955 MHz |
26 MHz AM Public Channels:
| Channel 1 | 26.330 MHz |
| Channel 2 | 26.340 MHz |
| Channel 3 | 26.350 MHz |
| Channel 4 | 26.370 MHz |
| Channel 5 | 26.380 MHz |
| Channel 6 | 26.390 MHz |
| Channel 7 | 26.400 MHz |
| Channel 8 | 26.420 MHz |
| Channel 9 | 26.430 MHz |
| Channel 10 | 26.440 MHz |
| Channel 11 | 26.450 MHz |
| Channel 12 | 26.470 MHz |
| Channel 13 | 26.480 MHz |
| Channel 14 | 26.490 MHz |
| Channel 15 | 26.500 MHz |
| Channel 16 | 26.520 MHz |
| Channel 17 | 26.530 MHz |
| Channel 18 | 26.540 MHz |
| Channel 19 | 26.550 MHz |
| Channel 20 | 26.570 MHz |
| Channel 21 | 26.580 MHz |
| Channel 22 | 26.590 MHz |
| Channel 23 | 26.620 MHz |
| Channel 24 | 26.600 MHz |
| Channel 25 | 26.610 MHz |
| Channel 26 | 26.630 MHz |
| Channel 27 | 26.640 MHz |
| Channel 28 | 26.650 MHz |
| Channel 29 | 26.660 MHz |
| Channel 30 | 26.670 MHz |
| Channel 31 | 26.680 MHz |
| Channel 32 | 26.690 MHz |
| Channel 33 | 26.700 MHz |
| Channel 34 | 26.710 MHz |
| Channel 35 | 26.720 MHz |
| Channel 36 | 26.730 MHz |
| Channel 37 | 26.740 MHz |
| Channel 38 | 26.750 MHz |
| Channel 39 | 26.760 MHz |
| Channel 40 | 26.770 MHz |
For example,
AM modulation only. 0.5 watt (500mw) power limit. Often included as part of the Japanese "DSB Fishery Radio Service" (27 MHz fishery radio system) that covers 26.760 MHz to 27.988 MHz in odd steps. Some fishery radio marine frequencies in-between CB channels. Illegal CB operations on the American/Australian frequencies is apparently common in Japan, despite the potential for interference with marine radio service allocations. These frequencies are often used in conjunction with the "standard" 10 kHz CB channeling for fishing, marine transport and other maritime purposes in Japan, Taiwan, China, and several other Asian countries. Japan's primary outband or freeband calling frequencies are 27.005 MHz in AM mode and 27.355 MHz / 27.385 MHz in LSB mode for SSB voice. All three of these frequencies interfere with the fishery radio services in Japan.
| Channel 1 | 26.968 MHz |
| Channel 2 | 26.976 MHz |
| Channel 3 | 27.040 MHz |
| Channel 4 | 27.080 MHz |
| Channel 5 | 27.088 MHz |
| Channel 6 | 27.112 MHz |
| Channel 7 | 27.120 MHz |
| Channel 8 | 27.144 MHz |
| 27310.5 kHz | 27.3105 MHz |
| 27334.5 kHz | 27.3345 MHz |
| 27338.5 kHz | 27.3385 MHz |
| 27342.5 kHz | 27.3425 MHz |
| 27346.5 kHz | 27.3465 MHz |
| 27350.5 kHz | 27.3505 MHz |
| 27354.5 kHz | 27.3545 MHz |
| 27358.5 kHz | 27.3585 MHz |
| 27362.5 kHz | 27.3625 MHz |
| 27366.5 kHz | 27.3665 MHz |
| 27370.5 kHz | 27.3705 MHz |
| 27378.5 kHz | 27.3785 MHz |
| 27382.5 kHz | 27.3825 MHz |
| 27386.5 kHz | 27.3865 MHz |
| 27388.5 kHz | 27.3885 MHz |
| 27398.5 kHz | 27.3985 MHz |
| 27404.5 kHz | 27.4045 MHz |
| 27418.5 kHz | 27.4185 MHz |
| 27426.5 kHz | 27.4265 MHz |
| 27434.5 kHz | 27.4345 MHz |
| 27442.5 kHz | 27.4425 MHz |
| 27452.5 kHz | 27.4525 MHz |
| 27458.5 kHz | 27.4585 MHz |
| 27466.5 kHz | 27.4665 MHz |
| 27470.5 kHz | 27.4705 MHz |
| Channel 41 | 27.415 MHz |
| Channel 42 | 27.425 MHz |
| Channel 43 | 27.435 MHz |
| Channel 44 | 27.455 MHz |
| Channel 45 | 27.465 MHz |
| Channel 46 | 27.475 MHz |
| Channel 47 | 27.485 MHz |
| Channel 48 | 27.505 MHz |
| Channel 49 | 27.515 MHz |
| Channel 50 | 27.525 MHz |
| Channel 51 | 27.535 MHz |
| Channel 52 | 27.555 MHz |
| Channel 53 | 27.565 MHz |
| Channel 54 | 27.575 MHz |
| Channel 55 | 27.585 MHz |
| Channel 56 | 27.605 MHz |
| Channel 57 | 27.615 MHz |
| Channel 58 | 27.625 MHz |
| Channel 59 | 27.635 MHz |
| Channel 60 | 27.655 MHz |
| Channel 61 | 27.665 MHz |
| Channel 62 | 27.675 MHz |
| Channel 63 | 27.685 MHz |
| Channel 64 | 27.695 MHz |
| Channel 65 | 27.705 MHz |
| Channel 66 | 27.715 MHz |
| Channel 67 | 27.725 MHz |
| Channel 68 | 27.735 MHz |
| Channel 69 | 27.745 MHz |
| Channel 70 | 27.755 MHz |
| Channel 71 | 27.765 MHz |
| Channel 72 | 27.775 MHz |
| Channel 73 | 27.785 MHz |
| Channel 74 | 27.795 MHz |
| Channel 75 | 27.805 MHz |
| Channel 76 | 27.815 MHz |
| Channel 77 | 27.825 MHz |
| Channel 78 | 27.835 MHz |
| Channel 79 | 27.845 MHz |
| Channel 80 | 27.855 MHz |
| 26.575 MHz | Germany | ||
| 26.675 MHz | |||
| 26.915 MHz | |||
| 26.925 MHz | |||
| 26.970 MHz | Lithuania | ||
| 27.110 MHz | Poland | ||
| 27.110 MHz | Russia | ||
| 27.150 MHz | Poland | ||
| 27.170 MHz | Poland | ||
| 27.190 MHz | |||
| 27.220 MHz | |||
| 27.230 MHz | |||
| 27.235 MHz | |||
| 27.250 MHz | Belarus | ||
| 27.300 MHz | |||
| 27.325 MHz | |||
| 27.430 MHz | |||
| 27.450 MHz | |||
| 27.470 MHz | |||
| 27.675 MHz | Russia | ||
| 27.765 MHz | Germany | ||
| 27.840 MHz | Poland | ||
[5] United States Federal Communications Commission (FCC) Part 95 - Personal Radio Services - including the CB Radio Service (CBRS) - aka Citizen's Band Radio Service 26.965 to 27.405 MHz AM/SSB FCC Rules Subpart D 47 CFR 95.401 through 47 CFR 95.673
do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio
