| Frequency | Remarks |
| Channel 2 | 26.975 MHz | |
| Channel 5 | 27.015 MHz | |
| Channel 7 | 27.035 MHz | |
| Channel 8 | 27.055 MHz | |
| Channel 12 | 27.105 MHz | |
| Channel 15 | 27.135 MHz | |
| Channel 16 | 27.155 MHz | 4x4 and off-roader common channel (4x4 = 16) |
| Channel 18 | 27.175 MHz | |
| Channel 22 | 27.225 MHz | |
| Channel 24 | 27.235 MHz | Used for ROS and other digital modes in some parts of Europe |
| Channel 25 | 27.245 MHz | Used for ROS and other digital modes in some parts of Europe |
| Channel 27 | 27.275 MHz | |
| Channel 29 | 27.295 MHz | |
| Channel 32 | 27.325 MHz | |
| Channel 33 | 27.335 MHz | |
| Channel 34 | 27.345 MHz | |
| Channel 35 | 27.355 MHz | |
| Channel 36 | 27.365 MHz | |
FM (Frequency Modulation)
| Channel 1 | 27.60125 MHz |
| Channel 2 | 27.61125 MHz |
| Channel 3 | 27.62125 MHz |
| Channel 4 | 27.63125 MHz |
| Channel 5 | 27.64125 MHz |
| Channel 6 | 27.65125 MHz |
| Channel 7 | 27.66125 MHz |
| Channel 8 | 27.67125 MHz |
| Channel 9 | 27.68125 MHz |
| Channel 10 | 27.69125 MHz |
| Channel 11 | 27.70125 MHz |
| Channel 12 | 27.71125 MHz |
| Channel 13 | 27.72125 MHz |
| Channel 14 | 27.73125 MHz |
| Channel 15 | 27.74125 MHz |
| Channel 16 | 27.75125 MHz |
| Channel 17 | 27.76125 MHz |
| Channel 18 | 27.77125 MHz |
| Channel 19 | 27.78125 MHz |
| Channel 20 | 27.79125 MHz |
| Channel 21 | 27.80125 MHz |
| Channel 22 | 27.81125 MHz |
| Channel 23 | 27.82125 MHz |
| Channel 24 | 27.83125 MHz |
| Channel 25 | 27.84125 MHz |
| Channel 26 | 27.85125 MHz |
| Channel 27 | 27.86125 MHz |
| Channel 28 | 27.87125 MHz |
| Channel 29 | 27.88125 MHz |
| Channel 30 | 27.89125 MHz |
| Channel 31 | 27.90125 MHz |
| Channel 32 | 27.91125 MHz |
| Channel 33 | 27.92125 MHz |
| Channel 34 | 27.93125 MHz |
| Channel 35 | 27.94125 MHz |
| Channel 36 | 27.95125 MHz |
| Channel 37 | 27.96125 MHz |
| Channel 38 | 27.97125 MHz |
| Channel 39 | 27.98125 MHz |
| Channel 40 | 27.99125 MHz |
| Channel 41 | 26.565 MHz |
| Channel 42 | 26.575 MHz |
| Channel 43 | 26.585 MHz |
| Channel 44 | 26.595 MHz |
| Channel 45 | 26.605 MHz |
| Channel 46 | 26.615 MHz |
| Channel 47 | 26.625 MHz |
| Channel 48 | 26.635 MHz |
| Channel 49 | 26.645 MHz |
| Channel 50 | 26.655 MHz |
| Channel 51 | 26.665 MHz |
| Channel 52 | 26.675 MHz |
| Channel 53 | 26.685 MHz |
| Channel 54 | 26.695 MHz |
| Channel 55 | 26.705 MHz |
| Channel 56 | 26.715 MHz |
| Channel 57 | 26.725 MHz |
| Channel 58 | 26.735 MHz |
| Channel 59 | 26.745 MHz |
| Channel 60 | 26.755 MHz |
| Channel 61 | 26.765 MHz |
| Channel 62 | 26.775 MHz |
| Channel 63 | 26.785 MHz |
| Channel 64 | 26.795 MHz |
| Channel 65 | 26.805 MHz |
| Channel 66 | 26.815 MHz |
| Channel 67 | 26.825 MHz |
| Channel 68 | 26.835 MHz |
| Channel 69 | 26.845 MHz |
| Channel 70 | 26.855 MHz |
| Channel 71 | 26.865 MHz |
| Channel 72 | 26.875 MHz |
| Channel 73 | 26.885 MHz |
| Channel 74 | 26.895 MHz |
| Channel 75 | 26.905 MHz |
| Channel 76 | 26.915 MHz |
| Channel 77 | 26.925 MHz |
| Channel 78 | 26.935 MHz |
| Channel 79 | 26.945 MHz |
| Channel 80 | 26.955 MHz |
26 MHz AM Public Channels:
| Channel 1 | 26.330 MHz |
| Channel 2 | 26.340 MHz |
| Channel 3 | 26.350 MHz |
| Channel 4 | 26.370 MHz |
| Channel 5 | 26.380 MHz |
| Channel 6 | 26.390 MHz |
| Channel 7 | 26.400 MHz |
| Channel 8 | 26.420 MHz |
| Channel 9 | 26.430 MHz |
| Channel 10 | 26.440 MHz |
| Channel 11 | 26.450 MHz |
| Channel 12 | 26.470 MHz |
| Channel 13 | 26.480 MHz |
| Channel 14 | 26.490 MHz |
| Channel 15 | 26.500 MHz |
| Channel 16 | 26.520 MHz |
| Channel 17 | 26.530 MHz |
| Channel 18 | 26.540 MHz |
| Channel 19 | 26.550 MHz |
| Channel 20 | 26.570 MHz |
| Channel 21 | 26.580 MHz |
| Channel 22 | 26.590 MHz |
| Channel 23 | 26.620 MHz |
| Channel 24 | 26.600 MHz |
| Channel 25 | 26.610 MHz |
| Channel 26 | 26.630 MHz |
| Channel 27 | 26.640 MHz |
| Channel 28 | 26.650 MHz |
| Channel 29 | 26.660 MHz |
| Channel 30 | 26.670 MHz |
| Channel 31 | 26.680 MHz |
| Channel 32 | 26.690 MHz |
| Channel 33 | 26.700 MHz |
| Channel 34 | 26.710 MHz |
| Channel 35 | 26.720 MHz |
| Channel 36 | 26.730 MHz |
| Channel 37 | 26.740 MHz |
| Channel 38 | 26.750 MHz |
| Channel 39 | 26.760 MHz |
| Channel 40 | 26.770 MHz |
For example,
6 band export radio frequency plan A-B-C-D-E-F 25.615 MHz to 28.305 MHz. For radios with wider frequency coverage, the lowest band will generally be Band A. On the 8 band Galaxy radios, coverage is 25.165 MHz to 28.755 MHz (A-B-C-D band selector plus a high band and low band switch). 12 band radios use the A-B-C-D-E-F-G-H-I-J-K-L naming convention, or A-B-C-D-E-F band selector plus a high band and a low band selector. These radios generally cover 24.265 MHz to 29.655 MHz. The newer generation Chinese radios cover 25.615 MHz to 30.105 MHz out of the box (10 bands) or 24.715 MHz to 30.105 MHz out of the box (12 bands).
| Band C Channel (low band, low channels or lowers) | Frequency |
| Channel 1 | 26.515 MHz |
| Channel B02 | 26.525 MHz |
| Channel B03 | 26.535 MHz |
| Channel B03A | 26.545 MHz |
| Channel B04 | 26.555 MHz |
| Channel B05 | 26.565 MHz |
| Channel B06 | 26.575 MHz |
| Channel B09 | 26.615 MHz |
| Channel B10 | 26.625 MHz |
| Channel B11 | 26.635 MHz |
| Channel B11A | 26.645 MHz |
| Channel B12 | 26.655 MHz |
| Channel B13 | 26.655 MHz |
| Channel B14 | 26.675 MHz |
| Channel B15 | 26.685 MHz |
| Channel B15A | 26.695 MHz |
| Channel B16 | 26.705 MHz |
| Channel B17 | 26.715 MHz |
| Channel B18 | 26.725 MHz |
| Channel B19 | 26.735 MHz |
| Channel B19A | 26.745 MHz |
| Channel B20 | 26.755 MHz |
| Channel B21 | 26.765 MHz |
| Channel B22 | 26.775 MHz |
| Channel B23 | 26.805 MHz |
| Channel B24 | 26.785 MHz |
| Channel B25 | 26.795 MHz |
| Channel B26 | 26.815 MHz |
| Channel B27 | 26.825 MHz |
| Channel B28 | 26.835 MHz |
| Channel B29 | 26.845 MHz |
| Channel B30 | 26.855 MHz |
| Channel B31 | 26.865 MHz |
| Channel B32 | 26.875 MHz |
| Channel B33 | 26.885 MHz |
| Channel B34 | 26.895 MHz |
| Channel B35 | 26.905 MHz |
| Channel B36 | 26.915 MHz |
| Channel B37 | 26.925 MHz |
| Channel B38 | 26.935 MHz |
| Channel B39 | 26.945 MHz |
| Channel B40 | 26.955 MHz |
| Band D Channel - Legal CB band (mid band, legal 40, middle 40, middle band, CEPT band, FCC band) | Frequency | Channel C01 | 26.965 MHz |
| Channel C02 | 26.975 MHz | ||
| Channel C03 | 26.985 MHz | ||
| Channel C03A | 26.995 MHz | ||
| Channel C04 | 27.005 MHz | ||
| Channel C05 | 27.015 MHz | ||
| Channel C06 | 27.025 MHz | ||
| Channel C07 | 27.035 MHz | ||
| Channel C07A | 27.045 MHz | ||
| Channel C08 | 27.055 MHz | ||
| Channel C09 | 27.065 MHz | ||
| Channel C10 | 27.075 MHz | ||
| Channel C11 | 27.085 MHz | ||
| Channel C11A | 27.095 MHz | ||
| Channel C12 | 27.105 MHz | ||
| Channel C13 | 27.115 MHz | ||
| Channel C14 | 27.120 MHz | 27.125 MHz | |
| Channel C15 | 27.130 MHz | 27.135 MHz | |
| Channel C15A | 27.140 MHz | 27.145 MHz | |
| Channel C16 | 27.150 MHz | 27.155 MHz | |
| Channel C17 | 27.160 MHz | 27.165 MHz | |
| Channel C18 | 27.170 MHz | 27.175 MHz | |
| Channel C19 | 27.180 MHz | 27.185 MHz | |
| Channel C19A | 27.190 MHz | 27.195 MHz | |
| Channel C20 | 27.200 MHz | 27.205 MHz | |
| Channel C21 | 27.210 MHz | 27.215 MHz | |
| Channel C22 | 27.220 MHz | 27.225 MHz | |
| Channel C23 | 27.250 MHz | 27.255 MHz | |
| Channel C24 | 27.230 MHz | 27.235 MHz | |
| Channel C25 | 27.240 MHz | 27.245 MHz | |
| Channel C26 | 27.260 MHz | 27.265 MHz | |
| Channel C27 | 27.270 MHz | 27.275 MHz | |
| Channel C28 | 27.280 MHz | 27.285 MHz | |
| Channel C29 | 27.290 MHz | 27.295 MHz | |
| Channel C30 | 27.300 MHz | 27.305 MHz | |
| Channel C31 | 27.310 MHz | 27.315 MHz | |
| Channel C32 | 27.320 MHz | 27.325 MHz | |
| Channel C33 | 27.330 MHz | 27.335 MHz | |
| Channel C34 | 27.340 MHz | 27.345 MHz | |
| Channel C35 | 27.350 MHz | 27.355 MHz | |
| Channel C36 | 27.360 MHz | 27.365 MHz | |
| Channel C37 | 27.370 MHz | 27.375 MHz | |
| Channel C38 | 27.380 MHz | 27.385 MHz | |
| Channel C39 | 27.390 MHz | 27.395 MHz | |
| Channel C40 | 27.400 MHz | 27.405 MHz | |
| Channel D01 | 27.410 MHz | 27.415 MHz | |
| Channel D02 | 27.420 MHz | 27.425 MHz | |
| Channel D03 | 27.430 MHz | 27.435 MHz | |
| Channel D03A | 27.440 MHz | 27.445 MHz | |
| Channel D04 | 27.450 MHz | 27.455 MHz | |
| Channel D05 | 27.460 MHz | 27.465 MHz | |
| Channel D06 | 27.470 MHz | 27.475 MHz | |
| Channel D07 | 27.480 MHz | 27.485 MHz | |
| Channel D07A | 27.490 MHz | 27.495 MHz | |
| Channel D08 | 27.500 MHz | 27.505 MHz | |
| Channel D09 | 27.510 MHz | 27.515 MHz | |
| Channel D10 | 27.520 MHz | 27.525 MHz | |
| Channel D11 | 27.530 MHz | 27.535 MHz | |
| Channel D11A | 27.540 MHz | 27.545 MHz | |
| Channel D12 | 27.550 MHz | 27.555 MHz | |
| Channel D13 | 27.560 MHz | 27.565 MHz | |
| Channel D14 | 27.570 MHz | 27.575 MHz | |
| Channel D15 | 27.580 MHz | 27.585 MHz | |
| Channel D15A | 27.590 MHz | 27.595 MHz | |
| Channel D16 | 27.600 MHz | 27.605 MHz | |
| Channel D17 | 27.610 MHz | 27.615 MHz | |
| Channel D18 | 27.620 MHz | 27.625 MHz | |
| Channel D19 | 27.630 MHz | 27.635 MHz | |
| Channel D19A | 27.640 MHz | 27.645 MHz | |
| Channel D20 | 27.650 MHz | 27.655 MHz | |
| Channel D21 | 27.660 MHz | 27.665 MHz | |
| Channel D22 | 27.670 MHz | 27.675 MHz | |
| Channel D23 | 27.700 MHz | 27.705 MHz | |
| Channel D24 | 27.680 MHz | 27.685 MHz | |
| Channel D25 | 27.690 MHz | 27.695 MHz | |
| Channel D26 | 27.710 MHz | 27.715 MHz | |
| Channel D27 | 27.720 MHz | 27.735 MHz | |
| Channel D28 | 27.730 MHz | 27.735 MHz | |
| Channel D29 | 27.740 MHz | 27.745 MHz | |
| Channel D30 | 27.750 MHz | 27.755 MHz | |
| Channel D31 | 27.760 MHz | 27.765 MHz | |
| Channel D32 | 27.770 MHz | 27.775 MHz | |
| Channel D33 | 27.780 MHz | 27.785 MHz | |
| Channel D34 | 27.790 MHz | 27.795 MHz | |
| Channel D35 | 27.800 MHz | 27.805 MHz | |
| Channel D36 | 27.810 MHz | 27.815 MHz | |
| Channel D37 | 27.820 MHz | 27.825 MHz | |
| Channel D38 | 27.830 MHz | 27.835 MHz | |
| Channel D39 | 27.840 MHz | 27.845 MHz | |
| Channel 1 | 26.968 MHz |
| Channel 2 | 26.976 MHz |
| Channel 3 | 27.040 MHz |
| Channel 4 | 27.080 MHz |
| Channel 5 | 27.088 MHz |
| Channel 6 | 27.112 MHz |
| Channel 7 | 27.120 MHz |
| Channel 8 | 27.144 MHz |
26.760-27.988 MHz. 1 watt maximum carrier power, often overlaid with standard 10 kHz step "marine CB" channeling. See 0.5 watt Japanese CB frequencies above. Not designated channel numbers per Japanese law, referred to by frequency. Radios display frequency and often feature selective calling features. Similar services exist in other Asian countries, with varying frequency allocations. Radios sold in Taiwan covering 26.475 MHz - 27.275 MHz, 26.475 MHz - 27.270 MHz (this appears to be used in China as well, see also the 27.500 MHz to 39.475 MHz allocation), 25.550 MHz - 30.495 MHz, 25.555 MHz - 30.500 MHz, others covering 26.065 MHz - 28.755 MHz, 24.265 MHz - 29.655 MHz, the de facto standard export 25.615 MHz - 30.105 MHz or other obvious "overlays" from the standard CB channels. See also, the Chinese 27.500 MHz - 39.500 MHz allocation (27.5 MHz - 39.475 MHz on some radios). Radios for the 1 watt DSB Fishery Radio Service are still sold as of 2017, despite issues the widespread proliferation of cheaper "export", "10 meter" and "marine CB" equipment. Ranger Communications (RCI) sells "Marine CB" equipment that covers 26.065-28.755 MHz out of the box. The 10 meter band is often plagued by fishery radio interference because of this.
| 27310.5 kHz | 27.3105 MHz |
| 27334.5 kHz | 27.3345 MHz |
| 27338.5 kHz | 27.3385 MHz |
| 27342.5 kHz | 27.3425 MHz |
| 27346.5 kHz | 27.3465 MHz |
| 27350.5 kHz | 27.3505 MHz |
| 27354.5 kHz | 27.3545 MHz |
| 27358.5 kHz | 27.3585 MHz |
| 27362.5 kHz | 27.3625 MHz |
| 27366.5 kHz | 27.3665 MHz |
| 27370.5 kHz | 27.3705 MHz |
| 27378.5 kHz | 27.3785 MHz |
| 27382.5 kHz | 27.3825 MHz |
| 27386.5 kHz | 27.3865 MHz |
| 27388.5 kHz | 27.3885 MHz |
| 27398.5 kHz | 27.3985 MHz |
| 27404.5 kHz | 27.4045 MHz |
| 27418.5 kHz | 27.4185 MHz |
| 27426.5 kHz | 27.4265 MHz |
| 27434.5 kHz | 27.4345 MHz |
| 27442.5 kHz | 27.4425 MHz |
| 27452.5 kHz | 27.4525 MHz |
| 27458.5 kHz | 27.4585 MHz |
| 27466.5 kHz | 27.4665 MHz |
| 27470.5 kHz | 27.4705 MHz |
| Channel 41 | 27.415 MHz |
| Channel 42 | 27.425 MHz |
| Channel 43 | 27.435 MHz |
| Channel 44 | 27.455 MHz |
| Channel 45 | 27.465 MHz |
| Channel 46 | 27.475 MHz |
| Channel 47 | 27.485 MHz |
| Channel 48 | 27.505 MHz |
| Channel 49 | 27.515 MHz |
| Channel 50 | 27.525 MHz |
| Channel 51 | 27.535 MHz |
| Channel 52 | 27.555 MHz |
| Channel 53 | 27.565 MHz |
| Channel 54 | 27.575 MHz |
| Channel 55 | 27.585 MHz |
| Channel 56 | 27.605 MHz |
| Channel 57 | 27.615 MHz |
| Channel 58 | 27.625 MHz |
| Channel 59 | 27.635 MHz |
| Channel 60 | 27.655 MHz |
| Channel 61 | 27.665 MHz |
| Channel 62 | 27.675 MHz |
| Channel 63 | 27.685 MHz |
| Channel 64 | 27.695 MHz |
| Channel 65 | 27.705 MHz |
| Channel 66 | 27.715 MHz |
| Channel 67 | 27.725 MHz |
| Channel 68 | 27.735 MHz |
| Channel 69 | 27.745 MHz |
| Channel 70 | 27.755 MHz |
| Channel 71 | 27.765 MHz |
| Channel 72 | 27.775 MHz |
| Channel 73 | 27.785 MHz |
| Channel 74 | 27.795 MHz |
| Channel 75 | 27.805 MHz |
| Channel 76 | 27.815 MHz |
| Channel 77 | 27.825 MHz |
| Channel 78 | 27.835 MHz |
| Channel 79 | 27.845 MHz |
| Channel 80 | 27.855 MHz |
| 26.575 MHz | Germany | ||
| 26.675 MHz | |||
| 26.915 MHz | |||
| 26.925 MHz | |||
| 26.970 MHz | Lithuania | ||
| 27.110 MHz | Poland | ||
| 27.110 MHz | Russia | ||
| 27.150 MHz | Poland | ||
| 27.170 MHz | Poland | ||
| 27.190 MHz | |||
| 27.220 MHz | |||
| 27.230 MHz | |||
| 27.235 MHz | |||
| 27.250 MHz | Belarus | ||
| 27.300 MHz | |||
| 27.325 MHz | |||
| 27.430 MHz | |||
| 27.450 MHz | |||
| 27.470 MHz | |||
| 27.675 MHz | Russia | ||
| 27.765 MHz | Germany | ||
| 27.840 MHz | Poland | ||
[5] Ofcom Citizens' Band (CB) radio spectrum use - information and operation - general information on the 80 UK CB channels available 26.96 MHz - 27.41 MHz band (26.965 MHz - 27.405 MHz European CEPT harmonized AM FM SSB CB band) and 27.59625 MHz - 27.99625 MHz band (27.60125 MHz - 27.99125 MHz UK FM band)
[6] United States Federal Communications Commission (FCC) Part 95 - Personal Radio Services - including the CB Radio Service (CBRS) - aka Citizen's Band Radio Service 26.965 to 27.405 MHz AM/SSB FCC Rules Subpart D 47 CFR 95.401 through 47 CFR 95.673
[7] RF-MAN's CB radio history and information page - lots of great information on the history of CB in the USA, history of UK CB, relation to ham radio and FRS/GMRS, PMR446, etc.
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band
