FRS
Family Radio Service
UHF 462 MHz/467 MHz replacement (or rather supplement) to the CB radio service. Short range walkie talkie radios, nearly endless uses. Popular with private individuals, businesses, families, security services, etc. The FRS channels are shared with the GMRS service. All users must share channels with each other.
- Do you need a license to use the 22 FRS channels? No, you do not need a license to use all 22 FRS frequencies. Transmitting more than 2 watts on the 462 MHz channels requires a GMRS license, however.
- Are the "color dot" frequencies license free or part of FRS? Yes and no. The old White Dot (462.575 MHz), Black Dot (462.625 MHz) and Orange Dot (462.675 MHz) are now part of the FRS and GMRS services. Use of those three frequencies is legal without a license for business purposes under the FRS rules.
- Are Baofeng radios illegal? or Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be just fine. Do not use the default out of the box channels unless the radio comes programmed with the FRS channels out of the box. Make sure to use narrow band mode on the MURS and FRS/GMRS frequencies. Certain radios are FCC type accepted for Part 95 use. Examples include the Baofeng Baofeng Tech BTECH MURS-V1 and GMRS-V1 radios currently available on the market.
- What are the FRS channels? I want to program them in my Baofeng, Hytera, Motorola, Kenwood, Icom, etc. See the section above listing the 22 FRS frequencies. Remember to use narrow deviation FM mode (on Baofeng radios this is the NARR/WIDE setting - do not use WIDE). Program in whichever CTCSS or DCS (PL or DPL) tone or codes you wish to use on whichever channels you wish to use.
- FRS Channel 01 - 462.5625 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 02 - 462.5875 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 03 - 462.6125 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 04 - 462.6375 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 05 - 462.6625 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 06 - 462.6875 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 07 - 462.7125 MHz - 2 watt power limit, shared with simplex GMRS
 - FRS Channel 08 - 467.5625 MHz - 0.5 watt 500mW power limit
 - FRS Channel 09 - 467.5875 MHz - 0.5 watt 500mW power limit
 - FRS Channel 10 - 467.6125 MHz - 0.5 watt 500mW power limit
 - FRS Channel 11 - 467.6375 MHz - 0.5 watt 500mW power limit
 - FRS Channel 12 - 467.6625 MHz - 0.5 watt 500mW power limit
 - FRS Channel 13 - 467.6875 MHz - 0.5 watt 500mW power limit
 - FRS Channel 14 - 467.7125 MHz - 0.5 watt 500mW power limit
 - FRS Channel 15 - 462.5500 MHz - 0.5 watt 500mW power limit
 - FRS Channel 16 - 462.5750 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
 - FRS Channel 17 - 462.6000 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
 - FRS Channel 18 - 462.6250 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
 - FRS Channel 19 - 462.6500 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
 - FRS Channel 20 - 462.6750 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
 - FRS Channel 21 - 462.7000 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
 - FRS Channel 22 - 462.7250 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
§ 95.587 FRS additional requirements. Each FRS transmitter type must be designed to meet the following additional requirements. (a) Transmit frequency capability. FRS transmitter types must not be capable of transmitting on any frequency or channel other than those listed in § 95.563. (b) Antenna. The antenna of each FRS transmitter type must meet the following requirements. (1) The antenna must be a non-removable integral part of the FRS transmitter type. (2) The gain of the antenna must not exceed that of a half-wave dipole antenna. (3) The antenna must be designed such that the electric field of the emitted waves is vertically polarized when the unit is operated in the normal orientation. (c) Digital data transmissions. FRS transmitter types having the capability to transmit digital data must be designed to meet the following requirements. (1) FRS units may transmit digital data containing location information, or requesting location information from one or more other FRS or GMRS units, or containing a brief text message to another specific FRS or GMRS unit or units. (2) Digital data transmissions must be initiated by a manual action or command of the operator, except that FRS units may be designed to automatically respond with location data upon receiving an interrogation request from another FRS unit or a GMRS unit. (3) Digital data transmissions must not exceed one second in duration. (4) Digital data transmissions must not be sent more frequently than one digital data transmission within a thirty-second period, except that an FRS unit may automatically respond to more than one interrogation request received within a thirty-second period. (d) Packet mode. FRS transmitter types must not be capable of transmitting data in the store-and-forward packet operation mode. (e) Effective September 30, 2019, no person shall manufacture or import hand-held portable radio equipment capable of operating under this subpart (FRS) and other licensed or licensed-by-rule services in this chapter (part 15 unlicensed equipment authorizations are permitted if consistent with part 15 rules).
 - FRS channel 1 - 462.5625 MHz CSQ (no tone) (1-0) Patriot Radio - Neighborhood Watch Channel
 - FRS channel 1 - 462.5625 MHz CSQ (no tone) (1-0) Militia and security forces common interagency inter-group tactical coordination channel (secondary)
 - FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) is the prepper/militia secondary channel (tactical)
 - FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) Patriot Radio - Sovereign Citizens Freeman Channel
 - FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) Militia and security forces common interagency inter-group channel (primary)
 - FRS channel 3 - 462.6125 MHz CSQ (no tone) (3-0) is the recommend prepper/militia channel with MURS 3 and CB 3 as part of the AmRRON CH3 Project
 - FRS channel 3 - 462.6125 MHz CSQ (no tone) (3-0) Patriot Radio - Patriot Preppers Primary (see above)
 - FRS channel 3 - 462.6125 MHz various Black Lives Matter Protest Coordination Walkie Talkies (various tones/codes)
 - FRS channel 4 - 462.6375 MHz CSQ (no tone) (4-0) is the prepper/militia secondary channel
 - FRS channel 4 - 462.6375 MHz CSQ (no tone) (4-0) Militia and security forces common interagency inter-group tactical coordination channel (secondary)
 - FRS channel 4 - 462.6375 MHz CSQ (no tone) (4-0) Jeep 4x4 Clubs
 - FRS channel 4 - 462.6375 MHz subcode 4 (4-4) Jeep 4x4 Clubs PL 77.0 Hz, see also: CB channels 4 and 16
 - FRS channel 4 - 462.6375 MHz subcode 16 (4-16) Jeep 4x4 Clubs PL 114.8 Hz
 - FRS channel 7 - 462.7125 MHz subcode 15 (7-15) Airshow/milcom hobbyist recommended channel (backup) PL 110.9 Hz
 - FRS channel 8 - 467.5625 MHz various Black Lives Matter Protest Coordination Walkie Talkies (various tones/codes)
 - FRS channel 8 - 467.5625 MHz subcode 8 (8-8) backup militia operations channel PL 88.5 Hz
 - FRS channel 8 - 467.5625 MHz subcode 14 (8-14) back up militia operations channel PL 107.2 Hz
 - FRS channel 14 - 467.7125 MHz subcode 8 (14-8) back up militia operations channel 88.5 Hz
 - FRS channel 16 - 462.5750 MHz CSQ (no tone) (16-0) Jeep 4x4 Clubs, see also, FRS channel 4, MURS channel 4, CB channel 4
 - FRS channel 17 - 462.6000 MHz CSQ (no tone) (17-0) Patriot Radio Patriot Militia Tactical
 - FRS channel 19 - 462.6500 MHz CSQ (no tone) (19-0) Militia and security forces common interagency inter-group tactical coordination channel (secondary)
 - FRS channel 21 - 462.7000 MHz CSQ (no tone) (21-0) Militia and security forces common interagency inter-group tactical coordination channel (secondary)
- Channel 1 - 462.5625 MHz
 - Channel 2 - 462.5875 MHz
 - Channel 3 - 462.6125 MHz
 - Channel 4 - 462.6375 MHz
 - Channel 5 - 462.6625 MHz
 - Channel 6 - 462.6875 MHz
 - Channel 7 - 462.7125 MHz
 - Channel 8 - 467.5625 MHz
 - Channel 9 - 467.5875 MHz
 - Channel 10 - 467.6125 MHz
 - Channel 11 - 467.6375 MHz
 - Channel 12 - 467.6625 MHz
 - Channel 13 - 467.6875 MHz
 - Channel 14 - 467.7125 MHz
 - Channel 15 - 462.5500 MHz
 - Channel 16 - 462.5750 MHz
 - Channel 17 - 462.6000 MHz
 - Channel 18 - 462.6250 MHz
 - Channel 19 - 462.6500 MHz
 - Channel 20 - 462.6750 MHz
 - Channel 21 - 462.7000 MHz
 - Channel 22 - 462.7250 MHz
 - Code 1 - 67.0 Hz
 - Code 2 - 71.9 Hz
 - Code 3 - 74.4 Hz
 - Code 4 - 77.0 Hz
 - Code 5 - 79.7 Hz
 - Code 6 - 82.5 Hz
 - Code 7 - 85.4 Hz
 - Code 8 - 88.5 Hz
 - Code 9 - 91.5 Hz
 - Code 10 - 94.8 Hz
 - Code 11 - 97.4 Hz
 - Code 12 - 100.0 Hz
 - Code 13 - 103.5 Hz
 - Code 14 - 107.2 Hz
 - Code 15 - 110.9 Hz
 - Code 16 - 114.8 Hz
 - Code 17 - 118.8 Hz
 - Code 18 - 123.0 Hz
 - Code 19 - 127.3 Hz
 - Code 20 - 131.8 Hz
 - Code 21 - 136.5 Hz
 - Code 22 - 141.3 Hz
 - Code 23 - 146.2 Hz
 - Code 24 - 151.4 Hz
 - Code 25 - 156.7 Hz
 - Code 26 - 162.2 Hz
 - Code 27 - 167.9 Hz
 - Code 28 - 173.8 Hz
 - Code 29 - 179.9 Hz
 - Code 30 - 186.2 Hz
 - Code 31 - 192.8 Hz
 - Code 32 - 203.5 Hz
 - Code 33 - 210.7 Hz
 - Code 34 - 218.1 Hz
 - Code 35 - 225.7 Hz
 - Code 36 - 233.6 Hz
 - Code 37 - 241.8 Hz
 - Code 38 - 250.3 Hz
 - Code 39 - D023
 - Code 40 - D025
 - Code 41 - D026
 - Code 42 - D031
 - Code 43 - D032
 - Code 44 - D043
 - Code 45 - D047
 - Code 46 - D051
 - Code 47 - D054
 - Code 48 - D065
 - Code 49 - D071
 - Code 50 - D072
 - Code 51 - D073
 - Code 52 - D074
 - Code 53 - D114
 - Code 54 - D115
 - Code 55 - D116
 - Code 56 - D125
 - Code 57 - D131
 - Code 58 - D132
 - Code 59 - D134
 - Code 60 - D143
 - Code 61 - D152
 - Code 62 - D155
 - Code 63 - D156
 - Code 64 - D162
 - Code 65 - D165
 - Code 66 - D172
 - Code 67 - D174
 - Code 68 - D205
 - Code 69 - D223
 - Code 70 - D226
 - Code 71 - D243
 - Code 72 - D244
 - Code 73 - D245
 - Code 74 - D251
 - Code 75 - D261
 - Code 76 - D263
 - Code 77 - D265
 - Code 78 - D271
 - Code 79 - D306
 - Code 80 - D311
 - Code 81 - D315
 - Code 82 - D331
 - Code 83 - D343
 - Code 84 - D346
 - Code 85 - D351
 - Code 86 - D364
 - Code 87 - D365
 - Code 88 - D371
 - Code 89 - D411
 - Code 90 - D412
 - Code 91 - D413
 - Code 92 - D423
 - Code 93 - D431
 - Code 94 - D432
 - Code 95 - D445
 - Code 96 - D464
 - Code 97 - D465
 - Code 98 - D466
 - Code 99 - D503
 - Code 100 - D506
 - Code 101 - D516
 - Code 102 - D532
 - Code 103 - D546
 - Code 104 - D565
 - Code 105 - D606
 - Code 106 - D612
 - Code 107 - D624
 - Code 108 - D627
 - Code 109 - D631
 - Code 110 - D632
 - Code 111 - D654
 - Code 112 - D662
 - Code 113 - D664
 - Code 114 - D703
 - Code 115 - D712
 - Code 116 - D723
 - Code 117 - D731
 - Code 118 - D732
 - Code 119 - D734
 - Code 120 - D743
 - Code 121 - D754
 - Code 1 - 67.0 Hz
 - Code 2 - 69.3 Hz
 - Code 3 - 71.9 Hz
 - Code 4 - 74.4 Hz
 - Code 5 - 77.0 Hz
 - Code 6 - 79.7 Hz
 - Code 7 - 82.5 Hz
 - Code 8 - 85.4 Hz
 - Code 9 - 88.5 Hz
 - Code 10 - 91.5 Hz
 - Code 11 - 94.8 Hz
 - Code 12 - 97.4 Hz
 - Code 13 - 100.0 Hz
 - Code 14 - 103.5 Hz
 - Code 15 - 107.2 Hz
 - Code 16 - 110.9 Hz
 - Code 17 - 114.8 Hz
 - Code 18 - 118.8 Hz
 - Code 19 - 123.0 Hz
 - Code 20 - 127.3 Hz
 - Code 21 - 131.8 Hz
 - Code 22 - 136.5 Hz
 - Code 23 - 141.3 Hz
 - Code 24 - 146.2 Hz
 - Code 25 - 151.4 Hz
 - Code 26 - 156.7 Hz
 - Code 27 - 159.8 Hz
 - Code 28 - 162.2 Hz
 - Code 29 - 165.5 Hz
 - Code 30 - 167.9 Hz
 - Code 31 - 171.3 Hz
 - Code 32 - 173.8 Hz
 - Code 33 - 177.3 Hz
 - Code 34 - 179.9 Hz
 - Code 35 - 183.5 Hz
 - Code 36 - 186.2 Hz
 - Code 37 - 189.9 Hz
 - Code 38 - 192.8 Hz
 - Code 39 - 196.6 Hz
 - Code 40 - 199.5 Hz
 - Code 41 - 203.5 Hz
 - Code 42 - 206.5 Hz
 - Code 43 - 210.7 Hz
 - Code 44 - 218.1 Hz
 - Code 45 - 225.7 Hz
 - Code 46 - 229.1 Hz
 - Code 47 - 233.6 Hz
 - Code 48 - 241.8 Hz
 - Code 49 - 250.3 Hz
 - Code 50 - 254.1 Hz
*See also: default/factory radio settings for Business Radio and MURS.
- Commonly heard / encountered tones/codes - by FRS channel and frequency:
- FRS Channel 1 - 462.5625 MHz CSQ - Default out of the box channel for many FRS handhelds
 - FRS Channel 1 - 462.5625 MHz CSQ - Patriot Militia Prepper Radio Neighborhood Watch Channel/Standby Channel
 - FRS Channel 1 - 462.5625 MHz CSQ - Unofficial FRS Calling/Emergency Channel (see also: Channel 20 code 22)
 - FRS Channel 1 - 462.5625 MHz 67.0 Hz - Default out of the box channel/privacy code for many FRS handhelds, including Motorola
 - FRS Channel 1 - 462.5625 MHz 67.0 Hz - Retevis FRS radios default channel 1
 - FRS Channel 1 - 462.5625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 3
 - FRS Channel 1 - 462.5625 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 1, group code A
 - FRS Channel 1 - 462.5625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 2
 - FRS Channel 1 - 462.5625 MHz 69.3 Hz - Calford NTC688 wireless intercom channel 1, group code B
 - FRS Channel 1 - 462.5625 MHz 107.2 Hz - Midland FRS extra channel channel 42
 - FRS Channel 1 - 462.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code A
 - FRS Channel 1 - 462.5625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 1
 - FRS Channel 1 - 462.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code B
 - FRS Channel 1 - 462.5625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 1
 - FRS Channel 1 - 462.5625 MHz 165.5 Hz - Calford NTC688 wireless intercom channel 1, group code C
 - FRS Channel 1 - 462.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code C
 - FRS Channel 1 - 462.5625 MHz 250.3 Hz - Midland FRS extra channel channel 23
 - FRS Channel 1 - 462.5625 MHz 026 DCS - Retevis RT-27 IC FRS radios default channel 15
 - FRS Channel 1 - 462.5625 MHz 261 DCS - Baofeng UV-B5 Pofung UV-B5 default channel 7
 - FRS Channel 2 - 462.5875 MHz CSQ - Patriot Militia Prepper Radio - FRS Calling Channel - Sovereign Citizens Ops Tactical
 - FRS Channel 2 - 462.5875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 3
 - FRS Channel 2 - 462.5875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 2
 - FRS Channel 2 - 462.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code A
 - FRS Channel 2 - 462.5875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 2
 - FRS Channel 2 - 462.5875 MHz 118.8 Hz - Retevis FRS radios default channel 2
 - FRS Channel 2 - 462.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code B
 - FRS Channel 2 - 462.5875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 1
 - FRS Channel 2 - 462.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code C
 - FRS Channel 2 - 462.5875 MHz 023 DCS - Midland FRS extra channel channel 31
 - FRS Channel 2 - 462.5875 MHz 025 DCS - Midland FRS extra channel channel 50
 - FRS Channel 2 - 462.5875 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
 - FRS Channel 2 - 462.5875 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
 - FRS Channel 2 - 462.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 2, group code C
 - FRS Channel 2 - 462.5875 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
 - FRS Channel 2 - 462.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 2, group code B
 - FRS Channel 2 - 462.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 2, group code A
 - FRS Channel 3 - 462.6125 MHz CSQ - Patriot Militia Prepper Radio - FRS Calling Channel - AmRRON CH3
 - FRS Channel 3 - 462.6125 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 3
 - FRS Channel 3 - 462.6125 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 2, group code A
 - FRS Channel 3 - 462.6125 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 2
 - FRS Channel 3 - 462.6125 MHz 69.3 Hz - Calford NCT688 wireless intercom channel 2, group code B
 - FRS Channel 3 - 462.6125 MHz 97.4 Hz - Midland FRS extra channel channel 43
 - FRS Channel 3 - 462.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code A
 - FRS Channel 3 - 462.6125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 3
 - FRS Channel 3 - 462.6125 MHz 118.8 Hz - HOSMART HY806 / HY810 wireless intercom channel 0
 - FRS Channel 3 - 462.6125 MHz 127.3 Hz - Retevis FRS radios default channel 3
 - FRS Channel 3 - 462.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code B
 - FRS Channel 3 - 462.6125 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 1
 - FRS Channel 3 - 462.6125 MHz 165.5 Hz - HOSMART HY777 / HY787 wireless intercom group call channel
 - FRS Channel 3 - 462.6125 MHz 165.5 Hz - Calford NCT688 wireless intercom channel 2, group code C
 - FRS Channel 3 - 462.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code C
 - FRS Channel 3 - 462.6125 MHz 225.7 Hz - Midland FRS extra channel channel 24
 - FRS Channel 3 - 462.6125 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 3
 - FRS Channel 3 - 462.6125 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 2
 - FRS Channel 3 - 462.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 3, group code C
 - FRS Channel 3 - 462.6125 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 1
 - FRS Channel 3 - 462.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 3, group code B
 - FRS Channel 3 - 462.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 3, group code A
 - FRS Channel 4 - 462.6375 MHz CSQ - Patriot Militia Prepper Radio - Prepper/Militia Secondary (shared with 4x4/Jeep users)
 - FRS Channel 4 - 462.6375 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 3
 - FRS Channel 4 - 462.6375 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 3, group code A
 - FRS Channel 4 - 462.6375 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 2
 - FRS Channel 4 - 462.6375 MHz 69.3 Hz - Calford NCT688 wireless intercom channel 3, group code B
 - FRS Channel 4 - 462.6375 MHz 77.0 Hz - Jeep and 4x4 Club channel (may be used with CSQ/no tone or 114.8 Hz)
 - FRS Channel 4 - 462.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code A
 - FRS Channel 4 - 462.6375 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 4
 - FRS Channel 4 - 462.6375 MHz 114.8 Hz - Jeep and 4x4 Club channel (may be used with CSQ/no tone or 77.0 Hz)
 - FRS Channel 4 - 462.6375 MHz 131.8 Hz - Retevis FRS radios default channel 4
 - FRS Channel 4 - 462.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code B
 - FRS Channel 4 - 462.6375 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 1
 - FRS Channel 4 - 462.6375 MHz 165.5 Hz - Calford NCT688 wireless intercom channel 3, group code C
 - FRS Channel 4 - 462.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code C
 - FRS Channel 4 - 462.6375 MHz 032 DCS - Midland FRS extra channel channel 32
 - FRS Channel 4 - 462.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 3
 - FRS Channel 4 - 462.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 2
 - FRS Channel 4 - 462.6375 MHz 734 DCS - Wuloo WL666 wireless intercom channel 4, group code C
 - FRS Channel 4 - 462.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 1
 - FRS Channel 4 - 462.6375 MHz 743 DCS - Wuloo WL666 wireless intercom channel 4, group code B
 - FRS Channel 4 - 462.6375 MHz 754 DCS - Wuloo WL666 wireless intercom channel 4, group code A
 - FRS Channel 5 - 462.6625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 3
 - FRS Channel 5 - 462.6625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 2
 - FRS Channel 5 - 462.6625 MHz 88.5 Hz - Midland FRS extra channel channel 44
 - FRS Channel 5 - 462.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code A
 - FRS Channel 5 - 462.6625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 5
 - FRS Channel 5 - 462.6625 MHz 136.5 Hz - Retevis FRS radios default channel 5
 - FRS Channel 5 - 462.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code B
 - FRS Channel 5 - 462.6625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 1
 - FRS Channel 5 - 462.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code C
 - FRS Channel 5 - 462.6625 MHz 203.5 Hz - Midland FRS extra channel channel 25
 - FRS Channel 5 - 462.6625 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 3
 - FRS Channel 5 - 462.6625 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 2
 - FRS Channel 5 - 462.6625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 5, group code C
 - FRS Channel 5 - 462.6625 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 1
 - FRS Channel 5 - 462.6625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 5, group code B
 - FRS Channel 5 - 462.6625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 5, group code A
 - FRS Channel 6 - 462.6875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 3
 - FRS Channel 6 - 462.6875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 2
 - FRS Channel 6 - 462.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code A
 - FRS Channel 6 - 462.6875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 6
 - FRS Channel 6 - 462.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code B
 - FRS Channel 6 - 462.6875 MHz 141.3 Hz - Retevis FRS radios default channel 8
 - FRS Channel 6 - 462.6875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 1
 - FRS Channel 6 - 462.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code C
 - FRS Channel 6 - 462.6875 MHz 047 DCS - Midland FRS extra channel channel 33
 - FRS Channel 6 - 462.6875 MHz 731 DCS - HOSMART HY810 wireless intercom channel 6, group code 3
 - FRS Channel 6 - 462.6875 MHz 732 DCS - HOSMART HY810 wireless intercom channel 6, group code 2
 - FRS Channel 6 - 462.6875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 6, group code C
 - FRS Channel 6 - 462.6875 MHz 743 DCS - HOSMART HY810 wireless intercom channel 6, group code 1
 - FRS Channel 6 - 462.6875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 6, group code B
 - FRS Channel 6 - 462.6875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 6, group code A
 - FRS Channel 7 - 462.7125 MHz 79.7 Hz - Midland FRS extra channel channel 45
 - FRS Channel 7 - 462.7125 MHz 97.4 Hz - Channel "7-11" - commonly used channel
 - FRS Channel 7 - 462.7125 MHz 110.9 Hz - Airshow and Milcom Hobbyist and Monitors Intercept Backup Channel
 - FRS Channel 7 - 462.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code A
 - FRS Channel 7 - 462.7125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 7
 - FRS Channel 7 - 462.7125 MHz 118.8 Hz - HOSMART HY777 / HY787 wireless intercom channel 7
 - FRS Channel 7 - 462.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code B
 - FRS Channel 7 - 462.7125 MHz 146.2 Hz - Retevis FRS radios default channel 9
 - FRS Channel 7 - 462.7125 MHz 179.9 Hz - Midland FRS extra channel channel 26
 - FRS Channel 7 - 462.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code C
 - FRS Channel 7 - 462.7125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 7, group code C
 - FRS Channel 7 - 462.7125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 7, group code B
 - FRS Channel 7 - 462.7125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 7, group code A
 - FRS Channel 8 - 467.5625 MHz 88.5 Hz - Patriot Militia Prepper Radio - FRS Operations/Tactical "88" or "8-8"
 - FRS Channel 8 - 467.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code A
 - FRS Channel 8 - 467.5625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 8
 - FRS Channel 8 - 467.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code B
 - FRS Channel 8 - 467.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code C
 - FRS Channel 8 - 467.5625 MHz 026 DCS - Retevis RT-27 IC FRS radios default channel 16
 - FRS Channel 8 - 467.5625 MHz 065 DCS - Midland FRS extra channel channel 34
 - FRS Channel 8 - 467.5625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 8, group code C
 - FRS Channel 8 - 467.5625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 8, group code B
 - FRS Channel 8 - 467.5625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 8, group code A
 - FRS Channel 9 - 467.5625 MHz 97.4 Hz - Patriot Militia Prepper Radio - FRS Operations/Tactical "911" or "9-11"
 - FRS Channel 9 - 467.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code A
 - FRS Channel 9 - 467.5875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 9
 - FRS Channel 9 - 467.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code B
 - FRS Channel 9 - 467.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code C
 - FRS Channel 9 - 467.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 9, group code C
 - FRS Channel 9 - 467.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 9, group code B
 - FRS Channel 9 - 467.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 9, group code A
 - FRS Channel 10 - 467.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code A
 - FRS Channel 10 - 467.6125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 10
 - FRS Channel 10 - 467.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code B
 - FRS Channel 10 - 467.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code C
 - FRS Channel 10 - 467.6125 MHz 073 DCS - Midland FRS extra channel channel 35
 - FRS Channel 10 - 467.6125 MHz 627 DCS - HOSMART HY806 / HY810 wireless intercom group call channel
 - FRS Channel 10 - 467.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 0, group code C
 - FRS Channel 10 - 467.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 0, group code B
 - FRS Channel 10 - 467.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 0, group code A
 - FRS Channel 11 - 467.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code A
 - FRS Channel 11 - 467.6375 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 11
 - FRS Channel 11 - 467.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code B
 - FRS Channel 11 - 467.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code C
 - FRS Channel 11 - 467.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
 - FRS Channel 11 - 467.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
 - FRS Channel 11 - 467.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
 - FRS Channel 12 - 467.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code A
 - FRS Channel 12 - 467.6625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 12
 - FRS Channel 12 - 467.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code B
 - FRS Channel 12 - 467.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code C
 - FRS Channel 12 - 467.6625 MHz 115 DCS - Midland FRS extra channel channel 36
 - FRS Channel 13 - 467.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code A
 - FRS Channel 13 - 467.6875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 13
 - FRS Channel 13 - 467.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code B
 - FRS Channel 13 - 467.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code C
 - FRS Channel 14 - 467.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code A
 - FRS Channel 14 - 467.7125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 14
 - FRS Channel 14 - 467.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code B
 - FRS Channel 14 - 467.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code C
 - FRS Channel 15 - 467.7125 MHz 250.3 Hz - Airshow and Milcom Hobbyist and Monitors Intercept Primary Channel
 - FRS Channel 14 - 467.7125 MHz 131 DCS - Midland FRS extra channel channel 37
 - FRS Channel 14 - 467.7125 MHz 731 DCS - HOSMART HY810 wireless intercom channel 7, group code 3
 - FRS Channel 14 - 467.7125 MHz 732 DCS - HOSMART HY810 wireless intercom channel 7, group code 2
 - FRS Channel 14 - 467.7125 MHz 743 DCS - HOSMART HY810 wireless intercom channel 7, group code 1
 - FRS Channel 14 - 467.7125 MHz 743 DCS - Wuloo 22 channel 100 code wireless intercom group call channel code
 - FRS Channel 15 - 462.5500 MHz 71.9 Hz - Midland FRS extra channel channel 46
 - FRS Channel 15 - 462.5500 MHz 123.0 Hz - Retevis FRS radios default channel 10
 - FRS Channel 15 - 462.5500 MHz 162.2 Hz - Midland FRS extra channel channel 27
 - FRS Channel 15 - 462.5500 MHz 731 DCS - HOSMART HY810 wireless intercom channel 8, group code 3
 - FRS Channel 15 - 462.5500 MHz 732 DCS - HOSMART HY810 wireless intercom channel 8, group code 2
 - FRS Channel 15 - 462.5500 MHz 743 DCS - HOSMART HY810 wireless intercom channel 8, group code 1
 - FRS Channel 16 - 462.5750 MHz Various - White Dot Itinerant Business Band - old color dot star channel designation
 - FRS Channel 16 - 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
 - FRS Channel 16 - 462.5750 MHz 023 DCS - BlackBox Bantam radio default channel 9
 - FRS Channel 16 - 462.5750 MHz 143 DCS - Midland FRS extra channel channel 38
 - FRS Channel 16 - 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS, D743I - D654N)
 - FRS Channel 16 - 462.5750 MHz 731 DCS - HOSMART HY810 wireless intercom channel 9, group code 3
 - FRS Channel 16 - 462.5750 MHz 732 DCS - HOSMART HY810 wireless intercom channel 9, group code 2
 - FRS Channel 16 - 462.5750 MHz 743 DCS - HOSMART HY810 wireless intercom channel 9, group code 1
 - FRS Channel 17 - 462.6000 MHz CSQ - Patriot Militia Prepper Radio - FRS/GMRS Operations Tactical Channel 17
 - FRS Channel 17 - 462.6000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code A
 - FRS Channel 17 - 462.6000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code B
 - FRS Channel 17 - 462.6000 MHz 146.2 Hz - Midland FRS extra channel channel 28
 - FRS Channel 17 - 462.6000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code C
 - FRS Channel 17 - 462.6000 MHz 241.8 Hz - Midland FRS extra channel channel 47
 - FRS Channel 17 - 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS, D332I - D455N)
 - FRS Channel 18 - 462.6250 MHz Various - Black Dot Itinerant Business Band - old color dot star channel designation
 - FRS Channel 18 - 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
 - FRS Channel 18 - 462.6250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code A
 - FRS Channel 18 - 462.6250 MHz 127.3 Hz - Baofeng BF-888S, B-888, BF-666S, etc. channel 6
 - FRS Channel 18 - 462.6250 MHz 127.3 Hz - Retevis FRS radios default channel 6
 - FRS Channel 18 - 462.6250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code B
 - FRS Channel 18 - 462.6250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code C
 - FRS Channel 18 - 462.6250 MHz 023 DCS - BlackBox Bantam radio default channel 10
 - FRS Channel 18 - 462.6250 MHz 156 DCS - Midland FRS extra channel channel 39
 - FRS Channel 19 - 462.6500 MHz CSQ - Patriot Militia Prepper Radio - FRS/GMRS Operations Tactical Channel 19
 - FRS Channel 19 - 462.6500 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code A
 - FRS Channel 19 - 462.6500 MHz 131.8 Hz - Midland FRS extra channel channel 29
 - FRS Channel 19 - 462.6500 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code B
 - FRS Channel 19 - 462.6500 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code C
 - FRS Channel 19 - 462.6500 MHz 218.1 Hz - Midland FRS extra channel channel 48
 - FRS Channel 19 - 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS, D243I - D351N)
 - FRS Channel 20 - 462.6750 MHz Various - Orange Dot Itinerant Business Band - old color dot star channel designation
 - FRS Channel 20 - 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
 - FRS Channel 20 - 462.6750 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code A
 - FRS Channel 20 - 462.6750 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code B
 - FRS Channel 20 - 462.6750 MHz 141.3 Hz - GMRS Calling / Travel Channel "GMRS 675"
 - FRS Channel 20 - 462.6750 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code C
 - FRS Channel 20 - 462.6750 MHz 023 DCS - Blackbox Bantam radio default channel 11
 - FRS Channel 20 - 462.6750 MHz 172 DCS - Midland FRS extra channel channel 40
 - FRS Channel 20 - 462.6750 MHz 606 DCS - Retevis FRS radios default channel 14 - D606N
 - FRS Channel 21 - 462.7000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code A
 - FRS Channel 21 - 462.7000 MHz 118.8 Hz - Midland FRS extra channel channel 30
 - FRS Channel 21 - 462.7000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code B
 - FRS Channel 21 - 462.7000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code C
 - FRS Channel 21 - 462.7000 MHz 192.8 Hz - Midland FRS extra channel channel 49
 - FRS Channel 21 - 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS, D731I - D155N)
 - FRS Channel 21 - 462.7000 MHz 743 DCS - HOSMART (and others) 10 channel wireless intercom group call channel
 - FRS Channel 21 - 462.7000 MHz 743 DCS - Wuloo WL666 wireless intercom group call channel
 - FRS Channel 22 - 462.7250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code A
 - FRS Channel 22 - 462.7250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code B
 - FRS Channel 22 - 462.7250 MHz 136.5 Hz - Baofeng BF-888S, B-888, BF-666S, etc. channel 7
 - FRS Channel 22 - 462.7250 MHz 136.5 Hz - Retevis FRS radios default channel 7
 - FRS Channel 22 - 462.7250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code C
 - FRS Channel 22 - 462.7250 MHz 250.3 Hz - Highest channel/privacy code combination possible (on CTCSS only radios)
 - FRS Channel 22 - 462.7250 MHz 223 DCS - Midland FRS extra channel channel 41
 - FRS Channel 22 - 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS, D462I - D252N)
 - FRS Channel 22 - 462.7250 MHz 734 DCS - Wuloo WL666 wireless intercom channel 1, group code C
 - FRS Channel 22 - 462.7250 MHz 743 DCS - Wuloo WL666 wireless intercom channel 1, group code B
 - FRS Channel 22 - 462.7250 MHz 754 DCS - Wuloo WL666 wireless intercom channel 1, group code A
 - FRS Channel 22 - 462.7250 MHz 754 DCS - Highest channel/privacy code combination possible (on radios with DCS)
The opposite of the commonly used tones/codes list - intended as guidance for somebody programming radios for a work crew, special event, radio rental, custom programming Baofeng BF-888S, BF-88A, UV-5R, UV-82, BTECH GMRS-V1 or similar field-programmable radios. See sister section for business radio frequencies.
 - CH17 - Code # 08 [88.5 PL] - Display Channel 17-08 ----- 462.6000 MHz 88.5 Hz
 - CH18 - Code # 12 [100.0 PL] - Display Channel 18-12 ----- 462.6250 MHz 100.0 Hz
 - CH19 - Code # 29 [179.9 PL] - Display Channel 19-29 ----- 462.6500 MHz 179.9 Hz
 - CH20 - Code # 25 [156.7 PL] - Display Channel 20-25 ----- 462.6750 MHz 156.7 Hz
 - CH21 - Code # 12 [100.0 PL] - Display Channel 21-12 ----- 462.7000 MHz 100.0 Hz
 - CH22 - Code # 11 [97.4 PL] - Display Channel 22-11 ----- 462.7250 MHz 97.4 Hz
- CH01 - 467.6625 MHz - 156.7 Hz
 - CH02 - 467.6375 MHz - 156.7 Hz
 - CH05 - 462.6000 MHz - 156.7 Hz
 - CH09 - 467.6625 MHz - 156.7 Hz
 - CH10 - 467.6375 MHz - 156.7 Hz
 - CH13 - 462.6000 MHz - 156.7 Hz
 - Channel 8 - 462.5500 MHz
 - Channel 9 - 462.5750 MHz
 - Channel 10 - 462.6000 MHz
 - Channel 11 - 462.6250 MHz
 - Channel 12 - 462.6500 MHz
 - Channel 13 - 462.6750 MHz
 - Channel 14 - 462.7000 MHz
 - Channel 15 - 462.7250 MHz
 - CHANNEL 1 - 467.6375 MHz
 - CHANNEL 2 - 462.5875 MHz
 - CHANNEL 3 - 462.6125 MHz
 - CHANNEL 4 - 462.6375 MHz
 - CHANNEL 5 - 462.6625 MHz
 - CHANNEL 6 - 462.6875 MHz
 - CHANNEL 7 - 467.7125 MHz
 - CHANNEL 8 - 462.5500 MHz
 - CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
 - Code 2 - 69.3 Hz PL
 - Code 3 - 67.0 Hz PL
 - CHANNEL 1 - 462.5625 MHz
 - Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
 - Code 2 - 732 DCS / 732 DPL
 - Code 3 - 731 DCS / 731 DPL
 - CHANNEL 2 - 462.6125 MHz
 - CHANNEL 3 - 462.6375 MHz
- CHANNEL A - 462.5625 MHz
 - CHANNEL B - 462.5875 MHz
 - CHANNEL C - 462.6125 MHz
 - CHANNEL D - 462.6375 MHz
- CHANNEL 0 - 462.6625 MHz
 - CHANNEL 1 - 467.7125 MHz
 - CHANNEL 2 - 467.6875 MHz
 - CHANNEL 3 - 467.6625 MHz
 - CHANNEL 4 - 467.6375 MHz
 - CHANNEL 5 - 467.6125 MHz
 - CHANNEL 6 - 467.5875 MHz
 - CHANNEL 7 - 467.5625 MHz
 - CHANNEL 8 - 462.7125 MHz
 - CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
 - Code B - 136.5 Hz PL
 - Code C - 186.2 Hz PL
 - CHANNEL 10 - 462.6375 MHz
 - CHANNEL 11 - 462.6125 MHz
 - CHANNEL 12 - 462.5875 MHz
 - CHANNEL 13 - 462.5625 MHz
 - CHANNEL 14 - 462.7250 MHz
 - CHANNEL 15 - 462.7000 MHz
 - CHANNEL 16 - 462.6750 MHz
 - CHANNEL 17 - 462.6500 MHz
 - CHANNEL 18 - 462.6250 MHz
 - CHANNEL 19 - 462.6000 MHz
 - CHANNEL 0 - 467.6125 MHz
 - CHANNEL 1 - 462.7250 MHz
 - CHANNEL 8 - 467.5625 MHz
 - CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
 - Code B - 743 DCS / 743 DPL
 - Code C - 734 DCS / 734 DPL
 - CHANNEL 7 - 462.7125 MHz
 - CHANNEL 10 - 467.6125 MHz
 - CHANNEL 11 - 467.6375 MHz
 - CHANNEL 12 - 467.6625 MHz
 - CHANNEL 13 - 467.6875 MHz
 - CHANNEL 14 - 467.7125 MHz
 - CHANNEL 15 - 462.5500 MHz
 - CHANNEL 16 - 462.5750 MHz
 - CHANNEL 17 - 462.6000 MHz
 - CHANNEL 19 - 462.6500 MHz
 - CHANNEL 20 - 462.6750 MHz
 - CHANNEL 21 - 462.7000 MHz
 - CHANNEL 22 - 462.5625 MHz
 - Code 01 - 754 DCS / 754 DPL
 - Code 02 - 743 DCS / 743 DPL
 - Code 03 - 734 DCS / 734 DPL
 - Code 04 - 77.0 Hz PL
 - Code 05 - 79.7 Hz PL
 - Code 06 - 82.5 Hz PL
 - Code 07 - 85.4 Hz PL
 - Code 08 - 88.5 Hz PL
 - Code 09 - 91.5 Hz PL
 - Code 10 - 94.8 Hz PL
 - Code 11 - 97.4 Hz PL
 - Code 12 - 100.0 Hz PL
 - Code 13 - 103.5 Hz PL
 - Code 14 - 107.2 Hz PL
 - Code 15 - 110.9 Hz PL
 - Code 16 - 114.8 Hz PL
 - Code 17 - 118.8 Hz PL
 - Code 18 - 123.0 Hz PL
 - Code 19 - 127.3 Hz PL
 - Code 20 - 131.8 Hz PL
 - Code 21 - 136.5 Hz PL
 - Code 22 - 141.3 Hz PL
 - Code 23 - 146.2 Hz PL
 - Code 24 - 151.4 Hz PL
 - Code 25 - 156.7 Hz PL
 - Code 26 - 162.2 Hz PL
 - Code 27 - 167.9 Hz PL
 - Code 28 - 173.8 Hz PL
 - Code 29 - 179.9 Hz PL
 - Code 30 - 186.2 Hz PL
 - Code 31 - 192.8 Hz PL
 - Code 32 - 203.5 Hz PL
 - Code 33 - 210.7 Hz PL
 - Code 34 - 218.1 Hz PL
 - Code 35 - 225.7 Hz PL
 - Code 36 - 233.6 Hz PL
 - Code 37 - 241.8 Hz PL
 - Code 38 - 250.3 Hz PL
 - Code 39 - 023 DCS
 - Code 40 - 025 DCS
 - Code 41 - 026 DCS
 - Code 42 - 031 DCS
 - Code 43 - 032 DCS
 - Code 44 - 043 DCS
 - Code 45 - 047 DCS
 - Code 46 - 051 DCS
 - Code 47 - 054 DCS
 - Code 48 - 065 DCS
 - Code 49 - 071 DCS
 - Code 50 - 072 DCS
 - Code 51 - 073 DCS
 - Code 52 - 074 DCS
 - Code 53 - 114 DCS
 - Code 54 - 115 DCS
 - Code 55 - 116 DCS
 - Code 56 - 125 DCS
 - Code 57 - 131 DCS
 - Code 58 - 132 DCS
 - Code 59 - 143 DCS
 - Code 60 - 143 DCS
 - Code 61 - 152 DCS
 - Code 62 - 155 DCS
 - Code 63 - 156 DCS
 - Code 64 - 162 DCS
 - Code 65 - 165 DCS
 - Code 66 - 172 DCS
 - Code 67 - 174 DCS
 - Code 68 - 205 DCS
 - Code 69 - 223 DCS
 - Code 70 - 226 DCS
 - Code 71 - 243 DCS
 - Code 72 - 244 DCS
 - Code 73 - 245 DCS
 - Code 74 - 251 DCS
 - Code 75 - 261 DCS
 - Code 76 - 263 DCS
 - Code 77 - 265 DCS
 - Code 78 - 271 DCS
 - Code 79 - 306 DCS
 - Code 80 - 311 DCS
 - Code 81 - 315 DCS
 - Code 82 - 331 DCS
 - Code 83 - 343 DCS
 - Code 84 - 346 DCS
 - Code 85 - 351 DCS
 - Code 86 - 364 DCS
 - Code 87 - 365 DCS
 - Code 88 - 371 DCS
 - Code 89 - 411 DCS
 - Code 90 - 412 DCS
 - Code 91 - 413 DCS
 - Code 92 - 423 DCS
 - Code 93 - 431 DCS
 - Code 94 - 432 DCS
 - Code 95 - 445 DCS
 - Code 96 - 464 DCS
 - Code 97 - 465 DCS
 - Code 98 - 466 DCS
 - Code 99 - 503 DCS
