FRS
Revision as of 18:33, 12 February 2021 by R4002 (Talk | contribs)
Family Radio Service
UHF 462 MHz/467 MHz replacement (or rather supplement) to the CB radio service. Short range walkie talkie radios, nearly endless uses. Popular with private individuals, businesses, families, security services, etc. The FRS channels are shared with the GMRS service. All users must share channels with each other. However, there are "recommended use" assignments for specific channels (much like the CB Radio, MURS and GMRS services).
Were you looking for militia tactical radio channel plans? (FRS is an important part).
  • Do you need a license to use the 22 FRS channels? No, you do not need a license to use all 22 FRS frequencies. Transmitting more than 2 watts on the 462 MHz channels requires a GMRS license, however. You may use FRS for business, personal or any other purpose.
  • Are the "color dot" frequencies license free or part of FRS? Yes and no. The old White Dot (462.575 MHz), Black Dot (462.625 MHz) and Orange Dot (462.675 MHz) are now part of the FRS and GMRS services. Use of those three frequencies is legal without a license for business purposes under the FRS rules. Other color dot channels (151.625 MHz, 151.955 MHz, 464.550 MHz, 464.500 MHz, etc.) require FCC licensing. The 154.570 MHz and 154.600 MHz MURS channels were previously color dot channels as well - and those are license free under the MURS service.
  • Are Baofeng radios illegal? or Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be just fine. Do not use the default out of the box channels unless the radio comes programmed with the FRS channels out of the box. Make sure to use narrow band mode on the MURS and FRS/GMRS frequencies. Certain radios are FCC type accepted for Part 95 use. Examples include the Baofeng Baofeng Tech BTECH MURS-V1 and GMRS-V1 radios currently available on the market. Other Baofeng radios such as the BF-88A and several others are now available. Other companies such as Retevis and others produce FCC approved FRS radios for the market as well.
  • What are the FRS channels? I want to program them in my Baofeng, Hytera, Retevis, BTECH, TYT, QYT, Motorola, Kenwood, Icom, etc. See the section above listing the 22 FRS frequencies. Remember to use narrow deviation FM mode (on Baofeng radios this is the NARR/WIDE or NFM/FM setting - do not use WIDE or FM - use NFM/NARR. Program in whichever CTCSS or DCS (PL or DPL) tone or codes you wish to use on whichever channels you wish to use.
  • Should I program the FRS frequencies or channels FM deviation in wide or narrow mode? All 22 FRS channels must be programmed in narrow deviation mode or narrow bandwidth mode. This is referred to as 12.5 kHz bandwidth, narrowband, NFM, NBFM, narrow FM or simply "narrow". Not only is this required by FCC rules but due to the frequency spacing used on the FRS band, 11 kHz or narrower bandwidth is strongly recommended. On CHIRP radio programming software this is NFM, not FM. Same with B-480 radio programming software. If you're manually programming radios, set the bandwidth to NARR or NARROW - not WIDE. Baofeng UV-5R, UV-82, UV-82HP, BF-F8HP, UV-6R, UV-9R, UV-5RE etc. family radios' narrow mode or NFM mode is 9K20F3E emission, which meets the bandwidth requirements for FRS. Other FRS radios transmit even more narrow FM (10 kHz, 8 kHz or even 5-6 kHz wide super narrow FM narrow FM).
  • I live in an urbanized area with lots of activity on the FRS channels, how do I avoid annoying interference from other groups on the same channel? See question below regarding which tones and codes should be avoided. Remember that most FRS radios default to with carrier squelch (no tone/code) or 67.0 Hz (code 1) when the radio comes from the factory.
  • I'm programming a set of radios with the FRS frequencies - which CTCSS PL or DCS DPL DTCS tones or codes should I avoid? See the list below of CTCSS or PL or CTCS tones and DCS or DPL or DTCS codes to avoid for each of the 22 FRS frequencies. These are the most commonly used tones and codes that are either commonly used or pre-programmed into radios. Avoid using these tones and codes to reduce the chance of co-channel interference from other users on the same channel. Carrier squelch (CSQ) or "code 0" should be avoided as well. When you set your radio to carrier squelch - you will hear all transmissions on the channel you're using, regardless of the tone or code the other groups you're hearing are using.
  • CTCSS Tones To Avoid
  • FRS Channel 16 - 114.8 Hz
  • DCS Codes To Avoid
§ 95.587 FRS additional requirements. Each FRS transmitter type must be designed to meet the following additional requirements. (a) Transmit frequency capability. FRS transmitter types must not be capable of transmitting on any frequency or channel other than those listed in § 95.563. (b) Antenna. The antenna of each FRS transmitter type must meet the following requirements. (1) The antenna must be a non-removable integral part of the FRS transmitter type. (2) The gain of the antenna must not exceed that of a half-wave dipole antenna. (3) The antenna must be designed such that the electric field of the emitted waves is vertically polarized when the unit is operated in the normal orientation. (c) Digital data transmissions. FRS transmitter types having the capability to transmit digital data must be designed to meet the following requirements. (1) FRS units may transmit digital data containing location information, or requesting location information from one or more other FRS or GMRS units, or containing a brief text message to another specific FRS or GMRS unit or units. (2) Digital data transmissions must be initiated by a manual action or command of the operator, except that FRS units may be designed to automatically respond with location data upon receiving an interrogation request from another FRS unit or a GMRS unit. (3) Digital data transmissions must not exceed one second in duration. (4) Digital data transmissions must not be sent more frequently than one digital data transmission within a thirty-second period, except that an FRS unit may automatically respond to more than one interrogation request received within a thirty-second period. (d) Packet mode. FRS transmitter types must not be capable of transmitting data in the store-and-forward packet operation mode. (e) Effective September 30, 2019, no person shall manufacture or import hand-held portable radio equipment capable of operating under this subpart (FRS) and other licensed or licensed-by-rule services in this chapter (part 15 unlicensed equipment authorizations are permitted if consistent with part 15 rules).
  • 462.6125 MHz - FRS 3 - UHF Primary/Calling FRS 3 - AmRRON - also MURS 3, CB 3
  • 462.6625 MHz - FRS 5
  • 462.6875 MHz - FRS 6
  • 462.7125 MHz - FRS 7
  • 462.5500 MHz - FRS 15
  • 462.6000 MHz - FRS 17
  • Channel 1 - 462.5625 MHz
  • Channel 2 - 462.5875 MHz
  • Channel 3 - 462.6125 MHz
  • Channel 4 - 462.6375 MHz
  • Channel 5 - 462.6625 MHz
  • Channel 6 - 462.6875 MHz
  • Channel 7 - 462.7125 MHz
  • Channel 8 - 467.5625 MHz
  • Channel 9 - 467.5875 MHz
  • Channel 10 - 467.6125 MHz
  • Channel 11 - 467.6375 MHz
  • Channel 12 - 467.6625 MHz
  • Channel 13 - 467.6875 MHz
  • Channel 14 - 467.7125 MHz
  • Channel 15 - 462.5500 MHz
  • Channel 16 - 462.5750 MHz
  • Channel 17 - 462.6000 MHz
  • Channel 18 - 462.6250 MHz
  • Channel 19 - 462.6500 MHz
  • Channel 20 - 462.6750 MHz
  • Channel 21 - 462.7000 MHz
  • Channel 22 - 462.7250 MHz
  • Code 1 - 67.0 Hz
  • Code 2 - 71.9 Hz
  • Code 3 - 74.4 Hz
  • Code 4 - 77.0 Hz
  • Code 5 - 79.7 Hz
  • Code 6 - 82.5 Hz
  • Code 7 - 85.4 Hz
  • Code 8 - 88.5 Hz
  • Code 9 - 91.5 Hz
  • Code 10 - 94.8 Hz
  • Code 11 - 97.4 Hz
  • Code 12 - 100.0 Hz
  • Code 13 - 103.5 Hz
  • Code 14 - 107.2 Hz
  • Code 15 - 110.9 Hz
  • Code 16 - 114.8 Hz
  • Code 17 - 118.8 Hz
  • Code 18 - 123.0 Hz
  • Code 19 - 127.3 Hz
  • Code 20 - 131.8 Hz
  • Code 21 - 136.5 Hz
  • Code 22 - 141.3 Hz
  • Code 23 - 146.2 Hz
  • Code 24 - 151.4 Hz
  • Code 25 - 156.7 Hz
  • Code 26 - 162.2 Hz
  • Code 27 - 167.9 Hz
  • Code 28 - 173.8 Hz
  • Code 29 - 179.9 Hz
  • Code 30 - 186.2 Hz
  • Code 31 - 192.8 Hz
  • Code 32 - 203.5 Hz
  • Code 33 - 210.7 Hz
  • Code 34 - 218.1 Hz
  • Code 35 - 225.7 Hz
  • Code 36 - 233.6 Hz
  • Code 37 - 241.8 Hz
  • Code 38 - 250.3 Hz
  • Code 39 - D023
  • Code 40 - D025
  • Code 41 - D026
  • Code 42 - D031
  • Code 43 - D032
  • Code 44 - D043
  • Code 45 - D047
  • Code 46 - D051
  • Code 47 - D054
  • Code 48 - D065
  • Code 49 - D071
  • Code 50 - D072
  • Code 51 - D073
  • Code 52 - D074
  • Code 53 - D114
  • Code 54 - D115
  • Code 55 - D116
  • Code 56 - D125
  • Code 57 - D131
  • Code 58 - D132
  • Code 59 - D134
  • Code 60 - D143
  • Code 61 - D152
  • Code 62 - D155
  • Code 63 - D156
  • Code 64 - D162
  • Code 65 - D165
  • Code 66 - D172
  • Code 67 - D174
  • Code 68 - D205
  • Code 69 - D223
  • Code 70 - D226
  • Code 71 - D243
  • Code 72 - D244
  • Code 73 - D245
  • Code 74 - D251
  • Code 75 - D261
  • Code 76 - D263
  • Code 77 - D265
  • Code 78 - D271
  • Code 79 - D306
  • Code 80 - D311
  • Code 81 - D315
  • Code 82 - D331
  • Code 83 - D343
  • Code 84 - D346
  • Code 85 - D351
  • Code 86 - D364
  • Code 87 - D365
  • Code 88 - D371
  • Code 89 - D411
  • Code 90 - D412
  • Code 91 - D413
  • Code 92 - D423
  • Code 93 - D431
  • Code 94 - D432
  • Code 95 - D445
  • Code 96 - D464
  • Code 97 - D465
  • Code 98 - D466
  • Code 99 - D503
  • Code 100 - D506
  • Code 101 - D516
  • Code 102 - D532
  • Code 103 - D546
  • Code 104 - D565
  • Code 105 - D606
  • Code 106 - D612
  • Code 107 - D624
  • Code 108 - D627
  • Code 109 - D631
  • Code 110 - D632
  • Code 111 - D654
  • Code 112 - D662
  • Code 113 - D664
  • Code 114 - D703
  • Code 115 - D712
  • Code 116 - D723
  • Code 117 - D731
  • Code 118 - D732
  • Code 119 - D734
  • Code 120 - D743
  • Code 121 - D754
  • Code 1 - 67.0 Hz
  • Code 2 - 69.3 Hz
  • Code 3 - 71.9 Hz
  • Code 4 - 74.4 Hz
  • Code 5 - 77.0 Hz
  • Code 6 - 79.7 Hz
  • Code 7 - 82.5 Hz
  • Code 8 - 85.4 Hz
  • Code 9 - 88.5 Hz
  • Code 10 - 91.5 Hz
  • Code 11 - 94.8 Hz
  • Code 12 - 97.4 Hz
  • Code 13 - 100.0 Hz
  • Code 14 - 103.5 Hz
  • Code 15 - 107.2 Hz
  • Code 16 - 110.9 Hz
  • Code 17 - 114.8 Hz
  • Code 18 - 118.8 Hz
  • Code 19 - 123.0 Hz
  • Code 20 - 127.3 Hz
  • Code 21 - 131.8 Hz
  • Code 22 - 136.5 Hz
  • Code 23 - 141.3 Hz
  • Code 24 - 146.2 Hz
  • Code 25 - 151.4 Hz
  • Code 26 - 156.7 Hz
  • Code 27 - 159.8 Hz
  • Code 28 - 162.2 Hz
  • Code 29 - 165.5 Hz
  • Code 30 - 167.9 Hz
  • Code 31 - 171.3 Hz
  • Code 32 - 173.8 Hz
  • Code 33 - 177.3 Hz
  • Code 34 - 179.9 Hz
  • Code 35 - 183.5 Hz
  • Code 36 - 186.2 Hz
  • Code 37 - 189.9 Hz
  • Code 38 - 192.8 Hz
  • Code 39 - 196.6 Hz
  • Code 40 - 199.5 Hz
  • Code 41 - 203.5 Hz
  • Code 42 - 206.5 Hz
  • Code 43 - 210.7 Hz
  • Code 44 - 218.1 Hz
  • Code 45 - 225.7 Hz
  • Code 46 - 229.1 Hz
  • Code 47 - 233.6 Hz
  • Code 48 - 241.8 Hz
  • Code 49 - 250.3 Hz
  • Code 50 - 254.1 Hz
  • FRS channel 3 - 462.6125 MHz CSQ - Black Lives Matter Protest Coordination Walkie Talkies
  • FRS channel 4 - 462.6375 MHz CSQ - Prepper/militia secondary channel (various transmit CTCSS tones in use)
  • FRS channel 4 - 462.6375 MHz CSQ - Militia, self-defense and security forces common interagency inter-group tactical coordination mutual aid channel (alternate)
  • FRS Channel 4 - 462.6375 MHz CSQ - Patriot Militia Prepper Radio - Prepper/Militia Secondary (shared with 4x4/Jeep users)
  • FRS channel 8 - 467.5625 MHz CSQ - Black Lives Matter Protest Coordination Walkie Talkies
  • FRS channel 8 - 467.5625 MHz 107.2 Hz - back up militia operations and tactical channel
  • FRS channel 14 - 467.7125 MHz CSQ - backup militia operations mutual aid channel
  • FRS channel 14 - 467.7125 MHz 88.5 Hz - back up militia operations mutual channel 88.5 Hz
  • FRS Channel 15 - 467.7125 MHz 250.3 Hz - Airshow and Milcom Hobbyist and Monitors Intercept Primary Channel
  • FRS channel 21 - 462.7000 MHz CSQ - Militia, self-defense and security forces common interagency inter-group tactical coordination mutual aid channel (alternate)
  • Channel 8 - 462.5500 MHz
  • Channel 9 - 462.5750 MHz
  • Channel 10 - 462.6000 MHz
  • Channel 11 - 462.6250 MHz
  • Channel 12 - 462.6500 MHz
  • Channel 13 - 462.6750 MHz
  • Channel 14 - 462.7000 MHz
  • Channel 15 - 462.7250 MHz
  • CHANNEL 1 - 467.6375 MHz
  • CHANNEL 2 - 462.5875 MHz
  • CHANNEL 3 - 462.6125 MHz
  • CHANNEL 4 - 462.6375 MHz
  • CHANNEL 5 - 462.6625 MHz
  • CHANNEL 6 - 462.6875 MHz
  • CHANNEL 7 - 467.7125 MHz
  • CHANNEL 8 - 462.5500 MHz
  • CHANNEL 9 - 462.5750 MHz
  • Code 1 - 162.2 Hz PL
  • Code 2 - 69.3 Hz PL
  • Code 3 - 67.0 Hz PL
  • CHANNEL 1 - 462.5625 MHz
  • Code 3 - 67.0 PL
  • Code 1 - 743 DCS / 743 DPL
  • Code 2 - 732 DCS / 732 DPL
  • Code 3 - 731 DCS / 731 DPL
  • CHANNEL 2 - 462.6125 MHz
  • CHANNEL 3 - 462.6375 MHz
  • CHANNEL A - 462.5625 MHz
  • CHANNEL B - 462.5875 MHz
  • CHANNEL C - 462.6125 MHz
  • CHANNEL D - 462.6375 MHz
  • CHANNEL 0 - 462.6625 MHz
  • CHANNEL 1 - 467.7125 MHz
  • CHANNEL 2 - 467.6875 MHz
  • CHANNEL 3 - 467.6625 MHz
  • CHANNEL 4 - 467.6375 MHz
  • CHANNEL 5 - 467.6125 MHz
  • CHANNEL 6 - 467.5875 MHz
  • CHANNEL 7 - 467.5625 MHz
  • CHANNEL 8 - 462.7125 MHz
  • CHANNEL 9 - 462.6875 MHz
  • Code A - 110.9 Hz PL
  • Code B - 136.5 Hz PL
  • Code C - 186.2 Hz PL
  • CHANNEL 10 - 462.6375 MHz
  • CHANNEL 11 - 462.6125 MHz
  • CHANNEL 12 - 462.5875 MHz
  • CHANNEL 13 - 462.5625 MHz
  • CHANNEL 14 - 462.7250 MHz
  • CHANNEL 15 - 462.7000 MHz
  • CHANNEL 16 - 462.6750 MHz
  • CHANNEL 17 - 462.6500 MHz
  • CHANNEL 18 - 462.6250 MHz
  • CHANNEL 19 - 462.6000 MHz
  • CHANNEL 0 - 467.6125 MHz
  • CHANNEL 1 - 462.7250 MHz
  • CHANNEL 8 - 467.5625 MHz
  • CHANNEL 9 - 467.5875 MHz
  • Code A - 754 DCS / 754 DPL
  • Code B - 743 DCS / 743 DPL
  • Code C - 734 DCS / 734 DPL
  • CHANNEL 7 - 462.7125 MHz
  • CHANNEL 10 - 467.6125 MHz
  • CHANNEL 11 - 467.6375 MHz
  • CHANNEL 12 - 467.6625 MHz
  • CHANNEL 13 - 467.6875 MHz
  • CHANNEL 14 - 467.7125 MHz
  • CHANNEL 15 - 462.5500 MHz
  • CHANNEL 16 - 462.5750 MHz
  • CHANNEL 17 - 462.6000 MHz
  • CHANNEL 19 - 462.6500 MHz
  • CHANNEL 20 - 462.6750 MHz
  • CHANNEL 21 - 462.7000 MHz
  • CHANNEL 22 - 462.5625 MHz
  • Code 01 - 754 DCS / 754 DPL
  • Code 02 - 743 DCS / 743 DPL
  • Code 03 - 734 DCS / 734 DPL
  • Code 04 - 77.0 Hz PL
  • Code 05 - 79.7 Hz PL
  • Code 06 - 82.5 Hz PL
  • Code 07 - 85.4 Hz PL
  • Code 08 - 88.5 Hz PL
  • Code 09 - 91.5 Hz PL
  • Code 10 - 94.8 Hz PL
  • Code 11 - 97.4 Hz PL
  • Code 12 - 100.0 Hz PL
  • Code 13 - 103.5 Hz PL
  • Code 14 - 107.2 Hz PL
  • Code 15 - 110.9 Hz PL
  • Code 16 - 114.8 Hz PL
  • Code 17 - 118.8 Hz PL
  • Code 18 - 123.0 Hz PL
  • Code 19 - 127.3 Hz PL
  • Code 20 - 131.8 Hz PL
  • Code 21 - 136.5 Hz PL
  • Code 22 - 141.3 Hz PL
  • Code 23 - 146.2 Hz PL
  • Code 24 - 151.4 Hz PL
  • Code 25 - 156.7 Hz PL
  • Code 26 - 162.2 Hz PL
  • Code 27 - 167.9 Hz PL
  • Code 28 - 173.8 Hz PL
  • Code 29 - 179.9 Hz PL
  • Code 30 - 186.2 Hz PL
  • Code 31 - 192.8 Hz PL
  • Code 32 - 203.5 Hz PL
  • Code 33 - 210.7 Hz PL
  • Code 34 - 218.1 Hz PL
  • Code 35 - 225.7 Hz PL
  • Code 36 - 233.6 Hz PL
  • Code 37 - 241.8 Hz PL
  • Code 38 - 250.3 Hz PL
  • Code 39 - 023 DCS
  • Code 40 - 025 DCS
  • Code 41 - 026 DCS
  • Code 42 - 031 DCS
  • Code 43 - 032 DCS
  • Code 44 - 043 DCS
  • Code 45 - 047 DCS
  • Code 46 - 051 DCS
  • Code 47 - 054 DCS
  • Code 48 - 065 DCS
  • Code 49 - 071 DCS
  • Code 50 - 072 DCS
  • Code 51 - 073 DCS
  • Code 52 - 074 DCS
  • Code 53 - 114 DCS
  • Code 54 - 115 DCS
  • Code 55 - 116 DCS
  • Code 56 - 125 DCS
  • Code 57 - 131 DCS
  • Code 58 - 132 DCS
  • Code 59 - 143 DCS
  • Code 60 - 143 DCS
  • Code 61 - 152 DCS
  • Code 62 - 155 DCS
  • Code 63 - 156 DCS
  • Code 64 - 162 DCS
  • Code 65 - 165 DCS
  • Code 66 - 172 DCS
  • Code 67 - 174 DCS
  • Code 68 - 205 DCS
  • Code 69 - 223 DCS
  • Code 70 - 226 DCS
  • Code 71 - 243 DCS
  • Code 72 - 244 DCS
  • Code 73 - 245 DCS
  • Code 74 - 251 DCS
  • Code 75 - 261 DCS
  • Code 76 - 263 DCS
  • Code 77 - 265 DCS
  • Code 78 - 271 DCS
  • Code 79 - 306 DCS
  • Code 80 - 311 DCS
  • Code 81 - 315 DCS
  • Code 82 - 331 DCS
  • Code 83 - 343 DCS
  • Code 84 - 346 DCS
  • Code 85 - 351 DCS
  • Code 86 - 364 DCS
  • Code 87 - 365 DCS
  • Code 88 - 371 DCS
  • Code 89 - 411 DCS
  • Code 90 - 412 DCS
  • Code 91 - 413 DCS
  • Code 92 - 423 DCS
  • Code 93 - 431 DCS
  • Code 94 - 432 DCS
  • Code 95 - 445 DCS
  • Code 96 - 464 DCS
  • Code 97 - 465 DCS
  • Code 98 - 466 DCS
  • Code 99 - 503 DCS
