Please see the 25-30 MHz users page here on the 11 meter page.
Channel 2 | 26.975 MHz | |
Channel 4 | 27.005 MHz | 4x4 and off-roader common channel, Latin American trucker channel, secondary militia frequency |
Channel 5 | 27.015 MHz | |
Channel 7 | 27.035 MHz | |
Channel 8 | 27.055 MHz | Australian “recommended” road / trucker channel |
Channel 12 | 27.105 MHz | |
Channel 13 | 27.115 MHz | Sometimes used by RV clubs/drivers as a "home channel" (many RVs are equipped with CB radios, although a lot of them simply sit on ch 19) |
Channel 15 | 27.135 MHz | |
Channel 16 | 27.155 MHz | 4x4 and off-roader common channel (4x4 = 16), old SSB calling channel |
Channel 18 | 27.175 MHz | |
Channel 20 | 27.205 MHz | While CH 19 is the middle of the band, CH 20 is often used for radio testing and antenna tuning to avoid causing interference on channel 19 |
Channel 22 | 27.225 MHz | |
Channel 24 | 27.235 MHz | Used for ROS, PSK31, packet radio and other digital modes |
Channel 25 | 27.245 MHz | Used for ROS, PSK31, packet radio and other digital modes |
Channel 27 | 27.275 MHz | |
Channel 29 | 27.295 MHz | |
Channel 32 | 27.325 MHz | |
Channel 33 | 27.335 MHz | |
Channel 34 | 27.345 MHz | |
Channel 35 | 27.355 MHz | Australian SSB calling frequency, 27.355 LSB, also see 27.385 LSB |
Channel 36 | 27.365 MHz | Militia Survivalist Patriot 11m CB SSB USB mode - CB CH 36 USB |
Channel 37 | 27.375 MHz | Secondary or backup SSB calling/working channel LSB mode (secondary to 27.385 MHz LSB), militia/patriot 27.375 USB |
FM (Frequency Modulation)
Channel 1 | 27.60125 MHz |
Channel 2 | 27.61125 MHz |
Channel 3 | 27.62125 MHz |
Channel 4 | 27.63125 MHz |
Channel 5 | 27.64125 MHz |
Channel 6 | 27.65125 MHz |
Channel 7 | 27.66125 MHz |
Channel 8 | 27.67125 MHz |
Channel 9 | 27.68125 MHz |
Channel 10 | 27.69125 MHz |
Channel 11 | 27.70125 MHz |
Channel 12 | 27.71125 MHz |
Channel 13 | 27.72125 MHz |
Channel 14 | 27.73125 MHz |
Channel 15 | 27.74125 MHz |
Channel 16 | 27.75125 MHz |
Channel 17 | 27.76125 MHz |
Channel 18 | 27.77125 MHz |
Channel 19 | 27.78125 MHz |
Channel 20 | 27.79125 MHz |
Channel 21 | 27.80125 MHz |
Channel 22 | 27.81125 MHz |
Channel 23 | 27.82125 MHz |
Channel 24 | 27.83125 MHz |
Channel 25 | 27.84125 MHz |
Channel 26 | 27.85125 MHz |
Channel 27 | 27.86125 MHz |
Channel 28 | 27.87125 MHz |
Channel 29 | 27.88125 MHz |
Channel 30 | 27.89125 MHz |
Channel 31 | 27.90125 MHz |
Channel 32 | 27.91125 MHz |
Channel 33 | 27.92125 MHz |
Channel 34 | 27.93125 MHz |
Channel 35 | 27.94125 MHz |
Channel 36 | 27.95125 MHz |
Channel 37 | 27.96125 MHz |
Channel 38 | 27.97125 MHz |
Channel 39 | 27.98125 MHz |
Channel 40 | 27.99125 MHz |
Channel 41 | 26.565 MHz |
Channel 42 | 26.575 MHz |
Channel 43 | 26.585 MHz |
Channel 44 | 26.595 MHz |
Channel 45 | 26.605 MHz |
Channel 46 | 26.615 MHz |
Channel 47 | 26.625 MHz |
Channel 48 | 26.635 MHz |
Channel 49 | 26.645 MHz |
Channel 50 | 26.655 MHz |
Channel 51 | 26.665 MHz |
Channel 52 | 26.675 MHz |
Channel 53 | 26.685 MHz |
Channel 54 | 26.695 MHz |
Channel 55 | 26.705 MHz |
Channel 56 | 26.715 MHz |
Channel 57 | 26.725 MHz |
Channel 58 | 26.735 MHz |
Channel 59 | 26.745 MHz |
Channel 60 | 26.755 MHz |
Channel 61 | 26.765 MHz |
Channel 62 | 26.775 MHz |
Channel 63 | 26.785 MHz |
Channel 64 | 26.795 MHz |
Channel 65 | 26.805 MHz |
Channel 66 | 26.815 MHz |
Channel 67 | 26.825 MHz |
Channel 68 | 26.835 MHz |
Channel 69 | 26.845 MHz |
Channel 70 | 26.855 MHz |
Channel 71 | 26.865 MHz |
Channel 72 | 26.875 MHz |
Channel 73 | 26.885 MHz |
Channel 74 | 26.895 MHz |
Channel 75 | 26.905 MHz |
Channel 76 | 26.915 MHz |
Channel 77 | 26.925 MHz |
Channel 78 | 26.935 MHz |
Channel 79 | 26.945 MHz |
Channel 80 | 26.955 MHz |
26 MHz AM Public Channels:
Channel 1 | 26.330 MHz |
Channel 2 | 26.340 MHz |
Channel 3 | 26.350 MHz |
Channel 4 | 26.370 MHz |
Channel 5 | 26.380 MHz |
Channel 6 | 26.390 MHz |
Channel 7 | 26.400 MHz |
Channel 8 | 26.420 MHz |
Channel 9 | 26.430 MHz |
Channel 10 | 26.440 MHz |
Channel 11 | 26.450 MHz |
Channel 12 | 26.470 MHz |
Channel 13 | 26.480 MHz |
Channel 14 | 26.490 MHz |
Channel 15 | 26.500 MHz |
Channel 16 | 26.520 MHz |
Channel 17 | 26.530 MHz |
Channel 18 | 26.540 MHz |
Channel 19 | 26.550 MHz |
Channel 20 | 26.570 MHz |
Channel 21 | 26.580 MHz |
Channel 22 | 26.590 MHz |
Channel 23 | 26.620 MHz |
Channel 24 | 26.600 MHz |
Channel 25 | 26.610 MHz |
Channel 26 | 26.630 MHz |
Channel 27 | 26.640 MHz |
Channel 28 | 26.650 MHz |
Channel 29 | 26.660 MHz |
Channel 30 | 26.670 MHz |
Channel 31 | 26.680 MHz |
Channel 32 | 26.690 MHz |
Channel 33 | 26.700 MHz |
Channel 34 | 26.710 MHz |
Channel 35 | 26.720 MHz |
Channel 36 | 26.730 MHz |
Channel 37 | 26.740 MHz |
Channel 38 | 26.750 MHz |
Channel 39 | 26.760 MHz |
Channel 40 | 26.770 MHz |
Channel 1 | 26.960 MHz |
Channel 2 | 26.970 MHz |
Channel 3 | 26.980 MHz |
Channel 4 | 27.000 MHz |
Channel 5 | 27.010 MHz |
Channel 6 | 27.020 MHz |
Channel 7 | 27.030 MHz |
Channel 8 | 27.050 MHz |
Channel 9 | 27.060 MHz |
Channel 10 | 27.070 MHz |
Channel 11 | 27.080 MHz |
Channel 12 | 27.100 MHz |
Channel 13 | 27.110 MHz |
Channel 14 | 27.120 MHz |
Channel 15 | 27.130 MHz |
Channel 16 | 27.150 MHz |
Channel 17 | 27.160 MHz |
Channel 18 | 27.170 MHz |
Channel 19 | 27.180 MHz |
Channel 20 | 27.200 MHz |
Channel 21 | 27.210 MHz |
Channel 22 | 27.220 MHz |
Channel 23 | 27.250 MHz |
Channel 24 | 27.230 MHz |
Channel 25 | 27.240 MHz |
Channel 26 | 27.260 MHz |
Channel 27 | 27.270 MHz |
Channel 28 | 27.280 MHz |
Channel 29 | 27.290 MHz |
Channel 30 | 27.300 MHz |
Channel 31 | 27.310 MHz |
Channel 32 | 27.320 MHz |
Channel 33 | 27.330 MHz |
Channel 34 | 27.340 MHz |
Channel 36 | 27.360 MHz |
Channel 37 | 27.370 MHz |
Channel 38 | 27.380 MHz |
Channel 39 | 27.390 MHz |
Channel 40 | 27.400 MHz |
For example,
Band A Channel | Standard Band Plan Frequency | Russian/Polish Band Plan Frequency |
Channel 1 | 25.615 MHz | 25.610 MHz |
Channel 2 | 25.625 MHz | 25.620 MHz |
Channel 3 | 25.635 MHz | 25.630 MHz |
Channel 3A | 25.645 MHz | 25.640 MHz |
Channel 4 | 25.655 MHz | 25.650 MHz |
Channel 5 | 26.665 MHz | 25.660 MHz |
Channel 6 | 25.675 MHz | 25.670 MHz |
Channel 7 | 25.685 MHz | 25.680 MHz |
Channel 7A | 25.695 MHz | 25.690 MHz |
Channel 8 | 25.705 MHz | 25.700 MHz |
Channel 9 | 25.715 MHz | 25.710 MHz |
Channel 10 | 25.725 MHz | 25.720 MHz |
Channel 11 | 25.735 MHz | 25.730 MHz |
Channel 11A | 25.745 MHz | 25.740 MHz |
Channel 12 | 25.755 MHz | 25.750 MHz |
Channel 13 | 25.765 MHz | 25.760 MHz |
Channel 14 | 25.775 MHz | 25.770 MHz |
Channel 15 | 25.785 MHz | 25.780 MHz |
Channel 15A | 25.795 MHz | 25.790 MHz |
Channel 16 | 25.805 MHz | 25.800 MHz |
Channel 17 | 25.815 MHz | 25.810 MHz |
Channel 18 | 25.825 MHz | 25.820 MHz |
Channel 19 | 25.835 MHz | 25.830 MHz |
Channel 19A | 25.845 MHz | 25.840 MHz |
Channel 20 | 25.855 MHz | 25.850 MHz |
Channel 21 | 25.865 MHz | 25.860 MHz |
Channel 22 | 25.875 MHz | 25.870 MHz |
Channel 23 | 25.905 MHz | 25.900 MHz |
Channel 24 | 25.885 MHz | 25.880 MHz |
Channel 25 | 25.895 MHz | 25.890 MHz |
Channel 26 | 25.915 MHz | 25.910 MHz |
Channel 27 | 25.925 MHz | 25.920 MHz |
Channel 28 | 25.935 MHz | 25.930 MHz |
Channel 29 | 25.945 MHz | 25.940 MHz |
Channel 30 | 25.955 MHz | 25.950 MHz |
Channel 31 | 25.965 MHz | 25.960 MHz |
Channel 32 | 25.975 MHz | 25.970 MHz |
Channel 33 | 25.985 MHz | 25.980 MHz |
Channel 34 | 25.995 MHz | 25.990 MHz |
Channel 35 | 26.005 MHz | 26.000 MHz |
Channel 36 | 26.015 MHz | 26.010 MHz |
Channel 37 | 26.025 MHz | 26.020 MHz |
Channel 38 | 26.035 MHz | 26.030 MHz |
Channel 39 | 26.045 MHz | 26.040 MHz |
Channel 40 | 26.055 MHz | 26.050 MHz |
Channel 40A | 26.065 MHz | 26.060 MHz |
Band B Channel | Standard Band Plan Frequency | Russian/Polish Band Plan Frequency |
Channel 1 | 26.065 MHz | 26.060 MHz |
Channel 2 | 26.075 MHz | 26.070 MHz |
Channel 3 | 26.085 MHz | 26.080 MHz |
Channel 3A | 26.095 MHz | 26.090 MHz |
Channel 4 | 26.105 MHz | 26.100 MHz |
Channel 5 | 26.115 MHz | 26.110 MHz |
Channel 6 | 26.125 MHz | 26.120 MHz |
Channel 7 | 26.135 MHz | 26.130 MHz |
Channel 7A | 26.145 MHz | 26.140 MHz |
Channel 8 | 26.155 MHz | 26.150 MHz |
Channel 9 | 26.165 MHz | 26.160 MHz |
Channel 10 | 26.175 MHz | 26.170 MHz |
Channel 11 | 26.185 MHz | 26.180 MHz |
Channel 11A | 26.195 MHz | 26.190 MHz |
Channel 12 | 26.205 MHz | 26.200 MHz |
Channel 13 | 26.215 MHz | 26.210 MHz |
Channel 14 | 26.225 MHz | 26.220 MHz |
Channel 15 | 26.235 MHz | 26.230 MHz |
Channel 15A | 26.245 MHz | 26.240 MHz |
Channel 16 | 26.255 MHz | 26.250 MHz |
Channel 17 | 26.265 MHz | 26.260 MHz |
Channel 18 | 26.275 MHz | 26.270 MHz |
Channel 19 | 26.285 MHz | 26.280 MHz |
Channel 19A | 26.295 MHz | 26.290 MHz |
Channel 20 | 26.305 MHz | 26.300 MHz |
Channel 21 | 26.315 MHz | 26.310 MHz |
Channel 22 | 26.325 MHz | 26.320 MHz |
Channel 23 | 26.355 MHz | 26.350 MHz |
Channel 24 | 26.335 MHz | 26.330 MHz |
Channel 25 | 26.345 MHz | 26.340 MHz |
Channel 26 | 26.365 MHz | 26.360 MHz |
Channel 27 | 26.375 MHz | 26.370 MHz |
Channel 28 | 26.385 MHz | 26.380 MHz |
Channel 29 | 26.395 MHz | 26.390 MHz |
Channel 30 | 26.405 MHz | 26.400 MHz |
Channel 31 | 26.415 MHz | 26.410 MHz |
Channel 32 | 26.425 MHz | 26.420 MHz |
Channel 33 | 26.435 MHz | 26.430 MHz |
Channel 34 | 26.445 MHz | 26.440 MHz |
Channel 35 | 26.455 MHz | 26.450 MHz |
Channel 36 | 26.465 MHz | 26.460 MHz |
Channel 37 | 26.475 MHz | 26.470 MHz |
Channel 38 | 26.485 MHz | 26.480 MHz |
Channel 39 | 26.495 MHz | 26.490 MHz |
Channel 40 | 26.505 MHz | 26.500 MHz |
Channel 40A | 26.515 MHz | 26.510 MHz |
Band C Channel | Standard Band Plan Frequency | Russian/Polish Band Plan Frequency |
Channel 1 | 26.515 MHz | 26.510 MHz |
Channel 2 | 26.525 MHz | 26.520 MHz |
Channel 3 | 26.535 MHz | 26.530 MHz |
Channel 3A | 26.545 MHz | 26.540 MHz |
Channel 4 | 26.555 MHz | 26.550 MHz |
Channel 5 | 26.565 MHz | 26.560 MHz |
Channel 6 | 26.575 MHz | 26.570 MHz |
Channel 7 | 26.585 MHz | 26.580 MHz |
Channel 7A | 26.595 MHz | 26.590 MHz |
Channel 8 | 26.605 MHz | 26.600 MHz |
Channel 9 | 26.615 MHz | 26.610 MHz |
Channel 10 | 26.625 MHz | 26.620 MHz |
Channel 11 | 26.635 MHz | 26.630 MHz |
Channel 11A | 26.645 MHz | 26.640 MHz |
Channel 12 | 26.655 MHz | 26.650 MHz |
Channel 13 | 26.665 MHz | 26.660 MHz |
Channel 14 | 26.675 MHz | 26.670 MHz |
Channel 15 | 26.685 MHz | 26.680 MHz |
Channel 15A | 26.695 MHz | 26.690 MHz |
Channel 16 | 26.705 MHz | 26.700 MHz |
Channel 17 | 26.715 MHz | 26.710 MHz |
Channel 18 | 26.725 MHz | 26.720 MHz |
Channel 19 | 26.735 MHz | 26.730 MHz |
Channel 19A | 26.745 MHz | 26.740 MHz |
Channel 20 | 26.755 MHz | 26.750 MHz |
Channel 21 | 26.765 MHz | 26.760 MHz |
Channel 22 | 26.775 MHz | 26.770 MHz |
Channel 23 | 26.805 MHz | 26.800 MHz |
Channel 24 | 26.785 MHz | 26.780 MHz |
Channel 25 | 26.795 MHz | 26.790 MHz |
Channel 26 | 26.815 MHz | 26.810 MHz |
Channel 27 | 26.825 MHz | 26.820 MHz |
Channel 28 | 26.835 MHz | 26.830 MHz |
Channel 29 | 26.845 MHz | 26.840 MHz |
Channel 30 | 26.855 MHz | 26.850 MHz |
Channel 31 | 26.865 MHz | 26.860 MHz |
Channel 32 | 26.875 MHz | 26.870 MHz |
Channel 33 | 26.885 MHz | 26.880 MHz |
Channel 34 | 26.895 MHz | 26.890 MHz |
Channel 35 | 26.905 MHz | 26.900 MHz |
Channel 36 | 26.915 MHz | 26.910 MHz |
Channel 37 | 26.925 MHz | 26.920 MHz |
Channel 38 | 26.935 MHz | 26.930 MHz |
Channel 39 | 26.945 MHz | 26.940 MHz |
Channel 40 | 26.955 MHz | 26.950 MHz |
Channel 40A | 26.965 MHz | 26.960 MHz |
Band D Channel | Standard Band Plan Frequency | Russian/Polish Band Plan Frequency |
Channel 1 | 26.965 MHz | 26.960 MHz |
Channel 2 | 26.975 MHz | 26.970 MHz |
Channel 3 | 26.985 MHz | 26.980 MHz |
Channel 3A | 26.995 MHz | 26.990 MHz |
Channel 4 | 27.005 MHz | 27.000 MHz |
Channel 5 | 27.015 MHz | 27.010 MHz |
Channel 6 | 27.025 MHz | 27.020 MHz |
Channel 7 | 27.035 MHz | 27.030 MHz |
Channel 7A | 27.045 MHz | 27.040 MHz |
Channel 8 | 27.055 MHz | 27.050 MHz |
Channel 9 | 27.065 MHz | 27.060 MHz |
Channel 10 | 27.075 MHz | 27.070 MHz |
Channel 11 | 27.085 MHz | 27.080 MHz |
Channel 11A | 27.095 MHz | 27.090 MHz |
Channel 12 | 27.105 MHz | 27.100 MHz |
Channel 13 | 27.115 MHz | 27.110 MHz |
Channel 14 | 27.125 MHz | 27.120 MHz |
Channel 15 | 27.135 MHz | 27.130 MHz |
Channel 15A | 27.145 MHz | 27.140 MHz |
Channel 16 | 27.155 MHz | 27.150 MHz |
Channel 17 | 27.165 MHz | 27.160 MHz |
Channel 18 | 27.175 MHz | 27.170 MHz |
Channel 19 | 27.185 MHz | 27.180 MHz |
Channel 19A | 27.195 MHz | 27.190 MHz |
Channel 20 | 27.205 MHz | 27.200 MHz |
Channel 21 | 27.215 MHz | 27.210 MHz |
Channel 22 | 27.225 MHz | 27.220 MHz |
Channel 23 | 27.255 MHz | 27.250 MHz |
Channel 24 | 27.235 MHz | 27.230 MHz |
Channel 25 | 27.245 MHz | 27.240 MHz |
Channel 26 | 27.265 MHz | 27.260 MHz |
Channel 27 | 27.275 MHz | 27.270 MHz |
Channel 28 | 27.285 MHz | 27.280 MHz |
Channel 29 | 27.295 MHz | 27.290 MHz |
Channel 30 | 27.305 MHz | 27.300 MHz |
Channel 31 | 27.315 MHz | 27.310 MHz |
Channel 32 | 27.325 MHz | 27.320 MHz |
Channel 33 | 27.335 MHz | 27.330 MHz |
Channel 34 | 27.345 MHz | 27.340 MHz |
Channel 35 | 27.355 MHz | 27.350 MHz |
Channel 36 | 27.365 MHz | 27.360 MHz |
Channel 37 | 27.375 MHz | 27.370 MHz |
Channel 38 | 27.385 MHz | 27.380 MHz |
Channel 39 | 27.395 MHz | 27.390 MHz |
Channel 40 | 27.405 MHz | 27.400 MHz |
Channel 40A | 27.415 MHz | 27.410 MHz |
Band E Channel | Standard Band Plan Frequency | Russian/Polish Band Plan Frequency |
Channel 1 | 27.415 MHz | 27.410 MHz |
Channel 2 | 27.425 MHz | 27.420 MHz |
Channel 3 | 27.435 MHz | 27.430 MHz |
Channel 3A | 27.445 MHz | 27.440 MHz |
Channel 4 | 27.455 MHz | 27.450 MHz |
Channel 5 | 27.465 MHz | 27.460 MHz |
Channel 6 | 27.475 MHz | 27.470 MHz |
Channel 7 | 27.485 MHz | 27.480 MHz |
Channel 7A | 27.495 MHz | 27.490 MHz |
Channel 8 | 27.505 MHz | 27.500 MHz |
Channel 9 | 27.515 MHz | 27.510 MHz |
Channel 10 | 27.525 MHz | 27.520 MHz |
Channel 11 | 27.535 MHz | 27.530 MHz |
Channel 11A | 27.545 MHz | 27.540 MHz |
Channel 12 | 27.555 MHz | 27.550 MHz |
Channel 13 | 27.565 MHz | 27.560 MHz |
Channel 14 | 27.575 MHz | 27.570 MHz |
Channel 15 | 27.585 MHz | 27.580 MHz |
Channel 15A | 27.595 MHz | 27.590 MHz |
Channel 16 | 27.605 MHz | 27.600 MHz |
Channel 17 | 27.615 MHz | 27.610 MHz |
Channel 18 | 27.625 MHz | 27.620 MHz |
Channel 19 | 27.635 MHz | 27.630 MHz |
Channel 19A | 27.645 MHz | 27.640 MHz |
Channel 20 | 27.655 MHz | 27.650 MHz |
Channel 21 | 27.665 MHz | 27.660 MHz |
Channel 22 | 27.675 MHz | 27.670 MHz |
Channel 23 | 27.705 MHz | 27.700 MHz |
Channel 24 | 27.685 MHz | 27.680 MHz |
Channel 25 | 27.695 MHz | 27.690 MHz |
Channel 26 | 27.715 MHz | 27.710 MHz |
Channel 27 | 27.725 MHz | 27.720 MHz |
Channel 28 | 27.735 MHz | 27.730 MHz |
Channel 29 | 27.745 MHz | 27.740 MHz |
Channel 30 | 27.755 MHz | 27.750 MHz |
Channel 31 | 27.765 MHz | 27.760 MHz |
Channel 32 | 27.775 MHz | 27.770 MHz |
Channel 33 | 27.785 MHz | 27.780 MHz |
Channel 34 | 27.795 MHz | 27.790 MHz |
Channel 35 | 27.805 MHz | 27.800 MHz |
Channel 36 | 27.815 MHz | 27.810 MHz |
Channel 37 | 27.825 MHz | 27.820 MHz |
Channel 38 | 27.835 MHz | 27.830 MHz |
Channel 39 | 27.845 MHz | 27.840 MHz |
Channel 40 | 27.855 MHz | 27.850 MHz |
Channel 40A | 27.865 MHz | 27.860 MHz |
Band F Channel | Standard Band Plan Frequency | Russian/Polish Band Plan Frequency |
Channel 1 | 27.865 MHz | 27.860 MHz |
Channel 2 | 27.875 MHz | 27.870 MHz |
Channel 3 | 27.885 MHz | 27.880 MHz |
Channel 3A | 27.895 MHz | 27.890 MHz |
Channel 4 | 27.905 MHz | 27.900 MHz |
Channel 5 | 27.915 MHz | 27.910 MHz |
Channel 6 | 27.925 MHz | 27.920 MHz |
Channel 7 | 27.935 MHz | 27.930 MHz |
Channel 7A | 27.945 MHz | 27.940 MHz |
Channel 8 | 27.955 MHz | 27.950 MHz |
Channel 9 | 27.965 MHz | 27.960 MHz |
Channel 10 | 27.975 MHz | 27.970 MHz |
Channel 11 | 27.985 MHz | 27.980 MHz |
Channel 11A | 27.995 MHz | 27.990 MHz |
Channel 12 | 28.005 MHz | 28.000 MHz |
Channel 13 | 28.015 MHz | 28.010 MHz |
Channel 14 | 28.025 MHz | 28.020 MHz |
Channel 15 | 28.035 MHz | 28.030 MHz |
Channel 15A | 28.045 MHz | 28.040 MHz |
Channel 16 | 28.055 MHz | 28.050 MHz |
Channel 17 | 28.065 MHz | 28.060 MHz |
Channel 18 | 28.075 MHz | 28.070 MHz |
Channel 19 | 28.085 MHz | 28.080 MHz |
Channel 19A | 28.095 MHz | 28.090 MHz |
Channel 20 | 28.105 MHz | 28.100 MHz |
Channel 21 | 28.115 MHz | 28.110 MHz |
Channel 22 | 28.125 MHz | 28.120 MHz |
Channel 23 | 28.155 MHz | 28.150 MHz |
Channel 24 | 28.135 MHz | 28.130 MHz |
Channel 25 | 28.145 MHz | 28.140 MHz |
Channel 26 | 28.165 MHz | 28.160 MHz |
Channel 27 | 28.175 MHz | 28.170 MHz |
Channel 28 | 28.185 MHz | 28.180 MHz |
Channel 29 | 28.195 MHz | 28.190 MHz |
Channel 30 | 28.205 MHz | 28.200 MHz |
Channel 31 | 28.215 MHz | 28.210 MHz |
Channel 32 | 28.225 MHz | 28.220 MHz |
Channel 33 | 28.235 MHz | 28.230 MHz |
Channel 34 | 28.245 MHz | 28.240 MHz |
Channel 35 | 28.255 MHz | 28.250 MHz |
Channel 36 | 28.265 MHz | 28.260 MHz |
Channel 37 | 28.275 MHz | 28.270 MHz |
Channel 38 | 28.285 MHz | 28.280 MHz |
Channel 39 | 28.295 MHz | 28.290 MHz |
Channel 40 | 28.305 MHz | 28.300 MHz |
Channel 40A | 28.315 MHz | 28.310 MHz |
Channel 1 | 26.968 MHz |
Channel 2 | 26.976 MHz |
Channel 3 | 27.040 MHz |
Channel 4 | 27.080 MHz |
Channel 5 | 27.088 MHz |
Channel 6 | 27.112 MHz |
Channel 7 | 27.120 MHz |
Channel 8 | 27.144 MHz |
27040-27144 kHz | Japanese CB channels 3-8 and 2 RC channels |
27152 kHz | Third RC Channel 27.152 MHz |
Channel 26760 | 26.760 MHz |
Channel 26768 | 26.768 MHz |
Channel 26776 | 26.776 MHz |
Channel 26824 | 26.824 MHz |
Channel 26840 | 26.840 MHz |
Channel 26848 | 26.848 MHz |
Channel 26856 | 26.856 MHz |
Channel 26864 | 26.864 MHz |
Channel 26872 | 26.872 MHz |
Channel 26880 | 26.880 MHz |
Channel 26888 | 26.888 MHz |
Channel 26896 | 26.896 MHz |
Channel 26912 | 26.912 MHz |
Channel 26920 | 26.920 MHz |
Channel 26928 | 26.928 MHz |
Channel 26936 | 26.936 MHz |
Channel 26944 | 26.944 MHz |
Channel 27016 | 27.016 MHz |
Channel 27524 | 27.524 MHz |
Channel 27532 | 27.532 MHz |
Channel 27540 | 27.540 MHz |
Channel 27548 | 27.548 MHz |
Channel 27556 | 27.556 MHz |
Channel 27572 | 27.572 MHz |
Channel 27580 | 27.580 MHz |
Channel 27628 | 27.628 MHz |
Channel 27636 | 27.636 MHz |
Channel 27644 | 27.644 MHz |
Channel 27652 | 27.652 MHz |
Channel 27660 | 27.660 MHz |
Channel 27668 | 27.668 MHz |
Channel 27676 | 27.676 MHz |
Channel 27724 | 27.724 MHz |
Channel 27732 | 27.732 MHz |
Channel 27740 | 27.740 MHz |
Channel 27748 | 27.748 MHz |
Channel 27756 | 27.756 MHz |
Channel 27764 | 27.764 MHz |
Channel 27772 | 27.772 MHz |
Channel 27780 | 27.780 MHz |
Channel 27828 | 27.828 MHz |
Channel 27836 | 27.836 MHz |
Channel 27852 | 27.852 MHz |
Channel 27860 | 27.860 MHz |
Channel 27884 | 27.884 MHz |
Channel 27892 | 27.892 MHz |
Channel 27908 | 27.908 MHz |
Channel 27916 | 27.916 MHz |
Channel 27932 | 27.932 MHz |
Channel 27940 | 27.940 MHz |
Channel 27956 | 27.956 MHz |
Channel 27964 | 27.964 MHz |
Channel 27980 | 27.980 MHz |
Channel 27988 | 27.988 MHz |
27310.5 kHz | 27.3105 MHz |
27334.5 kHz | 27.3345 MHz |
27338.5 kHz | 27.3385 MHz |
27342.5 kHz | 27.3425 MHz |
27346.5 kHz | 27.3465 MHz |
27350.5 kHz | 27.3505 MHz |
27354.5 kHz | 27.3545 MHz |
27358.5 kHz | 27.3585 MHz |
27362.5 kHz | 27.3625 MHz |
27366.5 kHz | 27.3665 MHz |
27370.5 kHz | 27.3705 MHz |
27378.5 kHz | 27.3785 MHz |
27382.5 kHz | 27.3825 MHz |
27386.5 kHz | 27.3865 MHz |
27388.5 kHz | 27.3885 MHz |
27398.5 kHz | 27.3985 MHz |
27404.5 kHz | 27.4045 MHz |
27418.5 kHz | 27.4185 MHz |
27426.5 kHz | 27.4265 MHz |
27434.5 kHz | 27.4345 MHz |
27442.5 kHz | 27.4425 MHz |
27452.5 kHz | 27.4525 MHz |
27458.5 kHz | 27.4585 MHz |
27466.5 kHz | 27.4665 MHz |
27470.5 kHz | 27.4705 MHz |
27821 kHz | 27.821 MHz | Fishery Radio - Distress Safety Calling Emergency Frequency - Maritime Mobile Distress |
27901 kHz | 27.901 MHz | Fishery Radio - Fisheries Radio Shore-to-Ship |
- SPECIFICATIONS
- 25 kHz channel spacing
- 480 channels
- FEATURES
Channel | Frequency (MHz) | Designated Use China Fishery Radio Network 27.5-39.475 MHz FM |
1 | 27.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
2 | 27.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
3 | 27.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
4 | 27.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
5 | 27.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
6 | 27.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
7 | 27.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
8 | 27.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
9 | 27.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
10 | 27.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
11 | 27.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
12 | 27.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
13 | 27.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
14 | 27.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
15 | 27.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
16 | 27.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
17 | 27.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
18 | 27.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
19 | 27.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
20 | 27.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
21 | 28.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
22 | 28.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
23 | 28.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
24 | 28.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
25 | 28.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
26 | 28.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
27 | 28.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
28 | 28.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
29 | 28.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
30 | 28.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
31 | 28.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
32 | 28.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
33 | 28.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
34 | 28.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
35 | 28.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
36 | 28.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
37 | 28.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
38 | 28.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
39 | 28.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
40 | 28.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
41 | 28.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
42 | 28.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
43 | 28.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
44 | 28.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
45 | 28.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
46 | 28.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
47 | 28.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
48 | 28.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
49 | 28.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
50 | 28.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
51 | 28.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
52 | 28.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
53 | 28.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
54 | 28.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
55 | 28.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
56 | 28.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
57 | 28.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
58 | 28.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
59 | 28.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
60 | 28.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
61 | 28.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
62 | 28.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
63 | 28.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
64 | 28.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
65 | 29.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
66 | 29.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
67 | 29.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
68 | 29.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
69 | 29.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
70 | 29.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
71 | 29.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
72 | 29.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
73 | 29.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
74 | 29.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
75 | 29.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
76 | 29.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
77 | 29.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
78 | 29.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
79 | 29.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
80 | 29.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
81 | 29.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
82 | 29.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
83 | 29.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
84 | 29.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
85 | 29.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
86 | 29.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
87 | 29.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
88 | 29.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
89 | 29.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
90 | 29.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
91 | 29.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
92 | 29.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
93 | 29.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
94 | 29.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
95 | 29.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
96 | 29.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
97 | 29.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
98 | 29.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
99 | 29.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
100 | 29.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
101 | 29.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
102 | 29.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
103 | 29.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
104 | 29.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
105 | 30.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
106 | 30.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
107 | 30.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
108 | 30.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
109 | 30.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
110 | 30.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
111 | 30.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
112 | 30.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
113 | 30.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
114 | 30.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
115 | 30.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
116 | 30.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
117 | 30.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
118 | 30.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
119 | 30.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
120 | 30.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
121 | 30.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
122 | 30.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
123 | 30.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
124 | 30.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
125 | 30.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
126 | 30.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
127 | 30.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
128 | 30.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
129 | 30.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
130 | 30.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
131 | 30.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
132 | 30.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
133 | 30.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
134 | 30.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
135 | 30.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
136 | 30.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
137 | 30.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
138 | 30.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
139 | 30.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
140 | 30.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
141 | 30.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
142 | 30.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
143 | 30.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
144 | 30.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
145 | 31.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
146 | 31.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
147 | 31.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
148 | 31.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
149 | 31.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
150 | 31.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
151 | 31.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
152 | 31.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
153 | 31.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
154 | 31.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
155 | 31.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
156 | 31.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
158 | 31.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
159 | 31.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
160 | 31.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
161 | 31.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
162 | 31.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
163 | 31.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
164 | 31.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
165 | 31.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
166 | 31.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
167 | 31.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
168 | 31.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
169 | 31.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
170 | 31.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
171 | 31.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
172 | 31.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
173 | 31.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
174 | 31.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
175 | 31.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
176 | 31.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
177 | 31.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
178 | 31.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
179 | 31.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
180 | 31.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
181 | 31.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
182 | 31.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
183 | 31.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
184 | 31.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
185 | 31.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
186 | 32.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
187 | 32.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
188 | 32.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
189 | 32.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
190 | 32.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
191 | 32.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
192 | 32.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
193 | 32.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
194 | 32.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
195 | 32.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
196 | 32.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
197 | 32.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
198 | 32.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
199 | 32.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
200 | 32.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
201 | 32.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
202 | 32.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
203 | 32.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
204 | 32.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
205 | 32.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
206 | 32.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
207 | 32.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
208 | 32.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
209 | 32.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
210 | 32.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
211 | 32.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
212 | 32.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
213 | 32.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
214 | 32.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
215 | 32.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
216 | 32.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
217 | 32.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
218 | 32.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
219 | 32.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
220 | 32.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
221 | 32.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
222 | 32.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
223 | 32.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
224 | 32.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
225 | 32.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
226 | 33.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
227 | 33.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
228 | 33.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
229 | 33.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
231 | 33.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
232 | 33.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
233 | 33.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
234 | 33.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
235 | 33.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
236 | 33.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
237 | 33.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
238 | 33.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
239 | 33.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
240 | 33.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
241 | 33.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
242 | 33.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
243 | 33.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
244 | 33.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
245 | 33.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
246 | 33.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
247 | 33.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
248 | 33.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
249 | 33.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
250 | 33.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
251 | 33.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
252 | 33.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
253 | 33.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
254 | 33.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
255 | 33.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
256 | 33.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
257 | 33.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
258 | 33.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
259 | 33.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
260 | 33.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
261 | 33.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
262 | 33.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
263 | 33.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
264 | 33.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
265 | 33.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
266 | 33.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
267 | 34.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
268 | 34.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
269 | 34.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
270 | 34.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
271 | 34.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
272 | 34.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
273 | 34.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
274 | 34.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
275 | 34.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
276 | 34.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
278 | 34.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
279 | 34.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
280 | 34.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
281 | 34.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
282 | 34.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
283 | 34.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
284 | 34.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
285 | 34.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
286 | 34.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
287 | 34.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
288 | 34.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
289 | 34.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
290 | 34.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
291 | 34.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
292 | 34.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
293 | 34.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
294 | 34.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
295 | 34.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
296 | 34.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
297 | 34.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
298 | 34.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
299 | 34.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
300 | 34.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
301 | 34.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
302 | 34.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
303 | 34.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
304 | 34.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
305 | 34.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
306 | 34.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
307 | 34.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
308 | 35.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
309 | 35.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
310 | 35.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
311 | 35.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
312 | 35.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
313 | 35.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
314 | 35.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
315 | 35.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
316 | 35.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
317 | 35.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
318 | 35.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
319 | 35.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
320 | 35.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
321 | 35.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
322 | 35.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
323 | 35.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
324 | 35.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
325 | 35.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
326 | 35.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
327 | 35.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
328 | 35.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
329 | 35.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
330 | 35.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
331 | 35.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
332 | 35.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
333 | 35.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
334 | 35.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
335 | 35.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
336 | 35.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
337 | 35.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
338 | 35.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
339 | 35.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
340 | 35.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
341 | 35.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
342 | 35.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
343 | 35.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
344 | 35.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
345 | 35.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
346 | 35.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
347 | 35.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
348 | 36.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
349 | 36.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
350 | 36.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
351 | 36.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
352 | 36.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
353 | 36.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
354 | 36.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
355 | 36.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
356 | 36.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
357 | 36.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
358 | 36.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
359 | 36.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
360 | 36.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
361 | 36.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
362 | 36.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
363 | 36.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
364 | 36.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
365 | 36.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
366 | 36.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
367 | 36.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
368 | 36.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
369 | 36.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
370 | 36.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
371 | 36.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
372 | 36.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
373 | 36.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
374 | 36.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
375 | 36.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
376 | 36.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
377 | 36.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
378 | 36.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
379 | 36.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
380 | 37.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
381 | 37.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
382 | 37.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
383 | 37.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
384 | 37.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
385 | 37.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
386 | 37.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
387 | 37.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
388 | 37.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
389 | 37.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
390 | 37.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
391 | 37.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
392 | 37.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
393 | 37.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
394 | 37.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
395 | 37.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
396 | 37.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
398 | 37.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
399 | 37.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
400 | 37.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
401 | 37.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
402 | 37.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
403 | 37.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
404 | 37.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
405 | 37.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
406 | 37.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
407 | 37.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
408 | 37.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
409 | 37.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
410 | 37.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
411 | 37.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
412 | 37.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
413 | 37.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
414 | 37.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
415 | 37.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
416 | 37.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
417 | 37.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
418 | 37.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
419 | 37.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
420 | 37.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
421 | 38.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
422 | 38.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
423 | 38.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
424 | 38.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
425 | 38.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
426 | 38.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
427 | 38.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
428 | 38.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
429 | 38.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
430 | 38.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
431 | 38.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
432 | 38.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
433 | 38.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
434 | 38.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
435 | 38.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
436 | 38.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
437 | 38.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
438 | 38.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
439 | 38.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
440 | 38.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
441 | 38.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
442 | 38.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
443 | 38.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
444 | 38.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
445 | 38.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
446 | 38.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
447 | 38.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
448 | 38.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
449 | 38.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
450 | 38.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
451 | 38.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
452 | 38.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
453 | 38.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
454 | 38.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
455 | 38.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
456 | 38.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
457 | 38.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
458 | 38.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
459 | 38.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
460 | 38.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
461 | 39.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
462 | 39.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
463 | 39.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
464 | 39.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
465 | 39.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
466 | 39.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
467 | 39.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
468 | 39.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
469 | 39.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
470 | 39.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
471 | 39.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
472 | 39.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
473 | 39.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
474 | 39.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
475 | 39.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
476 | 39.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
477 | 39.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
478 | 39.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
479 | 39.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
480 | 39.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
- SPECIFICATIONS
- 20 channels
- AM modulation
- FEATURES
CB Channel | Frequency |
Channel 19 | 27.185 MHz |
Channel 20 | 27.205 MHz |
Channel 21 | 27.215 MHz |
Channel 22 | 27.225 MHz |
Channel 23 | 27.255 MHz |
Channel 24 | 27.235 MHz |
Channel 25 | 27.245 MHz |
Channel 26 | 27.265 MHz |
Channel 27 | 27.275 MHz |
Channel 1 | 26.965 MHz |
Channel 2 | 26.975 MHz |
Channel 3 | 26.985 MHz |
Channel 4 | 27.005 MHz |
Channel 5 | 27.015 MHz |
Channel 6 | 27.025 MHz |
Channel 7 | 27.035 MHz |
Channel 8 | 27.055 MHz |
Channel 9 | 27.065 MHz |
Channel 10 | 27.075 MHz |
Channel 11 | 27.085 MHz |
Channel 12 | 27.105 MHz |
Channel 13 | 27.115 MHz |
Channel 14 | 27.125 MHz |
Channel 15 | 27.135 MHz |
Channel 16 | 27.155 MHz |
Channel 17 | 27.165 MHz |
Channel 18 | 27.175 MHz |
Channel 41 | 27.415 MHz |
Channel 42 | 27.425 MHz |
Channel 43 | 27.435 MHz |
Channel 44 | 27.455 MHz |
Channel 45 | 27.465 MHz |
Channel 46 | 27.475 MHz |
Channel 47 | 27.485 MHz |
Channel 48 | 27.505 MHz |
Channel 49 | 27.515 MHz |
Channel 50 | 27.525 MHz |
Channel 51 | 27.535 MHz |
Channel 52 | 27.555 MHz |
Channel 53 | 27.565 MHz |
Channel 54 | 27.575 MHz |
Channel 55 | 27.585 MHz |
Channel 56 | 27.605 MHz |
Channel 57 | 27.615 MHz |
Channel 58 | 27.625 MHz |
Channel 59 | 27.635 MHz |
Channel 60 | 27.655 MHz |
Channel 61 | 27.665 MHz |
Channel 62 | 27.675 MHz |
Channel 63 | 27.685 MHz |
Channel 64 | 27.695 MHz |
Channel 65 | 27.705 MHz |
Channel 66 | 27.715 MHz |
Channel 67 | 27.725 MHz |
Channel 68 | 27.735 MHz |
Channel 69 | 27.745 MHz |
Channel 70 | 27.755 MHz |
Channel 71 | 27.765 MHz |
Channel 72 | 27.775 MHz |
Channel 73 | 27.785 MHz |
Channel 74 | 27.795 MHz |
Channel 75 | 27.805 MHz |
Channel 76 | 27.815 MHz |
Channel 77 | 27.825 MHz |
Channel 78 | 27.835 MHz |
Channel 79 | 27.845 MHz |
Channel 80 | 27.855 MHz |
New Zealand 26 MHz CB AM/SSB Channel 1 | 26.330 MHz |
New Zealand 26 MHz CB AM/SSB Channel 2 | 26.340 MHz |
New Zealand 26 MHz CB AM/SSB Channel 3 | 26.350 MHz |
New Zealand 26 MHz CB AM/SSB Channel 4 | 26.370 MHz |
New Zealand 26 MHz CB AM/SSB Channel 5 | 26.380 MHz |
New Zealand 26 MHz CB AM/SSB Channel 6 | 26.390 MHz |
New Zealand 26 MHz CB AM/SSB Channel 7 | 26.400 MHz |
New Zealand 26 MHz CB AM/SSB Channel 8 | 26.420 MHz |
New Zealand 26 MHz CB AM/SSB Channel 9 | 26.430 MHz |
New Zealand 26 MHz CB AM/SSB Channel 10 | 26.440 MHz |
New Zealand 26 MHz CB AM/SSB Channel 11 | 26.450 MHz |
New Zealand 26 MHz CB AM/SSB Channel 12 | 26.470 MHz |
New Zealand 26 MHz CB AM/SSB Channel 13 | 26.480 MHz |
New Zealand 26 MHz CB AM/SSB Channel 14 | 26.490 MHz |
New Zealand 26 MHz CB AM/SSB Channel 15 | 26.500 MHz |
New Zealand 26 MHz CB AM/SSB Channel 16 | 26.520 MHz |
New Zealand 26 MHz CB AM/SSB Channel 17 | 26.530 MHz |
New Zealand 26 MHz CB AM Channel 18 | 26.540 MHz |
New Zealand 26 MHz CB AM Channel 19 | 26.550 MHz |
German Auxiliary CB Channel 41 | 26.565 MHz |
New Zealand 26 MHz CB AM Channel 20 | 26.570 MHz |
German Auxiliary CB Channel 42 | 26.575 MHz |
New Zealand 26 MHz CB AM Channel 21 | 26.580 MHz |
German Auxiliary CB Channel 43 | 26.585 MHz |
New Zealand 26 MHz CB AM Channel 22 | 26.590 MHz |
German Auxiliary CB Channel 44 | 26.595 MHz |
New Zealand 26 MHz CB AM Channel 24 | 26.600 MHz |
German Auxiliary CB Channel 45 | 26.605 MHz |
New Zealand 26 MHz CB AM Channel 25 | 26.610 MHz |
German Auxiliary CB Channel 46 | 26.615 MHz |
New Zealand 26 MHz CB AM Channel 23 | 26.620 MHz |
German Auxiliary CB Channel 47 | 26.625 MHz |
New Zealand 26 MHz CB AM/SSB Channel 26 | 26.630 MHz |
German Auxiliary CB Channel 48 | 26.635 MHz |
New Zealand 26 MHz CB AM/SSB Channel 27 | 26.640 MHz |
German Auxiliary CB Channel 49 | 26.645 MHz |
New Zealand 26 MHz CB AM/SSB Channel 28 | 26.650 MHz |
German Auxiliary CB Channel 50 | 26.655 MHz |
New Zealand 26 MHz CB AM/SSB Channel 29 | 26.660 MHz |
German Auxiliary CB Channel 51 | 26.665 MHz |
New Zealand 26 MHz CB AM/SSB Channel 30 | 26.670 MHz |
German Auxiliary CB Channel 52 | 26.675 MHz |
New Zealand 26 MHz CB AM/SSB Channel 31 | 26.680 MHz |
German Auxiliary CB Channel 53 | 26.685 MHz |
New Zealand 26 MHz CB AM/SSB Channel 32 | 26.690 MHz |
German Auxiliary CB Channel 54 | 26.695 MHz |
New Zealand 26 MHz CB AM/SSB Channel 33 | 26.700 MHz |
German Auxiliary CB Channel 55 | 26.705 MHz |
New Zealand 26 MHz CB AM/SSB Channel 34 | 26.710 MHz |
German Auxiliary CB Channel 56 | 26.715 MHz |
New Zealand 26 MHz CB AM/SSB Channel 35 | 26.720 MHz |
German Auxiliary CB Channel 57 | 26.725 MHz |
New Zealand 26 MHz CB AM/SSB Channel 36 | 26.730 MHz |
German Auxiliary CB Channel 58 | 26.735 MHz |
New Zealand 26 MHz CB AM/SSB Channel 37 | 26.740 MHz |
German Auxiliary CB Channel 59 | 26.745 MHz |
New Zealand 26 MHz CB AM/SSB Channel 38 | 26.750 MHz |
German Auxiliary CB Channel 60 | 26.755 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.760 MHz |
New Zealand 26 MHz CB AM/SSB Channel 39 | 26.760 MHz |
German Auxiliary CB Channel 61 | 26.765 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.768 MHz |
New Zealand 26 MHz CB AM/SSB Channel 40 | 26.770 MHz |
German Auxiliary CB Channel 62 | 26.775 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.776 MHz |
German Auxiliary CB Channel 63 | 26.785 MHz |
German Auxiliary CB Channel 64 | 26.795 MHz |
German Auxiliary CB Channel 65 | 26.805 MHz |
German Auxiliary CB Channel 66 | 26.815 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.824 MHz |
German Auxiliary CB Channel 67 | 26.825 MHz |
German Auxiliary CB Channel 68 | 26.835 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.840 MHz |
German Auxiliary CB Channel 69 | 26.845 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.848 MHz |
German Auxiliary CB Channel 70 | 26.855 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.856 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.864 MHz |
German Auxiliary CB Channel 71 | 26.865 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.872 MHz |
German Auxiliary CB Channel 72 | 26.875 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.880 MHz |
German Auxiliary CB Channel 73 | 26.885 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.888 MHz |
German Auxiliary CB Channel 74 | 26.895 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.896 MHz |
German Auxiliary CB Channel 75 | 26.905 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.912 MHz |
German Auxiliary CB Channel 76 | 26.915 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.920 MHz |
German Auxiliary CB Channel 77 | 26.925 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.928 MHz |
German Auxiliary CB Channel 78 | 26.935 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.938 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.944 MHz |
German Auxiliary CB Channel 79 | 26.945 MHz |
German Auxiliary CB Channel 80 | 26.955 MHz |
USA FCC/CEPT Standard CB Band Channel 1 | 26.965 MHz |
Japan CB Radio Japanese CB Channel 1 | 26.968 MHz |
USA FCC/CEPT Standard CB Band Channel 2 | 26.975 MHz |
Japan CB Radio Japanese CB Channel 2 | 26.976 MHz |
USA FCC/CEPT Standard CB Band Channel 3 | 26.985 MHz |
USA FCC/CEPT Standard CB Band Channel 4 | 27.005 MHz |
USA FCC/CEPT Standard CB Band Channel 5 | 27.015 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.016 MHz |
USA FCC/CEPT Standard CB Band Channel 6 | 27.025 MHz |
USA FCC/CEPT Standard CB Band Channel 7 | 27.035 MHz |
Japan CB Radio Japanese CB Channel 3 | 27.040 MHz |
USA FCC/CEPT Standard CB Band Channel 8 | 27.055 MHz |
USA FCC/CEPT Standard CB Band Channel 9 | 27.065 MHz |
USA FCC/CEPT Standard CB Band Channel 10 | 27.075 MHz |
Japan CB Radio Japanese CB Channel 4 | 27.080 MHz |
USA FCC/CEPT Standard CB Band Channel 11 | 27.085 MHz |
Japan CB Radio Japanese CB Channel 5 | 27.088 MHz |
Finland and Nordic Countries Channel 11A | 27.095 MHz |
USA FCC/CEPT Standard CB Band Channel 12 | 27.105 MHz |
Japan CB Radio Japanese CB Channel 6 | 27.112 MHz |
USA FCC/CEPT Standard CB Band Channel 13 | 27.115 MHz |
Japan CB Radio Japanese CB Channel 7 | 27.120 MHz |
USA FCC/CEPT Standard CB Band Channel 14 | 27.125 MHz |
USA FCC/CEPT Standard CB Band Channel 15 | 27.135 MHz |
Japan CB Radio Japanese CB Channel 8 | 27.144 MHz |
USA FCC/CEPT Standard CB Band Channel 16 | 27.155 MHz |
USA FCC/CEPT Standard CB Band Channel 17 | 27.165 MHz |
USA FCC/CEPT Standard CB Band Channel 18 | 27.175 MHz |
USA FCC/CEPT Standard CB Band Channel 19 | 27.185 MHz |
USA FCC/CEPT Standard CB Band Channel 20 | 27.205 MHz |
USA FCC/CEPT Standard CB Band Channel 21 | 27.215 MHz |
USA FCC/CEPT Standard CB Band Channel 22 | 27.225 MHz |
USA FCC/CEPT Standard CB Band Channel 23 | 27.255 MHz |
USA FCC/CEPT Standard CB Band Channel 24 | 27.235 MHz |
USA FCC/CEPT Standard CB Band Channel 25 | 27.245 MHz |
USA FCC/CEPT Standard CB Band Channel 26 | 27.265 MHz |
USA FCC/CEPT Standard CB Band Channel 27 | 27.275 MHz |
USA FCC/CEPT Standard CB Band Channel 28 | 27.285 MHz |
USA FCC/CEPT Standard CB Band Channel 29 | 27.295 MHz |
USA FCC/CEPT Standard CB Band Channel 30 | 27.305 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3105 MHz |
USA FCC/CEPT Standard CB Band Channel 31 | 27.315 MHz |
USA FCC/CEPT Standard CB Band Channel 32 | 27.325 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3345 MHz |
USA FCC/CEPT Standard CB Band Channel 33 | 27.335 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3385 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3425 MHz |
USA FCC/CEPT Standard CB Band Channel 34 | 27.345 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3465 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3505 MHz |
USA FCC/CEPT Standard CB Band Channel 35 | 27.355 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3625 MHz |
USA FCC/CEPT Standard CB Band Channel 36 | 27.365 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3665 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3705 MHz |
USA FCC/CEPT Standard CB Band Channel 37 | 27.375 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3785 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3825 MHz |
USA FCC/CEPT Standard CB Band Channel 38 | 27.385 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3865 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3885 MHz |
USA FCC/CEPT Standard CB Band Channel 39 | 27.395 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3985 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4045 MHz |
USA FCC/CEPT Standard CB Band Channel 40 | 27.405 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4185 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4265 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4425 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4525 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4585 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4665 MHz |
25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4705 MHz |
Chinese Fishery Radio Channel 1 | 27.500 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.508 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.516 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.524 MHz |
Chinese Fishery Radio Channel 2 | 27.525 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.532 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.540 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.544 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.548 MHz |
Chinese Fishery Radio Channel 3 | 27.550 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.552 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.556 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.572 MHz |
Chinese Fishery Radio Channel 4 | 27.575 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.580 MHz |
Chinese Fishery Radio Channel 5 | 27.600 MHz |
UK FM 27/81 and CADS/WPAS Channel 1 | 27.60125 MHz |
CADS/WPAS Channel UW01 | 27.605 MHz |
UK FM 27/81 and CADS/WPAS Channel 2 | 27.61125 MHz |
CADS/WPAS Channel UW02 | 27.615 MHz |
UK FM 27/81 and CADS/WPAS Channel 3 | 27.62125 MHz |
Chinese Fishery Radio Channel 6 | 27.625 MHz |
CADS/WPAS Channel UW03 | 27.625 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.628 MHz |
UK FM 27/81 and CADS/WPAS Channel 4 | 27.63125 MHz |
CADS/WPAS Channel UW04 | 27.635 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.636 MHz |
UK FM 27/81 and CADS/WPAS Channel 5 | 27.64125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.644 MHz |
CADS/WPAS Channel UW05 | 27.645 MHz |
Chinese Fishery Radio Channel 7 | 27.650 MHz |
UK FM 27/81 and CADS/WPAS Channel 6 | 27.65125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.652 MHz |
CADS/WPAS Channel UW06 | 27.655 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.660 MHz |
UK FM 27/81 and CADS/WPAS Channel 7 | 27.66125 MHz |
CADS/WPAS Channel UW07 | 27.665 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.668 MHz |
UK FM 27/81 and CADS/WPAS Channel 8 | 27.67125 MHz |
Chinese Fishery Radio Channel 8 | 27.675 MHz |
CADS/WPAS Channel UW08 | 27.675 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.676 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 68 | 27.680 MHz |
UK FM 27/81 and CADS/WPAS Channel 9 | 27.68125 MHz |
CADS/WPAS Channel UW09 | 27.685 MHz |
UK FM 27/81 and CADS/WPAS Channel 10 | 27.69125 MHz |
CADS/WPAS Channel UW10 | 27.695 MHz |
Chinese Fishery Radio Channel 9 | 27.700 MHz |
UK FM 27/81 and CADS/WPAS Channel 11 | 27.70125 MHz |
CADS/WPAS Channel UW11 | 27.705 MHz |
UK FM 27/81 and CADS/WPAS Channel 12 | 27.71125 MHz |
CADS/WPAS Channel UW12 | 27.715 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 72 | 27.720 MHz |
UK FM 27/81 and CADS/WPAS Channel 13 | 27.72125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.724 MHz |
Chinese Fishery Radio Channel 10 | 27.725 MHz |
CADS/WPAS Channel UW13 | 27.725 MHz |
UK FM 27/81 and CADS/WPAS Channel 14 | 27.73125 MHz |
CADS/WPAS Channel UW14 | 27.735 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.732 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.740 MHz |
UK FM 27/81 and CADS/WPAS Channel 15 | 27.74125 MHz |
CADS/WPAS Channel UW15 | 27.745 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.748 MHz |
Chinese Fishery Radio Channel 11 | 27.750 MHz |
UK FM 27/81 and CADS/WPAS Channel 16 | 27.75125 MHz |
CADS/WPAS Channel UW16 | 27.755 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.756 MHz |
UK FM 27/81 and CADS/WPAS Channel 17 | 27.76125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.764 MHz |
CADS/WPAS Channel UW17 | 27.765 MHz |
UK FM 27/81 and CADS/WPAS Channel 18 | 27.77125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.772 MHz |
Chinese Fishery Radio Channel 12 | 27.775 MHz |
CADS/WPAS Channel UW18 | 27.775 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.776 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.780 MHz |
UK FM 27/81 and CADS/WPAS Channel 19 | 27.78125 MHz |
CADS/WPAS Channel UW19 | 27.785 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.789 MHz |
UK FM 27/81 and CADS/WPAS Channel 20 | 27.79125 MHz |
CADS/WPAS Channel UW20 | 27.795 MHz |
Chinese Fishery Radio Channel 13 | 27.800 MHz |
UK FM 27/81 and CADS/WPAS Channel 21 | 27.80125 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.805 MHz |
CADS/WPAS Channel UW21 | 27.805 MHz |
UK FM 27/81 and CADS/WPAS Channel 22 | 27.81125 MHz |
CADS/WPAS Channel UW22 | 27.815 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 82 | 27.820 MHz |
Republic of Korea Fishery Radio - Ship to Ship/Ship to Shore | 27.821 MHz |
UK FM 27/81 and CADS/WPAS Channel 23 | 27.82125 MHz |
Chinese Fishery Radio Channel 14 | 27.825 MHz |
CADS/WPAS Channel UW23 | 27.825 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.828 MHz |
UK FM 27/81 and CADS/WPAS Channel 24 | 27.83125 MHz |
CADS/WPAS Channel UW24 | 27.835 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.836 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.837 MHz |
UK FM 27/81 and CADS/WPAS Channel 25 | 27.84125 MHz |
CADS/WPAS Channel UW25 | 27.845 MHz |
Chinese Fishery Radio Channel 15 | 27.850 MHz |
UK FM 27/81 and CADS/WPAS Channel 26 | 27.85125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.852 MHz |
CADS/WPAS Channel UW26 | 27.855 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.856 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 86 | 27.860 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.860 MHz |
UK FM 27/81 and CADS/WPAS Channel 27 | 27.86125 MHz |
CADS/WPAS Channel UW27 | 27.865 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.869 MHz |
UK FM 27/81 and CADS/WPAS Channel 28 | 27.87125 MHz |
Chinese Fishery Radio Channel 16 | 27.875 MHz |
CADS/WPAS Channel UW28 | 27.875 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 88 | 27.880 MHz |
UK FM 27/81 and CADS/WPAS Channel 29 | 27.88125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.884 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.885 MHz |
CADS/WPAS Channel UW29 | 27.885 MHz |
UK FM 27/81 and CADS/WPAS Channel 30 | 27.89125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.892 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.895 MHz |
CADS/WPAS Channel UW30 | 27.895 MHz |
Chinese Fishery Radio Channel 17 | 27.900 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 90 | 27.900 MHz |
Republic of Korea Fishery Radio - Ship to Shore | 27.901 MHz |
UK FM 27/81 and CADS/WPAS Channel 31 | 27.90125 MHz |
CADS/WPAS Channel UW31 | 27.905 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.908 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 91 | 27.910 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.911 MHz |
UK FM 27/81 and CADS/WPAS Channel 32 | 27.91125 MHz |
CADS/WPAS Channel UW32 | 27.915 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.916 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.919 MHz |
UK FM 27/81 and CADS/WPAS Channel 33 | 27.92125 MHz |
Chinese Fishery Radio Channel 18 | 27.925 MHz |
CADS/WPAS Channel UW33 | 27.925 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.927 MHz |
UK FM 27/81 and CADS/WPAS Channel 34 | 27.93125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.932 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.935 MHz |
CADS/WPAS Channel UW34 | 27.935 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 94 | 27.940 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.940 MHz |
UK FM 27/81 and CADS/WPAS Channel 35 | 27.94125 MHz |
Republic of Korea Fishery Radio - Ship to Ship | 27.943 MHz |
CADS/WPAS Channel UW35 | 27.945 MHz |
Chinese Fishery Radio Channel 19 | 27.950 MHz |
UK FM 27/81 and CADS/WPAS Channel 36 | 27.95125 MHz |
CADS/WPAS Channel UW36 | 27.955 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.956 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 96 | 27.960 MHz |
UK FM 27/81 and CADS/WPAS Channel 37 | 27.96125 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.964 MHz |
CADS/WPAS Channel UW37 | 27.965 MHz |
UK FM 27/81 and CADS/WPAS Channel 38 | 27.97125 MHz |
Chinese Fishery Radio Channel 20 | 27.975 MHz |
CADS/WPAS Channel UW38 | 27.975 MHz |
Australian Marine 27MHz 27 Meg Australia Channel 98 | 27.980 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.980 MHz |
UK FM 27/81 and CADS/WPAS Channel 39 | 27.98125 MHz |
CADS/WPAS Channel UW39 | 27.985 MHz |
1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.988 MHz |
UK FM 27/81 and CADS/WPAS Channel 40 | 27.99125 MHz |
CADS/WPAS Channel UW40 | 27.995 MHz |
Chinese Fishery Radio Channel 21 | 28.000 MHz |
27.085 MHz | 27.175 MHz | Netherlands FM mode | Multiple TX/RX sites, each site assigned a CW ID transmitted at the end of transmission |
27.600 MHz | 27.800 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
27.620 MHz | 27.820 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
27.640 MHz | 27.840 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
27.660 MHz | 27.860 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
26.575 MHz | Germany | ||
26.675 MHz | |||
26.915 MHz | |||
26.925 MHz | |||
26.935 MHz | Somewhere in the USA | Cross band repeater linked to FRS channel 3 - 462.6125 MHz FM | |
26.970 MHz | Lithuania | ||
27.110 MHz | Poland | ||
27.110 MHz | Russia | ||
27.150 MHz | Poland | ||
27.170 MHz | Poland | ||
27.185 MHz | Colorado, USA - possibly Arizona? | Remote location, either patched to 462.550 MHz or 462.5625 MHz (cross-band repeat) | |
27.190 MHz | |||
27.220 MHz | |||
27.230 MHz | |||
27.235 MHz | |||
27.250 MHz | Belarus | ||
27.255 MHz | Sochi, Russia | 27.255 MHz FM - "mid band 23" | |
27.290 MHz | Moscow, Russia | Northern Moscow - 27.290 MHz FM or 27.295 MHz FM | |
27.295 MHz | Moscow, Russia | Northern Moscow - 27.290 MHz FM or 27.295 MHz FM | |
27.300 MHz | |||
27.305 MHz | Western Europe | Belgium | |
27.325 MHz | |||
27.430 MHz | |||
27.450 MHz | |||
27.470 MHz | |||
27.675 MHz | Russia | ||
27.765 MHz | Germany | ||
27.840 MHz | Poland | ||
27.875 MHz | Rostov, Russia |
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band 27.9 MHz 27.900 MHz 20-27.9 MHz 27-38.9 MHz 20-28 mc megacycle 27.8 MHz, 27.4 MHz, 27.41 MHz what are the freeband CB frequencies survivalist CB frequencies emergency frequencies near me emergency channels near me UHF emergency frequency VHF emergency frequency 4125 kHz 4417 kHz 6215 kHz 6200 kHz 6212 kHz 6516 kHz 8255 kHz 8779 kHz 12290 kHz 12359 kHz 11175 kHz 13200 kHz 13137 kHz 16420 kHz 16537 kHz 17302 kHz 18795 kHz 19770 kHz 22060 kHz 22756 kHz 25097 kHz 26.097 MHz R4002 26172 kHz 26.172 MHz 2045 kHz 2638 kHz 2003 kHz 6765 kHz 6770 kHz 2048 kHz 2635 kHz ship-to-shore international frequencies radiotelephone emergency calling frequencies GMDSS DSC 2182 kHz 2187.5 kHz 4207.5 kHz 6312 kHz 8414.4 kHz 12577 kHz 16804.5 kHz 156.525 MHz 156.3 MHz 156.8 MHz 156.800 MHz telegraphy distress safety narrow band direct printing 2174.5 kHz 4177.5 kHz 6268 kHz 8376.5 kHz 12520 kHz 16695 kHz 8291 kHz 16420 kHz 4125kHz 3023 kHz 5680 kHz 8364 kHz 10003 kHz 14993 kHz 19993 kHz 19.993 MHz 10.003 MHz 14.993 MHz 123.025 MHz 123.1 MHz 122.9 MHz 455.5 kHz 458.5 kHz 16805.5 kHz 16805 kHz 25208 kHz 25.208 MHz 26121 kHz 26122 kHz 26.840 MHz
