Amateur radio
Not to be confused with CB radio, often referred to as 11 meters.
Amateur Radio Bands MF/HF
US band plan. ITU Region 2.
- 146.415 MHz
- 146.430 MHz
- 146.445 MHz
- 146.460 MHz
- 146.475 MHz
- 146.490 MHz
- 146.505 MHz
- 146.520 MHz
- 146.535 MHz
- 146.550 MHz
- 146.565 MHz
- 146.580 MHz
- 146.595 MHz
- 147.405 MHz
- 147.420 MHz
- 147.435 MHz
- 147.450 MHz
- 147.465 MHz
- 147.480 MHz
- 147.495 MHz
- 147.510 MHz
- 147.525 MHz
- 147.540 MHz
- 147.555 MHz
- 147.570 MHz
- 147.585 MHz
- 70cm band
- 445.9125 MHz
- 445.9250 MHz
- 445.9375 MHz
- 445.9500 MHz
- 445.9625 MHz
- 445.9750 MHz
- 445.9875 MHz
- 446.0000 MHz
- 446.0125 MHz
- 446.0250 MHz
- 446.0375 MHz
- 446.0500 MHz
- 446.0625 MHz
- 446.0750 MHz
- 446.0875 MHz
- 446.1000 MHz
- 446.1125 MHz
- 446.1250 MHz
- 446.1375 MHz
- 446.1500 MHz
- 446.1625 MHz
- 446.1750 MHz
- 446.5000 MHz
- 446.5125 MHz
- 446.5375 MHz
- 446.5625 MHz
- 446.5875 MHz
- 446.6125 MHz
- 446.6375 MHz
- 446.6625 MHz
- 446.6875 MHz
- 446.7125 MHz
- 446.7375 MHz
- 446.7625 MHz
- 446.7875 MHz
- 440.9125 MHz
- 440.9250 MHz
- 440.9375 MHz
- 440.9500 MHz
- 440.9625 MHz
- 440.9750 MHz
- 440.9875 MHz
- 441.0000 MHz
- 441.0125 MHz
- 441.0250 MHz
- 441.0375 MHz
- 441.0500 MHz
- 441.0625 MHz
- 441.0750 MHz
- 441.0875 MHz
- 441.1000 MHz
- 441.1125 MHz
- 441.1250 MHz
- 441.1375 MHz
- 441.1500 MHz
- 441.1625 MHz
- 441.1750 MHz
- 441.5000 MHz
- 441.5125 MHz
- 441.5375 MHz
- 441.5625 MHz
- 441.5875 MHz
- 441.6125 MHz
- 441.6375 MHz
- 441.6625 MHz
- 441.6875 MHz
- 441.7125 MHz
- 441.7375 MHz
- 441.7625 MHz
- 441.7875 MHz
